[U-Boot-Users] Compilation with gcc4 : Unknown values in msr
Hi all,
I sent two days ago, a mail concerning a trouble to compile u-boot with gcc4.3.2. I solve this problem by moving a section and concatenate with another in the beginning (you can have a look to the u-boot.lds to see the way the sections are organised). This section is named ".rodata.str1.1" (I have just added one line in the script)
Linker script : http://superuploader.net/1b01c39a7a52380fa48d40d81f17ae97-u-boot-lds.html
But now when I try to boot I have this error message : U-Boot 1.1.6-4
MPC8272 Reset Status: Check Stop, External Soft, External Hard
CLOCK: CPU= 264 MHz, CPM= 198 MHz, BUS= 66 MHz, PCI= 33 MHz CPU: MPC8272 (HiP7 Rev 14, Mask 1.0 1K50M) at 264 MHz
BOARD: type RMP100, rev.B, capabilities 802a, EPLD ver.1 I2C: ready DRAM: 64 MB DSP: 600Mhz-64Mo FLASH: 8 MB Bus Fault @ 0x03fe9450, fixup 0x00000000 Machine check in kernel mode. Caused by (from msr): regs 03bdfd78 Unknown values in msr NIP: 03FE9450 XER: 20000000 LR: 03FE93F0 REGS: 03bdfd78 TRAP: 0200 DAR: 03FFF6D4 MSR: 00003000 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 00
GPR00: 0001A06C 03BDFE68 FFFFFAFF 0BFDC9FC 00000000 00000000 F0010000 F0003F80 GPR08: F0002104 480000D8 480000D8 00000021 03BDFC50 FB7FFFFF 04003000 07FE0000 GPR16: FFFFFFFF FFFFFFFA FF7FFFFF EFFFEFB7 00003002 00000001 00000000 03FE3098 GPR24: 00000108 FFEDFFFF 0000FFFF 0000FFFF 03BDFF64 03BDFF0C 0400345C 00800000 Call backtrace: machine check
So I think I have a trouble in the organisation of sections. Maybe to see bugs, I made a objdump of 2 u-boot. One compiled with gcc3 and another compiled with gcc4.
Dump gcc3 http://superuploader.net/9b6c29af92deddb0cbfffe467ae51a97-dump-gcc3-txt.html
Dump gcc4 http://superuploader.net/90568c2250a4e92e1f37bb14210678bb-dump-gcc4-txt.html
I don't know where I have to look, someone can help me to see where I have to work ? And with what tools ? And any documentation which can help me.
Thanks again for your attention, Val.
In message 42288a480806200703v15c12409lecfa72743d25cbcd@mail.gmail.com you wrote:
It is a complete waste of efforts to try and get such an old, obsolete version of U-Boot running with bleeding edge toolchain versions. If you really want to stick with that old code, than use an adequate (i. e. old) tool chain. Or - recommended - update to the latest version of U-Boot from the git repository.
valerian NA
