[PATCH v2 00/19] i2c: designware_ic2: Improvements to timing and general cleanup
This series updates the Designware I2C driver to support reading its timing from the device tree and handling it in units of nanoseconds instead of clock cycles.
A new function converts from nanoseconds to the units used by the I2C controller and makes sure that the requested bus speed is not exceeded. This is more accurate than the existing method.
The series includes a few smaller clean-ups in the same driver.
In addition the v2 series adds enums for i2c speed and updates drivers to use them.
There is currently an existing configuration method used just for a few x86 boards (Baytrail). This method is retained but it should be removed in favour of using the device tree. I have not done this in this series since I am not sure of the timings to use.
Changes in v2: - Fix 'previde' typo - Add a few more clean-up patches for i2c
Simon Glass (19): i2c: designware_i2c: Add more registers i2c: designware_i2c: Don't allow changing IC_CLK i2c: designware_i2c: Include clk.h in the header file i2c: designware_i2c: Rename 'max' speed to 'high' speed i2c: designware_i2c: Use an enum for selected speed mode i2c: designware_i2c: Use an accurate bus clock instead of MHz i2c: designware_i2c: Bring in the binding file i2c: designware_i2c: Read device-tree properties i2c: designware_i2c: Drop scl_sda_cfg parameter i2c: designware_i2c: Put hold config in a struct i2c: designware_i2c: Rewrite timing calculation i2c: designware_i2c: Add spike supression i2c: Add enums for i2c speed and address size i2c: ast_i2c: Update to use standard enums for speed i2c: designware_i2c: Update to use standard enums for speed i2c: kona_i2c: Update to use standard enums for speed i2c: omap: Update to use standard enums for speed i2c: stm32: Update to use standard enums for speed i2c: Update drivers to use enum for speed
.../i2c/i2c-designware.txt | 73 +++++ drivers/i2c/ast_i2c.c | 2 +- drivers/i2c/ast_i2c.h | 2 - drivers/i2c/designware_i2c.c | 265 ++++++++++++++---- drivers/i2c/designware_i2c.h | 50 ++-- drivers/i2c/designware_i2c_pci.c | 4 +- drivers/i2c/exynos_hs_i2c.c | 4 +- drivers/i2c/fsl_i2c.c | 3 +- drivers/i2c/i2c-cdns.c | 2 +- drivers/i2c/i2c-uclass.c | 12 +- drivers/i2c/i2c-uniphier-f.c | 2 +- drivers/i2c/i2c-uniphier.c | 2 +- drivers/i2c/imx_lpi2c.c | 8 +- drivers/i2c/kona_i2c.c | 28 +- drivers/i2c/mv_i2c.c | 4 +- drivers/i2c/mvtwsi.c | 5 +- drivers/i2c/omap24xx_i2c.c | 5 +- drivers/i2c/omap24xx_i2c.h | 4 - drivers/i2c/rcar_i2c.c | 2 +- drivers/i2c/rcar_iic.c | 2 +- drivers/i2c/s3c24x0_i2c.c | 4 +- drivers/i2c/sandbox_i2c.c | 3 +- drivers/i2c/stm32f7_i2c.c | 43 ++- include/i2c.h | 26 ++ 24 files changed, 410 insertions(+), 145 deletions(-) create mode 100644 doc/device-tree-bindings/i2c/i2c-designware.txt
Some versions of this peripherals provide more control of the bus behaviour. Add definitions for these registers.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Ley Foon Tan ley.foon.tan@intel.com Reviewed-by: Jun Chen ptchentw@gmail.com ---
drivers/i2c/designware_i2c.h | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/i2c/designware_i2c.h b/drivers/i2c/designware_i2c.h index 48766d0806..d359c8c3f8 100644 --- a/drivers/i2c/designware_i2c.h +++ b/drivers/i2c/designware_i2c.h @@ -43,8 +43,19 @@ struct i2c_regs { u32 ic_rxflr; /* 0x78 */ u32 ic_sda_hold; /* 0x7c */ u32 ic_tx_abrt_source; /* 0x80 */ - u8 res1[0x18]; /* 0x84 */ + u32 slv_data_nak_only; + u32 dma_cr; + u32 dma_tdlr; + u32 dma_rdlr; + u32 sda_setup; + u32 ack_general_call; u32 ic_enable_status; /* 0x9c */ + u32 fs_spklen; + u32 hs_spklen; + u32 clr_restart_det; + u32 comp_param1; + u32 comp_version; + u32 comp_type; };
#if !defined(IC_CLK)
Hi, There is a gap from "clr_restart_det" 0xa8 to "comp_param1" 0xf4, you should reserve a space for them.
Best regards, Jun Chen Simon Glass sjg@chromium.org 於 2020年1月4日 週六 上午6:27寫道:
Changes in v2:
u32 dma_cr;
u32 dma_tdlr;
u32 dma_rdlr;
u32 sda_setup;
u32 fs_spklen;
u32 hs_spklen;
There is a gap here.
u32 comp_param1;
u32 comp_version;
u32 comp_type;
2.24.1.735.g03f4e72817-goog
Hello Simon,
Am 03.01.2020 um 23:26 schrieb Simon Glass:
Changes in v2:
Fix 'previde' typo
please add the gap Jun Chen reported, beside of this:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
If a different input clock is required then the correct way to do this is with a clock driver. Don't allow boards to override IC_CLK.
Changes in v2: None
drivers/i2c/designware_i2c.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/drivers/i2c/designware_i2c.h b/drivers/i2c/designware_i2c.h index d359c8c3f8..0eb28191d2 100644 --- a/drivers/i2c/designware_i2c.h +++ b/drivers/i2c/designware_i2c.h @@ -58,9 +58,7 @@ struct i2c_regs { u32 comp_type; };
-#if !defined(IC_CLK) #define IC_CLK 166 -#endif #define NANO_TO_MICRO 1000
/* High and low times in different speed modes (in ns) */
Hello Simon,
Changes in v2: None
bye, Heiko
We use struct clk here so really should include this header file to avoid build errors. Also switch the order of clk.h in the C file to match the required code style.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Ley Foon Tan ley.foon.tan@intel.com ---
Changes in v2: None
drivers/i2c/designware_i2c.c | 2 +- drivers/i2c/designware_i2c.h | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index b8cdd1c661..138fc72561 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -4,8 +4,8 @@ * Vipin Kumar, ST Micoelectronics, vipin.kumar@st.com. */
-#include <clk.h> #include <common.h> +#include <clk.h> #include <dm.h> #include <i2c.h> #include <pci.h> diff --git a/drivers/i2c/designware_i2c.h b/drivers/i2c/designware_i2c.h index 0eb28191d2..39e62bcf51 100644 --- a/drivers/i2c/designware_i2c.h +++ b/drivers/i2c/designware_i2c.h @@ -7,6 +7,7 @@ #ifndef __DW_I2C_H_ #define __DW_I2C_H_
+#include <clk.h> #include <reset.h>
struct i2c_regs {
Changes in v2: None
- Vipin Kumar, ST Micoelectronics, vipin.kumar@st.com.
struct i2c_regs {
Hello Simon,
Changes in v2: None
bye, Heiko
Some SoCs support a higher speed than what is currently called 'max' in this driver. Rename it to 'high' speed, which is the official name of the 3.4MHz speed.
Changes in v2: None
drivers/i2c/designware_i2c.c | 10 +++++----- drivers/i2c/designware_i2c.h | 8 ++++---- 2 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index 138fc72561..dd1cc0b823 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -62,10 +62,10 @@ static unsigned int __dw_i2c_set_bus_speed(struct i2c_regs *i2c_base, unsigned int ena; int i2c_spd;
- /* Allow max speed if there is no config, or the config allows it */ - if (speed >= I2C_MAX_SPEED && - (!scl_sda_cfg || scl_sda_cfg->has_max_speed)) - i2c_spd = IC_SPEED_MODE_MAX; + /* Allow high speed if there is no config, or the config allows it */ + if (speed >= I2C_HIGH_SPEED && + (!scl_sda_cfg || scl_sda_cfg->has_high_speed)) + i2c_spd = IC_SPEED_MODE_HIGH; else if (speed >= I2C_FAST_SPEED) i2c_spd = IC_SPEED_MODE_FAST; else @@ -80,7 +80,7 @@ static unsigned int __dw_i2c_set_bus_speed(struct i2c_regs *i2c_base, cntl = (readl(&i2c_base->ic_con) & (~IC_CON_SPD_MSK));
switch (i2c_spd) { - case IC_SPEED_MODE_MAX: + case IC_SPEED_MODE_HIGH: cntl |= IC_CON_SPD_SS; if (scl_sda_cfg) { hcnt = scl_sda_cfg->fs_hcnt; diff --git a/drivers/i2c/designware_i2c.h b/drivers/i2c/designware_i2c.h index 39e62bcf51..fcb7dde83a 100644 --- a/drivers/i2c/designware_i2c.h +++ b/drivers/i2c/designware_i2c.h @@ -137,16 +137,16 @@ struct i2c_regs { /* Speed Selection */ #define IC_SPEED_MODE_STANDARD 1 #define IC_SPEED_MODE_FAST 2 -#define IC_SPEED_MODE_MAX 3 +#define IC_SPEED_MODE_HIGH 3
-#define I2C_MAX_SPEED 3400000 +#define I2C_HIGH_SPEED 3400000 #define I2C_FAST_SPEED 400000 #define I2C_STANDARD_SPEED 100000
/** * struct dw_scl_sda_cfg - I2C timing configuration * - * @has_max_speed: Support maximum speed (1Mbps) + * @has_high_speed: Support high speed (3.4Mbps) * @ss_hcnt: Standard speed high time in ns * @fs_hcnt: Fast speed high time in ns * @ss_lcnt: Standard speed low time in ns @@ -154,7 +154,7 @@ struct i2c_regs { * @sda_hold: SDA hold time */ struct dw_scl_sda_cfg { - bool has_max_speed; + bool has_high_speed; u32 ss_hcnt; u32 fs_hcnt; u32 ss_lcnt;
Changes in v2: None
switch (i2c_spd) {
- struct dw_scl_sda_cfg - I2C timing configuration
- @has_max_speed: Support maximum speed (1Mbps)
- @has_high_speed: Support high speed (3.4Mbps)
- @ss_hcnt: Standard speed high time in ns
- @fs_hcnt: Fast speed high time in ns
- @ss_lcnt: Standard speed low time in ns
- @sda_hold: SDA hold time
bool has_max_speed;
-- 2.24.1.735.g03f4e72817-goog
Hello Simon,
Changes in v2: None
bye, Heiko
Group these #defines into an enum to make it easier to understand the relationship between them.
