[U-Boot] [PATCH v2 1/5] net: gem: Setup default phy address to -1
Undefined phy address is -1 not 0.
Signed-off-by: Michal Simek michal.simek@xilinx.com Acked-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v2: None
drivers/net/zynq_gem.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 0a41281e901d..b0755f5e3b48 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -666,11 +666,12 @@ static int zynq_gem_ofdata_to_platdata(struct udevice *dev) priv->iobase = (struct zynq_gem_regs *)pdata->iobase; /* Hardcode for now */ priv->emio = 0; + priv->phyaddr = -1;
offset = fdtdec_lookup_phandle(gd->fdt_blob, dev->of_offset, "phy-handle"); if (offset > 0) - priv->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, "reg", 0); + priv->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, "reg", -1);
phy_mode = fdt_getprop(gd->fdt_blob, dev->of_offset, "phy-mode", NULL); if (phy_mode)
recv function should return 0 instead of frame_len not to proceed the same packet again in core.
Changes in v2: None
drivers/net/zynq_gem.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index b0755f5e3b48..5f0f2005ceb3 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -569,7 +569,7 @@ static int zynq_gem_recv(struct udevice *dev, int flags, uchar **packetp) priv->rxbd_current = 0; }
- return frame_len; + return 0; }
static void zynq_gem_halt(struct udevice *dev)
Use core to call net_process_received_packet() instead of call inside the driver.
Changes in v2: None
drivers/net/zynq_gem.c | 52 +++++++++++++++++++++++++++++++------------------- 1 file changed, 32 insertions(+), 20 deletions(-)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 5f0f2005ceb3..f7c20dc9cd54 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -532,43 +532,54 @@ static int zynq_gem_send(struct udevice *dev, void *ptr, int len) static int zynq_gem_recv(struct udevice *dev, int flags, uchar **packetp) { int frame_len; + u32 addr; struct zynq_gem_priv *priv = dev_get_priv(dev); struct emac_bd *current_bd = &priv->rx_bd[priv->rxbd_current]; - struct emac_bd *first_bd;
if (!(current_bd->addr & ZYNQ_GEM_RXBUF_NEW_MASK)) - return 0; + return -1;
if (!(current_bd->status & (ZYNQ_GEM_RXBUF_SOF_MASK | ZYNQ_GEM_RXBUF_EOF_MASK))) { printf("GEM: SOF or EOF not set for last buffer received!\n"); - return 0; + return -1; }
frame_len = current_bd->status & ZYNQ_GEM_RXBUF_LEN_MASK; - if (frame_len) { - u32 addr = current_bd->addr & ZYNQ_GEM_RXBUF_ADD_MASK; - addr &= ~(ARCH_DMA_MINALIGN - 1); + if (!frame_len) { + printf("%s: Zero size packet?\n", __func__); + return -1; + }
- net_process_received_packet((u8 *)(ulong)addr, frame_len); + addr = current_bd->addr & ZYNQ_GEM_RXBUF_ADD_MASK; + addr &= ~(ARCH_DMA_MINALIGN - 1); + *packetp = (uchar *)(uintptr_t)addr;
- if (current_bd->status & ZYNQ_GEM_RXBUF_SOF_MASK) - priv->rx_first_buf = priv->rxbd_current; - else { - current_bd->addr &= ~ZYNQ_GEM_RXBUF_NEW_MASK; - current_bd->status = 0xF0000000; /* FIXME */ - } + return frame_len; +}
- if (current_bd->status & ZYNQ_GEM_RXBUF_EOF_MASK) { - first_bd = &priv->rx_bd[priv->rx_first_buf]; - first_bd->addr &= ~ZYNQ_GEM_RXBUF_NEW_MASK; - first_bd->status = 0xF0000000; - } +static int zynq_gem_free_pkt(struct udevice *dev, uchar *packet, int length) +{ + struct zynq_gem_priv *priv = dev_get_priv(dev); + struct emac_bd *current_bd = &priv->rx_bd[priv->rxbd_current]; + struct emac_bd *first_bd; + + if (current_bd->status & ZYNQ_GEM_RXBUF_SOF_MASK) { + priv->rx_first_buf = priv->rxbd_current; + } else { + current_bd->addr &= ~ZYNQ_GEM_RXBUF_NEW_MASK; + current_bd->status = 0xF0000000; /* FIXME */ + }
- if ((++priv->rxbd_current) >= RX_BUF) - priv->rxbd_current = 0; + if (current_bd->status & ZYNQ_GEM_RXBUF_EOF_MASK) { + first_bd = &priv->rx_bd[priv->rx_first_buf]; + first_bd->addr &= ~ZYNQ_GEM_RXBUF_NEW_MASK; + first_bd->status = 0xF0000000; }
+ if ((++priv->rxbd_current) >= RX_BUF) + priv->rxbd_current = 0; + return 0; }
@@ -651,6 +662,7 @@ static const struct eth_ops zynq_gem_ops = { .start = zynq_gem_init, .send = zynq_gem_send, .recv = zynq_gem_recv, + .free_pkt = zynq_gem_free_pkt, .stop = zynq_gem_halt, .write_hwaddr = zynq_gem_setup_mac, };
Changes in v2: None
drivers/net/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6905cc02e392..e77797ab286f 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -105,6 +105,6 @@ config ZYNQ_GEM depends on DM_ETH && (ARCH_ZYNQ || ARCH_ZYNQMP) bool "Xilinx Ethernet GEM" help - This MAC is presetn in Xilinx Zynq and ZynqMP SoCs. + This MAC is present in Xilinx Zynq and ZynqMP SoCs.
