[U-Boot] [PATCH-ARM 1/4, v2] Clean-up of cpu_arm920t and cpu_arm920t_s3c24x0 code
Changes since v1: - re-formatted patch to remove line wrapping
Note that patch 2/4 of this series has not changed.
This patch re-formats the code in cpu/arm920t and cpu/arm920t/23c24x0 in preparation for changes to add support for the Embest SBC2440-II Board.
The changes are as follows: - re-indent the code using Lindent - make sure register layouts are defined using a C struct - replace the upper-case typedef'ed C struct names with lower case non-typedef'ed ones - make sure registers are accessed using the proper accessor functions - run checkpatch.pl and fix any error reports
Note that usb_ohci.c still has two lines that exceed 80 characters. This is because the statements on those lines lose readability when wrapped - the Linux coding style guidelines allow for this.
It assumes the following patch has been applied first: - [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009
Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, ran MAKEALL for all ARM9 targets and no new warnings or errors were found.
Signed-off-by: Kevin Morfitt kevin.morfitt@fearnside-systems.co.uk --- cpu/arm920t/s3c24x0/interrupts.c | 2 +- cpu/arm920t/s3c24x0/speed.c | 42 +- cpu/arm920t/s3c24x0/timer.c | 74 ++- cpu/arm920t/s3c24x0/usb.c | 30 +- cpu/arm920t/s3c24x0/usb_ohci.c | 1268 ++++++++++++++++++++------------------ cpu/arm920t/s3c24x0/usb_ohci.h | 187 +++--- cpu/arm920t/start.S | 63 +- 7 files changed, 873 insertions(+), 793 deletions(-)
diff --git a/cpu/arm920t/s3c24x0/interrupts.c b/cpu/arm920t/s3c24x0/interrupts.c index 11ec95e..5a9256d 100644 --- a/cpu/arm920t/s3c24x0/interrupts.c +++ b/cpu/arm920t/s3c24x0/interrupts.c @@ -40,7 +40,7 @@
void do_irq (struct pt_regs *pt_regs) { - S3C24X0_INTERRUPT * irq = S3C24X0_GetBase_INTERRUPT(); + struct s3c24x0_interrupt * irq = s3c24x0_get_base_interrupt(); u_int32_t intpnd = irq->INTPND;
} diff --git a/cpu/arm920t/s3c24x0/speed.c b/cpu/arm920t/s3c24x0/speed.c index e0dca62..136c779 100644 --- a/cpu/arm920t/s3c24x0/speed.c +++ b/cpu/arm920t/s3c24x0/speed.c @@ -32,6 +32,8 @@ #include <common.h> #if defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB)
+#include <asm/io.h> + #if defined(CONFIG_S3C2400) #include <s3c2400.h> #elif defined(CONFIG_S3C2410) @@ -53,49 +55,51 @@
static ulong get_PLLCLK(int pllreg) { - S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); - ulong r, m, p, s; + struct s3c24x0_clock_power *clk_power = s3c24x0_get_base_clock_power(); + ulong r, m, p, s;
- if (pllreg == MPLL) - r = clk_power->MPLLCON; - else if (pllreg == UPLL) - r = clk_power->UPLLCON; - else - hang(); + if (pllreg == MPLL) + r = readl(&clk_power->MPLLCON); + else if (pllreg == UPLL) + r = readl(&clk_power->UPLLCON); + else + hang();
- m = ((r & 0xFF000) >> 12) + 8; - p = ((r & 0x003F0) >> 4) + 2; - s = r & 0x3; + m = ((r & 0xFF000) >> 12) + 8; + p = ((r & 0x003F0) >> 4) + 2; + s = r & 0x3;
- return((CONFIG_SYS_CLK_FREQ * m) / (p << s)); + return (CONFIG_SYS_CLK_FREQ * m) / (p << s); }
/* return FCLK frequency */ ulong get_FCLK(void) { - return(get_PLLCLK(MPLL)); + return get_PLLCLK(MPLL); }
/* return HCLK frequency */ ulong get_HCLK(void) { - S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + struct s3c24x0_clock_power *clk_power = s3c24x0_get_base_clock_power();
- return((clk_power->CLKDIVN & 0x2) ? get_FCLK()/2 : get_FCLK()); + return (readl(&clk_power->CLKDIVN) & 2) ? get_FCLK() / 2 : get_FCLK(); }
/* return PCLK frequency */ ulong get_PCLK(void) { - S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + struct s3c24x0_clock_power *clk_power = s3c24x0_get_base_clock_power();
- return((clk_power->CLKDIVN & 0x1) ? get_HCLK()/2 : get_HCLK()); + return (readl(&clk_power->CLKDIVN) & 1) ? get_HCLK() / 2 : get_HCLK(); }
/* return UCLK frequency */ ulong get_UCLK(void) { - return(get_PLLCLK(UPLL)); + return get_PLLCLK(UPLL); }
-#endif /* defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) */ +#endif /* defined(CONFIG_S3C2400) || + defined (CONFIG_S3C2410) || + defined (CONFIG_TRAB) */ diff --git a/cpu/arm920t/s3c24x0/timer.c b/cpu/arm920t/s3c24x0/timer.c index db472bf..20cedd4 100644 --- a/cpu/arm920t/s3c24x0/timer.c +++ b/cpu/arm920t/s3c24x0/timer.c @@ -30,7 +30,11 @@ */
#include <common.h> -#if defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) +#if defined(CONFIG_S3C2400) || \ + defined(CONFIG_S3C2410) || \ + defined(CONFIG_TRAB) + +#include <asm/io.h>
#if defined(CONFIG_S3C2400) #include <s3c2400.h> @@ -44,37 +48,40 @@ static ulong timer_clk; /* macro to read the 16 bit timer */ static inline ulong READ_TIMER(void) { - S3C24X0_TIMERS * const timers = S3C24X0_GetBase_TIMERS(); + struct s3c24x0_timers *timers = s3c24x0_get_base_timers();
- return (timers->TCNTO4 & 0xffff); + return readl(&timers->TCNTO4) & 0xffff; }
static ulong timestamp; static ulong lastdec;
-int timer_init (void) +int timer_init(void) { - S3C24X0_TIMERS * const timers = S3C24X0_GetBase_TIMERS(); + struct s3c24x0_timers *timers = s3c24x0_get_base_timers(); + ulong tmr;
/* use PWM Timer 4 because it has no output */ /* prescaler for Timer 4 is 16 */ - timers->TCFG0 = 0x0f00; - if (timer_load_val == 0) - { + writel(0x0f00, &timers->TCFG0); + if (timer_load_val == 0) { /* * for 10 ms clock period @ PCLK with 4 bit divider = 1/2 * (default) and prescaler = 16. Should be 10390 * @33.25MHz and 15625 @ 50 MHz */ - timer_load_val = get_PCLK()/(2 * 16 * 100); + timer_load_val = get_PCLK() / (2 * 16 * 100); timer_clk = get_PCLK() / (2 * 16); } /* load value for 10 ms timeout */ - lastdec = timers->TCNTB4 = timer_load_val; + lastdec = timer_load_val; + writel(timer_load_val, &timers->TCNTB4); /* auto load, manual update of Timer 4 */ - timers->TCON = (timers->TCON & ~0x0700000) | 0x600000; + tmr = (readl(&timers->TCON) & ~0x0700000) | 0x0600000; + writel(tmr, &timers->TCON); /* auto load, start Timer 4 */ - timers->TCON = (timers->TCON & ~0x0700000) | 0x500000; + tmr = (tmr & ~0x0700000) | 0x0500000; + writel(tmr, &timers->TCON); timestamp = 0;
return (0); @@ -84,22 +91,22 @@ int timer_init (void) * timer without interrupts */
-void reset_timer (void) +void reset_timer(void) { - reset_timer_masked (); + reset_timer_masked(); }
-ulong get_timer (ulong base) +ulong get_timer(ulong base) { - return get_timer_masked () - base; + return get_timer_masked() - base; }
-void set_timer (ulong t) +void set_timer(ulong t) { timestamp = t; }
-void udelay (unsigned long usec) +void udelay(unsigned long usec) { ulong tmo; ulong start = get_ticks(); @@ -112,21 +119,21 @@ void udelay (unsigned long usec) /*NOP*/; }
-void reset_timer_masked (void) +void reset_timer_masked(void) { /* reset time */ lastdec = READ_TIMER(); timestamp = 0; }
-ulong get_timer_masked (void) +ulong get_timer_masked(void) { ulong tmr = get_ticks();
return tmr / (timer_clk / CONFIG_SYS_HZ); }
-void udelay_masked (unsigned long usec) +void udelay_masked(unsigned long usec) { ulong tmo; ulong endtime; @@ -138,7 +145,7 @@ void udelay_masked (unsigned long usec) tmo /= 1000; } else { tmo = usec * (timer_load_val * 100); - tmo /= (1000*1000); + tmo /= (1000 * 1000); }
endtime = get_ticks() + tmo; @@ -173,7 +180,7 @@ unsigned long long get_ticks(void) * This function is derived from PowerPC code (timebase clock frequency). * On ARM it returns the number of timer ticks per second. */ -ulong get_tbclk (void) +ulong get_tbclk(void) { ulong tbclk;
@@ -193,30 +200,31 @@ ulong get_tbclk (void) /* * reset the cpu by setting up the watchdog timer and let him time out */ -void reset_cpu (ulong ignored) +void reset_cpu(ulong ignored) { - volatile S3C24X0_WATCHDOG * watchdog; + struct s3c24x0_watchdog *watchdog;
#ifdef CONFIG_TRAB - extern void disable_vfd (void); - disable_vfd(); #endif
- watchdog = S3C24X0_GetBase_WATCHDOG(); + watchdog = s3c24x0_get_base_watchdog();
/* Disable watchdog */ - watchdog->WTCON = 0x0000; + writel(0x0000, &watchdog->WTCON);
/* Initialize watchdog timer count register */ - watchdog->WTCNT = 0x0001; + writel(0x0001, &watchdog->WTCNT);
/* Enable watchdog timer; assert reset at timer timeout */ - watchdog->WTCON = 0x0021; + writel(0x0021, &watchdog->WTCON);
- while(1); /* loop forever and wait for reset to happen */ + while (1) + /* loop forever and wait for reset to happen */;
/*NOTREACHED*/ }
-#endif /* defined(CONFIG_S3C2400) || defined (CONFIG_S3C2410) || defined (CONFIG_TRAB) */ +#endif /* defined(CONFIG_S3C2400) || + defined (CONFIG_S3C2410) || + defined (CONFIG_TRAB) */ diff --git a/cpu/arm920t/s3c24x0/usb.c b/cpu/arm920t/s3c24x0/usb.c index 9ccf575..b5ba8c4 100644 --- a/cpu/arm920t/s3c24x0/usb.c +++ b/cpu/arm920t/s3c24x0/usb.c @@ -32,41 +32,43 @@ # include <s3c2410.h> #endif
-int usb_cpu_init (void) -{ +#include <asm/io.h>
- S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); - S3C24X0_GPIO * const gpio = S3C24X0_GetBase_GPIO(); +int usb_cpu_init(void) +{ + struct s3c24x0_clock_power *clk_power = s3c24x0_get_base_clock_power(); + struct s3c24x0_gpio *gpio = s3c24x0_get_base_gpio();
/* * Set the 48 MHz UPLL clocking. Values are taken from * "PLL value selection guide", 6-23, s3c2400_UM.pdf. */ - clk_power->UPLLCON = ((40 << 12) + (1 << 4) + 2); - gpio->MISCCR |= 0x8; /* 1 = use pads related USB for USB host */ + writel((40 << 12) + (1 << 4) + 2, &clk_power->UPLLCON); + /* 1 = use pads related USB for USB host */ + writel(readl(&gpio->MISCCR) | 0x8, &gpio->MISCCR);
/* * Enable USB host clock. */ - clk_power->CLKCON |= (1 << 4); + writel(readl(&clk_power->CLKCON) | (1 << 4), &clk_power->CLKCON);
return 0; }
-int usb_cpu_stop (void) +int usb_cpu_stop(void) { - S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + struct s3c24x0_clock_power *clk_power = s3c24x0_get_base_clock_power(); /* may not want to do this */ - clk_power->CLKCON &= ~(1 << 4); + writel(readl(&clk_power->CLKCON) & ~(1 << 4), &clk_power->CLKCON); return 0; }
-int usb_cpu_init_fail (void) +int usb_cpu_init_fail(void) { - S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); - clk_power->CLKCON &= ~(1 << 4); + struct s3c24x0_clock_power *clk_power = s3c24x0_get_base_clock_power(); + writel(readl(&clk_power->CLKCON) & ~(1 << 4), &clk_power->CLKCON); return 0; }
-# endif /* defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) */ +# endif /* defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410) */ #endif /* defined(CONFIG_USB_OHCI_NEW) && defined(CONFIG_SYS_USB_OHCI_CPU_INIT) */ diff --git a/cpu/arm920t/s3c24x0/usb_ohci.c b/cpu/arm920t/s3c24x0/usb_ohci.c index 7838014..42557f5 100644 --- a/cpu/arm920t/s3c24x0/usb_ohci.c +++ b/cpu/arm920t/s3c24x0/usb_ohci.c @@ -44,6 +44,7 @@ #include <s3c2410.h> #endif