Changes in v2: None
drivers/i2c/designware_i2c.c | 2 +- drivers/i2c/designware_i2c.h | 10 +++++++--- 2 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index dd1cc0b823..2416ef32f9 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -57,10 +57,10 @@ static unsigned int __dw_i2c_set_bus_speed(struct i2c_regs *i2c_base, unsigned int speed, unsigned int bus_mhz) { + enum i2c_speed_mode i2c_spd; unsigned int cntl; unsigned int hcnt, lcnt; unsigned int ena; - int i2c_spd;
/* Allow high speed if there is no config, or the config allows it */ if (speed >= I2C_HIGH_SPEED && diff --git a/drivers/i2c/designware_i2c.h b/drivers/i2c/designware_i2c.h index fcb7dde83a..06d794ca64 100644 --- a/drivers/i2c/designware_i2c.h +++ b/drivers/i2c/designware_i2c.h @@ -135,9 +135,13 @@ struct i2c_regs { #define IC_STATUS_ACT 0x0001
/* Speed Selection */ -#define IC_SPEED_MODE_STANDARD 1 -#define IC_SPEED_MODE_FAST 2 -#define IC_SPEED_MODE_HIGH 3 +enum i2c_speed_mode { + IC_SPEED_MODE_STANDARD, + IC_SPEED_MODE_FAST, + IC_SPEED_MODE_HIGH, + + IC_SPEED_MODE_COUNT, +};
Changes in v2: None
int i2c_spd; /* Allow high speed if there is no config, or the config allows it
IC_SPEED_MODE_FAST,
IC_SPEED_MODE_HIGH,
Hello Simon,
Changes in v2: None
bye, Heiko
At present the driver uses an approximation for the bus clock, e.g. 166MHz instead of 166 2/3 MHz.
This can result in small errors in the resulting I2C speed, perhaps 0.5% or so.
Adjust the existing code to start from the accurate figure, even if later rounding reduces this accuracy.
Update the bus speed code to work in KHz instead of MHz, which removes most of the error.
Changes in v2: None
drivers/i2c/designware_i2c.c | 18 ++++++++---------- drivers/i2c/designware_i2c.h | 4 ++-- 2 files changed, 10 insertions(+), 12 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index 2416ef32f9..0a1df8015f 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -55,8 +55,9 @@ static int dw_i2c_enable(struct i2c_regs *i2c_base, bool enable) static unsigned int __dw_i2c_set_bus_speed(struct i2c_regs *i2c_base, struct dw_scl_sda_cfg *scl_sda_cfg, unsigned int speed, - unsigned int bus_mhz) + unsigned int bus_clk) { + ulong bus_khz = bus_clk / 1000; enum i2c_speed_mode i2c_spd; unsigned int cntl; unsigned int hcnt, lcnt; @@ -86,8 +87,8 @@ static unsigned int __dw_i2c_set_bus_speed(struct i2c_regs *i2c_base, hcnt = scl_sda_cfg->fs_hcnt; lcnt = scl_sda_cfg->fs_lcnt; } else { - hcnt = (bus_mhz * MIN_HS_SCL_HIGHTIME) / NANO_TO_MICRO; - lcnt = (bus_mhz * MIN_HS_SCL_LOWTIME) / NANO_TO_MICRO; + hcnt = (bus_khz * MIN_HS_SCL_HIGHTIME) / NANO_TO_KILO; + lcnt = (bus_khz * MIN_HS_SCL_LOWTIME) / NANO_TO_KILO; } writel(hcnt, &i2c_base->ic_hs_scl_hcnt); writel(lcnt, &i2c_base->ic_hs_scl_lcnt); @@ -99,8 +100,8 @@ static unsigned int __dw_i2c_set_bus_speed(struct i2c_regs *i2c_base, hcnt = scl_sda_cfg->ss_hcnt; lcnt = scl_sda_cfg->ss_lcnt; } else { - hcnt = (bus_mhz * MIN_SS_SCL_HIGHTIME) / NANO_TO_MICRO; - lcnt = (bus_mhz * MIN_SS_SCL_LOWTIME) / NANO_TO_MICRO; + hcnt = (bus_khz * MIN_SS_SCL_HIGHTIME) / NANO_TO_KILO; + lcnt = (bus_khz * MIN_SS_SCL_LOWTIME) / NANO_TO_KILO; } writel(hcnt, &i2c_base->ic_ss_scl_hcnt); writel(lcnt, &i2c_base->ic_ss_scl_lcnt); @@ -113,8 +114,8 @@ static unsigned int __dw_i2c_set_bus_speed(struct i2c_regs *i2c_base, hcnt = scl_sda_cfg->fs_hcnt; lcnt = scl_sda_cfg->fs_lcnt; } else { - hcnt = (bus_mhz * MIN_FS_SCL_HIGHTIME) / NANO_TO_MICRO; - lcnt = (bus_mhz * MIN_FS_SCL_LOWTIME) / NANO_TO_MICRO; + hcnt = (bus_khz * MIN_FS_SCL_HIGHTIME) / NANO_TO_KILO; + lcnt = (bus_khz * MIN_FS_SCL_LOWTIME) / NANO_TO_KILO; } writel(hcnt, &i2c_base->ic_fs_scl_hcnt); writel(lcnt, &i2c_base->ic_fs_scl_lcnt); @@ -511,9 +512,6 @@ static int designware_i2c_set_bus_speed(struct udevice *bus, unsigned int speed) rate = clk_get_rate(&i2c->clk); if (IS_ERR_VALUE(rate)) return -EINVAL; - - /* Convert to MHz */ - rate /= 1000000; #else rate = IC_CLK; #endif diff --git a/drivers/i2c/designware_i2c.h b/drivers/i2c/designware_i2c.h index 06d794ca64..1f9940c2ba 100644 --- a/drivers/i2c/designware_i2c.h +++ b/drivers/i2c/designware_i2c.h @@ -59,8 +59,8 @@ struct i2c_regs { u32 comp_type; };
-#define IC_CLK 166 -#define NANO_TO_MICRO 1000 +#define IC_CLK 166666666 +#define NANO_TO_KILO 1000000
/* High and low times in different speed modes (in ns) */ #define MIN_SS_SCL_HIGHTIME 4000
Hello Simon,
Changes in v2: None
bye, Heiko
Bring in this file from Linux v5.4.
Changes in v2: None
.../i2c/i2c-designware.txt | 73 +++++++++++++++++++ 1 file changed, 73 insertions(+) create mode 100644 doc/device-tree-bindings/i2c/i2c-designware.txt
diff --git a/doc/device-tree-bindings/i2c/i2c-designware.txt b/doc/device-tree-bindings/i2c/i2c-designware.txt new file mode 100644 index 0000000000..be766be812 --- /dev/null +++ b/doc/device-tree-bindings/i2c/i2c-designware.txt @@ -0,0 +1,73 @@ +* Synopsys DesignWare I2C + +Required properties : + + - compatible : should be "snps,designware-i2c" + or "mscc,ocelot-i2c" with "snps,designware-i2c" for fallback + - reg : Offset and length of the register set for the device + - interrupts : <IRQ> where IRQ is the interrupt number. + - clocks : phandles for the clocks, see the description of clock-names below. + The phandle for the "ic_clk" clock is required. The phandle for the "pclk" + clock is optional. If a single clock is specified but no clock-name, it is + the "ic_clk" clock. If both clocks are listed, the "ic_clk" must be first. + +Recommended properties : + + - clock-frequency : desired I2C bus clock frequency in Hz. + +Optional properties : + + - clock-names : Contains the names of the clocks: + "ic_clk", for the core clock used to generate the external I2C clock. + "pclk", the interface clock, required for register access. + + - reg : for "mscc,ocelot-i2c", a second register set to configure the SDA hold + time, named ICPU_CFG:TWI_DELAY in the datasheet. + + - i2c-sda-hold-time-ns : should contain the SDA hold time in nanoseconds. + This option is only supported in hardware blocks version 1.11a or newer and + on Microsemi SoCs ("mscc,ocelot-i2c" compatible). + + - i2c-scl-falling-time-ns : should contain the SCL falling time in nanoseconds. + This value which is by default 300ns is used to compute the tLOW period. + + - i2c-sda-falling-time-ns : should contain the SDA falling time in nanoseconds. + This value which is by default 300ns is used to compute the tHIGH period. + +Examples : + + i2c@f0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0xf0000 0x1000>; + interrupts = <11>; + clock-frequency = <400000>; + }; + + i2c@1120000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,designware-i2c"; + reg = <0x1120000 0x1000>; + interrupt-parent = <&ictl>; + interrupts = <12 1>; + clock-frequency = <400000>; + i2c-sda-hold-time-ns = <300>; + i2c-sda-falling-time-ns = <300>; + i2c-scl-falling-time-ns = <300>; + };x + + i2c@1120000 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x2000 0x100>; + clock-frequency = <400000>; + clocks = <&i2cclk>; + interrupts = <0>; + + eeprom@64 { + compatible = "linux,slave-24c02"; + reg = <0x40000064>; + }; + };
Hello Simon,
may you can add here the commit ID ? Or is it from tag "v5.4" ?
