[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit 605e15db2b54302364a2528d3c6604fbc57be846:
Merge git://git.denx.de/u-boot-x86 (2015-07-15 10:41:20 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to db14f11dfe348550d8c10c6609277488d9f500d6:
armv8/fsl-lsch3: Fix TCR_EL3 for the final MMU setup. (2015-07-20 11:44:40 -0700)
---------------------------------------------------------------- Alison Wang (2): arm: ls1021a: Remove the inappropriate use of the function 'sprintf' arm/ls102xa: Add little-endian mode support for audio IPs
Bhupesh Sharma (4): armv8/ls2085a: Increase the supported kernel size armv8/ls2085a: Expose all DDR region(s) to Linux driver/fsl_debug_server: Fix the DDR hide logic for LS2085a arm/errata: Update required bits for A57 cores erratas
Haikun Wang (7): arm/dts/ls2085a: Bring in ls2085a dts files from linux kernel arm/dts/ls2085a: Add DSPI dts node arm/dts/ls2085a: Add dts files for LS2085AQDS and LS2085ARDB armv8/ls2085a: Enable DSPI get input clk form 'mxc_get_clock' armv8/ls2085aqds: DSPI pin muxing configure through QIXIS armv8/ls2085aqds: Enable DSPI flash support for LS2085AQDS armv8/ls2085ardb: Enable DSPI flash support for LS2085ARDB
Haikun.Wang@freescale.com (2): armv8/ls2085ardb: DSPI pin muxing configure through QIXIS CPLD armv8/ls2085a/defconfig: Enable FSL_DSPI, OF_CONTROL and DM support
J. German Rivera (2): drivers/fsl-mc: Make MC boot error messages more readable drivers/fsl-mc: Autoload AOIP image from NOR flash
Jaiprakash Singh (1): board/fsl/common: Fix eeprom system version endianness
Prabhakar Kushwaha (21): armv8/ls2085ardb: Add eth & phy firmware loading support armv8/ls2085aqds: Add support of SerDes protocol 0x49 armv8/ls2085a: Update LS2085a PCIe compatible armv8/ls2085a: call ft_pcie_setup() to change dts status armv8/ls2085qds: Update SFP TX bit as "0" to enable XFI armv8/ls2085rdb: Update PCA9547PW slave address armv8/ls2085RDB: Update board version print logic armv8/fsl-ch3: Add support to print SoC personality armv8/ls2085a: Avoid hard-coding for board name print armv8/ls2085a: Update SoC README for DDR layout armv8/fsl-lsch3: Support 256M mem split for MC & dbg-srvr driver/ldpaa_eth:Flush buffer before seeding BMAN after TX_conf drivers: fsl-mc: Update flibs to mc-0.6.0.1 drivers: fsl-mc: Update qbman driver drivers: fsl-mc: Return error for major version mismatch driver/ldpaa_eth: Retry enqueue if portal was busy driver/ldpaa_eth: Add timeout handling DQRR entry read driver/ldpaa_eth: Avoid TX conf frames driver/ldpaa_eth:Avoid infinite loop in ldpaa_eth_rx board/ls2085rdb: Export functions for standalone AQ FW load apps board/ls2085a: Increase kernel_size value in env variable
Priyanka Jain (1): armv8/ls2085a: Enable "date" command for QDS and RDB
Stuart Yoder (4): armv8/ls2085a: enable debug server armv8/fsl-lsch3: partition stream IDs drivers/fsl-mc: dynamically create ICID pool in DPC armv8/fsl-lsch3: device tree fixups for PCI stream IDs
Wang Dongsheng (2): ARMv7: Factor out reusable timer_wait from sunxi/psci_sun7i.S arm/ls102xa: Add PSCI support for ls102xa
Yangbo Lu (1): armv8/ls2085ardb: add hwconfig setting for eSDHC
York Sun (3): armv8/fsl-lsch3: Fix DDR speed message driver/ddr/fsl: Add a hook to update SPD address armv8/ls2085ardb: Fix SPD address error on early boards
Zhichun Hua (2): armv8: Fix TCR macros for shareability attribute armv8/fsl-lsch3: Fix TCR_EL3 for the final MMU setup.
