[U-Boot] [UBOOT PATCH v2 0/2] mmc: Added Kconfig support to set minimum and maximum frequency of the mmc controller
This series of patch added Kconfig support for CONFIG_ZYNQ_SDHCI_MAX_FREQ and CONFIG_ZYNQ_SDHCI_MIN_FREQ and set the default values.
-Changes in V2: -Set min. frequency for ep 100KHz -Branch: u-boot-microblaze/kconfig
Vipul Kumar (2): mmc: Added Kconfig support for CONFIG_ZYNQ_SDHCI_MAX_FREQ mmc: Added Kconfig support for CONFIG_ZYNQ_SDHCI_MIN_FREQ
arch/arm/cpu/armv8/zynqmp/Kconfig | 3 +++ arch/arm/mach-zynq/Kconfig | 3 +++ configs/xilinx_zynqmp_ep_defconfig | 2 ++ drivers/mmc/Kconfig | 13 +++++++++++++ drivers/mmc/zynq_sdhci.c | 4 ---- include/configs/xilinx_zynqmp.h | 3 --- include/configs/xilinx_zynqmp_ep.h | 2 -- include/configs/zynq-common.h | 5 ----- 8 files changed, 21 insertions(+), 14 deletions(-)
-- 2.7.4
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
This patch added Kconfig support for CONFIG_ZYNQ_SDHCI_MAX_FREQ and enabled it in respective defconfig.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- arch/arm/cpu/armv8/zynqmp/Kconfig | 3 +++ arch/arm/mach-zynq/Kconfig | 3 +++ configs/xilinx_zynqmp_ep_defconfig | 1 + drivers/mmc/Kconfig | 6 ++++++ include/configs/xilinx_zynqmp.h | 3 --- include/configs/xilinx_zynqmp_ep.h | 1 - include/configs/zynq-common.h | 5 ----- 7 files changed, 13 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv8/zynqmp/Kconfig b/arch/arm/cpu/armv8/zynqmp/Kconfig index 9e521ed..8a311e1 100644 --- a/arch/arm/cpu/armv8/zynqmp/Kconfig +++ b/arch/arm/cpu/armv8/zynqmp/Kconfig @@ -96,6 +96,9 @@ config SPL_ZYNQMP_ALT_BOOTMODE_ENABLED Overwrite bootmode selected via boot mode pins to tell SPL what should be the next boot device.
+config ZYNQ_SDHCI_MAX_FREQ + default 200000000 + config SPL_ZYNQMP_ALT_BOOTMODE hex default 0x0 if JTAG_MODE diff --git a/arch/arm/mach-zynq/Kconfig b/arch/arm/mach-zynq/Kconfig index b9cd45b..8772904 100644 --- a/arch/arm/mach-zynq/Kconfig +++ b/arch/arm/mach-zynq/Kconfig @@ -63,4 +63,7 @@ config BOOT_INIT_FILE Add register writes to boot.bin format (max 256 pairs). Expect a table of register-value pairs, e.g. "0x12345678 0x4321"
+config ZYNQ_SDHCI_MAX_FREQ + default 52000000 + endif diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index 7f8e774..00db5e3 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_ep" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_ZYNQ_SDHCI_MAX_FREQ=52000000 CONFIG_ZYNQMP_USB=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-ep108" CONFIG_DEBUG_UART=y diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index f2d8256..42b7d21 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -472,6 +472,12 @@ config MMC_SDHCI_ZYNQ help Support for Arasan SDHCI host controller on Zynq/ZynqMP ARM SoCs platform
+config ZYNQ_SDHCI_MAX_FREQ + int "Set the maximum frequency of cotroller" + depends on MMC_SDHCI_ZYNQ + help + Set the maximum frequency for the SDHCI controller. + config MMC_SUNXI bool "Allwinner sunxi SD/MMC Host Controller support" depends on ARCH_SUNXI && !UART0_PORT_F diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 825af80..f5fc245 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -56,9 +56,6 @@
