[U-Boot] [PATCH] dm: spi: Correct SPI claim/release_bus() methods
These methods should be passed a slave device, not a bus. This matches the old SPI interface. It is important to know which device is claiming the bus so passing a bus is not that useful.
Reported-by: Haikun Wang haikun.wang@freescale.com Signed-off-by: Simon Glass sjg@chromium.org ---
drivers/spi/exynos_spi.c | 6 ++++-- drivers/spi/spi-uclass.c | 4 ++-- drivers/spi/tegra114_spi.c | 3 ++- drivers/spi/tegra20_sflash.c | 3 ++- drivers/spi/tegra20_slink.c | 3 ++- include/spi.h | 10 +++++----- 6 files changed, 17 insertions(+), 12 deletions(-)
diff --git a/drivers/spi/exynos_spi.c b/drivers/spi/exynos_spi.c index a46d8c1..67f6b2d 100644 --- a/drivers/spi/exynos_spi.c +++ b/drivers/spi/exynos_spi.c @@ -296,8 +296,9 @@ static int exynos_spi_probe(struct udevice *bus) return 0; }
-static int exynos_spi_claim_bus(struct udevice *bus) +static int exynos_spi_claim_bus(struct udevice *dev) { + struct udevice *bus = dev->parent; struct exynos_spi_priv *priv = dev_get_priv(bus);
exynos_pinmux_config(priv->periph_id, PINMUX_FLAG_NONE); @@ -308,8 +309,9 @@ static int exynos_spi_claim_bus(struct udevice *bus) return 0; }
-static int exynos_spi_release_bus(struct udevice *bus) +static int exynos_spi_release_bus(struct udevice *dev) { + struct udevice *bus = dev->parent; struct exynos_spi_priv *priv = dev_get_priv(bus);
spi_flush_fifo(priv->regs); diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index 866c48f..83fe8e0 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -67,7 +67,7 @@ int spi_claim_bus(struct spi_slave *slave) if (ret) return ret;
- return ops->claim_bus ? ops->claim_bus(bus) : 0; + return ops->claim_bus ? ops->claim_bus(dev) : 0; }
void spi_release_bus(struct spi_slave *slave) @@ -77,7 +77,7 @@ void spi_release_bus(struct spi_slave *slave) struct dm_spi_ops *ops = spi_get_ops(bus);
if (ops->release_bus) - ops->release_bus(bus); + ops->release_bus(dev); }
int spi_xfer(struct spi_slave *slave, unsigned int bitlen, diff --git a/drivers/spi/tegra114_spi.c b/drivers/spi/tegra114_spi.c index 53ff9ea..4bec663 100644 --- a/drivers/spi/tegra114_spi.c +++ b/drivers/spi/tegra114_spi.c @@ -153,8 +153,9 @@ static int tegra114_spi_probe(struct udevice *bus) return 0; }
-static int tegra114_spi_claim_bus(struct udevice *bus) +static int tegra114_spi_claim_bus(struct udevice *dev) { + struct udevice *bus = dev->parent; struct tegra114_spi_priv *priv = dev_get_priv(bus); struct spi_regs *regs = priv->regs;
diff --git a/drivers/spi/tegra20_sflash.c b/drivers/spi/tegra20_sflash.c index 78c74cd..82c1b84 100644 --- a/drivers/spi/tegra20_sflash.c +++ b/drivers/spi/tegra20_sflash.c @@ -125,8 +125,9 @@ static int tegra20_sflash_probe(struct udevice *bus) return 0; }
-static int tegra20_sflash_claim_bus(struct udevice *bus) +static int tegra20_sflash_claim_bus(struct udevice *dev) { + struct udevice *bus = dev->parent; struct tegra20_sflash_priv *priv = dev_get_priv(bus); struct spi_regs *regs = priv->regs; u32 reg; diff --git a/drivers/spi/tegra20_slink.c b/drivers/spi/tegra20_slink.c index 597d6ad..f6fb89b 100644 --- a/drivers/spi/tegra20_slink.c +++ b/drivers/spi/tegra20_slink.c @@ -141,8 +141,9 @@ static int tegra30_spi_probe(struct udevice *bus) return 0; }
-static int tegra30_spi_claim_bus(struct udevice *bus) +static int tegra30_spi_claim_bus(struct udevice *dev) { + struct udevice *bus = dev->parent; struct tegra30_spi_priv *priv = dev_get_priv(bus); struct spi_regs *regs = priv->regs; u32 reg; diff --git a/include/spi.h b/include/spi.h index c58e453..863e6db 100644 --- a/include/spi.h +++ b/include/spi.h @@ -385,12 +385,12 @@ struct dm_spi_ops { * allowed to claim the same bus for several slaves without releasing * the bus in between. * - * @bus: The SPI slave + * @dev: The SPI slave * * Returns: 0 if the bus was claimed successfully, or a negative value * if it wasn't. */ - int (*claim_bus)(struct udevice *bus); + int (*claim_bus)(struct udevice *dev);
/** * Release the SPI bus @@ -399,9 +399,9 @@ struct dm_spi_ops { * all transfers have finished. It may disable any SPI hardware as * appropriate. * - * @bus: The SPI slave + * @dev: The SPI slave */ - int (*release_bus)(struct udevice *bus); + int (*release_bus)(struct udevice *dev);
/** * Set the word length for SPI transactions @@ -413,7 +413,7 @@ struct dm_spi_ops { * * Returns: 0 on success, -ve on failure. */ - int (*set_wordlen)(struct udevice *bus, unsigned int wordlen); + int (*set_wordlen)(struct udevice *dev, unsigned int wordlen);
/** * SPI transfer
Hi, Simon
- struct udevice *bus = dev->parent; struct tegra114_spi_priv *priv = dev_get_priv(bus); struct spi_regs *regs = priv->regs;
- struct udevice *bus = dev->parent; struct tegra20_sflash_priv *priv = dev_get_priv(bus); struct spi_regs *regs = priv->regs; u32 reg;
- struct udevice *bus = dev->parent; struct tegra30_spi_priv *priv = dev_get_priv(bus); struct spi_regs *regs = priv->regs; u32 reg;
- Returns: 0 if the bus was claimed successfully, or a negative value
- if it wasn't.
