[PATCH] net/tftp: make tftpput working with servers that do not use OACK
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- net/tftp.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/net/tftp.c b/net/tftp.c index 2e335413492..2534dec1c9f 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -494,8 +494,15 @@ static void tftp_handler(uchar *pkt, unsigned dest, struct in_addr sip, tftp_prev_block = tftp_cur_block; tftp_cur_block = (unsigned short)(block + 1); update_block_number(); - if (ack_ok) + if (ack_ok) { + if (block == 0 && + tftp_state == STATE_SEND_WRQ){ + /* connection's first ACK */ + tftp_state = STATE_DATA; + tftp_remote_port = src; + } tftp_send(); /* Send next data block */ + } } } #endif
Please don't put the only detail in the subject, please outline the fix here too, that should allow a more concise subject.
if (ack_ok)
if (ack_ok) {
if (block == 0 &&
#endif
2.43.0
Mikhail Kshevetskiy
Peter Robinson