#if defined(CONFIG_MMC_SDHCI_ZYNQ) # define CONFIG_SUPPORT_EMMC_BOOT -# ifndef CONFIG_ZYNQ_SDHCI_MAX_FREQ -# define CONFIG_ZYNQ_SDHCI_MAX_FREQ 200000000 -# endif #endif
#ifdef CONFIG_NAND_ARASAN diff --git a/include/configs/xilinx_zynqmp_ep.h b/include/configs/xilinx_zynqmp_ep.h index 3a572b7..a77eeea 100644 --- a/include/configs/xilinx_zynqmp_ep.h +++ b/include/configs/xilinx_zynqmp_ep.h @@ -13,7 +13,6 @@ #ifndef __CONFIG_ZYNQMP_EP_H #define __CONFIG_ZYNQMP_EP_H
-#define CONFIG_ZYNQ_SDHCI_MAX_FREQ 52000000 #define CONFIG_ZYNQ_SDHCI_MIN_FREQ (CONFIG_ZYNQ_SDHCI_MAX_FREQ >> 9) #define CONFIG_ZYNQ_EEPROM #define CONFIG_ZYNQMP_XHCI_LIST {ZYNQMP_USB0_XHCI_BASEADDR, \ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 0ebb66b..554fb66 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -73,11 +73,6 @@ #define CONFIG_MTD_DEVICE #endif
-/* MMC */ -#if defined(CONFIG_MMC_SDHCI_ZYNQ) -# define CONFIG_ZYNQ_SDHCI_MAX_FREQ 52000000 -#endif - #ifdef CONFIG_USB_EHCI_ZYNQ # define CONFIG_EHCI_IS_TDI
-- 2.7.4
This patch added Kconfig support for CONFIG_ZYNQ_SDHCI_MIN_FREQ and enabled it in respective defconfig.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- - Changes in v2: - Set min. frequency for ep 100KHz - Branch: u-boot-microblaze/kconfig --- configs/xilinx_zynqmp_ep_defconfig | 1 + drivers/mmc/Kconfig | 7 +++++++ drivers/mmc/zynq_sdhci.c | 4 ---- include/configs/xilinx_zynqmp_ep.h | 1 - 4 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index 00db5e3..a0c8f28 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -62,6 +62,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_ZYNQ_SDHCI_MIN_FREQ=100000 CONFIG_NAND=y CONFIG_NAND_ARASAN=y CONFIG_SPI_FLASH=y diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 42b7d21..4f2993c 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -478,6 +478,13 @@ config ZYNQ_SDHCI_MAX_FREQ help Set the maximum frequency for the SDHCI controller.
+config ZYNQ_SDHCI_MIN_FREQ + int "Set the minimum frequencyof the controller" + depends on MMC_SDHCI_ZYNQ + default 0 + help + Set the minimum frequencyof the controller. + config MMC_SUNXI bool "Allwinner sunxi SD/MMC Host Controller support" depends on ARCH_SUNXI && !UART0_PORT_F diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 0fddb42..414778c 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -16,10 +16,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#ifndef CONFIG_ZYNQ_SDHCI_MIN_FREQ -# define CONFIG_ZYNQ_SDHCI_MIN_FREQ 0 -#endif - struct arasan_sdhci_plat { struct mmc_config cfg; struct mmc mmc; diff --git a/include/configs/xilinx_zynqmp_ep.h b/include/configs/xilinx_zynqmp_ep.h index a77eeea..a26377a 100644 --- a/include/configs/xilinx_zynqmp_ep.h +++ b/include/configs/xilinx_zynqmp_ep.h @@ -13,7 +13,6 @@ #ifndef __CONFIG_ZYNQMP_EP_H #define __CONFIG_ZYNQMP_EP_H
-#define CONFIG_ZYNQ_SDHCI_MIN_FREQ (CONFIG_ZYNQ_SDHCI_MAX_FREQ >> 9) #define CONFIG_ZYNQ_EEPROM #define CONFIG_ZYNQMP_XHCI_LIST {ZYNQMP_USB0_XHCI_BASEADDR, \ ZYNQMP_USB1_XHCI_BASEADDR} -- 2.7.4
Applied both but I had to fix typos and sync Kconfig descriptions.
Thanks, Michal
Michal Simek
Vipul Kumar