+#include <asm/io.h> #include <malloc.h> #include <usb.h> #include "usb_ohci.h" @@ -56,10 +57,8 @@ #define OHCI_CONTROL_INIT \ (OHCI_CTRL_CBSR & 0x3) | OHCI_CTRL_IE | OHCI_CTRL_PLE
-#define readl(a) (*((volatile u32 *)(a))) -#define writel(a, b) (*((volatile u32 *)(b)) = ((volatile u32)a)) - -#define min_t(type,x,y) ({ type __x = (x); type __y = (y); __x < __y ? __x: __y; }) +#define min_t(type, x, y) \ + ({ type __x = (x); type __y = (y); __x < __y ? __x : __y; })
#undef DEBUG #ifdef DEBUG @@ -109,21 +108,29 @@ int urb_finished = 0; temp = readl (&hc->regs->roothub.register); \ temp; })
-static u32 roothub_a (struct ohci *hc) - { return read_roothub (hc, a, 0xfc0fe000); } -static inline u32 roothub_b (struct ohci *hc) - { return readl (&hc->regs->roothub.b); } -static inline u32 roothub_status (struct ohci *hc) - { return readl (&hc->regs->roothub.status); } -static u32 roothub_portstatus (struct ohci *hc, int i) - { return read_roothub (hc, portstatus [i], 0xffe0fce0); } - +static u32 roothub_a(struct ohci *hc) +{ + return read_roothub(hc, a, 0xfc0fe000); +} +static inline u32 roothub_b(struct ohci *hc) +{ + return readl(&hc->regs->roothub.b); +} +static inline u32 roothub_status(struct ohci *hc) +{ + return readl(&hc->regs->roothub.status); +} +static u32 roothub_portstatus(struct ohci *hc, int i) +{ + return read_roothub(hc, portstatus[i], 0xffe0fce0); +}
/* forward declaration */ -static int hc_interrupt (void); -static void -td_submit_job (struct usb_device * dev, unsigned long pipe, void * buffer, - int transfer_len, struct devrequest * setup, urb_priv_t * urb, int interval); +static int hc_interrupt(void); +static void td_submit_job(struct usb_device *dev, unsigned long pipe, + void *buffer, int transfer_len, + struct devrequest *setup, urb_priv_t *urb, + int interval);
/*-------------------------------------------------------------------------* * URB support functions @@ -131,11 +138,11 @@ td_submit_job (struct usb_device * dev, unsigned long pipe, void * buffer,
/* free HCD-private data associated with this URB */
-static void urb_free_priv (urb_priv_t * urb) +static void urb_free_priv(urb_priv_t *urb) { - int i; - int last; - struct td * td; + int i; + int last; + struct td *td;
last = urb->length - 1; if (last >= 0) { @@ -152,227 +159,219 @@ static void urb_free_priv (urb_priv_t * urb) /*-------------------------------------------------------------------------*/
#ifdef DEBUG -static int sohci_get_current_frame_number (struct usb_device * dev); +static int sohci_get_current_frame_number(struct usb_device *dev);
/* debug| print the main components of an URB * small: 0) header + data packets 1) just header */
-static void pkt_print (struct usb_device * dev, unsigned long pipe, void * buffer, - int transfer_len, struct devrequest * setup, char * str, int small) +static void pkt_print(struct usb_device *dev, unsigned long pipe, void *buffer, + int transfer_len, struct devrequest *setup, char *str, + int small) { - urb_priv_t * purb = &urb_priv; + urb_priv_t *purb = &urb_priv;
dbg("%s URB:[%4x] dev:%2d,ep:%2d-%c,type:%s,len:%d/%d stat:%#lx", - str, - sohci_get_current_frame_number (dev), - usb_pipedevice (pipe), - usb_pipeendpoint (pipe), - usb_pipeout (pipe)? 'O': 'I', - usb_pipetype (pipe) < 2? (usb_pipeint (pipe)? "INTR": "ISOC"): - (usb_pipecontrol (pipe)? "CTRL": "BULK"), - purb->actual_length, - transfer_len, dev->status); + str, + sohci_get_current_frame_number(dev), + usb_pipedevice(pipe), + usb_pipeendpoint(pipe), + usb_pipeout(pipe) ? 'O' : 'I', + usb_pipetype(pipe) < 2 ? + (usb_pipeint(pipe) ? "INTR" : "ISOC") : + (usb_pipecontrol(pipe) ? "CTRL" : "BULK"), + purb->actual_length, transfer_len, dev->status); #ifdef OHCI_VERBOSE_DEBUG if (!small) { int i, len;
- if (usb_pipecontrol (pipe)) { - printf (__FILE__ ": cmd(8):"); - for (i = 0; i < 8 ; i++) - printf (" %02x", ((__u8 *) setup) [i]); - printf ("\n"); + if (usb_pipecontrol(pipe)) { + printf(__FILE__ ": cmd(8):"); + for (i = 0; i < 8; i++) + printf(" %02x", ((__u8 *) setup)[i]); + printf("\n"); } if (transfer_len > 0 && buffer) { - printf (__FILE__ ": data(%d/%d):", - purb->actual_length, - transfer_len); - len = usb_pipeout (pipe)? - transfer_len: purb->actual_length; + printf(__FILE__ ": data(%d/%d):", + purb->actual_length, transfer_len); + len = usb_pipeout(pipe) ? + transfer_len : purb->actual_length; for (i = 0; i < 16 && i < len; i++) - printf (" %02x", ((__u8 *) buffer) [i]); - printf ("%s\n", i < len? "...": ""); + printf(" %02x", ((__u8 *) buffer)[i]); + printf("%s\n", i < len ? "..." : ""); } } #endif }
-/* just for debugging; prints non-empty branches of the int ed tree inclusive iso eds*/ -void ep_print_int_eds (ohci_t *ohci, char * str) { +/* just for debugging; prints non-empty branches of the + int ed tree inclusive iso eds*/ +void ep_print_int_eds(ohci_t *ohci, char *str) +{ int i, j; - __u32 * ed_p; - for (i= 0; i < 32; i++) { + __u32 *ed_p; + for (i = 0; i < 32; i++) { j = 5; - ed_p = &(ohci->hcca->int_table [i]); + ed_p = &(ohci->hcca->int_table[i]); if (*ed_p == 0) - continue; - printf (__FILE__ ": %s branch int %2d(%2x):", str, i, i); + continue; + printf(__FILE__ ": %s branch int %2d(%2x):", str, i, i); while (*ed_p != 0 && j--) { - ed_t *ed = (ed_t *)m32_swap(ed_p); - printf (" ed: %4x;", ed->hwINFO); + ed_t *ed = (ed_t *) m32_swap(ed_p); + printf(" ed: %4x;", ed->hwINFO); ed_p = &ed->hwNextED; } - printf ("\n"); + printf("\n"); } }
-static void ohci_dump_intr_mask (char *label, __u32 mask) +static void ohci_dump_intr_mask(char *label, __u32 mask) { - dbg ("%s: 0x%08x%s%s%s%s%s%s%s%s%s", - label, - mask, - (mask & OHCI_INTR_MIE) ? " MIE" : "", - (mask & OHCI_INTR_OC) ? " OC" : "", - (mask & OHCI_INTR_RHSC) ? " RHSC" : "", - (mask & OHCI_INTR_FNO) ? " FNO" : "", - (mask & OHCI_INTR_UE) ? " UE" : "", - (mask & OHCI_INTR_RD) ? " RD" : "", - (mask & OHCI_INTR_SF) ? " SF" : "", - (mask & OHCI_INTR_WDH) ? " WDH" : "", - (mask & OHCI_INTR_SO) ? " SO" : "" - ); + dbg("%s: 0x%08x%s%s%s%s%s%s%s%s%s", + label, + mask, + (mask & OHCI_INTR_MIE) ? " MIE" : "", + (mask & OHCI_INTR_OC) ? " OC" : "", + (mask & OHCI_INTR_RHSC) ? " RHSC" : "", + (mask & OHCI_INTR_FNO) ? " FNO" : "", + (mask & OHCI_INTR_UE) ? " UE" : "", + (mask & OHCI_INTR_RD) ? " RD" : "", + (mask & OHCI_INTR_SF) ? " SF" : "", + (mask & OHCI_INTR_WDH) ? " WDH" : "", + (mask & OHCI_INTR_SO) ? " SO" : ""); }
-static void maybe_print_eds (char *label, __u32 value) +static void maybe_print_eds(char *label, __u32 value) { - ed_t *edp = (ed_t *)value; + ed_t *edp = (ed_t *) value;
if (value) { - dbg ("%s %08x", label, value); - dbg ("%08x", edp->hwINFO); - dbg ("%08x", edp->hwTailP); - dbg ("%08x", edp->hwHeadP); - dbg ("%08x", edp->hwNextED); + dbg("%s %08x", label, value); + dbg("%08x", edp->hwINFO); + dbg("%08x", edp->hwTailP); + dbg("%08x", edp->hwHeadP); + dbg("%08x", edp->hwNextED); } }
-static char * hcfs2string (int state) +static char *hcfs2string(int state) { switch (state) { - case OHCI_USB_RESET: return "reset"; - case OHCI_USB_RESUME: return "resume"; - case OHCI_USB_OPER: return "operational"; - case OHCI_USB_SUSPEND: return "suspend"; + case OHCI_USB_RESET: + return "reset"; + case OHCI_USB_RESUME: + return "resume"; + case OHCI_USB_OPER: + return "operational"; + case OHCI_USB_SUSPEND: + return "suspend"; } return "?"; }
/* dump control and status registers */ -static void ohci_dump_status (ohci_t *controller) +static void ohci_dump_status(ohci_t *controller) { - struct ohci_regs *regs = controller->regs; - __u32 temp; + struct ohci_regs *regs = controller->regs; + __u32 temp;
- temp = readl (®s->revision) & 0xff; + temp = readl(®s->revision) & 0xff; if (temp != 0x10) - dbg ("spec %d.%d", (temp >> 4), (temp & 0x0f)); - - temp = readl (®s->control); - dbg ("control: 0x%08x%s%s%s HCFS=%s%s%s%s%s CBSR=%d", temp, - (temp & OHCI_CTRL_RWE) ? " RWE" : "", - (temp & OHCI_CTRL_RWC) ? " RWC" : "", - (temp & OHCI_CTRL_IR) ? " IR" : "", - hcfs2string (temp & OHCI_CTRL_HCFS), - (temp & OHCI_CTRL_BLE) ? " BLE" : "", - (temp & OHCI_CTRL_CLE) ? " CLE" : "", - (temp & OHCI_CTRL_IE) ? " IE" : "", - (temp & OHCI_CTRL_PLE) ? " PLE" : "", - temp & OHCI_CTRL_CBSR - ); - - temp = readl (®s->cmdstatus); - dbg ("cmdstatus: 0x%08x SOC=%d%s%s%s%s", temp, - (temp & OHCI_SOC) >> 16, - (temp & OHCI_OCR) ? " OCR" : "", - (temp & OHCI_BLF) ? " BLF" : "", - (temp & OHCI_CLF) ? " CLF" : "", - (temp & OHCI_HCR) ? " HCR" : "" - ); - - ohci_dump_intr_mask ("intrstatus", readl (®s->intrstatus)); - ohci_dump_intr_mask ("intrenable", readl (®s->intrenable)); - - maybe_print_eds ("ed_periodcurrent", readl (®s->ed_periodcurrent)); - - maybe_print_eds ("ed_controlhead", readl (®s->ed_controlhead)); - maybe_print_eds ("ed_controlcurrent", readl (®s->ed_controlcurrent)); - - maybe_print_eds ("ed_bulkhead", readl (®s->ed_bulkhead)); - maybe_print_eds ("ed_bulkcurrent", readl (®s->ed_bulkcurrent)); - - maybe_print_eds ("donehead", readl (®s->donehead)); + dbg("spec %d.%d", (temp >> 4), (temp & 0x0f)); + + temp = readl(®s->control); + dbg("control: 0x%08x%s%s%s HCFS=%s%s%s%s%s CBSR=%d", temp, + (temp & OHCI_CTRL_RWE) ? " RWE" : "", + (temp & OHCI_CTRL_RWC) ? " RWC" : "", + (temp & OHCI_CTRL_IR) ? " IR" : "", + hcfs2string(temp & OHCI_CTRL_HCFS), + (temp & OHCI_CTRL_BLE) ? " BLE" : "", + (temp & OHCI_CTRL_CLE) ? " CLE" : "", + (temp & OHCI_CTRL_IE) ? " IE" : "", + (temp & OHCI_CTRL_PLE) ? " PLE" : "", temp & OHCI_CTRL_CBSR); + + temp = readl(®s->cmdstatus); + dbg("cmdstatus: 0x%08x SOC=%d%s%s%s%s", temp, + (temp & OHCI_SOC) >> 16, + (temp & OHCI_OCR) ? " OCR" : "", + (temp & OHCI_BLF) ? " BLF" : "", + (temp & OHCI_CLF) ? " CLF" : "", (temp & OHCI_HCR) ? " HCR" : ""); + + ohci_dump_intr_mask("intrstatus", readl(®s->intrstatus)); + ohci_dump_intr_mask("intrenable", readl(®s->intrenable)); + + maybe_print_eds("ed_periodcurrent", readl(®s->ed_periodcurrent)); + + maybe_print_eds("ed_controlhead", readl(®s->ed_controlhead)); + maybe_print_eds("ed_controlcurrent", readl(®s->ed_controlcurrent)); + + maybe_print_eds("ed_bulkhead", readl(®s->ed_bulkhead)); + maybe_print_eds("ed_bulkcurrent", readl(®s->ed_bulkcurrent)); + + maybe_print_eds("donehead", readl(®s->donehead)); }
-static void ohci_dump_roothub (ohci_t *controller, int verbose) +static void ohci_dump_roothub(ohci_t *controller, int verbose) { - __u32 temp, ndp, i; + __u32 temp, ndp, i;
- temp = roothub_a (controller); + temp = roothub_a(controller); ndp = (temp & RH_A_NDP);
