[[PATCH] colibri-imx7: move CONFIG_BOOTCOMMAND from header to defconfig
Move CONFIG_BOOTCOMMAND definition from colibri_imx7.h to colibri_imx7_defconfig, to be more flexible, for instance, it could be overridden by merge_config.sh script.
Signed-off-by: Ming Liu liu.ming50@gmail.com --- configs/colibri_imx7_defconfig | 3 ++- include/configs/colibri_imx7.h | 2 -- 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 39149167e0..03536b43f7 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -14,7 +14,8 @@ CONFIG_IMX_HAB=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_imx7/imximage.cfg,MX7D" CONFIG_BOOTDELAY=1 -# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run ubiboot; echo; echo ubiboot failed; run distro_bootcmd;" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv fdtfile ${soc}-colibri-${fdt_board}.dtb " # CONFIG_CONSOLE_MUX is not set diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 2fffaa39c0..f663865156 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -117,8 +117,6 @@ "run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \
#if defined(CONFIG_TARGET_COLIBRI_IMX7_NAND) -#define CONFIG_BOOTCOMMAND "run ubiboot ; echo ; echo ubiboot failed ; " \ - "run distro_bootcmd;" #define MODULE_EXTRA_ENV_SETTINGS \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ UBI_BOOTCMD
