[PATCH] efi: Rename the base efi self-test
This function uses the same base name as all the others in this file, so it is not easy to run just that one test. Add a _base suffix so that it can be run on its own.
test/py/tests/test_efi_selftest.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/py/tests/test_efi_selftest.py b/test/py/tests/test_efi_selftest.py index e92d63cde6e1..43f242455828 100644 --- a/test/py/tests/test_efi_selftest.py +++ b/test/py/tests/test_efi_selftest.py @@ -7,7 +7,7 @@ import pytest
@pytest.mark.buildconfigspec('cmd_bootefi_selftest') -def test_efi_selftest(u_boot_console): +def test_efi_selftest_base(u_boot_console): """Run UEFI unit tests
u_boot_console -- U-Boot console
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