if (verbose) { - dbg ("roothub.a: %08x POTPGT=%d%s%s%s%s%s NDP=%d", temp, - ((temp & RH_A_POTPGT) >> 24) & 0xff, - (temp & RH_A_NOCP) ? " NOCP" : "", - (temp & RH_A_OCPM) ? " OCPM" : "", - (temp & RH_A_DT) ? " DT" : "", - (temp & RH_A_NPS) ? " NPS" : "", - (temp & RH_A_PSM) ? " PSM" : "", - ndp - ); - temp = roothub_b (controller); - dbg ("roothub.b: %08x PPCM=%04x DR=%04x", - temp, - (temp & RH_B_PPCM) >> 16, - (temp & RH_B_DR) - ); - temp = roothub_status (controller); - dbg ("roothub.status: %08x%s%s%s%s%s%s", - temp, - (temp & RH_HS_CRWE) ? " CRWE" : "", - (temp & RH_HS_OCIC) ? " OCIC" : "", - (temp & RH_HS_LPSC) ? " LPSC" : "", - (temp & RH_HS_DRWE) ? " DRWE" : "", - (temp & RH_HS_OCI) ? " OCI" : "", - (temp & RH_HS_LPS) ? " LPS" : "" - ); + dbg("roothub.a: %08x POTPGT=%d%s%s%s%s%s NDP=%d", temp, + ((temp & RH_A_POTPGT) >> 24) & 0xff, + (temp & RH_A_NOCP) ? " NOCP" : "", + (temp & RH_A_OCPM) ? " OCPM" : "", + (temp & RH_A_DT) ? " DT" : "", + (temp & RH_A_NPS) ? " NPS" : "", + (temp & RH_A_PSM) ? " PSM" : "", ndp); + temp = roothub_b(controller); + dbg("roothub.b: %08x PPCM=%04x DR=%04x", + temp, (temp & RH_B_PPCM) >> 16, (temp & RH_B_DR) + ); + temp = roothub_status(controller); + dbg("roothub.status: %08x%s%s%s%s%s%s", + temp, + (temp & RH_HS_CRWE) ? " CRWE" : "", + (temp & RH_HS_OCIC) ? " OCIC" : "", + (temp & RH_HS_LPSC) ? " LPSC" : "", + (temp & RH_HS_DRWE) ? " DRWE" : "", + (temp & RH_HS_OCI) ? " OCI" : "", + (temp & RH_HS_LPS) ? " LPS" : ""); }
for (i = 0; i < ndp; i++) { - temp = roothub_portstatus (controller, i); - dbg ("roothub.portstatus [%d] = 0x%08x%s%s%s%s%s%s%s%s%s%s%s%s", - i, - temp, - (temp & RH_PS_PRSC) ? " PRSC" : "", - (temp & RH_PS_OCIC) ? " OCIC" : "", - (temp & RH_PS_PSSC) ? " PSSC" : "", - (temp & RH_PS_PESC) ? " PESC" : "", - (temp & RH_PS_CSC) ? " CSC" : "", - - (temp & RH_PS_LSDA) ? " LSDA" : "", - (temp & RH_PS_PPS) ? " PPS" : "", - (temp & RH_PS_PRS) ? " PRS" : "", - (temp & RH_PS_POCI) ? " POCI" : "", - (temp & RH_PS_PSS) ? " PSS" : "", - - (temp & RH_PS_PES) ? " PES" : "", - (temp & RH_PS_CCS) ? " CCS" : "" - ); + temp = roothub_portstatus(controller, i); + dbg("roothub.portstatus [%d] = 0x%08x%s%s%s%s%s%s%s%s%s%s%s%s", + i, + temp, + (temp & RH_PS_PRSC) ? " PRSC" : "", + (temp & RH_PS_OCIC) ? " OCIC" : "", + (temp & RH_PS_PSSC) ? " PSSC" : "", + (temp & RH_PS_PESC) ? " PESC" : "", + (temp & RH_PS_CSC) ? " CSC" : "", + (temp & RH_PS_LSDA) ? " LSDA" : "", + (temp & RH_PS_PPS) ? " PPS" : "", + (temp & RH_PS_PRS) ? " PRS" : "", + (temp & RH_PS_POCI) ? " POCI" : "", + (temp & RH_PS_PSS) ? " PSS" : "", + (temp & RH_PS_PES) ? " PES" : "", + (temp & RH_PS_CCS) ? " CCS" : ""); } }
-static void ohci_dump (ohci_t *controller, int verbose) +static void ohci_dump(ohci_t *controller, int verbose) { - dbg ("OHCI controller usb-%s state", controller->slot_name); + dbg("OHCI controller usb-%s state", controller->slot_name);
/* dumps some of the state we know about */ - ohci_dump_status (controller); + ohci_dump_status(controller); if (verbose) - ep_print_int_eds (controller, "hcca"); - dbg ("hcca frame #%04x", controller->hcca->frame_no); - ohci_dump_roothub (controller, 1); + ep_print_int_eds(controller, "hcca"); + dbg("hcca frame #%04x", controller->hcca->frame_no); + ohci_dump_roothub(controller, 1); }
- #endif /* DEBUG */
/*-------------------------------------------------------------------------* @@ -382,10 +381,10 @@ static void ohci_dump (ohci_t *controller, int verbose) /* get a transfer request */
int sohci_submit_job(struct usb_device *dev, unsigned long pipe, void *buffer, - int transfer_len, struct devrequest *setup, int interval) + int transfer_len, struct devrequest *setup, int interval) { ohci_t *ohci; - ed_t * ed; + ed_t *ed; urb_priv_t *purb_priv; int i, size = 0;
@@ -405,24 +404,27 @@ int sohci_submit_job(struct usb_device *dev, unsigned long pipe, void *buffer, err("sohci_submit_job: URB NOT FINISHED"); return -1; } - /* we're about to begin a new transaction here so mark the URB unfinished */ + /* we're about to begin a new transaction here + so mark the URB unfinished */ urb_finished = 0;
/* every endpoint has a ed, locate and fill it */ - if (!(ed = ep_add_ed (dev, pipe))) { + ed = ep_add_ed(dev, pipe); + if (!ed) { err("sohci_submit_job: ENOMEM"); return -1; }
/* for the private part of the URB we need the number of TDs (size) */ - switch (usb_pipetype (pipe)) { - case PIPE_BULK: /* one TD for every 4096 Byte */ - size = (transfer_len - 1) / 4096 + 1; - break; - case PIPE_CONTROL: /* 1 TD for setup, 1 for ACK and 1 for every 4096 B */ - size = (transfer_len == 0)? 2: - (transfer_len - 1) / 4096 + 3; - break; + switch (usb_pipetype(pipe)) { + case PIPE_BULK: + /* one TD for every 4096 Byte */ + size = (transfer_len - 1) / 4096 + 1; + break; + case PIPE_CONTROL: + /* 1 TD for setup, 1 for ACK and 1 for every 4096 B */ + size = (transfer_len == 0) ? 2 : (transfer_len - 1) / 4096 + 3; + break; }
if (size >= (N_URB_TD - 1)) { @@ -440,27 +442,28 @@ int sohci_submit_job(struct usb_device *dev, unsigned long pipe, void *buffer, /* allocate the TDs */ /* note that td[0] was allocated in ep_add_ed */ for (i = 0; i < size; i++) { - purb_priv->td[i] = td_alloc (dev); + purb_priv->td[i] = td_alloc(dev); if (!purb_priv->td[i]) { purb_priv->length = i; - urb_free_priv (purb_priv); + urb_free_priv(purb_priv); err("sohci_submit_job: ENOMEM"); return -1; } }
if (ed->state == ED_NEW || (ed->state & ED_DEL)) { - urb_free_priv (purb_priv); + urb_free_priv(purb_priv); err("sohci_submit_job: EINVAL"); return -1; }
/* link the ed into a chain if is not already */ if (ed->state != ED_OPER) - ep_link (ohci, ed); + ep_link(ohci, ed);
/* fill the TDs and link it to the ed */ - td_submit_job(dev, pipe, buffer, transfer_len, setup, purb_priv, interval); + td_submit_job(dev, pipe, buffer, transfer_len, setup, purb_priv, + interval);
return 0; } @@ -470,11 +473,11 @@ int sohci_submit_job(struct usb_device *dev, unsigned long pipe, void *buffer, #ifdef DEBUG /* tell us the current USB frame number */
-static int sohci_get_current_frame_number (struct usb_device *usb_dev) +static int sohci_get_current_frame_number(struct usb_device *usb_dev) { ohci_t *ohci = &gohci;
- return m16_swap (ohci->hcca->frame_no); + return m16_swap(ohci->hcca->frame_no); } #endif
@@ -484,7 +487,7 @@ static int sohci_get_current_frame_number (struct usb_device *usb_dev)
/* link an ed into one of the HC chains */
-static int ep_link (ohci_t *ohci, ed_t *edi) +static int ep_link(ohci_t *ohci, ed_t *edi) { volatile ed_t *ed = edi;
@@ -494,15 +497,15 @@ static int ep_link (ohci_t *ohci, ed_t *edi) case PIPE_CONTROL: ed->hwNextED = 0; if (ohci->ed_controltail == NULL) { - writel (ed, &ohci->regs->ed_controlhead); + writel((u32)ed, &ohci->regs->ed_controlhead); } else { - ohci->ed_controltail->hwNextED = (__u32)m32_swap (ed); + ohci->ed_controltail->hwNextED = (__u32) m32_swap(ed); } ed->ed_prev = ohci->ed_controltail; if (!ohci->ed_controltail && !ohci->ed_rm_list[0] && - !ohci->ed_rm_list[1] && !ohci->sleeping) { + !ohci->ed_rm_list[1] && !ohci->sleeping) { ohci->hc_control |= OHCI_CTRL_CLE; - writel (ohci->hc_control, &ohci->regs->control); + writel(ohci->hc_control, &ohci->regs->control); } ohci->ed_controltail = edi; break; @@ -510,15 +513,15 @@ static int ep_link (ohci_t *ohci, ed_t *edi) case PIPE_BULK: ed->hwNextED = 0; if (ohci->ed_bulktail == NULL) { - writel (ed, &ohci->regs->ed_bulkhead); + writel((u32)ed, &ohci->regs->ed_bulkhead); } else { - ohci->ed_bulktail->hwNextED = (__u32)m32_swap (ed); + ohci->ed_bulktail->hwNextED = (__u32) m32_swap(ed); } ed->ed_prev = ohci->ed_bulktail; if (!ohci->ed_bulktail && !ohci->ed_rm_list[0] && - !ohci->ed_rm_list[1] && !ohci->sleeping) { + !ohci->ed_rm_list[1] && !ohci->sleeping) { ohci->hc_control |= OHCI_CTRL_BLE; - writel (ohci->hc_control, &ohci->regs->control); + writel(ohci->hc_control, &ohci->regs->control); } ohci->ed_bulktail = edi; break; @@ -533,25 +536,27 @@ static int ep_link (ohci_t *ohci, ed_t *edi) * the link from the ed still points to another operational ed or 0 * so the HC can eventually finish the processing of the unlinked ed */
-static int ep_unlink (ohci_t *ohci, ed_t *ed) +static int ep_unlink(ohci_t *ohci, ed_t *ed) { - ed->hwINFO |= m32_swap (OHCI_ED_SKIP); + ed->hwINFO |= m32_swap(OHCI_ED_SKIP);
switch (ed->type) { case PIPE_CONTROL: if (ed->ed_prev == NULL) { if (!ed->hwNextED) { ohci->hc_control &= ~OHCI_CTRL_CLE; - writel (ohci->hc_control, &ohci->regs->control); + writel(ohci->hc_control, &ohci->regs->control); } - writel (m32_swap (*((__u32 *)&ed->hwNextED)), &ohci->regs->ed_controlhead); + writel(m32_swap(*((__u32 *) &ed->hwNextED)), + &ohci->regs->ed_controlhead); } else { ed->ed_prev->hwNextED = ed->hwNextED; } if (ohci->ed_controltail == ed) { ohci->ed_controltail = ed->ed_prev; } else { - ((ed_t *)m32_swap (*((__u32 *)&ed->hwNextED)))->ed_prev = ed->ed_prev; + ((ed_t *)m32_swap(*((__u32 *)&ed->hwNextED)))->ed_prev = + ed->ed_prev; } break;
@@ -559,16 +564,18 @@ static int ep_unlink (ohci_t *ohci, ed_t *ed) if (ed->ed_prev == NULL) { if (!ed->hwNextED) { ohci->hc_control &= ~OHCI_CTRL_BLE; - writel (ohci->hc_control, &ohci->regs->control); + writel(ohci->hc_control, &ohci->regs->control); } - writel (m32_swap (*((__u32 *)&ed->hwNextED)), &ohci->regs->ed_bulkhead); + writel(m32_swap(*((__u32 *) &ed->hwNextED)), + &ohci->regs->ed_bulkhead); } else { ed->ed_prev->hwNextED = ed->hwNextED; } if (ohci->ed_bulktail == ed) { ohci->ed_bulktail = ed->ed_prev; } else { - ((ed_t *)m32_swap (*((__u32 *)&ed->hwNextED)))->ed_prev = ed->ed_prev; + ((ed_t *)m32_swap(*((__u32 *)&ed->hwNextED)))->ed_prev = + ed->ed_prev; } break; } @@ -576,23 +583,24 @@ static int ep_unlink (ohci_t *ohci, ed_t *ed) return 0; }
-/* add/reinit an endpoint; this should be done once at the usb_set_configuration command, - * but the USB stack is a little bit stateless so we do it at every transaction - * if the state of the ed is ED_NEW then a dummy td is added and the state is changed to ED_UNLINK - * in all other cases the state is left unchanged - * the ed info fields are setted anyway even though most of them should not change */ +/* add/reinit an endpoint; this should be done once at the usb_set_configuration + * command, but the USB stack is a little bit stateless so we do it at every + * transaction. If the state of the ed is ED_NEW then a dummy td is added and + * the state is changed to ED_UNLINK. In all other cases the state is left + * unchanged. The ed info fields are setted anyway even though most of them + * should not change */
-static ed_t * ep_add_ed (struct usb_device *usb_dev, unsigned long pipe) +static ed_t *ep_add_ed(struct usb_device *usb_dev, unsigned long pipe) { td_t *td; ed_t *ed_ret; volatile ed_t *ed;
- ed = ed_ret = &ohci_dev.ed[(usb_pipeendpoint (pipe) << 1) | - (usb_pipecontrol (pipe)? 0: usb_pipeout (pipe))]; + ed = ed_ret = &ohci_dev.ed[(usb_pipeendpoint(pipe) << 1) | + (usb_pipecontrol(pipe) ? 0 : + usb_pipeout(pipe))];