Changes in v2: None
bye, Heiko
The i2c controller defines a few timing properties. Read these in and store them for use by the driver.
Changes in v2: None
drivers/i2c/designware_i2c.c | 8 ++++++-- drivers/i2c/designware_i2c.h | 15 +++++++++++++++ drivers/i2c/designware_i2c_pci.c | 2 +- 3 files changed, 22 insertions(+), 3 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index 0a1df8015f..34b6816545 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -535,11 +535,15 @@ static int designware_i2c_probe_chip(struct udevice *bus, uint chip_addr, return ret; }
-static int designware_i2c_ofdata_to_platdata(struct udevice *bus) +int designware_i2c_ofdata_to_platdata(struct udevice *bus) { struct dw_i2c *priv = dev_get_priv(bus);
- priv->regs = (struct i2c_regs *)devfdt_get_addr_ptr(bus); + if (!priv->regs) + priv->regs = (struct i2c_regs *)devfdt_get_addr_ptr(bus); + dev_read_u32(bus, "i2c-scl-rising-time-ns", &priv->scl_rise_time_ns); + dev_read_u32(bus, "i2c-scl-falling-time-ns", &priv->scl_fall_time_ns); + dev_read_u32(bus, "i2c-sda-hold-time-ns", &priv->sda_hold_time_ns);
return 0; } diff --git a/drivers/i2c/designware_i2c.h b/drivers/i2c/designware_i2c.h index 1f9940c2ba..55e440f0c0 100644 --- a/drivers/i2c/designware_i2c.h +++ b/drivers/i2c/designware_i2c.h @@ -166,10 +166,24 @@ struct dw_scl_sda_cfg { u32 sda_hold; };
+/** + * struct dw_i2c - private information for the bus + * + * @regs: Registers pointer + * @scl_sda_cfg: Deprecated information for x86 (should move to device tree) + * @resets: Resets for the I2C controller + * @scl_rise_time_ns: Configured SCL rise time in nanoseconds + * @scl_fall_time_ns: Configured SCL fall time in nanoseconds + * @sda_hold_time_ns: Configured SDA hold time in nanoseconds + * @clk: Clock input to the I2C controller + */ struct dw_i2c { struct i2c_regs *regs; struct dw_scl_sda_cfg *scl_sda_cfg; struct reset_ctl_bulk resets; + u32 scl_rise_time_ns; + u32 scl_fall_time_ns; + u32 sda_hold_time_ns; #if CONFIG_IS_ENABLED(CLK) struct clk clk; #endif @@ -179,5 +193,6 @@ extern const struct dm_i2c_ops designware_i2c_ops;
int designware_i2c_probe(struct udevice *bus); int designware_i2c_remove(struct udevice *dev); +int designware_i2c_ofdata_to_platdata(struct udevice *bus);
#endif /* __DW_I2C_H_ */ diff --git a/drivers/i2c/designware_i2c_pci.c b/drivers/i2c/designware_i2c_pci.c index 7f0625df66..2b974a07c3 100644 --- a/drivers/i2c/designware_i2c_pci.c +++ b/drivers/i2c/designware_i2c_pci.c @@ -63,7 +63,7 @@ static int designware_i2c_pci_ofdata_to_platdata(struct udevice *dev) /* Use BayTrail specific timing values */ priv->scl_sda_cfg = &byt_config;
- return 0; + return designware_i2c_ofdata_to_platdata(dev); }
static int designware_i2c_pci_probe(struct udevice *dev)
Hello Simon,
Changes in v2: None
bye, Heiko
Instead of passing this parameter into __dw_i2c_set_bus_speed(), pass in the driver's private data, from which the function can obtain that information. This allows the function to have access to the full state of the driver.
Changes in v2: None
drivers/i2c/designware_i2c.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index 34b6816545..6e5545cd0c 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -52,17 +52,20 @@ static int dw_i2c_enable(struct i2c_regs *i2c_base, bool enable) * * Set the i2c speed. */ -static unsigned int __dw_i2c_set_bus_speed(struct i2c_regs *i2c_base, - struct dw_scl_sda_cfg *scl_sda_cfg, +static unsigned int __dw_i2c_set_bus_speed(struct dw_i2c *priv, + struct i2c_regs *i2c_base, unsigned int speed, unsigned int bus_clk) { + const struct dw_scl_sda_cfg *scl_sda_cfg = NULL; ulong bus_khz = bus_clk / 1000; enum i2c_speed_mode i2c_spd; unsigned int cntl; unsigned int hcnt, lcnt; unsigned int ena;
+ if (priv) + scl_sda_cfg = priv->scl_sda_cfg; /* Allow high speed if there is no config, or the config allows it */ if (speed >= I2C_HIGH_SPEED && (!scl_sda_cfg || scl_sda_cfg->has_high_speed)) @@ -371,7 +374,7 @@ static int __dw_i2c_init(struct i2c_regs *i2c_base, int speed, int slaveaddr) writel(IC_TX_TL, &i2c_base->ic_tx_tl); writel(IC_STOP_DET, &i2c_base->ic_intr_mask); #ifndef CONFIG_DM_I2C - __dw_i2c_set_bus_speed(i2c_base, NULL, speed, IC_CLK); + __dw_i2c_set_bus_speed(NULL, i2c_base, speed, IC_CLK); writel(slaveaddr, &i2c_base->ic_sar); #endif
@@ -416,7 +419,7 @@ static unsigned int dw_i2c_set_bus_speed(struct i2c_adapter *adap, unsigned int speed) { adap->speed = speed; - return __dw_i2c_set_bus_speed(i2c_get_base(adap), NULL, speed, IC_CLK); + return __dw_i2c_set_bus_speed(NULL, i2c_get_base(adap), speed, IC_CLK); }
static void dw_i2c_init(struct i2c_adapter *adap, int speed, int slaveaddr) @@ -515,8 +518,7 @@ static int designware_i2c_set_bus_speed(struct udevice *bus, unsigned int speed) #else rate = IC_CLK; #endif - return __dw_i2c_set_bus_speed(i2c->regs, i2c->scl_sda_cfg, speed, - rate); + return __dw_i2c_set_bus_speed(i2c, i2c->regs, speed, rate); }
Hello Simon,
Changes in v2: None
bye, Heiko
Create a struct to hold the three timing parameters. This will make it easier to move these calculations into a separate function in a later patch.