endif # NETDEVICES
Clear driver dependecies via Kconfig. Remove PHYLIB dependency from the driver.
Changes in v2: - Move select MII from Kconfig back to board file because MII is not in Kconfig yet.
configs/zynq_microzed_defconfig | 1 - configs/zynq_picozed_defconfig | 1 - configs/zynq_zc702_defconfig | 1 - configs/zynq_zc706_defconfig | 1 - configs/zynq_zc770_xm010_defconfig | 1 - configs/zynq_zc770_xm011_defconfig | 1 - configs/zynq_zc770_xm012_defconfig | 1 - configs/zynq_zc770_xm013_defconfig | 1 - configs/zynq_zed_defconfig | 1 - configs/zynq_zybo_defconfig | 1 - drivers/net/Kconfig | 1 + drivers/net/zynq_gem.c | 4 ---- include/configs/xilinx_zynqmp.h | 1 - 13 files changed, 1 insertion(+), 15 deletions(-)
diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index c68efc8f41af..e577c931735e 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -15,6 +15,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHYLIB=y CONFIG_ZYNQ_GEM=y CONFIG_ZYNQ_QSPI=y diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig index 62eb79f630e3..7d52d8e941b7 100644 --- a/configs/zynq_picozed_defconfig +++ b/configs/zynq_picozed_defconfig @@ -8,5 +8,4 @@ CONFIG_SPL=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_PHYLIB=y CONFIG_ZYNQ_GEM=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 5261b73e18ba..9d1b40d76ef6 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -14,7 +14,6 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHYLIB=y CONFIG_ZYNQ_GEM=y CONFIG_DEBUG_UART=y CONFIG_DEBUG_UART_ZYNQ=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 2e525b42d42a..bba91dfdfa78 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -15,6 +15,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHYLIB=y CONFIG_ZYNQ_GEM=y CONFIG_ZYNQ_QSPI=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index 6f2ad17985e1..96f0a794a382 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -17,7 +17,6 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHYLIB=y CONFIG_ZYNQ_GEM=y CONFIG_ZYNQ_SPI=y CONFIG_ZYNQ_QSPI=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index d20b3edf5cb3..b0c535e88e19 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -12,5 +12,4 @@ CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM011" CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_PHYLIB=y CONFIG_ZYNQ_GEM=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 4e963a45e2cf..7fb03eb0491b 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -10,5 +10,4 @@ CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM012" CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_PHYLIB=y CONFIG_ZYNQ_GEM=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index f2d8f14f8784..67665127b5ba 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -12,5 +12,4 @@ CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM013" CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_PHYLIB=y CONFIG_ZYNQ_GEM=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 2e7c68d6a49e..058bb05ba658 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -15,6 +15,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHYLIB=y CONFIG_ZYNQ_GEM=y CONFIG_ZYNQ_QSPI=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 6f0bd0b79c5e..eb66b87d6bbe 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -11,7 +11,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_PHYLIB=y CONFIG_ZYNQ_GEM=y CONFIG_DEBUG_UART=y CONFIG_DEBUG_UART_ZYNQ=y diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index e77797ab286f..ae5e78dd3449 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -103,6 +103,7 @@ config PCH_GBE
config ZYNQ_GEM depends on DM_ETH && (ARCH_ZYNQ || ARCH_ZYNQMP) + select PHYLIB bool "Xilinx Ethernet GEM" help This MAC is present in Xilinx Zynq and ZynqMP SoCs. diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index f7c20dc9cd54..7059c8432a34 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -27,10 +27,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#if !defined(CONFIG_PHYLIB) -# error XILINX_GEM_ETHERNET requires PHYLIB -#endif - /* Bit/mask specification */ #define ZYNQ_GEM_PHYMNTNC_OP_MASK 0x40020000 /* operation mask bits */ #define ZYNQ_GEM_PHYMNTNC_OP_R_MASK 0x20000000 /* read operation */ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 50ac5f531c49..03f74508efea 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -188,7 +188,6 @@ # define CONFIG_NET_MULTI # define CONFIG_MII # define CONFIG_SYS_FAULT_ECHO_LINK_DOWN -# define CONFIG_PHYLIB # define CONFIG_PHY_MARVELL # define CONFIG_PHY_TI #endif
Michal Simek