if ((ed->state & ED_DEL) || (ed->state & ED_URB_DEL)) { err("ep_add_ed: pending delete"); @@ -601,22 +609,23 @@ static ed_t * ep_add_ed (struct usb_device *usb_dev, unsigned long pipe) }
if (ed->state == ED_NEW) { - ed->hwINFO = m32_swap (OHCI_ED_SKIP); /* skip ed */ + ed->hwINFO = m32_swap(OHCI_ED_SKIP); /* skip ed */ /* dummy td; end of td list for ed */ - td = td_alloc (usb_dev); - ed->hwTailP = (__u32)m32_swap (td); + td = td_alloc(usb_dev); + ed->hwTailP = (__u32) m32_swap(td); ed->hwHeadP = ed->hwTailP; ed->state = ED_UNLINK; - ed->type = usb_pipetype (pipe); + ed->type = usb_pipetype(pipe); ohci_dev.ed_cnt++; }
- ed->hwINFO = m32_swap (usb_pipedevice (pipe) - | usb_pipeendpoint (pipe) << 7 - | (usb_pipeisoc (pipe)? 0x8000: 0) - | (usb_pipecontrol (pipe)? 0: (usb_pipeout (pipe)? 0x800: 0x1000)) - | usb_pipeslow (pipe) << 13 - | usb_maxpacket (usb_dev, pipe) << 16); + ed->hwINFO = m32_swap(usb_pipedevice(pipe) + | usb_pipeendpoint(pipe) << 7 + | (usb_pipeisoc(pipe) ? 0x8000 : 0) + | (usb_pipecontrol(pipe) ? 0 : + (usb_pipeout(pipe) ? 0x800 : 0x1000)) + | usb_pipeslow(pipe) << 13 | + usb_maxpacket(usb_dev, pipe) << 16);
return ed_ret; } @@ -627,11 +636,10 @@ static ed_t * ep_add_ed (struct usb_device *usb_dev, unsigned long pipe)
/* enqueue next TD for this URB (OHCI spec 5.2.8.2) */
-static void td_fill (ohci_t *ohci, unsigned int info, - void *data, int len, - struct usb_device *dev, int index, urb_priv_t *urb_priv) +static void td_fill(ohci_t *ohci, unsigned int info, void *data, int len, + struct usb_device *dev, int index, urb_priv_t *urb_priv) { - volatile td_t *td, *td_pt; + volatile td_t *td, *td_pt; #ifdef OHCI_FILL_TRACE int i; #endif @@ -641,33 +649,35 @@ static void td_fill (ohci_t *ohci, unsigned int info, return; } /* use this td as the next dummy */ - td_pt = urb_priv->td [index]; + td_pt = urb_priv->td[index]; td_pt->hwNextTD = 0;
/* fill the old dummy TD */ - td = urb_priv->td [index] = (td_t *)(m32_swap (urb_priv->ed->hwTailP) & ~0xf); + td = urb_priv->td[index] = + (td_t *) (m32_swap(urb_priv->ed->hwTailP) & ~0xf);
td->ed = urb_priv->ed; td->next_dl_td = NULL; td->index = index; - td->data = (__u32)data; + td->data = (__u32) data; #ifdef OHCI_FILL_TRACE if (usb_pipebulk(urb_priv->pipe) && usb_pipeout(urb_priv->pipe)) { for (i = 0; i < len; i++) - printf("td->data[%d] %#2x ",i, ((unsigned char *)td->data)[i]); + printf("td->data[%d] %#2x ", i, + ((unsigned char *)td->data)[i]); printf("\n"); } #endif if (!len) data = 0;
- td->hwINFO = (__u32)m32_swap (info); - td->hwCBP = (__u32)m32_swap (data); + td->hwINFO = (__u32) m32_swap(info); + td->hwCBP = (__u32) m32_swap(data); if (data) - td->hwBE = (__u32)m32_swap (data + len - 1); + td->hwBE = (__u32) m32_swap(data + len - 1); else td->hwBE = 0; - td->hwNextTD = (__u32)m32_swap (td_pt); + td->hwNextTD = (__u32) m32_swap(td_pt);
/* append to queue */ td->ed->hwTailP = td->hwNextTD; @@ -677,8 +687,10 @@ static void td_fill (ohci_t *ohci, unsigned int info,
/* prepare all TDs of a transfer */
-static void td_submit_job (struct usb_device *dev, unsigned long pipe, void *buffer, - int transfer_len, struct devrequest *setup, urb_priv_t *urb, int interval) +static void td_submit_job(struct usb_device *dev, unsigned long pipe, + void *buffer, int transfer_len, + struct devrequest *setup, urb_priv_t *urb, + int interval) { ohci_t *ohci = &gohci; int data_len = transfer_len; @@ -687,12 +699,14 @@ static void td_submit_job (struct usb_device *dev, unsigned long pipe, void *buf __u32 info = 0; unsigned int toggle = 0;
- /* OHCI handles the DATA-toggles itself, we just use the USB-toggle bits for reseting */ - if(usb_gettoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe))) { + /* OHCI handles the DATA-toggles itself, we just + use the USB-toggle bits for reseting */ + if (usb_gettoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe))) { toggle = TD_T_TOGGLE; } else { toggle = TD_T_DATA0; - usb_settoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe), 1); + usb_settoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe), + 1); } urb->td_cnt = 0; if (data_len) @@ -700,37 +714,45 @@ static void td_submit_job (struct usb_device *dev, unsigned long pipe, void *buf else data = 0;
- switch (usb_pipetype (pipe)) { + switch (usb_pipetype(pipe)) { case PIPE_BULK: - info = usb_pipeout (pipe)? - TD_CC | TD_DP_OUT : TD_CC | TD_DP_IN ; - while(data_len > 4096) { - td_fill (ohci, info | (cnt? TD_T_TOGGLE:toggle), data, 4096, dev, cnt, urb); - data += 4096; data_len -= 4096; cnt++; + info = usb_pipeout(pipe) ? TD_CC | TD_DP_OUT : TD_CC | TD_DP_IN; + while (data_len > 4096) { + td_fill(ohci, info | (cnt ? TD_T_TOGGLE : toggle), data, + 4096, dev, cnt, urb); + data += 4096; + data_len -= 4096; + cnt++; } - info = usb_pipeout (pipe)? - TD_CC | TD_DP_OUT : TD_CC | TD_R | TD_DP_IN ; - td_fill (ohci, info | (cnt? TD_T_TOGGLE:toggle), data, data_len, dev, cnt, urb); + info = usb_pipeout(pipe) ? + TD_CC | TD_DP_OUT : + TD_CC | TD_R | TD_DP_IN; + td_fill(ohci, info | (cnt ? TD_T_TOGGLE : toggle), data, + data_len, dev, cnt, urb); cnt++;
if (!ohci->sleeping) - writel (OHCI_BLF, &ohci->regs->cmdstatus); /* start bulk list */ + /* start bulk list */ + writel(OHCI_BLF, &ohci->regs->cmdstatus); break;
case PIPE_CONTROL: info = TD_CC | TD_DP_SETUP | TD_T_DATA0; - td_fill (ohci, info, setup, 8, dev, cnt++, urb); + td_fill(ohci, info, setup, 8, dev, cnt++, urb); if (data_len > 0) { - info = usb_pipeout (pipe)? - TD_CC | TD_R | TD_DP_OUT | TD_T_DATA1 : TD_CC | TD_R | TD_DP_IN | TD_T_DATA1; + info = usb_pipeout(pipe) ? + TD_CC | TD_R | TD_DP_OUT | TD_T_DATA1 : + TD_CC | TD_R | TD_DP_IN | TD_T_DATA1; /* NOTE: mishandles transfers >8K, some >4K */ - td_fill (ohci, info, data, data_len, dev, cnt++, urb); + td_fill(ohci, info, data, data_len, dev, cnt++, urb); } - info = usb_pipeout (pipe)? - TD_CC | TD_DP_IN | TD_T_DATA1: TD_CC | TD_DP_OUT | TD_T_DATA1; - td_fill (ohci, info, data, 0, dev, cnt++, urb); + info = usb_pipeout(pipe) ? + TD_CC | TD_DP_IN | TD_T_DATA1 : + TD_CC | TD_DP_OUT | TD_T_DATA1; + td_fill(ohci, info, data, 0, dev, cnt++, urb); if (!ohci->sleeping) - writel (OHCI_CLF, &ohci->regs->cmdstatus); /* start Control list */ + /* start Control list */ + writel(OHCI_CLF, &ohci->regs->cmdstatus); break; } if (urb->length != cnt) @@ -749,13 +771,12 @@ static void dl_transfer_length(td_t * td) __u32 tdINFO, tdBE, tdCBP; urb_priv_t *lurb_priv = &urb_priv;
- tdINFO = m32_swap (td->hwINFO); - tdBE = m32_swap (td->hwBE); - tdCBP = m32_swap (td->hwCBP); - + tdINFO = m32_swap(td->hwINFO); + tdBE = m32_swap(td->hwBE); + tdCBP = m32_swap(td->hwCBP);
if (!(usb_pipecontrol(lurb_priv->pipe) && - ((td->index == 0) || (td->index == lurb_priv->length - 1)))) { + ((td->index == 0) || (td->index == lurb_priv->length - 1)))) { if (tdBE != 0) { if (td->hwCBP == 0) lurb_priv->actual_length += tdBE - td->data + 1; @@ -770,37 +791,39 @@ static void dl_transfer_length(td_t * td) /* replies to the request have to be on a FIFO basis so * we reverse the reversed done-list */
-static td_t * dl_reverse_done_list (ohci_t *ohci) +static td_t *dl_reverse_done_list(ohci_t *ohci) { __u32 td_list_hc; td_t *td_rev = NULL; td_t *td_list = NULL; urb_priv_t *lurb_priv = NULL;
- td_list_hc = m32_swap (ohci->hcca->done_head) & 0xfffffff0; + td_list_hc = m32_swap(ohci->hcca->done_head) & 0xfffffff0; ohci->hcca->done_head = 0;
while (td_list_hc) { - td_list = (td_t *)td_list_hc; + td_list = (td_t *) td_list_hc;
- if (TD_CC_GET (m32_swap (td_list->hwINFO))) { + if (TD_CC_GET(m32_swap(td_list->hwINFO))) { lurb_priv = &urb_priv; dbg(" USB-error/status: %x : %p", - TD_CC_GET (m32_swap (td_list->hwINFO)), td_list); - if (td_list->ed->hwHeadP & m32_swap (0x1)) { + TD_CC_GET(m32_swap(td_list->hwINFO)), td_list); + if (td_list->ed->hwHeadP & m32_swap(0x1)) { if (lurb_priv && ((td_list->index + 1) < lurb_priv->length)) { td_list->ed->hwHeadP = - (lurb_priv->td[lurb_priv->length - 1]->hwNextTD & m32_swap (0xfffffff0)) | - (td_list->ed->hwHeadP & m32_swap (0x2)); + (lurb_priv->td[lurb_priv->length-1]->hwNextTD & + m32_swap(0xfffffff0)) | + (td_list->ed->hwHeadP & m32_swap(0x2)); lurb_priv->td_cnt += lurb_priv->length - td_list->index - 1; } else - td_list->ed->hwHeadP &= m32_swap (0xfffffff2); + td_list->ed->hwHeadP &= + m32_swap(0xfffffff2); } }
td_list->next_dl_td = td_rev; td_rev = td_list; - td_list_hc = m32_swap (td_list->hwNextTD) & 0xfffffff0; + td_list_hc = m32_swap(td_list->hwNextTD) & 0xfffffff0; }
return td_list; @@ -809,7 +832,7 @@ static td_t * dl_reverse_done_list (ohci_t *ohci) /*-------------------------------------------------------------------------*/
/* td done list */ -static int dl_done_list (ohci_t *ohci, td_t *td_list) +static int dl_done_list(ohci_t *ohci, td_t *td_list) { td_t *td_list_next = NULL; ed_t *ed; @@ -823,14 +846,14 @@ static int dl_done_list (ohci_t *ohci, td_t *td_list) td_list_next = td_list->next_dl_td;
lurb_priv = &urb_priv; - tdINFO = m32_swap (td_list->hwINFO); + tdINFO = m32_swap(td_list->hwINFO);
ed = td_list->ed;
dl_transfer_length(td_list);
/* error code of transfer */ - cc = TD_CC_GET (tdINFO); + cc = TD_CC_GET(tdINFO); if (cc != 0) { dbg("ConditionCode %#x", cc); stat = cc_to_error[cc]; @@ -842,18 +865,19 @@ static int dl_done_list (ohci_t *ohci, td_t *td_list) if ((ed->state & (ED_OPER | ED_UNLINK))) urb_finished = 1; else - dbg("dl_done_list: strange.., ED state %x, ed->state\n"); + dbg("dl_done_list: strange.., ED state %x, " + "ed->state\n"); } else - dbg("dl_done_list: processing TD %x, len %x\n", lurb_priv->td_cnt, - lurb_priv->length); + dbg("dl_done_list: processing TD %x, len %x\n", + lurb_priv->td_cnt, lurb_priv->length);
if (ed->state != ED_NEW) { - edHeadP = m32_swap (ed->hwHeadP) & 0xfffffff0; - edTailP = m32_swap (ed->hwTailP); + edHeadP = m32_swap(ed->hwHeadP) & 0xfffffff0; + edTailP = m32_swap(ed->hwTailP);
/* unlink eds if they are not busy */ if ((edHeadP == edTailP) && (ed->state == ED_OPER)) - ep_unlink (ohci, ed); + ep_unlink(ohci, ed); }
td_list = td_list_next; @@ -866,102 +890,98 @@ static int dl_done_list (ohci_t *ohci, td_t *td_list) *-------------------------------------------------------------------------*/
/* Device descriptor */ -static __u8 root_hub_dev_des[] = -{ - 0x12, /* __u8 bLength; */ - 0x01, /* __u8 bDescriptorType; Device */ - 0x10, /* __u16 bcdUSB; v1.1 */ +static __u8 root_hub_dev_des[] = { + 0x12, /* __u8 bLength; */ + 0x01, /* __u8 bDescriptorType; Device */ + 0x10, /* __u16 bcdUSB; v1.1 */ 0x01, - 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ - 0x00, /* __u8 bDeviceSubClass; */ - 0x00, /* __u8 bDeviceProtocol; */ - 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ - 0x00, /* __u16 idVendor; */ + 0x09, /* __u8 bDeviceClass; HUB_CLASSCODE */ + 0x00, /* __u8 bDeviceSubClass; */ + 0x00, /* __u8 bDeviceProtocol; */ + 0x08, /* __u8 bMaxPacketSize0; 8 Bytes */ + 0x00, /* __u16 idVendor; */ 0x00, - 0x00, /* __u16 idProduct; */ + 0x00, /* __u16 idProduct; */ 0x00, - 0x00, /* __u16 bcdDevice; */ + 0x00, /* __u16 bcdDevice; */ 0x00, - 0x00, /* __u8 iManufacturer; */ - 0x01, /* __u8 iProduct; */ - 0x00, /* __u8 iSerialNumber; */ - 0x01 /* __u8 bNumConfigurations; */ + 0x00, /* __u8 iManufacturer; */ + 0x01, /* __u8 iProduct; */ + 0x00, /* __u8 iSerialNumber; */ + 0x01 /* __u8 bNumConfigurations; */ };