Changes in v2: None
drivers/i2c/designware_i2c.c | 82 ++++++++++++++++++++++++------------ 1 file changed, 55 insertions(+), 27 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index 6e5545cd0c..e50987a717 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -13,6 +13,23 @@ #include <asm/io.h> #include "designware_i2c.h"
+/** + * struct dw_i2c_speed_config - timings to use for a particular speed + * + * This holds calculated values to be written to the I2C controller. Each value + * is represented as a number of IC clock cycles. + * + * @scl_lcnt: Low count value for SCL + * @scl_hcnt: High count value for SCL + * @sda_hold: Data hold count + */ +struct dw_i2c_speed_config { + /* SCL high and low period count */ + uint scl_lcnt; + uint scl_hcnt; + uint sda_hold; +}; + #ifdef CONFIG_SYS_I2C_DW_ENABLE_STATUS_UNSUPPORTED static int dw_i2c_enable(struct i2c_regs *i2c_base, bool enable) { @@ -58,10 +75,10 @@ static unsigned int __dw_i2c_set_bus_speed(struct dw_i2c *priv, unsigned int bus_clk) { const struct dw_scl_sda_cfg *scl_sda_cfg = NULL; + struct dw_i2c_speed_config config; ulong bus_khz = bus_clk / 1000; enum i2c_speed_mode i2c_spd; unsigned int cntl; - unsigned int hcnt, lcnt; unsigned int ena;
if (priv) @@ -83,53 +100,64 @@ static unsigned int __dw_i2c_set_bus_speed(struct dw_i2c *priv,
+ config.scl_hcnt = 0; + config.scl_lcnt = 0; + config.sda_hold = 0; + if (scl_sda_cfg) { + config.sda_hold = scl_sda_cfg->sda_hold; + if (i2c_spd == IC_SPEED_MODE_STANDARD) { + config.scl_hcnt = scl_sda_cfg->ss_hcnt; + config.scl_lcnt = scl_sda_cfg->ss_lcnt; + } else { + config.scl_hcnt = scl_sda_cfg->fs_hcnt; + config.scl_lcnt = scl_sda_cfg->fs_lcnt; + } + } + switch (i2c_spd) { case IC_SPEED_MODE_HIGH: cntl |= IC_CON_SPD_SS; - if (scl_sda_cfg) { - hcnt = scl_sda_cfg->fs_hcnt; - lcnt = scl_sda_cfg->fs_lcnt; - } else { - hcnt = (bus_khz * MIN_HS_SCL_HIGHTIME) / NANO_TO_KILO; - lcnt = (bus_khz * MIN_HS_SCL_LOWTIME) / NANO_TO_KILO; + if (!scl_sda_cfg) { + config.scl_hcnt = (bus_khz * MIN_HS_SCL_HIGHTIME) / + NANO_TO_KILO; + config.scl_lcnt = (bus_khz * MIN_HS_SCL_LOWTIME) / + NANO_TO_KILO; } - writel(hcnt, &i2c_base->ic_hs_scl_hcnt); - writel(lcnt, &i2c_base->ic_hs_scl_lcnt); + writel(config.scl_hcnt, &i2c_base->ic_hs_scl_hcnt); + writel(config.scl_lcnt, &i2c_base->ic_hs_scl_lcnt); break;
case IC_SPEED_MODE_STANDARD: cntl |= IC_CON_SPD_SS; - if (scl_sda_cfg) { - hcnt = scl_sda_cfg->ss_hcnt; - lcnt = scl_sda_cfg->ss_lcnt; - } else { - hcnt = (bus_khz * MIN_SS_SCL_HIGHTIME) / NANO_TO_KILO; - lcnt = (bus_khz * MIN_SS_SCL_LOWTIME) / NANO_TO_KILO; + if (!scl_sda_cfg) { + config.scl_hcnt = (bus_khz * MIN_SS_SCL_HIGHTIME) / + NANO_TO_KILO; + config.scl_lcnt = (bus_khz * MIN_SS_SCL_LOWTIME) / + NANO_TO_KILO; } - writel(hcnt, &i2c_base->ic_ss_scl_hcnt); - writel(lcnt, &i2c_base->ic_ss_scl_lcnt); + writel(config.scl_hcnt, &i2c_base->ic_ss_scl_hcnt); + writel(config.scl_lcnt, &i2c_base->ic_ss_scl_lcnt); break;
case IC_SPEED_MODE_FAST: default: cntl |= IC_CON_SPD_FS; - if (scl_sda_cfg) { - hcnt = scl_sda_cfg->fs_hcnt; - lcnt = scl_sda_cfg->fs_lcnt; - } else { - hcnt = (bus_khz * MIN_FS_SCL_HIGHTIME) / NANO_TO_KILO; - lcnt = (bus_khz * MIN_FS_SCL_LOWTIME) / NANO_TO_KILO; + if (!scl_sda_cfg) { + config.scl_hcnt = (bus_khz * MIN_FS_SCL_HIGHTIME) / + NANO_TO_KILO; + config.scl_lcnt = (bus_khz * MIN_FS_SCL_LOWTIME) / + NANO_TO_KILO; } - writel(hcnt, &i2c_base->ic_fs_scl_hcnt); - writel(lcnt, &i2c_base->ic_fs_scl_lcnt); + writel(config.scl_hcnt, &i2c_base->ic_fs_scl_hcnt); + writel(config.scl_lcnt, &i2c_base->ic_fs_scl_lcnt); break; }
writel(cntl, &i2c_base->ic_con);
/* Configure SDA Hold Time if required */ - if (scl_sda_cfg) - writel(scl_sda_cfg->sda_hold, &i2c_base->ic_sda_hold); + if (config.sda_hold) + writel(config.sda_hold, &i2c_base->ic_sda_hold);
/* Restore back i2c now speed set */ if (ena == IC_ENABLE_0B)
Hello Simon,
Changes in v2: None
bye, Heiko
At present the driver can end up with timing parameters which are slightly faster than those expected. It is possible to optimise the parameters to get the best possible result.
Create a new function to handle the timing calculation. This uses a table of defaults for each speed mode rather than writing it in code.
The function works by calculating the 'period' of each bit on the bus in terms of the input clock to the controller (IC_CLK). It makes sure that the constraints are met and that the different components of that period add up correctly.
This code was taken from coreboot which has ended up with this same driver, but now in a much-different form.
Changes in v2: None
drivers/i2c/designware_i2c.c | 169 ++++++++++++++++++++++++++++++----- 1 file changed, 147 insertions(+), 22 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index e50987a717..0069602103 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -63,6 +63,147 @@ static int dw_i2c_enable(struct i2c_regs *i2c_base, bool enable) } #endif
+/* High and low times in different speed modes (in ns) */ +enum { + /* SDA Hold Time */ + DEFAULT_SDA_HOLD_TIME = 300, +}; + +/** + * calc_counts() - Convert a period to a number of IC clk cycles + * + * @ic_clk: Input clock in Hz + * @period_ns: Period to represent, in ns + * @return calculated count + */ +static uint calc_counts(uint ic_clk, uint period_ns) +{ + return DIV_ROUND_UP(ic_clk / 1000 * period_ns, NANO_TO_KILO); +} + +/** + * struct i2c_mode_info - Information about an I2C speed mode + * + * Each speed mode has its own characteristics. This struct holds these to aid + * calculations in dw_i2c_calc_timing(). + * + * @speed: Speed in Hz + * @min_scl_lowtime_ns: Minimum value for SCL low period in ns + * @min_scl_hightime_ns: Minimum value for SCL high period in ns + * @def_rise_time_ns: Default rise time in ns + * @def_fall_time_ns: Default fall time in ns + */ +struct i2c_mode_info { + int speed; + int min_scl_hightime_ns; + int min_scl_lowtime_ns; + int def_rise_time_ns; + int def_fall_time_ns; +}; + +static const struct i2c_mode_info info_for_mode[] = { + [IC_SPEED_MODE_STANDARD] = { + I2C_STANDARD_SPEED, + MIN_SS_SCL_HIGHTIME, + MIN_SS_SCL_LOWTIME, + 1000, + 300, + }, + [IC_SPEED_MODE_FAST] = { + I2C_FAST_SPEED, + MIN_FS_SCL_HIGHTIME, + MIN_FS_SCL_LOWTIME, + 300, + 300, + }, + [IC_SPEED_MODE_HIGH] = { + I2C_HIGH_SPEED, + MIN_HS_SCL_HIGHTIME, + MIN_HS_SCL_LOWTIME, + 120, + 120, + }, +}; + +/** + * dw_i2c_calc_timing() - Calculate the timings to use for a bus + * + * @priv: Bus private information (NULL if not using driver model) + * @mode: Speed mode to use + * @ic_clk: IC clock speed in Hz + * @spk_cnt: Spike-suppression count + * @config: Returns value to use + * @return 0 if OK, -EINVAL if the calculation failed due to invalid data + */ +static int dw_i2c_calc_timing(struct dw_i2c *priv, enum i2c_speed_mode mode, + int ic_clk, int spk_cnt, + struct dw_i2c_speed_config *config) +{ + int fall_cnt, rise_cnt, min_tlow_cnt, min_thigh_cnt; + int hcnt, lcnt, period_cnt, diff, tot; + int sda_hold_time_ns, scl_rise_time_ns, scl_fall_time_ns; + const struct i2c_mode_info *info; + + /* + * Find the period, rise, fall, min tlow, and min thigh in terms of + * counts of the IC clock + */ + info = &info_for_mode[mode]; + period_cnt = ic_clk / info->speed; + scl_rise_time_ns = priv && priv->scl_rise_time_ns ? + priv->scl_rise_time_ns : info->def_rise_time_ns; + scl_fall_time_ns = priv && priv->scl_fall_time_ns ? + priv->scl_fall_time_ns : info->def_fall_time_ns; + rise_cnt = calc_counts(ic_clk, scl_rise_time_ns); + fall_cnt = calc_counts(ic_clk, scl_fall_time_ns); + min_tlow_cnt = calc_counts(ic_clk, info->min_scl_lowtime_ns); + min_thigh_cnt = calc_counts(ic_clk, info->min_scl_hightime_ns); + + debug("dw_i2c: period %d rise %d fall %d tlow %d thigh %d spk %d\n", + period_cnt, rise_cnt, fall_cnt, min_tlow_cnt, min_thigh_cnt, + spk_cnt); + + /* + * Back-solve for hcnt and lcnt according to the following equations: + * SCL_High_time = [(HCNT + IC_*_SPKLEN + 7) * ic_clk] + SCL_Fall_time + * SCL_Low_time = [(LCNT + 1) * ic_clk] - SCL_Fall_time + SCL_Rise_time + */ + hcnt = min_thigh_cnt - fall_cnt - 7 - spk_cnt; + lcnt = min_tlow_cnt - rise_cnt + fall_cnt - 1; + + if (hcnt < 0 || lcnt < 0) { + debug("dw_i2c: bad counts. hcnt = %d lcnt = %d\n", hcnt, lcnt); + return -EINVAL; + } + + /* + * Now add things back up to ensure the period is hit. If it is off, + * split the difference and bias to lcnt for remainder + */ + tot = hcnt + lcnt + 7 + spk_cnt + rise_cnt + 1; + + if (tot < period_cnt) { + diff = (period_cnt - tot) / 2; + hcnt += diff; + lcnt += diff; + tot = hcnt + lcnt + 7 + spk_cnt + rise_cnt + 1; + lcnt += period_cnt - tot; + } + + config->scl_lcnt = lcnt; + config->scl_hcnt = hcnt; + + /* Use internal default unless other value is specified */ + sda_hold_time_ns = priv && priv->sda_hold_time_ns ? + priv->sda_hold_time_ns : DEFAULT_SDA_HOLD_TIME; + config->sda_hold = calc_counts(ic_clk, sda_hold_time_ns); + + debug("dw_i2c: hcnt = %d lcnt = %d sda hold = %d\n", hcnt, lcnt, + config->sda_hold); + + return 0; +} + /* * i2c_set_bus_speed - Set the i2c speed * @speed: required i2c speed @@ -76,10 +217,10 @@ static unsigned int __dw_i2c_set_bus_speed(struct dw_i2c *priv, { const struct dw_scl_sda_cfg *scl_sda_cfg = NULL; struct dw_i2c_speed_config config; - ulong bus_khz = bus_clk / 1000; enum i2c_speed_mode i2c_spd; unsigned int cntl; unsigned int ena; + int ret;
if (priv) scl_sda_cfg = priv->scl_sda_cfg; @@ -100,9 +241,6 @@ static unsigned int __dw_i2c_set_bus_speed(struct dw_i2c *priv,
- config.scl_hcnt = 0; - config.scl_lcnt = 0; - config.sda_hold = 0; if (scl_sda_cfg) { config.sda_hold = scl_sda_cfg->sda_hold; if (i2c_spd == IC_SPEED_MODE_STANDARD) { @@ -112,29 +250,22 @@ static unsigned int __dw_i2c_set_bus_speed(struct dw_i2c *priv, config.scl_hcnt = scl_sda_cfg->fs_hcnt; config.scl_lcnt = scl_sda_cfg->fs_lcnt; } + } else { + ret = dw_i2c_calc_timing(priv, i2c_spd, bus_clk, 0, + &config); + if (ret) + return log_msg_ret("gen_confg", ret); }
switch (i2c_spd) { case IC_SPEED_MODE_HIGH: cntl |= IC_CON_SPD_SS; - if (!scl_sda_cfg) { - config.scl_hcnt = (bus_khz * MIN_HS_SCL_HIGHTIME) / - NANO_TO_KILO; - config.scl_lcnt = (bus_khz * MIN_HS_SCL_LOWTIME) / - NANO_TO_KILO; - } writel(config.scl_hcnt, &i2c_base->ic_hs_scl_hcnt); writel(config.scl_lcnt, &i2c_base->ic_hs_scl_lcnt); break;
case IC_SPEED_MODE_STANDARD: cntl |= IC_CON_SPD_SS; - if (!scl_sda_cfg) { - config.scl_hcnt = (bus_khz * MIN_SS_SCL_HIGHTIME) / - NANO_TO_KILO; - config.scl_lcnt = (bus_khz * MIN_SS_SCL_LOWTIME) / - NANO_TO_KILO; - } writel(config.scl_hcnt, &i2c_base->ic_ss_scl_hcnt); writel(config.scl_lcnt, &i2c_base->ic_ss_scl_lcnt); break; @@ -142,12 +273,6 @@ static unsigned int __dw_i2c_set_bus_speed(struct dw_i2c *priv, case IC_SPEED_MODE_FAST: default: cntl |= IC_CON_SPD_FS; - if (!scl_sda_cfg) { - config.scl_hcnt = (bus_khz * MIN_FS_SCL_HIGHTIME) / - NANO_TO_KILO; - config.scl_lcnt = (bus_khz * MIN_FS_SCL_LOWTIME) / - NANO_TO_KILO; - } writel(config.scl_hcnt, &i2c_base->ic_fs_scl_hcnt); writel(config.scl_lcnt, &i2c_base->ic_fs_scl_lcnt); break;
Hello Simon,
Changes in v2: None
bye, Heiko
Some versions of this peripheral include a spike-suppression phase of the bus. Add support for this.
Changes in v2: - Add a few more clean-up patches for i2c
drivers/i2c/designware_i2c.c | 10 +++++++++- drivers/i2c/designware_i2c.h | 2 ++ drivers/i2c/designware_i2c_pci.c | 2 ++ 3 files changed, 13 insertions(+), 1 deletion(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index 0069602103..4aee25c543 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -220,6 +220,7 @@ static unsigned int __dw_i2c_set_bus_speed(struct dw_i2c *priv, enum i2c_speed_mode i2c_spd; unsigned int cntl; unsigned int ena; + int spk_cnt; int ret;
if (priv) @@ -241,6 +242,13 @@ static unsigned int __dw_i2c_set_bus_speed(struct dw_i2c *priv,
+ /* Get the proper spike-suppression count based on target speed */ + if (!priv || !priv->has_spk_cnt) + spk_cnt = 0; + else if (i2c_spd >= IC_SPEED_MODE_HIGH) + spk_cnt = readl(&i2c_base->hs_spklen); + else + spk_cnt = readl(&i2c_base->fs_spklen); if (scl_sda_cfg) { config.sda_hold = scl_sda_cfg->sda_hold; if (i2c_spd == IC_SPEED_MODE_STANDARD) { @@ -251,7 +259,7 @@ static unsigned int __dw_i2c_set_bus_speed(struct dw_i2c *priv, config.scl_lcnt = scl_sda_cfg->fs_lcnt; } } else { - ret = dw_i2c_calc_timing(priv, i2c_spd, bus_clk, 0, + ret = dw_i2c_calc_timing(priv, i2c_spd, bus_clk, spk_cnt, &config); if (ret) return log_msg_ret("gen_confg", ret); diff --git a/drivers/i2c/designware_i2c.h b/drivers/i2c/designware_i2c.h index 55e440f0c0..2c572a9e1f 100644 --- a/drivers/i2c/designware_i2c.h +++ b/drivers/i2c/designware_i2c.h @@ -175,6 +175,7 @@ struct dw_scl_sda_cfg { * @scl_rise_time_ns: Configured SCL rise time in nanoseconds * @scl_fall_time_ns: Configured SCL fall time in nanoseconds * @sda_hold_time_ns: Configured SDA hold time in nanoseconds + * @has_spk_cnt: true if the spike-count register is present * @clk: Clock input to the I2C controller */ struct dw_i2c { @@ -184,6 +185,7 @@ struct dw_i2c { u32 scl_rise_time_ns; u32 scl_fall_time_ns; u32 sda_hold_time_ns; + bool has_spk_cnt; #if CONFIG_IS_ENABLED(CLK) struct clk clk; #endif diff --git a/drivers/i2c/designware_i2c_pci.c b/drivers/i2c/designware_i2c_pci.c index 2b974a07c3..50f03e3d90 100644 --- a/drivers/i2c/designware_i2c_pci.c +++ b/drivers/i2c/designware_i2c_pci.c @@ -62,6 +62,8 @@ static int designware_i2c_pci_ofdata_to_platdata(struct udevice *dev) if (IS_ENABLED(CONFIG_INTEL_BAYTRAIL)) /* Use BayTrail specific timing values */ priv->scl_sda_cfg = &byt_config; + if (dev_get_driver_data(dev) == INTEL_APL) + priv->has_spk_cnt = true;
Hello Simon,
Changes in v2:
bye, Heiko
Some drivers define their own speed enums and use their own constants for speed. It makes sense to have a unified defition of the different speeds.
Since many controllers have to do different things for fast/high speed, it is a good idea to have an enum for the mode.
Add these as well as an enum for the address mode.
Changes in v2: None
include/i2c.h | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/include/i2c.h b/include/i2c.h index 72e2e8e426..0faf8542e2 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -30,6 +30,32 @@ enum dm_i2c_chip_flags { DM_I2C_CHIP_WR_ADDRESS = 1 << 2, /* Send address for each write byte */ };
+/** enum i2c_speed_mode - standard I2C speed modes */ +enum i2c_speed_mode { + IC_SPEED_MODE_STANDARD, + IC_SPEED_MODE_FAST, + IC_SPEED_MODE_FAST_PLUS, + IC_SPEED_MODE_HIGH, + IC_SPEED_MODE_FAST_ULTRA, + + IC_SPEED_MODE_COUNT, +}; + +/** enum i2c_speed_rate - standard I2C speeds in Hz */ +enum i2c_speed_rate { + I2C_SPEED_STANDARD_RATE = 100000, + I2C_SPEED_FAST_RATE = 400000, + I2C_SPEED_FAST_PLUS_RATE = 1000000, + I2C_SPEED_HIGH_RATE = 3400000, + I2C_SPEED_FAST_ULTRA_RATE = 5000000, +}; + +/** enum i2c_address_mode - available address modes */ +enum i2c_address_mode { + I2C_MODE_7_BIT, + I2C_MODE_10_BIT +}; + struct udevice; /** * struct dm_i2c_chip - information about an i2c chip
Hello Simon,
Changes in v2: None
bye, Heiko
Update this driver to use the new standard enums for speed.
