Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Tom Rini trini@konsulko.com --- Once ack'd I'll run moveconfig.py to migrate everyone over and check for size changes. This will also depend on the patch I sent to change the malloc pool size on TI parts as we otherwise will now expose the bug about DFU_MMC being unset. --- cmd/Kconfig | 1 + drivers/dfu/Kconfig | 28 ++++++++++++++++++++++++++++ 2 files changed, 29 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index d28da54ed659..26720b6e1f0d 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -404,6 +404,7 @@ config CMD_USB
config CMD_DFU bool "dfu" + select USB_FUNCTION_DFU help Enables the command "dfu" which is used to have U-Boot create a DFU class device via USB. diff --git a/drivers/dfu/Kconfig b/drivers/dfu/Kconfig index 6b92064f0b52..56a98f5273ce 100644 --- a/drivers/dfu/Kconfig +++ b/drivers/dfu/Kconfig @@ -1,5 +1,9 @@ menu "DFU support"
+config USB_FUNCTION_DFU + bool + +if CMD_DFU config DFU_TFTP bool "DFU via TFTP" help @@ -7,4 +11,28 @@ config DFU_TFTP sent via TFTP boot.
Detailed description of this feature can be found at ./doc/README.dfutftp + +config DFU_MMC + bool "MMC back end for DFU" + help + This option enables using DFU to read and write to MMC based storage. + +config DFU_NAND + bool "NAND back end for DFU" + help + This option enables using DFU to read and write to NAND based + storage. + +config DFU_RAM + bool "RAM back end for DFU" + help + This option enables using DFU to read and write RAM on the target. + +config DFU_SF + bool "SPI flash back end for DFU" + help + This option enables using DFU to read and write to SPI flash based + storage. + +endif endmenu
[snip]
+config DFU_MMC
- bool "MMC back end for DFU"
- help
Adding: If working with an underlying filesystem rather than raw storage you will still need to enable the appropriate write commands.
As in doing local testing of stuff that drove me to scratch this itch I noticed that CMD_EXT4_WRITE is not set on sunxi. But I don't think we should force fat+ext4 write to be enabled simply because DFU_MMC is set. I should however follow up with adding default y if DFU_MMC to CMD_EXT4_WRITE and migrate FAT_WRITE to Kconfig as well.
Hi Tom,
[snip]
+config DFU_MMC
- help
based storage.
+1
Thanks for investigation.
(It comes to me that inevitably it is the highest time to move DFU/THor/UMS and underlying USB layers to DM and Kconfig).
Hi Tom,
- select USB_FUNCTION_DFU help Enables the command "dfu" which is used to have U-Boot
- bool
- help
- bool "NAND back end for DFU"
- help
based
storage.
+config DFU_RAM
- bool "RAM back end for DFU"
- help
- bool "SPI flash back end for DFU"
- help
flash based
storage.
+endif endmenu
Acked-by: Lukasz Majewski l.majewski@samsung.com
Tom, thanks for the patch.
Cc: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Tom Rini trini@konsulko.com Acked-by: Lukasz Majewski l.majewski@samsung.com
Lukasz Majewski