- /* Configuration descriptor */ -static __u8 root_hub_config_des[] = -{ - 0x09, /* __u8 bLength; */ - 0x02, /* __u8 bDescriptorType; Configuration */ - 0x19, /* __u16 wTotalLength; */ +static __u8 root_hub_config_des[] = { + 0x09, /* __u8 bLength; */ + 0x02, /* __u8 bDescriptorType; Configuration */ + 0x19, /* __u16 wTotalLength; */ 0x00, - 0x01, /* __u8 bNumInterfaces; */ - 0x01, /* __u8 bConfigurationValue; */ - 0x00, /* __u8 iConfiguration; */ - 0x40, /* __u8 bmAttributes; - Bit 7: Bus-powered, 6: Self-powered, 5 Remote-wakwup, 4..0: resvd */ - 0x00, /* __u8 MaxPower; */ + 0x01, /* __u8 bNumInterfaces; */ + 0x01, /* __u8 bConfigurationValue; */ + 0x00, /* __u8 iConfiguration; */ + 0x40, /* __u8 bmAttributes; + Bit 7: Bus-powered, 6: Self-powered, + 5 Remote-wakwup, 4..0: resvd */ + 0x00, /* __u8 MaxPower; */
/* interface */ - 0x09, /* __u8 if_bLength; */ - 0x04, /* __u8 if_bDescriptorType; Interface */ - 0x00, /* __u8 if_bInterfaceNumber; */ - 0x00, /* __u8 if_bAlternateSetting; */ - 0x01, /* __u8 if_bNumEndpoints; */ - 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ - 0x00, /* __u8 if_bInterfaceSubClass; */ - 0x00, /* __u8 if_bInterfaceProtocol; */ - 0x00, /* __u8 if_iInterface; */ + 0x09, /* __u8 if_bLength; */ + 0x04, /* __u8 if_bDescriptorType; Interface */ + 0x00, /* __u8 if_bInterfaceNumber; */ + 0x00, /* __u8 if_bAlternateSetting; */ + 0x01, /* __u8 if_bNumEndpoints; */ + 0x09, /* __u8 if_bInterfaceClass; HUB_CLASSCODE */ + 0x00, /* __u8 if_bInterfaceSubClass; */ + 0x00, /* __u8 if_bInterfaceProtocol; */ + 0x00, /* __u8 if_iInterface; */
/* endpoint */ - 0x07, /* __u8 ep_bLength; */ - 0x05, /* __u8 ep_bDescriptorType; Endpoint */ - 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ - 0x03, /* __u8 ep_bmAttributes; Interrupt */ - 0x02, /* __u16 ep_wMaxPacketSize; ((MAX_ROOT_PORTS + 1) / 8 */ + 0x07, /* __u8 ep_bLength; */ + 0x05, /* __u8 ep_bDescriptorType; Endpoint */ + 0x81, /* __u8 ep_bEndpointAddress; IN Endpoint 1 */ + 0x03, /* __u8 ep_bmAttributes; Interrupt */ + 0x02, /* __u16 ep_wMaxPacketSize; ((MAX_ROOT_PORTS + 1) / 8 */ 0x00, - 0xff /* __u8 ep_bInterval; 255 ms */ + 0xff /* __u8 ep_bInterval; 255 ms */ };
-static unsigned char root_hub_str_index0[] = -{ - 0x04, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 0x09, /* __u8 lang ID */ - 0x04, /* __u8 lang ID */ +static unsigned char root_hub_str_index0[] = { + 0x04, /* __u8 bLength; */ + 0x03, /* __u8 bDescriptorType; String-descriptor */ + 0x09, /* __u8 lang ID */ + 0x04, /* __u8 lang ID */ };
-static unsigned char root_hub_str_index1[] = -{ - 28, /* __u8 bLength; */ - 0x03, /* __u8 bDescriptorType; String-descriptor */ - 'O', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'C', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'I', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'R', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'o', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 't', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - ' ', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'H', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'u', /* __u8 Unicode */ - 0, /* __u8 Unicode */ - 'b', /* __u8 Unicode */ - 0, /* __u8 Unicode */ +static unsigned char root_hub_str_index1[] = { + 28, /* __u8 bLength; */ + 0x03, /* __u8 bDescriptorType; String-descriptor */ + 'O', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'H', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'C', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'I', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + ' ', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'R', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'o', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'o', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 't', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + ' ', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'H', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'u', /* __u8 Unicode */ + 0, /* __u8 Unicode */ + 'b', /* __u8 Unicode */ + 0, /* __u8 Unicode */ };
/* Hub class-specific descriptor is constructed dynamically */ @@ -971,14 +991,24 @@ static unsigned char root_hub_str_index1[] =
#define OK(x) len = (x); break #ifdef DEBUG -#define WR_RH_STAT(x) {info("WR:status %#8x", (x));writel((x), &gohci.regs->roothub.status);} -#define WR_RH_PORTSTAT(x) {info("WR:portstatus[%d] %#8x", wIndex-1, (x));writel((x), &gohci.regs->roothub.portstatus[wIndex-1]);} +#define WR_RH_STAT(x) \ +{ \ + info("WR:status %#8x", (x)); \ + writel((x), &gohci.regs->roothub.status); \ +} +#define WR_RH_PORTSTAT(x) \ +{ \ + info("WR:portstatus[%d] %#8x", wIndex-1, (x)); \ + writel((x), &gohci.regs->roothub.portstatus[wIndex-1]); \ +} #else -#define WR_RH_STAT(x) writel((x), &gohci.regs->roothub.status) -#define WR_RH_PORTSTAT(x) writel((x), &gohci.regs->roothub.portstatus[wIndex-1]) +#define WR_RH_STAT(x) \ + writel((x), &gohci.regs->roothub.status) +#define WR_RH_PORTSTAT(x)\ + writel((x), &gohci.regs->roothub.portstatus[wIndex-1]) #endif -#define RD_RH_STAT roothub_status(&gohci) -#define RD_RH_PORTSTAT roothub_portstatus(&gohci,wIndex-1) +#define RD_RH_STAT roothub_status(&gohci) +#define RD_RH_PORTSTAT roothub_portstatus(&gohci, wIndex-1)
/* request to virtual root hub */
@@ -988,14 +1018,13 @@ int rh_check_port_status(ohci_t *controller) int res;
res = -1; - temp = roothub_a (controller); + temp = roothub_a(controller); ndp = (temp & RH_A_NDP); for (i = 0; i < ndp; i++) { - temp = roothub_portstatus (controller, i); + temp = roothub_portstatus(controller, i); /* check for a device disconnect */ if (((temp & (RH_PS_PESC | RH_PS_CSC)) == - (RH_PS_PESC | RH_PS_CSC)) && - ((temp & RH_PS_CCS) == 0)) { + (RH_PS_PESC | RH_PS_CSC)) && ((temp & RH_PS_CCS) == 0)) { res = i; break; } @@ -1004,22 +1033,24 @@ int rh_check_port_status(ohci_t *controller) }
static int ohci_submit_rh_msg(struct usb_device *dev, unsigned long pipe, - void *buffer, int transfer_len, struct devrequest *cmd) + void *buffer, int transfer_len, + struct devrequest *cmd) { - void * data = buffer; + void *data = buffer; int leni = transfer_len; int len = 0; int stat = 0; __u32 datab[4]; - __u8 *data_buf = (__u8 *)datab; + __u8 *data_buf = (__u8 *) datab; __u16 bmRType_bReq; __u16 wValue; __u16 wIndex; __u16 wLength;
#ifdef DEBUG -urb_priv.actual_length = 0; -pkt_print(dev, pipe, buffer, transfer_len, cmd, "SUB(rh)", usb_pipein(pipe)); + urb_priv.actual_length = 0; + pkt_print(dev, pipe, buffer, transfer_len, cmd, "SUB(rh)", + usb_pipein(pipe)); #else wait_ms(1); #endif @@ -1028,189 +1059,216 @@ pkt_print(dev, pipe, buffer, transfer_len, cmd, "SUB(rh)", usb_pipein(pipe)); return 0; }
- bmRType_bReq = cmd->requesttype | (cmd->request << 8); - wValue = m16_swap (cmd->value); - wIndex = m16_swap (cmd->index); - wLength = m16_swap (cmd->length); + bmRType_bReq = cmd->requesttype | (cmd->request << 8); + wValue = m16_swap(cmd->value); + wIndex = m16_swap(cmd->index); + wLength = m16_swap(cmd->length);
info("Root-Hub: adr: %2x cmd(%1x): %08x %04x %04x %04x", - dev->devnum, 8, bmRType_bReq, wValue, wIndex, wLength); + dev->devnum, 8, bmRType_bReq, wValue, wIndex, wLength);
switch (bmRType_bReq) { - /* Request Destination: - without flags: Device, - RH_INTERFACE: interface, - RH_ENDPOINT: endpoint, - RH_CLASS means HUB here, - RH_OTHER | RH_CLASS almost ever means HUB_PORT here - */ + /* Request Destination: + without flags: Device, + RH_INTERFACE: interface, + RH_ENDPOINT: endpoint, + RH_CLASS means HUB here, + RH_OTHER | RH_CLASS almost ever means HUB_PORT here + */
case RH_GET_STATUS: - *(__u16 *) data_buf = m16_swap (1); OK (2); + *(__u16 *) data_buf = m16_swap(1); + OK(2); case RH_GET_STATUS | RH_INTERFACE: - *(__u16 *) data_buf = m16_swap (0); OK (2); + *(__u16 *) data_buf = m16_swap(0); + OK(2); case RH_GET_STATUS | RH_ENDPOINT: - *(__u16 *) data_buf = m16_swap (0); OK (2); + *(__u16 *) data_buf = m16_swap(0); + OK(2); case RH_GET_STATUS | RH_CLASS: - *(__u32 *) data_buf = m32_swap ( - RD_RH_STAT & ~(RH_HS_CRWE | RH_HS_DRWE)); - OK (4); + *(__u32 *) data_buf = + m32_swap(RD_RH_STAT & ~(RH_HS_CRWE | RH_HS_DRWE)); + OK(4); case RH_GET_STATUS | RH_OTHER | RH_CLASS: - *(__u32 *) data_buf = m32_swap (RD_RH_PORTSTAT); OK (4); + *(__u32 *) data_buf = m32_swap(RD_RH_PORTSTAT); + OK(4);
case RH_CLEAR_FEATURE | RH_ENDPOINT: switch (wValue) { - case (RH_ENDPOINT_STALL): OK (0); + case (RH_ENDPOINT_STALL): + OK(0); } break;
case RH_CLEAR_FEATURE | RH_CLASS: switch (wValue) { - case RH_C_HUB_LOCAL_POWER: - OK(0); - case (RH_C_HUB_OVER_CURRENT): - WR_RH_STAT(RH_HS_OCIC); OK (0); + case RH_C_HUB_LOCAL_POWER: + OK(0); + case (RH_C_HUB_OVER_CURRENT): + WR_RH_STAT(RH_HS_OCIC); + OK(0); } break;
case RH_CLEAR_FEATURE | RH_OTHER | RH_CLASS: switch (wValue) { - case (RH_PORT_ENABLE): - WR_RH_PORTSTAT (RH_PS_CCS ); OK (0); - case (RH_PORT_SUSPEND): - WR_RH_PORTSTAT (RH_PS_POCI); OK (0); - case (RH_PORT_POWER): - WR_RH_PORTSTAT (RH_PS_LSDA); OK (0); - case (RH_C_PORT_CONNECTION): - WR_RH_PORTSTAT (RH_PS_CSC ); OK (0); - case (RH_C_PORT_ENABLE): - WR_RH_PORTSTAT (RH_PS_PESC); OK (0); - case (RH_C_PORT_SUSPEND): - WR_RH_PORTSTAT (RH_PS_PSSC); OK (0); - case (RH_C_PORT_OVER_CURRENT): - WR_RH_PORTSTAT (RH_PS_OCIC); OK (0); - case (RH_C_PORT_RESET): - WR_RH_PORTSTAT (RH_PS_PRSC); OK (0); + case (RH_PORT_ENABLE): + WR_RH_PORTSTAT(RH_PS_CCS); + OK(0); + case (RH_PORT_SUSPEND): + WR_RH_PORTSTAT(RH_PS_POCI); + OK(0); + case (RH_PORT_POWER): + WR_RH_PORTSTAT(RH_PS_LSDA); + OK(0); + case (RH_C_PORT_CONNECTION): + WR_RH_PORTSTAT(RH_PS_CSC); + OK(0); + case (RH_C_PORT_ENABLE): + WR_RH_PORTSTAT(RH_PS_PESC); + OK(0); + case (RH_C_PORT_SUSPEND): + WR_RH_PORTSTAT(RH_PS_PSSC); + OK(0); + case (RH_C_PORT_OVER_CURRENT): + WR_RH_PORTSTAT(RH_PS_OCIC); + OK(0); + case (RH_C_PORT_RESET): + WR_RH_PORTSTAT(RH_PS_PRSC); + OK(0); } break;