Changes in v2: None
drivers/i2c/ast_i2c.c | 2 +- drivers/i2c/ast_i2c.h | 2 -- 2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/i2c/ast_i2c.c b/drivers/i2c/ast_i2c.c index 763183d649..35dc234160 100644 --- a/drivers/i2c/ast_i2c.c +++ b/drivers/i2c/ast_i2c.c @@ -314,7 +314,7 @@ static int ast_i2c_set_speed(struct udevice *dev, unsigned int speed) divider = i2c_rate / speed;
priv->speed = speed; - if (speed > I2C_HIGHSPEED_RATE) { + if (speed > I2C_SPEED_FAST_RATE) { debug("Enable High Speed\n"); setbits_le32(®s->fcr, I2CD_M_HIGH_SPEED_EN | I2CD_M_SDA_DRIVE_1T_EN diff --git a/drivers/i2c/ast_i2c.h b/drivers/i2c/ast_i2c.h index 401e0970f7..928785989e 100644 --- a/drivers/i2c/ast_i2c.h +++ b/drivers/i2c/ast_i2c.h @@ -126,6 +126,4 @@ struct ast_i2c_regs { #define I2CD_RX_DATA_SHIFT 8 #define I2CD_RX_DATA_MASK (0xff << I2CD_RX_DATA_SHIFT)
-#define I2C_HIGHSPEED_RATE 400000 - #endif /* __AST_I2C_H_ */
Hello Simon,
Changes in v2: None
Thanks for cleaning this up!
bye, Heiko
Changes in v2: None
drivers/i2c/designware_i2c.c | 10 +++++----- drivers/i2c/designware_i2c.h | 13 ------------- 2 files changed, 5 insertions(+), 18 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index 4aee25c543..1f41e3eae0 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -103,21 +103,21 @@ struct i2c_mode_info {
static const struct i2c_mode_info info_for_mode[] = { [IC_SPEED_MODE_STANDARD] = { - I2C_STANDARD_SPEED, + I2C_SPEED_STANDARD_RATE, MIN_SS_SCL_HIGHTIME, MIN_SS_SCL_LOWTIME, 1000, 300, }, [IC_SPEED_MODE_FAST] = { - I2C_FAST_SPEED, + I2C_SPEED_FAST_RATE, MIN_FS_SCL_HIGHTIME, MIN_FS_SCL_LOWTIME, 300, 300, }, [IC_SPEED_MODE_HIGH] = { - I2C_HIGH_SPEED, + I2C_SPEED_HIGH_RATE, MIN_HS_SCL_HIGHTIME, MIN_HS_SCL_LOWTIME, 120, @@ -226,10 +226,10 @@ static unsigned int __dw_i2c_set_bus_speed(struct dw_i2c *priv, if (priv) scl_sda_cfg = priv->scl_sda_cfg; /* Allow high speed if there is no config, or the config allows it */ - if (speed >= I2C_HIGH_SPEED && + if (speed >= I2C_SPEED_HIGH_RATE && (!scl_sda_cfg || scl_sda_cfg->has_high_speed)) i2c_spd = IC_SPEED_MODE_HIGH; - else if (speed >= I2C_FAST_SPEED) + else if (speed >= I2C_SPEED_FAST_RATE) i2c_spd = IC_SPEED_MODE_FAST; else i2c_spd = IC_SPEED_MODE_STANDARD; diff --git a/drivers/i2c/designware_i2c.h b/drivers/i2c/designware_i2c.h index 2c572a9e1f..4738f4642d 100644 --- a/drivers/i2c/designware_i2c.h +++ b/drivers/i2c/designware_i2c.h @@ -134,19 +134,6 @@ struct i2c_regs { #define IC_STATUS_TFNF 0x0002 #define IC_STATUS_ACT 0x0001
-/* Speed Selection */ -enum i2c_speed_mode { - IC_SPEED_MODE_STANDARD, - IC_SPEED_MODE_FAST, - IC_SPEED_MODE_HIGH, - - IC_SPEED_MODE_COUNT, -}; - -#define I2C_HIGH_SPEED 3400000 -#define I2C_FAST_SPEED 400000 -#define I2C_STANDARD_SPEED 100000 - /** * struct dw_scl_sda_cfg - I2C timing configuration *
Hello Simon,
Changes in v2: None
bye, Heiko
Note: This driver needs to move to driver model.
Changes in v2: None
drivers/i2c/kona_i2c.c | 28 +++++++++++----------------- 1 file changed, 11 insertions(+), 17 deletions(-)
diff --git a/drivers/i2c/kona_i2c.c b/drivers/i2c/kona_i2c.c index d13e4deee5..0726b4c956 100644 --- a/drivers/i2c/kona_i2c.c +++ b/drivers/i2c/kona_i2c.c @@ -98,12 +98,6 @@ enum bcm_kona_cmd_t { BCM_CMD_STOP, };
-enum bus_speed_index { - BCM_SPD_100K = 0, - BCM_SPD_400K, - BCM_SPD_1MHZ, -}; - /* Internal divider settings for standard mode, fast mode and fast mode plus */ struct bus_speed_cfg { uint8_t time_m; /* Number of cycles for setup time */ @@ -115,9 +109,9 @@ struct bus_speed_cfg { };
static const struct bus_speed_cfg std_cfg_table[] = { - [BCM_SPD_100K] = {0x01, 0x01, 0x03, 0x06, 0x00, 0x02}, - [BCM_SPD_400K] = {0x05, 0x01, 0x03, 0x05, 0x01, 0x02}, - [BCM_SPD_1MHZ] = {0x01, 0x01, 0x03, 0x01, 0x01, 0x03}, + [IC_SPEED_MODE_STANDARD] = {0x01, 0x01, 0x03, 0x06, 0x00, 0x02}, + [IC_SPEED_MODE_FAST] = {0x05, 0x01, 0x03, 0x05, 0x01, 0x02}, + [IC_SPEED_MODE_FAST_PLUS] = {0x01, 0x01, 0x03, 0x01, 0x01, 0x03}, };
struct bcm_kona_i2c_dev { @@ -127,8 +121,8 @@ struct bcm_kona_i2c_dev { };
/* Keep these two defines in sync */ -#define DEF_SPD 100000 -#define DEF_SPD_ENUM BCM_SPD_100K +#define DEF_SPD I2C_SPEED_STANDARD_RATE +#define DEF_SPD_ENUM IC_SPEED_MODE_STANDARD
#define DEF_DEVICE(num) \ {(void *)CONFIG_SYS_I2C_BASE##num, DEF_SPD, &std_cfg_table[DEF_SPD_ENUM]} @@ -560,14 +554,14 @@ static uint bcm_kona_i2c_assign_bus_speed(struct bcm_kona_i2c_dev *dev, uint speed) { switch (speed) { - case 100000: - dev->std_cfg = &std_cfg_table[BCM_SPD_100K]; + case I2C_SPEED_STANDARD_RATE: + dev->std_cfg = &std_cfg_table[IC_SPEED_MODE_STANDARD]; break; - case 400000: - dev->std_cfg = &std_cfg_table[BCM_SPD_400K]; + case I2C_SPEED_FAST_RATE: + dev->std_cfg = &std_cfg_table[IC_SPEED_MODE_FAST]; break; - case 1000000: - dev->std_cfg = &std_cfg_table[BCM_SPD_1MHZ]; + case I2C_SPEED_FAST_PLUS_RATE: + dev->std_cfg = &std_cfg_table[IC_SPEED_MODE_FAST_PLUS]; break; default: printf("%d hz bus speed not supported\n", speed);
Hello simon,
Changes in v2: None
bye, Heiko
Changes in v2: None
drivers/i2c/omap24xx_i2c.c | 2 +- drivers/i2c/omap24xx_i2c.h | 4 ---- 2 files changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 4b93e02bbe..7e6e3c4f81 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -306,7 +306,7 @@ static int __omap24_i2c_setspeed(void __iomem *i2c_base, int ip_rev, uint speed, int hsscll = 0, hssclh = 0; u32 scll = 0, sclh = 0;
- if (speed >= OMAP_I2C_HIGH_SPEED) { + if (speed >= I2C_SPEED_HIGH_RATE) { /* High speed */ psc = I2C_IP_CLK / I2C_INTERNAL_SAMPLING_CLK; psc -= 1; diff --git a/drivers/i2c/omap24xx_i2c.h b/drivers/i2c/omap24xx_i2c.h index 3458cf3a7d..6904f2d9ad 100644 --- a/drivers/i2c/omap24xx_i2c.h +++ b/drivers/i2c/omap24xx_i2c.h @@ -81,10 +81,6 @@ #define I2C_SCLH_HSSCLH 8 #define I2C_SCLH_HSSCLH_M 0xFF
-#define OMAP_I2C_STANDARD 100000 -#define OMAP_I2C_FAST_MODE 400000 -#define OMAP_I2C_HIGH_SPEED 3400000 - #define SYSTEM_CLOCK_12 12000000 #define SYSTEM_CLOCK_13 13000000 #define SYSTEM_CLOCK_192 19200000
Hello Simon,
Changes in v2: None
bye, Heiko
Changes in v2: None
drivers/i2c/stm32f7_i2c.c | 43 +++++++++++++++------------------------ 1 file changed, 16 insertions(+), 27 deletions(-)
diff --git a/drivers/i2c/stm32f7_i2c.c b/drivers/i2c/stm32f7_i2c.c index 2b18735fea..def84f2e0a 100644 --- a/drivers/i2c/stm32f7_i2c.c +++ b/drivers/i2c/stm32f7_i2c.c @@ -115,17 +115,6 @@ struct stm32_i2c_regs {
#define STM32_NSEC_PER_SEC 1000000000L
-#define STANDARD_RATE 100000 -#define FAST_RATE 400000 -#define FAST_PLUS_RATE 1000000 - -enum stm32_i2c_speed { - STM32_I2C_SPEED_STANDARD, /* 100 kHz */ - STM32_I2C_SPEED_FAST, /* 400 kHz */ - STM32_I2C_SPEED_FAST_PLUS, /* 1 MHz */ - STM32_I2C_SPEED_END, -}; - /** * struct stm32_i2c_spec - private i2c specification timing * @rate: I2C bus speed (Hz) @@ -164,7 +153,7 @@ struct stm32_i2c_spec { * @analog_filter: Analog filter delay (On/Off) */ struct stm32_i2c_setup { - enum stm32_i2c_speed speed; + enum i2c_speed_mode speed; u32 speed_freq; u32 clock_src; u32 rise_time; @@ -198,8 +187,8 @@ struct stm32_i2c_priv { };
