[u-boot/next] Pull request efi-next-20230608
Dear Tom,
The following changes since commit ac6096fe9c4d99f1dc37db95f213e08a48b11e70:
Merge branch '2023-06-01-assorted-platform-updates' into next (2023-06-01 15:43:38 -0400)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-next-20230608
for you to fetch changes up to b6f954e5b09545d18a150e4a4431a648e41ff287:
test/py: efi_capsule: test for FMP versioning (2023-06-08 09:20:36 +0200)
Gitlab CI showed no issues: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/16516
---------------------------------------------------------------- Pull request efi-next-20230608
UEFI:
* Support for firmware versions in capsule updates
---------------------------------------------------------------- Masahisa Kojima (10): efi_loader: add the number of image entries in efi_capsule_update_info efi_loader: store firmware version into FmpState variable efi_loader: versioning support in GetImageInfo efi_loader: get lowest supported version from device tree efi_loader: check lowest supported version mkeficapsule: add FMP Payload Header doc: uefi: add firmware versioning documentation doc: uefi: add anti-rollback documentation test: efi_capsule: refactor efi_capsule test test/py: efi_capsule: test for FMP versioning
arch/arm/mach-rockchip/board.c | 4 +- .../advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 2 +- .../imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c | 2 +- board/emulation/qemu-arm/qemu-arm.c | 2 +- board/kontron/pitx_imx8m/pitx_imx8m.c | 2 +- board/kontron/sl-mx8mm/sl-mx8mm.c | 2 +- board/kontron/sl28/sl28.c | 2 +- board/rockchip/evb_rk3399/evb-rk3399.c | 2 +- board/sandbox/sandbox.c | 2 +- board/socionext/developerbox/developerbox.c | 2 +- board/st/stm32mp1/stm32mp1.c | 2 +- board/xilinx/common/board.c | 2 +- doc/develop/uefi/uefi.rst | 66 +++++ .../firmware/firmware-version.txt | 22 ++ doc/mkeficapsule.1 | 10 + include/efi_loader.h | 3 +- lib/efi_loader/efi_firmware.c | 276 +++++++++++++++++-- lib/fwu_updates/fwu.c | 2 +- test/py/tests/test_efi_capsule/capsule_common.py | 142 ++++++++++ test/py/tests/test_efi_capsule/conftest.py | 82 ++++++ .../test_efi_capsule/test_capsule_firmware_fit.py | 213 +++++++-------- .../test_efi_capsule/test_capsule_firmware_raw.py | 301 ++++++++------------- .../test_capsule_firmware_signed_fit.py | 269 +++++++----------- .../test_capsule_firmware_signed_raw.py | 276 ++++++++----------- test/py/tests/test_efi_capsule/version.dts | 24 ++ tools/eficapsule.h | 30 ++ tools/mkeficapsule.c | 37 ++- 27 files changed, 1102 insertions(+), 677 deletions(-) create mode 100644 doc/device-tree-bindings/firmware/firmware-version.txt create mode 100644 test/py/tests/test_efi_capsule/capsule_common.py create mode 100644 test/py/tests/test_efi_capsule/version.dts
On Thu, Jun 08, 2023 at 11:49:00AM +0200, Heinrich Schuchardt wrote:
Dear Tom,