case RH_SET_FEATURE | RH_OTHER | RH_CLASS: switch (wValue) { - case (RH_PORT_SUSPEND): - WR_RH_PORTSTAT (RH_PS_PSS ); OK (0); - case (RH_PORT_RESET): /* BUG IN HUP CODE *********/ - if (RD_RH_PORTSTAT & RH_PS_CCS) - WR_RH_PORTSTAT (RH_PS_PRS); - OK (0); - case (RH_PORT_POWER): - WR_RH_PORTSTAT (RH_PS_PPS ); OK (0); - case (RH_PORT_ENABLE): /* BUG IN HUP CODE *********/ - if (RD_RH_PORTSTAT & RH_PS_CCS) - WR_RH_PORTSTAT (RH_PS_PES ); - OK (0); + case (RH_PORT_SUSPEND): + WR_RH_PORTSTAT(RH_PS_PSS); + OK(0); + case (RH_PORT_RESET): /* BUG IN HUP CODE ******** */ + if (RD_RH_PORTSTAT & RH_PS_CCS) + WR_RH_PORTSTAT(RH_PS_PRS); + OK(0); + case (RH_PORT_POWER): + WR_RH_PORTSTAT(RH_PS_PPS); + OK(0); + case (RH_PORT_ENABLE): /* BUG IN HUP CODE ******** */ + if (RD_RH_PORTSTAT & RH_PS_CCS) + WR_RH_PORTSTAT(RH_PS_PES); + OK(0); } break;
- case RH_SET_ADDRESS: gohci.rh.devnum = wValue; OK(0); + case RH_SET_ADDRESS: + gohci.rh.devnum = wValue; + OK(0);
case RH_GET_DESCRIPTOR: switch ((wValue & 0xff00) >> 8) { - case (0x01): /* device descriptor */ + case (0x01): /* device descriptor */ + len = min_t(unsigned int, + leni, + min_t(unsigned int, + sizeof(root_hub_dev_des), wLength)); + data_buf = root_hub_dev_des; + OK(len); + case (0x02): /* configuration descriptor */ + len = min_t(unsigned int, + leni, + min_t(unsigned int, + sizeof(root_hub_config_des), + wLength)); + data_buf = root_hub_config_des; + OK(len); + case (0x03): /* string descriptors */ + if (wValue == 0x0300) { len = min_t(unsigned int, - leni, - min_t(unsigned int, - sizeof (root_hub_dev_des), - wLength)); - data_buf = root_hub_dev_des; OK(len); - case (0x02): /* configuration descriptor */ + leni, + min_t(unsigned int, + sizeof(root_hub_str_index0), + wLength)); + data_buf = root_hub_str_index0; + OK(len); + } + if (wValue == 0x0301) { len = min_t(unsigned int, - leni, - min_t(unsigned int, - sizeof (root_hub_config_des), - wLength)); - data_buf = root_hub_config_des; OK(len); - case (0x03): /* string descriptors */ - if(wValue==0x0300) { - len = min_t(unsigned int, - leni, - min_t(unsigned int, - sizeof (root_hub_str_index0), - wLength)); - data_buf = root_hub_str_index0; - OK(len); - } - if(wValue==0x0301) { - len = min_t(unsigned int, - leni, - min_t(unsigned int, - sizeof (root_hub_str_index1), - wLength)); - data_buf = root_hub_str_index1; - OK(len); + leni, + min_t(unsigned int, + sizeof(root_hub_str_index1), + wLength)); + data_buf = root_hub_str_index1; + OK(len); } - default: - stat = USB_ST_STALLED; + default: + stat = USB_ST_STALLED; } break;
case RH_GET_DESCRIPTOR | RH_CLASS: - { - __u32 temp = roothub_a (&gohci); - - data_buf [0] = 9; /* min length; */ - data_buf [1] = 0x29; - data_buf [2] = temp & RH_A_NDP; - data_buf [3] = 0; - if (temp & RH_A_PSM) /* per-port power switching? */ - data_buf [3] |= 0x1; - if (temp & RH_A_NOCP) /* no overcurrent reporting? */ - data_buf [3] |= 0x10; - else if (temp & RH_A_OCPM) /* per-port overcurrent reporting? */ - data_buf [3] |= 0x8; - - /* corresponds to data_buf[4-7] */ - datab [1] = 0; - data_buf [5] = (temp & RH_A_POTPGT) >> 24; - temp = roothub_b (&gohci); - data_buf [7] = temp & RH_B_DR; - if (data_buf [2] < 7) { - data_buf [8] = 0xff; - } else { - data_buf [0] += 2; - data_buf [8] = (temp & RH_B_DR) >> 8; - data_buf [10] = data_buf [9] = 0xff; - } - - len = min_t(unsigned int, leni, - min_t(unsigned int, data_buf [0], wLength)); - OK (len); + { + __u32 temp = roothub_a(&gohci); + + data_buf[0] = 9; /* min length; */ + data_buf[1] = 0x29; + data_buf[2] = temp & RH_A_NDP; + data_buf[3] = 0; + if (temp & RH_A_PSM) + /* per-port power switching? */ + data_buf[3] |= 0x1; + if (temp & RH_A_NOCP) + /* no overcurrent reporting? */ + data_buf[3] |= 0x10; + else if (temp & RH_A_OCPM) + /* per-port overcurrent reporting? */ + data_buf[3] |= 0x8; + + /* corresponds to data_buf[4-7] */ + datab[1] = 0; + data_buf[5] = (temp & RH_A_POTPGT) >> 24; + temp = roothub_b(&gohci); + data_buf[7] = temp & RH_B_DR; + if (data_buf[2] < 7) { + data_buf[8] = 0xff; + } else { + data_buf[0] += 2; + data_buf[8] = (temp & RH_B_DR) >> 8; + data_buf[10] = data_buf[9] = 0xff; + } + + len = min_t(unsigned int, leni, + min_t(unsigned int, data_buf[0], wLength)); + OK(len); }
- case RH_GET_CONFIGURATION: *(__u8 *) data_buf = 0x01; OK (1); + case RH_GET_CONFIGURATION: + *(__u8 *) data_buf = 0x01; + OK(1);
- case RH_SET_CONFIGURATION: WR_RH_STAT (0x10000); OK (0); + case RH_SET_CONFIGURATION: + WR_RH_STAT(0x10000); + OK(0);
default: - dbg ("unsupported root hub command"); + dbg("unsupported root hub command"); stat = USB_ST_STALLED; }
#ifdef DEBUG - ohci_dump_roothub (&gohci, 1); + ohci_dump_roothub(&gohci, 1); #else wait_ms(1); #endif
len = min_t(int, len, leni); if (data != data_buf) - memcpy (data, data_buf, len); + memcpy(data, data_buf, len); dev->act_len = len; dev->status = stat;
#ifdef DEBUG if (transfer_len) urb_priv.actual_length = transfer_len; - pkt_print(dev, pipe, buffer, transfer_len, cmd, "RET(rh)", 0/*usb_pipein(pipe)*/); + pkt_print(dev, pipe, buffer, transfer_len, cmd, "RET(rh)", + 0 /*usb_pipein(pipe) */); #else wait_ms(1); #endif @@ -1223,7 +1281,7 @@ pkt_print(dev, pipe, buffer, transfer_len, cmd, "SUB(rh)", usb_pipein(pipe)); /* common code for handling submit messages - used for all but root hub */ /* accesses. */ int submit_common_msg(struct usb_device *dev, unsigned long pipe, void *buffer, - int transfer_len, struct devrequest *setup, int interval) + int transfer_len, struct devrequest *setup, int interval) { int stat = 0; int maxsize = usb_maxpacket(dev, pipe); @@ -1234,20 +1292,21 @@ int submit_common_msg(struct usb_device *dev, unsigned long pipe, void *buffer, dev->status = USB_ST_CRC_ERR; return 0; } - #ifdef DEBUG urb_priv.actual_length = 0; - pkt_print(dev, pipe, buffer, transfer_len, setup, "SUB", usb_pipein(pipe)); + pkt_print(dev, pipe, buffer, transfer_len, setup, "SUB", + usb_pipein(pipe)); #else wait_ms(1); #endif if (!maxsize) { err("submit_common_message: pipesize for pipe %lx is zero", - pipe); + pipe); return -1; }
- if (sohci_submit_job(dev, pipe, buffer, transfer_len, setup, interval) < 0) { + if (sohci_submit_job(dev, pipe, buffer, transfer_len, setup, interval) < + 0) { err("sohci_submit_job failed"); return -1; } @@ -1256,7 +1315,7 @@ int submit_common_msg(struct usb_device *dev, unsigned long pipe, void *buffer, /* ohci_dump_status(&gohci); */
/* allow more time for a BULK device to react - some are slow */ -#define BULK_TO 5000 /* timeout in milliseconds */ +#define BULK_TO 5000 /* timeout in milliseconds */ if (usb_pipebulk(pipe)) timeout = BULK_TO; else @@ -1304,13 +1363,14 @@ int submit_common_msg(struct usb_device *dev, unsigned long pipe, void *buffer, /* we got an Root Hub Status Change interrupt */ if (got_rhsc) { #ifdef DEBUG - ohci_dump_roothub (&gohci, 1); + ohci_dump_roothub(&gohci, 1); #endif got_rhsc = 0; /* abuse timeout */ timeout = rh_check_port_status(&gohci); if (timeout >= 0) { -#if 0 /* this does nothing useful, but leave it here in case that changes */ +#if 0 /* this does nothing useful, but leave it here + in case that changes */ /* the called routine adds 1 to the passed value */ usb_hub_port_connect_change(gohci.rh.dev, timeout - 1); #endif @@ -1328,53 +1388,55 @@ int submit_common_msg(struct usb_device *dev, unsigned long pipe, void *buffer, dev->act_len = transfer_len;
#ifdef DEBUG - pkt_print(dev, pipe, buffer, transfer_len, setup, "RET(ctlr)", usb_pipein(pipe)); + pkt_print(dev, pipe, buffer, transfer_len, setup, "RET(ctlr)", + usb_pipein(pipe)); #else wait_ms(1); #endif
/* free TDs in urb_priv */ - urb_free_priv (&urb_priv); + urb_free_priv(&urb_priv); return 0; }
/* submit routines called from usb.c */ int submit_bulk_msg(struct usb_device *dev, unsigned long pipe, void *buffer, - int transfer_len) + int transfer_len) { info("submit_bulk_msg"); return submit_common_msg(dev, pipe, buffer, transfer_len, NULL, 0); }
int submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer, - int transfer_len, struct devrequest *setup) + int transfer_len, struct devrequest *setup) { int maxsize = usb_maxpacket(dev, pipe);
info("submit_control_msg"); #ifdef DEBUG urb_priv.actual_length = 0; - pkt_print(dev, pipe, buffer, transfer_len, setup, "SUB", usb_pipein(pipe)); + pkt_print(dev, pipe, buffer, transfer_len, setup, "SUB", + usb_pipein(pipe)); #else wait_ms(1); #endif if (!maxsize) { err("submit_control_message: pipesize for pipe %lx is zero", - pipe); + pipe); return -1; } if (((pipe >> 8) & 0x7f) == gohci.rh.devnum) { gohci.rh.dev = dev; /* root hub - redirect */ return ohci_submit_rh_msg(dev, pipe, buffer, transfer_len, - setup); + setup); }
return submit_common_msg(dev, pipe, buffer, transfer_len, setup, 0); }
int submit_int_msg(struct usb_device *dev, unsigned long pipe, void *buffer, - int transfer_len, int interval) + int transfer_len, int interval) { info("submit_int_msg"); return -1; @@ -1386,16 +1448,17 @@ int submit_int_msg(struct usb_device *dev, unsigned long pipe, void *buffer,
/* reset the HC and BUS */
-static int hc_reset (ohci_t *ohci) +static int hc_reset(ohci_t *ohci) { int timeout = 30; - int smm_timeout = 50; /* 0,5 sec */ + int smm_timeout = 50; /* 0,5 sec */
- if (readl (&ohci->regs->control) & OHCI_CTRL_IR) { /* SMM owns the HC */ - writel (OHCI_OCR, &ohci->regs->cmdstatus); /* request ownership */ + if (readl(&ohci->regs->control) & OHCI_CTRL_IR) { + /* SMM owns the HC - request ownership */ + writel(OHCI_OCR, &ohci->regs->cmdstatus); info("USB HC TakeOver from SMM"); - while (readl (&ohci->regs->control) & OHCI_CTRL_IR) { - wait_ms (10); + while (readl(&ohci->regs->control) & OHCI_CTRL_IR) { + wait_ms(10); if (--smm_timeout == 0) { err("USB HC TakeOver failed!"); return -1; @@ -1404,23 +1467,22 @@ static int hc_reset (ohci_t *ohci) }
/* Disable HC interrupts */ - writel (OHCI_INTR_MIE, &ohci->regs->intrdisable); + writel(OHCI_INTR_MIE, &ohci->regs->intrdisable);
dbg("USB HC reset_hc usb-%s: ctrl = 0x%X ;", - ohci->slot_name, - readl (&ohci->regs->control)); + ohci->slot_name, readl(&ohci->regs->control));
/* Reset USB (needed by some controllers) */ - writel (0, &ohci->regs->control); + writel(0, &ohci->regs->control);
/* HC Reset requires max 10 us delay */ - writel (OHCI_HCR, &ohci->regs->cmdstatus); - while ((readl (&ohci->regs->cmdstatus) & OHCI_HCR) != 0) { + writel(OHCI_HCR, &ohci->regs->cmdstatus); + while ((readl(&ohci->regs->cmdstatus) & OHCI_HCR) != 0) { if (--timeout == 0) { err("USB HC reset timed out!"); return -1; } - udelay (1); + udelay(1); } return 0; } @@ -1431,7 +1493,7 @@ static int hc_reset (ohci_t *ohci) * enable interrupts * connect the virtual root hub */
-static int hc_start (ohci_t * ohci) +static int hc_start(ohci_t *ohci) { __u32 mask; unsigned int fminterval; @@ -1441,44 +1503,45 @@ static int hc_start (ohci_t * ohci) /* Tell the controller where the control and bulk lists are * The lists are empty now. */
- writel (0, &ohci->regs->ed_controlhead); - writel (0, &ohci->regs->ed_bulkhead); + writel(0, &ohci->regs->ed_controlhead); + writel(0, &ohci->regs->ed_bulkhead);
