[U-Boot] [RFC 3/5] common/env: Point default envirenoment for GD
16 Sep
2013
16 Sep
'13
6:05 p.m.
GD(Global Data) structure has pointer to envirenoment variable array. but, it is not being assigned for SPL framwork.
So update GD pointer with env variable array.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- common/env_common.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/common/env_common.c b/common/env_common.c index 1ac3377..84843e1 100644 --- a/common/env_common.c +++ b/common/env_common.c @@ -162,6 +162,9 @@ int env_import(const char *buf, int check) if (himport_r(&env_htab, (char *)ep->data, ENV_SIZE, '\0', 0, 0, NULL)) { gd->flags |= GD_FLG_ENV_READY; +#ifdef CONFIG_SPL_BUILD + gd->env_addr = ep->data; +#endif return 1; }
1.7.9.5
4259
Prabhakar Kushwaha
