[U-Boot] [PATCH 1/2] mmc: dw_mmc: transfer proper bytes to FIFO
The former implement, dw_mmc will push and pop the redundant data to FIFO, we should transfer it according to the real size.
Signed-off-by: Ziyuan Xu xzy.xu@rock-chips.com ---
drivers/mmc/dw_mmc.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index 2cf7bae..38d4a64 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -126,6 +126,7 @@ static int dwmci_data_transfer(struct dwmci_host *host, struct mmc_data *data) len = dwmci_readl(host, DWMCI_STATUS); len = (len >> DWMCI_FIFO_SHIFT) & DWMCI_FIFO_MASK; + len = min(size, len); for (i = 0; i < len; i++) *buf++ = dwmci_readl(host, DWMCI_DATA); @@ -139,6 +140,7 @@ static int dwmci_data_transfer(struct dwmci_host *host, struct mmc_data *data) len = fifo_depth - ((len >> DWMCI_FIFO_SHIFT) & DWMCI_FIFO_MASK); + len = min(size, len); for (i = 0; i < len; i++) dwmci_writel(host, DWMCI_DATA, *buf++);
This patch fixes data starvation by host timeout(HTO) error interrupt which occurred under FIFO mode transfer on rk3036 board.
The former implement, the actual bytes were transmitted may be less than should be. The size will still subtract value of len in case of there is no receive/transmit FIFO data request interrupt.
drivers/mmc/dw_mmc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index 38d4a64..41b7035 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -120,6 +120,7 @@ static int dwmci_data_transfer(struct dwmci_host *host, struct mmc_data *data) }
if (host->fifo_mode && size) { + len = 0; if (data->flags == MMC_DATA_READ) { if ((dwmci_readl(host, DWMCI_RINTSTS) & DWMCI_INTMSK_RXDR)) {
Hi Ziyuan,
Looks good to me.
Acked-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
Signed-off-by: Ziyuan Xu xzy.xu@rock-chips.com Acked-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Simon Glass sjg@chromium.org
Applied on u-boot-mmc. Thanks!
Hi Ziyuan,
Looks good to me.
在 2016/7/28 10:25, Ziyuan Xu 写道:
Bascially I never checked any bootloader code, but I get dw_mmc of uboot to check your patch. Obviously it should be the case you mentioned.
Feel free to add
Reviewed-by: Shawn Lin shawn.lin@rock-chips.com
Signed-off-by: Ziyuan Xu xzy.xu@rock-chips.com Acked-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Shawn Lin shawn.lin@rock-chips.com
Jaehoon Chung
Shawn Lin
Ziyuan Xu