- writel ((__u32)ohci->hcca, &ohci->regs->hcca); /* a reset clears this */ + /* a reset clears this */ + writel((__u32) ohci->hcca, &ohci->regs->hcca);
fminterval = 0x2edf; - writel ((fminterval * 9) / 10, &ohci->regs->periodicstart); + writel((fminterval * 9) / 10, &ohci->regs->periodicstart); fminterval |= ((((fminterval - 210) * 6) / 7) << 16); - writel (fminterval, &ohci->regs->fminterval); - writel (0x628, &ohci->regs->lsthresh); + writel(fminterval, &ohci->regs->fminterval); + writel(0x628, &ohci->regs->lsthresh);
/* start controller operations */ ohci->hc_control = OHCI_CONTROL_INIT | OHCI_USB_OPER; ohci->disabled = 0; - writel (ohci->hc_control, &ohci->regs->control); + writel(ohci->hc_control, &ohci->regs->control);
/* disable all interrupts */ mask = (OHCI_INTR_SO | OHCI_INTR_WDH | OHCI_INTR_SF | OHCI_INTR_RD | - OHCI_INTR_UE | OHCI_INTR_FNO | OHCI_INTR_RHSC | - OHCI_INTR_OC | OHCI_INTR_MIE); - writel (mask, &ohci->regs->intrdisable); + OHCI_INTR_UE | OHCI_INTR_FNO | OHCI_INTR_RHSC | + OHCI_INTR_OC | OHCI_INTR_MIE); + writel(mask, &ohci->regs->intrdisable); /* clear all interrupts */ mask &= ~OHCI_INTR_MIE; - writel (mask, &ohci->regs->intrstatus); + writel(mask, &ohci->regs->intrstatus); /* Choose the interrupts we care about now - but w/o MIE */ mask = OHCI_INTR_RHSC | OHCI_INTR_UE | OHCI_INTR_WDH | OHCI_INTR_SO; - writel (mask, &ohci->regs->intrenable); + writel(mask, &ohci->regs->intrenable);
#ifdef OHCI_USE_NPS /* required for AMD-756 and some Mac platforms */ - writel ((roothub_a (ohci) | RH_A_NPS) & ~RH_A_PSM, - &ohci->regs->roothub.a); - writel (RH_HS_LPSC, &ohci->regs->roothub.status); -#endif /* OHCI_USE_NPS */ + writel((roothub_a(ohci) | RH_A_NPS) & ~RH_A_PSM, + &ohci->regs->roothub.a); + writel(RH_HS_LPSC, &ohci->regs->roothub.status); +#endif /* OHCI_USE_NPS */
#define mdelay(n) ({unsigned long msec=(n); while (msec--) udelay(1000);}) /* POTPGT delay is bits 24-31, in 2 ms units. */ - mdelay ((roothub_a (ohci) >> 23) & 0x1fe); + mdelay((roothub_a(ohci) >> 23) & 0x1fe);
/* connect the virtual root hub */ ohci->rh.devnum = 0; @@ -1490,8 +1553,7 @@ static int hc_start (ohci_t * ohci)
/* an interrupt happens */
-static int -hc_interrupt (void) +static int hc_interrupt(void) { ohci_t *ohci = &gohci; struct ohci_regs *regs = ohci->regs; @@ -1499,21 +1561,26 @@ hc_interrupt (void) int stat = -1;
if ((ohci->hcca->done_head != 0) && - !(m32_swap (ohci->hcca->done_head) & 0x01)) { + !(m32_swap(ohci->hcca->done_head) & 0x01)) {
- ints = OHCI_INTR_WDH; + ints = OHCI_INTR_WDH;
- } else if ((ints = readl (®s->intrstatus)) == ~(u32)0) { - ohci->disabled++; - err ("%s device removed!", ohci->slot_name); - return -1; - - } else if ((ints &= readl (®s->intrenable)) == 0) { - dbg("hc_interrupt: returning..\n"); - return 0xff; + } else { + ints = readl(®s->intrstatus); + if (ints == ~(u32) 0) { + ohci->disabled++; + err("%s device removed!", ohci->slot_name); + return -1; + } + ints &= readl(®s->intrenable); + if (ints == 0) { + dbg("hc_interrupt: returning..\n"); + return 0xff; + } }
- /* dbg("Interrupt: %x frame: %x", ints, le16_to_cpu (ohci->hcca->frame_no)); */ + /* dbg("Interrupt: %x frame: %x", ints, + le16_to_cpu(ohci->hcca->frame_no)); */
if (ints & OHCI_INTR_RHSC) { got_rhsc = 1; @@ -1522,48 +1589,48 @@ hc_interrupt (void)
if (ints & OHCI_INTR_UE) { ohci->disabled++; - err ("OHCI Unrecoverable Error, controller usb-%s disabled", - ohci->slot_name); + err("OHCI Unrecoverable Error, controller usb-%s disabled", + ohci->slot_name); /* e.g. due to PCI Master/Target Abort */
#ifdef DEBUG - ohci_dump (ohci, 1); + ohci_dump(ohci, 1); #else - wait_ms(1); + wait_ms(1); #endif /* FIXME: be optimistic, hope that bug won't repeat often. */ /* Make some non-interrupt context restart the controller. */ /* Count and limit the retries though; either hardware or */ /* software errors can go forever... */ - hc_reset (ohci); + hc_reset(ohci); return -1; }
if (ints & OHCI_INTR_WDH) { wait_ms(1);
- writel (OHCI_INTR_WDH, ®s->intrdisable); - stat = dl_done_list (&gohci, dl_reverse_done_list (&gohci)); - writel (OHCI_INTR_WDH, ®s->intrenable); + writel(OHCI_INTR_WDH, ®s->intrdisable); + stat = dl_done_list(&gohci, dl_reverse_done_list(&gohci)); + writel(OHCI_INTR_WDH, ®s->intrenable); }
if (ints & OHCI_INTR_SO) { dbg("USB Schedule overrun\n"); - writel (OHCI_INTR_SO, ®s->intrenable); + writel(OHCI_INTR_SO, ®s->intrenable); stat = -1; }
/* FIXME: this assumes SOF (1/ms) interrupts don't get lost... */ if (ints & OHCI_INTR_SF) { - unsigned int frame = m16_swap (ohci->hcca->frame_no) & 1; + unsigned int frame = m16_swap(ohci->hcca->frame_no) & 1; wait_ms(1); - writel (OHCI_INTR_SF, ®s->intrdisable); + writel(OHCI_INTR_SF, ®s->intrdisable); if (ohci->ed_rm_list[frame] != NULL) - writel (OHCI_INTR_SF, ®s->intrenable); + writel(OHCI_INTR_SF, ®s->intrenable); stat = 0xff; }
- writel (ints, ®s->intrstatus); + writel(ints, ®s->intrstatus); return stat; }
@@ -1573,12 +1640,12 @@ hc_interrupt (void)
/* De-allocate all resources.. */
-static void hc_release_ohci (ohci_t *ohci) +static void hc_release_ohci(ohci_t *ohci) { - dbg ("USB HC release ohci usb-%s", ohci->slot_name); + dbg("USB HC release ohci usb-%s", ohci->slot_name);
if (!ohci->disabled) - hc_reset (ohci); + hc_reset(ohci); }
/*-------------------------------------------------------------------------*/ @@ -1590,44 +1657,44 @@ static char ohci_inited = 0;
int usb_lowlevel_init(void) { - S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); - S3C24X0_GPIO * const gpio = S3C24X0_GetBase_GPIO(); + struct s3c24x0_clock_power *clk_power = s3c24x0_get_base_clock_power(); + struct s3c24x0_gpio *gpio = s3c24x0_get_base_gpio();
/* * Set the 48 MHz UPLL clocking. Values are taken from * "PLL value selection guide", 6-23, s3c2400_UM.pdf. */ clk_power->UPLLCON = ((40 << 12) + (1 << 4) + 2); - gpio->MISCCR |= 0x8; /* 1 = use pads related USB for USB host */ + gpio->MISCCR |= 0x8; /* 1 = use pads related USB for USB host */
/* * Enable USB host clock. */ clk_power->CLKCON |= (1 << 4);
- memset (&gohci, 0, sizeof (ohci_t)); - memset (&urb_priv, 0, sizeof (urb_priv_t)); + memset(&gohci, 0, sizeof(ohci_t)); + memset(&urb_priv, 0, sizeof(urb_priv_t));
/* align the storage */ - if ((__u32)&ghcca[0] & 0xff) { + if ((__u32) &ghcca[0] & 0xff) { err("HCCA not aligned!!"); return -1; } phcca = &ghcca[0]; info("aligned ghcca %p", phcca); memset(&ohci_dev, 0, sizeof(struct ohci_device)); - if ((__u32)&ohci_dev.ed[0] & 0x7) { + if ((__u32) &ohci_dev.ed[0] & 0x7) { err("EDs not aligned!!"); return -1; } memset(gtd, 0, sizeof(td_t) * (NUM_TD + 1)); - if ((__u32)gtd & 0x7) { + if ((__u32) gtd & 0x7) { err("TDs not aligned!!"); return -1; } ptd = gtd; gohci.hcca = phcca; - memset (phcca, 0, sizeof (struct ohci_hcca)); + memset(phcca, 0, sizeof(struct ohci_hcca));
gohci.disabled = 1; gohci.sleeping = 0; @@ -1637,8 +1704,8 @@ int usb_lowlevel_init(void) gohci.flags = 0; gohci.slot_name = "s3c2400";
- if (hc_reset (&gohci) < 0) { - hc_release_ohci (&gohci); + if (hc_reset(&gohci) < 0) { + hc_release_ohci(&gohci); /* Initialization failed */ clk_power->CLKCON &= ~(1 << 4); return -1; @@ -1646,19 +1713,18 @@ int usb_lowlevel_init(void)
/* FIXME this is a second HC reset; why?? */ gohci.hc_control = OHCI_USB_RESET; - writel (gohci.hc_control, &gohci.regs->control); - wait_ms (10); + writel(gohci.hc_control, &gohci.regs->control); + wait_ms(10);
- if (hc_start (&gohci) < 0) { - err ("can't start usb-%s", gohci.slot_name); - hc_release_ohci (&gohci); + if (hc_start(&gohci) < 0) { + err("can't start usb-%s", gohci.slot_name); + hc_release_ohci(&gohci); /* Initialization failed */ clk_power->CLKCON &= ~(1 << 4); return -1; } - #ifdef DEBUG - ohci_dump (&gohci, 1); + ohci_dump(&gohci, 1); #else wait_ms(1); #endif @@ -1670,7 +1736,7 @@ int usb_lowlevel_init(void)
int usb_lowlevel_stop(void) { - S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + struct s3c24x0_clock_power *clk_power = s3c24x0_get_base_clock_power();
/* this gets called really early - before the controller has */ /* even been initialized! */ @@ -1678,7 +1744,7 @@ int usb_lowlevel_stop(void) return 0; /* TODO release any interrupts, etc. */ /* call hc_release_ohci() here ? */ - hc_reset (&gohci); + hc_reset(&gohci); /* may not want to do this */ clk_power->CLKCON &= ~(1 << 4); return 0; diff --git a/cpu/arm920t/s3c24x0/usb_ohci.h b/cpu/arm920t/s3c24x0/usb_ohci.h index 8e093fb..6ae1716 100644 --- a/cpu/arm920t/s3c24x0/usb_ohci.h +++ b/cpu/arm920t/s3c24x0/usb_ohci.h @@ -11,22 +11,22 @@ static int cc_to_error[16] = {
/* mapping of the OHCI CC status to error codes */ - /* No Error */ 0, - /* CRC Error */ USB_ST_CRC_ERR, - /* Bit Stuff */ USB_ST_BIT_ERR, - /* Data Togg */ USB_ST_CRC_ERR, - /* Stall */ USB_ST_STALLED, - /* DevNotResp */ -1, - /* PIDCheck */ USB_ST_BIT_ERR, - /* UnExpPID */ USB_ST_BIT_ERR, - /* DataOver */ USB_ST_BUF_ERR, - /* DataUnder */ USB_ST_BUF_ERR, - /* reservd */ -1, - /* reservd */ -1, - /* BufferOver */ USB_ST_BUF_ERR, - /* BuffUnder */ USB_ST_BUF_ERR, - /* Not Access */ -1, - /* Not Access */ -1 + /* No Error */ 0, + /* CRC Error */ USB_ST_CRC_ERR, + /* Bit Stuff */ USB_ST_BIT_ERR, + /* Data Togg */ USB_ST_CRC_ERR, + /* Stall */ USB_ST_STALLED, + /* DevNotResp */ -1, + /* PIDCheck */ USB_ST_BIT_ERR, + /* UnExpPID */ USB_ST_BIT_ERR, + /* DataOver */ USB_ST_BUF_ERR, + /* DataUnder */ USB_ST_BUF_ERR, + /* reservd */ -1, + /* reservd */ -1, + /* BufferOver */ USB_ST_BUF_ERR, + /* BuffUnder */ USB_ST_BUF_ERR, + /* Not Access */ -1, + /* Not Access */ -1 };
/* ED States */ @@ -55,14 +55,14 @@ struct ed {
struct usb_device *usb_dev; __u32 unused[3]; -} __attribute__((aligned(16))); +} __attribute__ ((aligned(16))); typedef struct ed ed_t;
- /* TD info field */ #define TD_CC 0xf0000000 -#define TD_CC_GET(td_p) ((td_p >>28) & 0x0f) -#define TD_CC_SET(td_p, cc) (td_p) = ((td_p) & 0x0fffffff) | (((cc) & 0x0f) << 28) +#define TD_CC_GET(td_p) (((td_p) >> 28) & 0x0f) +#define TD_CC_SET(td_p, cc) \ + {(td_p) = ((td_p) & 0x0fffffff) | (((cc) & 0x0f) << 28)} #define TD_EC 0x0C000000 #define TD_T 0x03000000 #define TD_T_DATA0 0x02000000 @@ -112,7 +112,7 @@ struct td { __u32 data;
__u32 unused2[2]; -} __attribute__((aligned(32))); +} __attribute__ ((aligned(32))); typedef struct td td_t;
#define OHCI_ED_SKIP (1 << 14) @@ -123,15 +123,14 @@ typedef struct td td_t; * told the base address of. It must be 256-byte aligned. */
