[PATCH v5 0/3] rockpi4: Add capsule update support
Add capsule update support for the RockPi4B and RockPi4C boards. Support is being added for updating the idbloader.img and u-boot.itb firmware images on configurations with the firmware images stored on GPT partitioned uSD card device.
Changes since V5: * Get the pointer to struct efi_fw_image through struct efi_capsule_update_info * Mark fw_images array as a static variable * Populate num_image_type_guids through ROCKPI4_UPDATABLE_IMAGES
Sughosh Ganu (3): rockchip: capsule: Add functions for supporting capsule updates rockpi4: board: Add firmware image information for capsule updates rockpi4: capsule: Enable UEFI capsule update on RockPi4 boards
arch/arm/include/asm/arch-rockchip/misc.h | 1 + arch/arm/mach-rockchip/Kconfig | 1 + arch/arm/mach-rockchip/board.c | 153 ++++++++++++++++++++++ board/rockchip/evb_rk3399/evb-rk3399.c | 55 +++++++- configs/rock-pi-4-rk3399_defconfig | 8 ++ configs/rock-pi-4c-rk3399_defconfig | 8 ++ include/configs/rk3399_common.h | 16 +++ 7 files changed, 241 insertions(+), 1 deletion(-)
Add functions needed to support the UEFI capsule update feature on rockchip boards. Currently, the feature is being enabled on the RockPi4 boards with firmware images residing on GPT partitioned storage media.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Changes since V4: * Get the pointer to struct efi_fw_image through struct efi_capsule_update_info
arch/arm/mach-rockchip/Kconfig | 1 + arch/arm/mach-rockchip/board.c | 153 +++++++++++++++++++++++++++++++++ 2 files changed, 154 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 69d51ff378..4898260017 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -246,6 +246,7 @@ config ROCKCHIP_RK3399 select DM_PMIC select DM_REGULATOR_FIXED select BOARD_LATE_INIT + imply PARTITION_TYPE_GUID imply PRE_CONSOLE_BUFFER imply ROCKCHIP_COMMON_BOARD imply ROCKCHIP_SDRAM_COMMON diff --git a/arch/arm/mach-rockchip/board.c b/arch/arm/mach-rockchip/board.c index cbe00d646c..6e05a8f76e 100644 --- a/arch/arm/mach-rockchip/board.c +++ b/arch/arm/mach-rockchip/board.c @@ -6,11 +6,15 @@ #include <clk.h> #include <cpu_func.h> #include <dm.h> +#include <efi_loader.h> #include <fastboot.h> #include <init.h> #include <log.h> +#include <mmc.h> +#include <part.h> #include <ram.h> #include <syscon.h> +#include <uuid.h> #include <asm/cache.h> #include <asm/global_data.h> #include <asm/io.h> @@ -22,8 +26,157 @@
DECLARE_GLOBAL_DATA_PTR;
+#if defined(CONFIG_EFI_HAVE_CAPSULE_SUPPORT) && defined(CONFIG_EFI_PARTITION) + +#define DFU_ALT_BUF_LEN SZ_1K + +static struct efi_fw_image *fw_images; + +static bool updatable_image(struct disk_partition *info) +{ + int i; + bool ret = false; + efi_guid_t image_type_guid; + + uuid_str_to_bin(info->type_guid, image_type_guid.b, + UUID_STR_FORMAT_GUID); + + for (i = 0; i < num_image_type_guids; i++) { + if (!guidcmp(&fw_images[i].image_type_id, &image_type_guid)) { + ret = true; + break; + } + } + + return ret; +} + +static void set_image_index(struct disk_partition *info, int index) +{ + int i; + efi_guid_t image_type_guid; + + uuid_str_to_bin(info->type_guid, image_type_guid.b, + UUID_STR_FORMAT_GUID); + + for (i = 0; i < num_image_type_guids; i++) { + if (!guidcmp(&fw_images[i].image_type_id, &image_type_guid)) { + fw_images[i].image_index = index; + break; + } + } +} + +static int get_mmc_desc(struct blk_desc **desc) +{ + int ret; + struct mmc *mmc; + struct udevice *dev; + + /* + * For now the firmware images are assumed to + * be on the SD card + */ + ret = uclass_get_device(UCLASS_MMC, 1, &dev); + if (ret) + return -1; + + mmc = mmc_get_mmc_dev(dev); + if (!mmc) + return -ENODEV; + + if ((ret = mmc_init(mmc))) + return ret; + + *desc = mmc_get_blk_desc(mmc); + if (!*desc) + return -1; + + return 0; +} + +void set_dfu_alt_info(char *interface, char *devstr) +{ + const char *name; + bool first = true; + int p, len, devnum, ret; + char buf[DFU_ALT_BUF_LEN]; + struct disk_partition info; + struct blk_desc *desc = NULL; + + ret = get_mmc_desc(&desc); + if (ret) { + log_err("Unable to get mmc desc\n"); + return; + } + + memset(buf, 0, sizeof(buf)); + name = blk_get_uclass_name(desc->uclass_id); + devnum = desc->devnum; + len = strlen(buf); + + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, + "%s %d=", name, devnum); + + for (p = 1; p <= MAX_SEARCH_PARTITIONS; p++) { + if (part_get_info(desc, p, &info)) + continue; + + /* Add entry to dfu_alt_info