static const struct stm32_i2c_spec i2c_specs[] = { - [STM32_I2C_SPEED_STANDARD] = { - .rate = STANDARD_RATE, + [IC_SPEED_MODE_STANDARD] = { + .rate = I2C_SPEED_STANDARD_RATE, .rate_min = 8000, .rate_max = 120000, .fall_max = 300, @@ -210,8 +199,8 @@ static const struct stm32_i2c_spec i2c_specs[] = { .l_min = 4700, .h_min = 4000, }, - [STM32_I2C_SPEED_FAST] = { - .rate = FAST_RATE, + [IC_SPEED_MODE_FAST] = { + .rate = I2C_SPEED_FAST_RATE, .rate_min = 320000, .rate_max = 480000, .fall_max = 300, @@ -222,8 +211,8 @@ static const struct stm32_i2c_spec i2c_specs[] = { .l_min = 1300, .h_min = 600, }, - [STM32_I2C_SPEED_FAST_PLUS] = { - .rate = FAST_PLUS_RATE, + [IC_SPEED_MODE_FAST_PLUS] = { + .rate = I2C_SPEED_FAST_PLUS_RATE, .rate_min = 800000, .rate_max = 1200000, .fall_max = 100, @@ -648,9 +637,9 @@ static int stm32_i2c_compute_timing(struct stm32_i2c_priv *i2c_priv, struct list_head solutions; int ret;
- if (setup->speed >= STM32_I2C_SPEED_END) { + if (setup->speed >= IC_SPEED_MODE_HIGH) { pr_err("%s: speed out of bound {%d/%d}\n", __func__, - setup->speed, STM32_I2C_SPEED_END - 1); + setup->speed, IC_SPEED_MODE_FAST_PLUS); return -EINVAL; }
@@ -719,7 +708,7 @@ static int stm32_i2c_setup_timing(struct stm32_i2c_priv *i2c_priv, if (ret) { debug("%s: failed to compute I2C timings.\n", __func__); - if (i2c_priv->speed > STM32_I2C_SPEED_STANDARD) { + if (i2c_priv->speed > IC_SPEED_MODE_STANDARD) { i2c_priv->speed--; setup->speed = i2c_priv->speed; setup->speed_freq = @@ -784,14 +773,14 @@ static int stm32_i2c_set_bus_speed(struct udevice *bus, unsigned int speed) struct stm32_i2c_priv *i2c_priv = dev_get_priv(bus);
switch (speed) { - case STANDARD_RATE: - i2c_priv->speed = STM32_I2C_SPEED_STANDARD; + case I2C_SPEED_STANDARD_RATE: + i2c_priv->speed = IC_SPEED_MODE_STANDARD; break; - case FAST_RATE: - i2c_priv->speed = STM32_I2C_SPEED_FAST; + case I2C_SPEED_FAST_RATE: + i2c_priv->speed = IC_SPEED_MODE_FAST; break; - case FAST_PLUS_RATE: - i2c_priv->speed = STM32_I2C_SPEED_FAST_PLUS; + case I2C_SPEED_FAST_PLUS_RATE: + i2c_priv->speed = IC_SPEED_MODE_FAST_PLUS; break; default: debug("%s: Speed %d not supported\n", __func__, speed);
Hi Simon,
From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Simon Glass Sent: vendredi 3 janvier 2020 23:27
This driver i2c/stm32f7_i2c.c is already a driver model (I think this note is a copy paste of previous commit)
One minor remarks below, but anyway tested on stm32mp1.
Reviewed-by: Patrick Delaunay patrick.delaunay@st.com Tested-by: Patrick Delaunay patrick.delaunay@st.com
Changes in v2: None
- struct stm32_i2c_spec - private i2c specification timing
- @rate: I2C bus speed (Hz)
- @analog_filter: Analog filter delay (On/Off)
- enum i2c_speed_mode speed; u32 speed_freq; u32 clock_src; u32 rise_time;
- [IC_SPEED_MODE_STANDARD] = {
.rate_min = 8000, .rate_max = 120000, .fall_max = 300,.rate = I2C_SPEED_STANDARD_RATE,
.rate = FAST_RATE,
- [IC_SPEED_MODE_FAST] = {
.rate_min = 320000, .rate_max = 480000, .fall_max = 300,.rate = I2C_SPEED_FAST_RATE,
- [IC_SPEED_MODE_FAST_PLUS] = {
.rate_min = 800000, .rate_max = 1200000, .fall_max = 100,.rate = I2C_SPEED_FAST_PLUS_RATE,
- if (setup->speed >= IC_SPEED_MODE_HIGH) { pr_err("%s: speed out of bound {%d/%d}\n", __func__,
return -EINVAL; }setup->speed, IC_SPEED_MODE_FAST_PLUS);
It could be perhaps more clear to use the size of i2c_specs as the test is aonly use to protect access to this array.
if (setup->speed >= ARRAY_SIZE (i2c_specs)) { pr_err("%s: speed out of bound {%d/%d}\n", __func__, setup->speed, ARRAY_SIZE (i2c_specs) - 1); return -EINVAL; }
switch (speed) {
- case I2C_SPEED_STANDARD_RATE:
break;i2c_priv->speed = IC_SPEED_MODE_STANDARD;
- case FAST_RATE:
- case I2C_SPEED_FAST_RATE:
break;i2c_priv->speed = IC_SPEED_MODE_FAST;
- case I2C_SPEED_FAST_PLUS_RATE:
break; default: debug("%s: Speed %d not supported\n", __func__, speed);i2c_priv->speed = IC_SPEED_MODE_FAST_PLUS;
Hello Simon,
Changes in v2: None
bye, Heiko
Convert the obvious uses of i2c bus speeds to use the enum.
Use livetree access for code changes.
Changes in v2: None
drivers/i2c/exynos_hs_i2c.c | 4 ++-- drivers/i2c/fsl_i2c.c | 3 ++- drivers/i2c/i2c-cdns.c | 2 +- drivers/i2c/i2c-uclass.c | 12 ++++++------ drivers/i2c/i2c-uniphier-f.c | 2 +- drivers/i2c/i2c-uniphier.c | 2 +- drivers/i2c/imx_lpi2c.c | 8 ++++---- drivers/i2c/mv_i2c.c | 4 ++-- drivers/i2c/mvtwsi.c | 5 +++-- drivers/i2c/omap24xx_i2c.c | 3 ++- drivers/i2c/rcar_i2c.c | 2 +- drivers/i2c/rcar_iic.c | 2 +- drivers/i2c/s3c24x0_i2c.c | 4 ++-- drivers/i2c/sandbox_i2c.c | 3 ++- 14 files changed, 30 insertions(+), 26 deletions(-)
diff --git a/drivers/i2c/exynos_hs_i2c.c b/drivers/i2c/exynos_hs_i2c.c index a0821c9257..048272c6b5 100644 --- a/drivers/i2c/exynos_hs_i2c.c +++ b/drivers/i2c/exynos_hs_i2c.c @@ -527,8 +527,8 @@ static int s3c_i2c_ofdata_to_platdata(struct udevice *dev)
i2c_bus->id = pinmux_decode_periph_id(blob, node);
- i2c_bus->clock_frequency = fdtdec_get_int(blob, node, - "clock-frequency", 100000); + i2c_bus->clock_frequency = dev_read_u32_default(dev, "clock-frequency", + I2C_SPEED_STANDARD_RATE); i2c_bus->node = node; i2c_bus->bus_num = dev->seq;
diff --git a/drivers/i2c/fsl_i2c.c b/drivers/i2c/fsl_i2c.c index bbbd6ef5bf..097c54388f 100644 --- a/drivers/i2c/fsl_i2c.c +++ b/drivers/i2c/fsl_i2c.c @@ -584,7 +584,8 @@ static int fsl_i2c_ofdata_to_platdata(struct udevice *bus) dev->index = dev_read_u32_default(bus, "cell-index", -1); dev->slaveadd = dev_read_u32_default(bus, "u-boot,i2c-slave-addr", 0x7f); - dev->speed = dev_read_u32_default(bus, "clock-frequency", 400000); + dev->speed = dev_read_u32_default(bus, "clock-frequency", + I2C_SPEED_FAST_RATE);
if (!clk_get_by_index(bus, 0, &clock)) dev->i2c_clk = clk_get_rate(&clock); diff --git a/drivers/i2c/i2c-cdns.c b/drivers/i2c/i2c-cdns.c index ff3956d8c2..ac15da2c67 100644 --- a/drivers/i2c/i2c-cdns.c +++ b/drivers/i2c/i2c-cdns.c @@ -213,7 +213,7 @@ static int cdns_i2c_set_bus_speed(struct udevice *dev, unsigned int speed) unsigned long speed_p = speed; int ret = 0;
- if (speed > 400000) { + if (speed > I2C_SPEED_FAST_RATE) { debug("%s, failed to set clock speed to %u\n", __func__, speed); return -EINVAL; diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index fe77e64619..2aa3efe8aa 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -641,7 +641,8 @@ static int i2c_post_probe(struct udevice *dev) #if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) struct dm_i2c_bus *i2c = dev_get_uclass_priv(dev);
- i2c->speed_hz = dev_read_u32_default(dev, "clock-frequency", 100000); + i2c->speed_hz = dev_read_u32_default(dev, "clock-frequency", + I2C_SPEED_STANDARD_RATE);