- Release the SPI bus
*/* @dev: The SPI slave
- Set the word length for SPI transactions
- SPI transfer
After applying this patch, qspi flashes can be correctly probed and read/write on i.MX platform. I original posted a patch https://patchwork.ozlabs.org/patch/461034/ which seems in wrong way:)
Tested-by: Peng Fan Peng.Fan@freescale.com
Regards, Peng.
On 20 April 2015 at 10:11, Peng Fan Peng.Fan@freescale.com wrote:
Hi, Simon
diff --git a/drivers/spi/exynos_spi.c b/drivers/spi/exynos_spi.c index a46d8c1..67f6b2d 100644 --- a/drivers/spi/exynos_spi.c +++ b/drivers/spi/exynos_spi.c @@ -296,8 +296,9 @@ static int exynos_spi_probe(struct udevice *bus) return 0; } -static int exynos_spi_claim_bus(struct udevice *bus) +static int exynos_spi_claim_bus(struct udevice *dev) {
struct udevice *bus = dev->parent; struct exynos_spi_priv *priv = dev_get_priv(bus); exynos_pinmux_config(priv->periph_id, PINMUX_FLAG_NONE);
@@ -308,8 +309,9 @@ static int exynos_spi_claim_bus(struct udevice *bus) return 0; } -static int exynos_spi_release_bus(struct udevice *bus) +static int exynos_spi_release_bus(struct udevice *dev) {
struct udevice *bus = dev->parent; struct exynos_spi_priv *priv = dev_get_priv(bus); spi_flush_fifo(priv->regs);
} void spi_release_bus(struct spi_slave *slave)return ops->claim_bus ? ops->claim_bus(dev) : 0;
@@ -77,7 +77,7 @@ void spi_release_bus(struct spi_slave *slave) struct dm_spi_ops *ops = spi_get_ops(bus); if (ops->release_bus)
} int spi_xfer(struct spi_slave *slave, unsigned int bitlen,ops->release_bus(dev);
diff --git a/drivers/spi/tegra114_spi.c b/drivers/spi/tegra114_spi.c index 53ff9ea..4bec663 100644 --- a/drivers/spi/tegra114_spi.c +++ b/drivers/spi/tegra114_spi.c @@ -153,8 +153,9 @@ static int tegra114_spi_probe(struct udevice *bus) return 0; } -static int tegra114_spi_claim_bus(struct udevice *bus) +static int tegra114_spi_claim_bus(struct udevice *dev) {
diff --git a/drivers/spi/tegra20_sflash.c b/drivers/spi/tegra20_sflash.cstruct udevice *bus = dev->parent; struct tegra114_spi_priv *priv = dev_get_priv(bus); struct spi_regs *regs = priv->regs;
index 78c74cd..82c1b84 100644 --- a/drivers/spi/tegra20_sflash.c +++ b/drivers/spi/tegra20_sflash.c @@ -125,8 +125,9 @@ static int tegra20_sflash_probe(struct udevice *bus) return 0; } -static int tegra20_sflash_claim_bus(struct udevice *bus) +static int tegra20_sflash_claim_bus(struct udevice *dev) {
diff --git a/drivers/spi/tegra20_slink.c b/drivers/spi/tegra20_slink.c index 597d6ad..f6fb89b 100644 --- a/drivers/spi/tegra20_slink.c +++ b/drivers/spi/tegra20_slink.c @@ -141,8 +141,9 @@ static int tegra30_spi_probe(struct udevice *bus) return 0; } -static int tegra30_spi_claim_bus(struct udevice *bus) +static int tegra30_spi_claim_bus(struct udevice *dev) {
int (*claim_bus)(struct udevice *dev); /** * Release the SPI bus
int (*release_bus)(struct udevice *dev); /** * Set the word length for SPI transactions
int (*set_wordlen)(struct udevice *dev, unsigned int wordlen); /** * SPI transfer
I'm picking on -spi/master! any concerns?
thanks!
Hi Jagan,
Hi, Simon
That's fine with me.
On 23 April 2015 at 02:12, Simon Glass sjg@chromium.org wrote:
Hi Jagan,
Hi, Simon
Applied to u-boot-spi/master
thanks!
Jagan Teki
Peng Fan