README | 15 ++ arch/arm/cpu/armv7/ls102xa/Makefile | 4 + arch/arm/cpu/armv7/ls102xa/fdt.c | 21 +-- arch/arm/cpu/armv7/ls102xa/psci.S | 126 +++++++++++++++ arch/arm/cpu/armv7/sunxi/psci_sun6i.S | 22 +-- arch/arm/cpu/armv7/sunxi/psci_sun7i.S | 22 +-- arch/arm/cpu/armv8/fsl-lsch3/README | 25 +++ arch/arm/cpu/armv8/fsl-lsch3/cpu.c | 64 ++++++-- arch/arm/cpu/armv8/fsl-lsch3/fdt.c | 114 ++++++++++++++ arch/arm/cpu/armv8/fsl-lsch3/speed.c | 2 + arch/arm/cpu/armv8/start.S | 8 +- arch/arm/dts/Makefile | 2 + arch/arm/dts/fsl-ls2085a-qds.dts | 53 +++++++ arch/arm/dts/fsl-ls2085a-rdb.dts | 35 +++++ arch/arm/dts/fsl-ls2085a.dtsi | 129 ++++++++++++++++ arch/arm/include/asm/arch-armv7/generictimer.h | 50 ++++++ arch/arm/include/asm/arch-fsl-lsch3/clock.h | 1 + arch/arm/include/asm/arch-fsl-lsch3/config.h | 2 + arch/arm/include/asm/arch-fsl-lsch3/fdt.h | 10 ++ .../include/asm/arch-fsl-lsch3/ls2085a_stream_id.h | 64 ++++++++ arch/arm/include/asm/arch-fsl-lsch3/soc.h | 20 +++ arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 3 +- arch/arm/include/asm/armv8/mmu.h | 4 +- board/freescale/common/sys_eeprom.c | 8 +- board/freescale/ls1021aqds/ls1021aqds.c | 3 + board/freescale/ls1021atwr/ls1021atwr.c | 3 + board/freescale/ls2085a/README | 11 ++ board/freescale/ls2085a/ls2085a.c | 17 +- board/freescale/ls2085aqds/README | 19 +++ board/freescale/ls2085aqds/eth.c | 4 +- board/freescale/ls2085aqds/ls2085aqds.c | 71 ++++++++- board/freescale/ls2085ardb/Makefile | 2 +- board/freescale/ls2085ardb/README | 11 ++ board/freescale/ls2085ardb/eth_ls2085rdb.c | 148 ++++++++++++++++++ board/freescale/ls2085ardb/ls2085ardb.c | 111 +++++++++++--- common/exports.c | 7 + configs/ls2085aqds_defconfig | 7 + configs/ls2085ardb_defconfig | 7 + drivers/ddr/fsl/main.c | 8 + drivers/misc/fsl_debug_server.c | 5 + drivers/net/fsl-mc/dpio/qbman_portal.c | 66 ++++---- drivers/net/fsl-mc/dpio/qbman_portal.h | 22 ++- drivers/net/fsl-mc/dpio/qbman_private.h | 2 +- drivers/net/fsl-mc/dpni.c | 2 +- drivers/net/fsl-mc/mc.c | 121 +++++++++++---- drivers/net/ldpaa_eth/ldpaa_eth.c | 162 ++++++-------------- drivers/net/ldpaa_eth/ldpaa_eth.h | 1 - drivers/pci/pcie_layerscape.c | 62 ++++++++ include/_exports.h | 13 ++ include/configs/ls1021aqds.h | 2 + include/configs/ls1021atwr.h | 2 + include/configs/ls2085a_common.h | 28 +++- include/configs/ls2085aqds.h | 17 +- include/configs/ls2085ardb.h | 49 +++++- include/exports.h | 13 +- include/fsl-mc/fsl_dpio.h | 32 ++-- include/fsl-mc/fsl_dpmng.h | 2 +- include/fsl-mc/fsl_dpni.h | 144 ++++++++++++++--- include/fsl-mc/fsl_dprc.h | 64 ++++++-- include/fsl-mc/fsl_mc.h | 5 +- include/fsl_ddr.h | 3 + 61 files changed, 1673 insertions(+), 377 deletions(-) create mode 100644 arch/arm/cpu/armv7/ls102xa/psci.S create mode 100644 arch/arm/dts/fsl-ls2085a-qds.dts create mode 100644 arch/arm/dts/fsl-ls2085a-rdb.dts create mode 100644 arch/arm/dts/fsl-ls2085a.dtsi create mode 100644 arch/arm/include/asm/arch-armv7/generictimer.h create mode 100644 arch/arm/include/asm/arch-fsl-lsch3/fdt.h create mode 100644 arch/arm/include/asm/arch-fsl-lsch3/ls2085a_stream_id.h create mode 100644 board/freescale/ls2085ardb/eth_ls2085rdb.c
Thanks.
York
On Mon, Jul 20, 2015 at 02:07:27PM -0700, York Sun wrote:
Tom,
York Sun