return dm_i2c_set_bus_speed(dev, i2c->speed_hz); #else @@ -699,11 +700,10 @@ int i2c_uclass_init(struct uclass *class) return -ENOMEM;
/* Get the last allocated alias. */ -#if CONFIG_IS_ENABLED(OF_CONTROL) - priv->max_id = dev_read_alias_highest_id("i2c"); -#else - priv->max_id = -1; -#endif + if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) + priv->max_id = dev_read_alias_highest_id("i2c"); + else + priv->max_id = -1;
debug("%s: highest alias id is %d\n", __func__, priv->max_id);
diff --git a/drivers/i2c/i2c-uniphier-f.c b/drivers/i2c/i2c-uniphier-f.c index ced606bf36..62acd28e1b 100644 --- a/drivers/i2c/i2c-uniphier-f.c +++ b/drivers/i2c/i2c-uniphier-f.c @@ -281,7 +281,7 @@ static int uniphier_fi2c_set_bus_speed(struct udevice *bus, unsigned int speed) struct uniphier_fi2c_regs __iomem *regs = priv->regs;
/* max supported frequency is 400 kHz */ - if (speed > 400000) + if (speed > I2C_SPEED_FAST_RATE) return -EINVAL;
ret = uniphier_fi2c_check_bus_busy(priv); diff --git a/drivers/i2c/i2c-uniphier.c b/drivers/i2c/i2c-uniphier.c index e427415e7e..07a7e03033 100644 --- a/drivers/i2c/i2c-uniphier.c +++ b/drivers/i2c/i2c-uniphier.c @@ -177,7 +177,7 @@ static int uniphier_i2c_set_bus_speed(struct udevice *bus, unsigned int speed) struct uniphier_i2c_priv *priv = dev_get_priv(bus);
/* bus reset: make sure the bus is idle when change the frequency */ diff --git a/drivers/i2c/imx_lpi2c.c b/drivers/i2c/imx_lpi2c.c index 2de99d019e..c9d3faa911 100644 --- a/drivers/i2c/imx_lpi2c.c +++ b/drivers/i2c/imx_lpi2c.c @@ -169,7 +169,7 @@ static int bus_i2c_start(struct udevice *bus, u8 addr, u8 dir) debug("i2c: start check busy bus: 0x%x\n", result);
/* Try to init the lpi2c then check the bus busy again */ - bus_i2c_init(bus, 100000); + bus_i2c_init(bus, I2C_SPEED_STANDARD_RATE); result = imx_lpci2c_check_busy_bus(regs); if (result) { printf("i2c: Error check busy bus: 0x%x\n", result); @@ -388,13 +388,13 @@ static int imx_lpi2c_probe_chip(struct udevice *bus, u32 chip, result = bus_i2c_start(bus, chip, 0); if (result) { bus_i2c_stop(bus); - bus_i2c_init(bus, 100000); + bus_i2c_init(bus, I2C_SPEED_STANDARD_RATE); return result; }
result = bus_i2c_stop(bus); if (result) - bus_i2c_init(bus, 100000); + bus_i2c_init(bus, I2C_SPEED_STANDARD_RATE);
return result; } @@ -489,7 +489,7 @@ static int imx_lpi2c_probe(struct udevice *bus) return ret; }
- ret = bus_i2c_init(bus, 100000); + ret = bus_i2c_init(bus, I2C_SPEED_STANDARD_RATE); if (ret < 0) return ret;
diff --git a/drivers/i2c/mv_i2c.c b/drivers/i2c/mv_i2c.c index 8a56ef9a24..63665f0952 100644 --- a/drivers/i2c/mv_i2c.c +++ b/drivers/i2c/mv_i2c.c @@ -434,7 +434,7 @@ void i2c_init(int speed, int slaveaddr) base_glob = (struct mv_i2c *)CONFIG_MV_I2C_REG; #endif
- if (speed > 100000) + if (speed > I2C_SPEED_STANDARD_RATE) val = ICR_FM; else val = ICR_SM; @@ -565,7 +565,7 @@ static int mv_i2c_set_bus_speed(struct udevice *bus, unsigned int speed) struct mv_i2c_priv *priv = dev_get_priv(bus); u32 val;
- if (speed > 100000) + if (speed > I2C_SPEED_STANDARD_RATE) val = ICR_FM; else val = ICR_SM; diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index 0a2dafcec6..382cf4b304 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -805,8 +805,9 @@ static int mvtwsi_i2c_ofdata_to_platdata(struct udevice *bus) "cell-index", -1); dev->slaveadd = fdtdec_get_int(gd->fdt_blob, dev_of_offset(bus), "u-boot,i2c-slave-addr", 0x0); - dev->speed = fdtdec_get_int(gd->fdt_blob, dev_of_offset(bus), - "clock-frequency", 100000); + dev->speed = dev_read_u32_default(bus, "clock-frequency", + I2C_SPEED_STANDARD_RATE); + return 0; }
diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 7e6e3c4f81..6e7d24d727 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -1066,7 +1066,8 @@ static int omap_i2c_ofdata_to_platdata(struct udevice *bus) struct omap_i2c_platdata *plat = dev_get_platdata(bus);
plat->base = devfdt_get_addr(bus); - plat->speed = dev_read_u32_default(bus, "clock-frequency", 100000); + plat->speed = dev_read_u32_default(bus, "clock-frequency", + I2C_SPEED_STANDARD_RATE); plat->ip_rev = dev_get_driver_data(bus);
return 0; diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index 2ebae349ed..05d0dc6012 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -344,7 +344,7 @@ static int rcar_i2c_probe(struct udevice *dev) writel(0, priv->base + RCAR_I2C_ICMSR); writel(0, priv->base + RCAR_I2C_ICMAR);
- ret = rcar_i2c_set_speed(dev, 100000); + ret = rcar_i2c_set_speed(dev, I2C_SPEED_STANDARD_RATE); if (ret) clk_disable(&priv->clk);
diff --git a/drivers/i2c/rcar_iic.c b/drivers/i2c/rcar_iic.c index 9d45f547d1..2a82eb0b76 100644 --- a/drivers/i2c/rcar_iic.c +++ b/drivers/i2c/rcar_iic.c @@ -248,7 +248,7 @@ static int rcar_iic_probe(struct udevice *dev)
rcar_iic_finish(dev);
- return rcar_iic_set_speed(dev, 100000); + return rcar_iic_set_speed(dev, I2C_SPEED_STANDARD_RATE); }
static const struct dm_i2c_ops rcar_iic_ops = { diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index ad0bc69fa3..612f5af168 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -313,8 +313,8 @@ static int s3c_i2c_ofdata_to_platdata(struct udevice *dev)
diff --git a/drivers/i2c/sandbox_i2c.c b/drivers/i2c/sandbox_i2c.c index 0dbbaa0c44..1a4521d5b8 100644 --- a/drivers/i2c/sandbox_i2c.c +++ b/drivers/i2c/sandbox_i2c.c @@ -72,7 +72,8 @@ static int sandbox_i2c_xfer(struct udevice *bus, struct i2c_msg *msg, * 400KHz for reads. */ is_read = nmsgs > 1; - if (i2c->speed_hz > (is_read ? 400000 : 100000)) { + if (i2c->speed_hz > (is_read ? I2C_SPEED_FAST_RATE : + I2C_SPEED_STANDARD_RATE)) { debug("%s: Max speed exceeded\n", __func__); return -EINVAL; }
Hi Simon, I found this commit has style problems reported by checkpatch.pl, is it better to fix it?
Changes in v2: None
"clock-frequency",
100000);
"clock-frequency",
CHECK: Alignment should match open parenthesis
I2C_SPEED_FAST_RATE); if (!clk_get_by_index(bus, 0, &clock)) dev->i2c_clk = clk_get_rate(&clock);
100000);
I2C_SPEED_STANDARD_RATE); return dm_i2c_set_bus_speed(dev, i2c->speed_hz);
-#else
priv->max_id = -1;
-#endif
else
priv->max_id = -1; debug("%s: highest alias id is %d\n", __func__, priv->max_id);
if (speed > 400000)
if (speed > I2C_SPEED_FAST_RATE) return -EINVAL; ret = uniphier_fi2c_check_bus_busy(priv);
if (speed > 400000)
if (speed > I2C_SPEED_FAST_RATE) return -EINVAL; /* bus reset: make sure the bus is idle when change the frequency
bus_i2c_init(bus, I2C_SPEED_STANDARD_RATE); return result; } result = bus_i2c_stop(bus); if (result)
if (speed > 100000)
if (speed > 100000)
I2C_SPEED_STANDARD_RATE); plat->ip_rev = dev_get_driver_data(bus); return 0;
"clock-frequency",
100000);
"clock-frequency",
Jun Chen
Hello Simon,
Changes in v2: None
bye, Heiko
Heiko Schocher
Patrick DELAUNAY
pt