-#define NUM_INTS 32 /* part of the OHCI standard */ +#define NUM_INTS 32 /* part of the OHCI standard */ struct ohci_hcca { - __u32 int_table[NUM_INTS]; /* Interrupt ED table */ - __u16 frame_no; /* current frame number */ - __u16 pad1; /* set to 0 on each frame_no change */ - __u32 done_head; /* info returned for an interrupt */ - u8 reserved_for_hc[116]; -} __attribute__((aligned(256))); - + __u32 int_table[NUM_INTS]; /* Interrupt ED table */ + __u16 frame_no; /* current frame number */ + __u16 pad1; /* set to 0 on each frame_no change */ + __u32 done_head; /* info returned for an interrupt */ + u8 reserved_for_hc[116]; +} __attribute__ ((aligned(256)));
/* * Maximum number of root hub ports. @@ -145,35 +144,34 @@ struct ohci_hcca { */ struct ohci_regs { /* control and status registers */ - __u32 revision; - __u32 control; - __u32 cmdstatus; - __u32 intrstatus; - __u32 intrenable; - __u32 intrdisable; + __u32 revision; + __u32 control; + __u32 cmdstatus; + __u32 intrstatus; + __u32 intrenable; + __u32 intrdisable; /* memory pointers */ - __u32 hcca; - __u32 ed_periodcurrent; - __u32 ed_controlhead; - __u32 ed_controlcurrent; - __u32 ed_bulkhead; - __u32 ed_bulkcurrent; - __u32 donehead; + __u32 hcca; + __u32 ed_periodcurrent; + __u32 ed_controlhead; + __u32 ed_controlcurrent; + __u32 ed_bulkhead; + __u32 ed_bulkcurrent; + __u32 donehead; /* frame counters */ - __u32 fminterval; - __u32 fmremaining; - __u32 fmnumber; - __u32 periodicstart; - __u32 lsthresh; + __u32 fminterval; + __u32 fmremaining; + __u32 fmnumber; + __u32 periodicstart; + __u32 lsthresh; /* Root hub ports */ - struct ohci_roothub_regs { - __u32 a; - __u32 b; - __u32 status; - __u32 portstatus[MAX_ROOT_PORTS]; + struct ohci_roothub_regs { + __u32 a; + __u32 b; + __u32 status; + __u32 portstatus[MAX_ROOT_PORTS]; } roothub; -} __attribute__((aligned(32))); - +} __attribute__ ((aligned(32)));
/* OHCI CONTROL AND STATUS REGISTER MASKS */
@@ -221,11 +219,10 @@ struct ohci_regs { #define OHCI_INTR_OC (1 << 30) /* ownership change */ #define OHCI_INTR_MIE (1 << 31) /* master interrupt enable */
- /* Virtual Root HUB */ struct virt_root_hub { - int devnum; /* Address of Root Hub endpoint */ - void *dev; /* was urb */ + int devnum; /* Address of Root Hub endpoint */ + void *dev; /* was urb */ void *int_addr; int send; int interval; @@ -288,51 +285,51 @@ struct virt_root_hub { /* OHCI ROOT HUB REGISTER MASKS */
/* roothub.portstatus [i] bits */ -#define RH_PS_CCS 0x00000001 /* current connect status */ -#define RH_PS_PES 0x00000002 /* port enable status*/ -#define RH_PS_PSS 0x00000004 /* port suspend status */ -#define RH_PS_POCI 0x00000008 /* port over current indicator */ -#define RH_PS_PRS 0x00000010 /* port reset status */ -#define RH_PS_PPS 0x00000100 /* port power status */ -#define RH_PS_LSDA 0x00000200 /* low speed device attached */ -#define RH_PS_CSC 0x00010000 /* connect status change */ -#define RH_PS_PESC 0x00020000 /* port enable status change */ -#define RH_PS_PSSC 0x00040000 /* port suspend status change */ -#define RH_PS_OCIC 0x00080000 /* over current indicator change */ -#define RH_PS_PRSC 0x00100000 /* port reset status change */ +#define RH_PS_CCS 0x00000001 /* current connect status */ +#define RH_PS_PES 0x00000002 /* port enable status */ +#define RH_PS_PSS 0x00000004 /* port suspend status */ +#define RH_PS_POCI 0x00000008 /* port over current indicator */ +#define RH_PS_PRS 0x00000010 /* port reset status */ +#define RH_PS_PPS 0x00000100 /* port power status */ +#define RH_PS_LSDA 0x00000200 /* low speed device attached */ +#define RH_PS_CSC 0x00010000 /* connect status change */ +#define RH_PS_PESC 0x00020000 /* port enable status change */ +#define RH_PS_PSSC 0x00040000 /* port suspend status change */ +#define RH_PS_OCIC 0x00080000 /* over current indicator change */ +#define RH_PS_PRSC 0x00100000 /* port reset status change */
/* roothub.status bits */ -#define RH_HS_LPS 0x00000001 /* local power status */ -#define RH_HS_OCI 0x00000002 /* over current indicator */ -#define RH_HS_DRWE 0x00008000 /* device remote wakeup enable */ -#define RH_HS_LPSC 0x00010000 /* local power status change */ -#define RH_HS_OCIC 0x00020000 /* over current indicator change */ -#define RH_HS_CRWE 0x80000000 /* clear remote wakeup enable */ +#define RH_HS_LPS 0x00000001 /* local power status */ +#define RH_HS_OCI 0x00000002 /* over current indicator */ +#define RH_HS_DRWE 0x00008000 /* device remote wakeup enable */ +#define RH_HS_LPSC 0x00010000 /* local power status change */ +#define RH_HS_OCIC 0x00020000 /* over current indicator change */ +#define RH_HS_CRWE 0x80000000 /* clear remote wakeup enable */
/* roothub.b masks */ -#define RH_B_DR 0x0000ffff /* device removable flags */ -#define RH_B_PPCM 0xffff0000 /* port power control mask */ +#define RH_B_DR 0x0000ffff /* device removable flags */ +#define RH_B_PPCM 0xffff0000 /* port power control mask */
/* roothub.a masks */ -#define RH_A_NDP (0xff << 0) /* number of downstream ports */ -#define RH_A_PSM (1 << 8) /* power switching mode */ -#define RH_A_NPS (1 << 9) /* no power switching */ -#define RH_A_DT (1 << 10) /* device type (mbz) */ -#define RH_A_OCPM (1 << 11) /* over current protection mode */ -#define RH_A_NOCP (1 << 12) /* no over current protection */ -#define RH_A_POTPGT (0xff << 24) /* power on to power good time */ +#define RH_A_NDP (0xff << 0) /* number of downstream ports */ +#define RH_A_PSM (1 << 8) /* power switching mode */ +#define RH_A_NPS (1 << 9) /* no power switching */ +#define RH_A_DT (1 << 10) /* device type (mbz) */ +#define RH_A_OCPM (1 << 11) /* over current protection mode */ +#define RH_A_NOCP (1 << 12) /* no over current protection */ +#define RH_A_POTPGT (0xff << 24) /* power on to power good time */
/* urb */ #define N_URB_TD 48 -typedef struct -{ +typedef struct { ed_t *ed; - __u16 length; /* number of tds associated with this request */ - __u16 td_cnt; /* number of tds already serviced */ - int state; + __u16 length; /* number of tds associated with this request */ + __u16 td_cnt; /* number of tds already serviced */ + int state; unsigned long pipe; int actual_length; - td_t *td[N_URB_TD]; /* list pointer to all corresponding TDs associated with this request */ + td_t *td[N_URB_TD]; /* list pointer to all corresponding TDs + associated with this request */ } urb_priv_t; #define URB_DEL 1
@@ -375,9 +372,9 @@ struct ohci_device {
/* hcd */ /* endpoint */ -static int ep_link (ohci_t * ohci, ed_t * ed); -static int ep_unlink (ohci_t * ohci, ed_t * ed); -static ed_t *ep_add_ed (struct usb_device *usb_dev, unsigned long pipe); +static int ep_link(ohci_t *ohci, ed_t *ed); +static int ep_unlink(ohci_t *ohci, ed_t *ed); +static ed_t *ep_add_ed(struct usb_device *usb_dev, unsigned long pipe);
@@ -391,7 +388,7 @@ td_t gtd[NUM_TD + 1]; td_t *ptd;
/* TDs ... */ -static inline struct td *td_alloc (struct usb_device *usb_dev) +static inline struct td *td_alloc(struct usb_device *usb_dev) { int i; struct td *td; @@ -408,7 +405,7 @@ static inline struct td *td_alloc (struct usb_device *usb_dev) return td; }
-static inline void ed_free (struct ed *ed) +static inline void ed_free(struct ed *ed) { ed->usb_dev = NULL; } diff --git a/cpu/arm920t/start.S b/cpu/arm920t/start.S index 27f38b8..114427a 100644 --- a/cpu/arm920t/start.S +++ b/cpu/arm920t/start.S @@ -37,7 +37,7 @@
.globl _start -_start: b start_code +_start: b start_code ldr pc, _undefined_instruction ldr pc, _software_interrupt ldr pc, _prefetch_abort @@ -109,13 +109,13 @@ start_code: /* * set the cpu to SVC32 mode */ - mrs r0,cpsr - bic r0,r0,#0x1f - orr r0,r0,#0xd3 - msr cpsr,r0 + mrs r0, cpsr + bic r0, r0, #0x1f + orr r0, r0, #0xd3 + msr cpsr, r0
- bl coloured_LED_init - bl red_LED_on + bl coloured_LED_init + bl red_LED_on
#if defined(CONFIG_AT91RM9200DK) || defined(CONFIG_AT91RM9200EK) /* @@ -135,19 +135,19 @@ copyex: /* turn off the watchdog */
# if defined(CONFIG_S3C2400) -# define pWTCON 0x15300000 -# define INTMSK 0x14400008 /* Interupt-Controller base addresses */ +# define pWTCON 0x15300000 +# define INTMSK 0x14400008 /* Interupt-Controller base addresses */ # define CLKDIVN 0x14800014 /* clock divisor register */ #else -# define pWTCON 0x53000000 -# define INTMSK 0x4A000008 /* Interupt-Controller base addresses */ +# define pWTCON 0x53000000 +# define INTMSK 0x4A000008 /* Interupt-Controller base addresses */ # define INTSUBMSK 0x4A00001C # define CLKDIVN 0x4C000014 /* clock divisor register */ # endif
- ldr r0, =pWTCON - mov r1, #0x0 - str r1, [r0] + ldr r0, =pWTCON + mov r1, #0x0 + str r1, [r0]
/* * mask all IRQs by setting all bits in the INTMR - default @@ -180,8 +180,8 @@ copyex: relocate: /* relocate U-Boot to RAM */ adr r0, _start /* r0 <- current position of code */ ldr r1, _TEXT_BASE /* test if we run from flash or RAM */ - cmp r0, r1 /* don't reloc during debug */ - beq stack_setup + cmp r0, r1 /* don't reloc during debug */ + beq stack_setup
ldr r2, _armboot_start ldr r3, _bss_start @@ -198,8 +198,8 @@ copy_loop: /* Set up the stack */ stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ - sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ + sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -297,8 +297,8 @@ cpu_init_crit: #define S_R1 4 #define S_R0 0
-#define MODE_SVC 0x13 -#define I_BIT 0x80 +#define MODE_SVC 0x13 +#define I_BIT 0x80
/* * use bad_save_user_regs for abort/prefetch/undef/swi ... @@ -311,7 +311,8 @@ cpu_init_crit: ldr r2, _armboot_start sub r2, r2, #(CONFIG_STACKSIZE) sub r2, r2, #(CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + /* set base 2 words into abort stack */ + sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) ldmia r2, {r2 - r3} @ get pc, cpsr add r0, sp, #S_FRAME_SIZE @ restore sp_SVC
@@ -324,12 +325,12 @@ cpu_init_crit: .macro irq_save_user_regs sub sp, sp, #S_FRAME_SIZE stmia sp, {r0 - r12} @ Calling r0-r12 - add r7, sp, #S_PC - stmdb r7, {sp, lr}^ @ Calling SP, LR - str lr, [r7, #0] @ Save calling PC - mrs r6, spsr - str r6, [r7, #4] @ Save CPSR - str r0, [r7, #8] @ Save OLD_R0 + add r7, sp, #S_PC + stmdb r7, {sp, lr}^ @ Calling SP, LR + str lr, [r7, #0] @ Save calling PC + mrs r6, spsr + str r6, [r7, #4] @ Save CPSR + str r0, [r7, #8] @ Save OLD_R0 mov r0, sp .endm
@@ -338,18 +339,20 @@ cpu_init_crit: mov r0, r0 ldr lr, [sp, #S_PC] @ Get PC add sp, sp, #S_FRAME_SIZE - subs pc, lr, #4 @ return & move spsr_svc into cpsr + /* return & move spsr_svc into cpsr */ + subs pc, lr, #4 .endm
.macro get_bad_stack ldr r13, _armboot_start @ setup our mode stack sub r13, r13, #(CONFIG_STACKSIZE) sub r13, r13, #(CONFIG_SYS_MALLOC_LEN) - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack + /* reserve a couple spots in abort stack */ + sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8)
str lr, [r13] @ save caller lr / spsr mrs lr, spsr - str lr, [r13, #4] + str lr, [r13, #4]
mov r13, #MODE_SVC @ prepare SVC-Mode @ msr spsr_c, r13 -- 1.6.1.2
kevin.morfitt@fearnside-systems.co.uk
