Simon,
Your patch
commit 669dfc2ed8d853d6bcdcafa1de6aca22929465e5 Author: Simon Glass sjg@chromium.org Date: Mon Mar 11 06:30:27 2013 +0000
fdt: Ensure that libfdt_env.h comes from U-Boot
adds libfdt_env.h to HOSTCPPFLAGS. The causes a problem with one of our older hosts. On the old hosts, getline prototype is protected by
#ifdef __USE_GNU
This should be OK if the C file has #define _GNU_SOURCE. However, because of your patch, the stdio.h is included before _GNU_SOURCE is defined. The result is warnings like this
aisimage.c: In function ‘aisimage_generate’: aisimage.c:313: warning: implicit declaration of function ‘getline’ kwbimage.c: In function ‘kwdimage_set_ext_header’: kwbimage.c:236: warning: implicit declaration of function ‘getline’ imximage.c: In function ‘parse_cfg_file’: imximage.c:430: warning: implicit declaration of function ‘getline’ pblimage.c: In function ‘pbl_parser’: pblimage.c:137: warning: implicit declaration of function ‘getline’ ublimage.c: In function ‘parse_cfg_file’: ublimage.c:179: warning: implicit declaration of function ‘getline’
York
Hi York,
On Tue, Jul 30, 2013 at 3:12 PM, York Sun yorksun@freescale.com wrote:
Simon,
Your patch
#ifdef __USE_GNU
I took a quick look at this. It seems that many of the host C files in tools/ define _GNU_SOURCE. Should we just move that #define to the Makefile?
York
On 07/30/2013 02:17 PM, Simon Glass wrote:
Hi York,
On Tue, Jul 30, 2013 at 3:12 PM, York Sun <yorksun@freescale.com mailto:yorksun@freescale.com> wrote:
Simon, Your patch commit 669dfc2ed8d853d6bcdcafa1de6aca22929465e5 Author: Simon Glass <sjg@chromium.org <mailto:sjg@chromium.org>> Date: Mon Mar 11 06:30:27 2013 +0000 fdt: Ensure that libfdt_env.h comes from U-Boot adds libfdt_env.h to HOSTCPPFLAGS. The causes a problem with one of our older hosts. On the old hosts, getline prototype is protected by #ifdef __USE_GNU This should be OK if the C file has #define _GNU_SOURCE. However, because of your patch, the stdio.h is included before _GNU_SOURCE is defined. The result is warnings like this aisimage.c: In function ‘aisimage_generate’: aisimage.c:313: warning: implicit declaration of function ‘getline’ kwbimage.c: In function ‘kwdimage_set_ext_header’: kwbimage.c:236: warning: implicit declaration of function ‘getline’ imximage.c: In function ‘parse_cfg_file’: imximage.c:430: warning: implicit declaration of function ‘getline’ pblimage.c: In function ‘pbl_parser’: pblimage.c:137: warning: implicit declaration of function ‘getline’ ublimage.c: In function ‘parse_cfg_file’: ublimage.c:179: warning: implicit declaration of function ‘getline’
Adding -D_GNU_SOURCE in Makefile can fix this problem.
York
Hi York,
Are you going to send out a patch soon?
York
Hi York,
our
Makefile?
No, but if you do a patch and cc me I will Ack it :-) Sorry but I can't actually test this case here.
York Sun