only for updatable images */ + if (updatable_image(&info)) { + if (!first) + len += snprintf(buf + len, + DFU_ALT_BUF_LEN - len, ";"); + + len += snprintf(buf + len, DFU_ALT_BUF_LEN - len, + "%s%d_%s part %d %d", + name, devnum, info.name, devnum, p); + first = false; + } + } + + log_debug("dfu_alt_info => %s\n", buf); + env_set("dfu_alt_info", buf); +} + +static void gpt_capsule_update_setup(void) +{ + int p, i, ret; + struct disk_partition info; + struct blk_desc *desc = NULL; + + fw_images = update_info.images; + rockchip_capsule_update_board_setup(); + + ret = get_mmc_desc(&desc); + if (ret) { + log_err("Unable to get mmc desc\n"); + return; + } + + for (p = 1, i = 1; p <= MAX_SEARCH_PARTITIONS; p++) { + if (part_get_info(desc, p, &info)) + continue; + + /* + * Since we have a GPT partitioned device, the updatable + * images could be stored in any order. Populate the + * image_index at runtime. + */ + if (updatable_image(&info)) { + set_image_index(&info, i); + i++; + } + } +} +#endif /* CONFIG_EFI_HAVE_CAPSULE_SUPPORT && CONFIG_EFI_PARTITION */ + __weak int rk_board_late_init(void) { +#if defined(CONFIG_EFI_HAVE_CAPSULE_SUPPORT) && defined(CONFIG_EFI_PARTITION) + gpt_capsule_update_setup(); +#endif + return 0; }
Add information that will be needed for enabling the UEFI capsule update feature on the RockPi4 boards. With the feature enabled, it would be possible to update the idbloader and u-boot.itb images on the RockPi4B and RockPi4C variants.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Changes since V5: * Mark fw_images array as a static variable * Populate num_image_type_guids through ROCKPI4_UPDATABLE_IMAGES
arch/arm/include/asm/arch-rockchip/misc.h | 1 + board/rockchip/evb_rk3399/evb-rk3399.c | 55 ++++++++++++++++++++++- include/configs/rk3399_common.h | 16 +++++++ 3 files changed, 71 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-rockchip/misc.h b/arch/arm/include/asm/arch-rockchip/misc.h index b6b03c934e..4155af8c3b 100644 --- a/arch/arm/include/asm/arch-rockchip/misc.h +++ b/arch/arm/include/asm/arch-rockchip/misc.h @@ -11,3 +11,4 @@ int rockchip_cpuid_from_efuse(const u32 cpuid_offset, u8 *cpuid); int rockchip_cpuid_set(const u8 *cpuid, const u32 cpuid_length); int rockchip_setup_macaddr(void); +void rockchip_capsule_update_board_setup(void); diff --git a/board/rockchip/evb_rk3399/evb-rk3399.c b/board/rockchip/evb_rk3399/evb-rk3399.c index abb76585cf..f56b379b93 100644 --- a/board/rockchip/evb_rk3399/evb-rk3399.c +++ b/board/rockchip/evb_rk3399/evb-rk3399.c @@ -5,11 +5,25 @@
#include <common.h> #include <dm.h> +#include <efi_loader.h> #include <init.h> #include <log.h> #include <asm/arch-rockchip/periph.h> +#include <linux/kernel.h> #include <power/regulator.h>
+#define ROCKPI4_UPDATABLE_IMAGES 2 + +#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) +static struct efi_fw_image fw_images[ROCKPI4_UPDATABLE_IMAGES] = {0}; + +struct efi_capsule_update_info update_info = { + .images = fw_images, +}; + +u8 num_image_type_guids = ROCKPI4_UPDATABLE_IMAGES; +#endif + #ifndef CONFIG_SPL_BUILD int board_early_init_f(void) { @@ -29,4 +43,43 @@ int board_early_init_f(void) out: return 0; } -#endif + +#if defined(CONFIG_EFI_HAVE_CAPSULE_SUPPORT) && defined(CONFIG_EFI_PARTITION) +static bool board_is_rockpi_4b(void) +{ + return CONFIG_IS_ENABLED(TARGET_EVB_RK3399) && + of_machine_is_compatible("radxa,rockpi4b"); +} + +static bool board_is_rockpi_4c(void) +{ + return CONFIG_IS_ENABLED(TARGET_EVB_RK3399) && + of_machine_is_compatible("radxa,rockpi4c"); +} + +void rockchip_capsule_update_board_setup(void) +{ + if (board_is_rockpi_4b()) { + efi_guid_t idbldr_image_type_guid = + ROCKPI_4B_IDBLOADER_IMAGE_GUID; + efi_guid_t uboot_image_type_guid = ROCKPI_4B_UBOOT_IMAGE_GUID; + + guidcpy(&fw_images[0].image_type_id, &idbldr_image_type_guid); + guidcpy(&fw_images[1].image_type_id, &uboot_image_type_guid); + + fw_images[0].fw_name = u"ROCKPI4B-IDBLOADER"; + fw_images[1].fw_name = u"ROCKPI4B-UBOOT"; + } else if (board_is_rockpi_4c()) { + efi_guid_t idbldr_image_type_guid = + ROCKPI_4C_IDBLOADER_IMAGE_GUID; + efi_guid_t uboot_image_type_guid = ROCKPI_4C_UBOOT_IMAGE_GUID; + + guidcpy(&fw_images[0].image_type_id, &idbldr_image_type_guid); + guidcpy(&fw_images[1].image_type_id, &uboot_image_type_guid); + + fw_images[0].fw_name = u"ROCKPI4C-IDBLOADER"; + fw_images[1].fw_name = u"ROCKPI4C-UBOOT"; + } +} +#endif /* CONFIG_EFI_HAVE_CAPSULE_SUPPORT && CONFIG_EFI_PARTITION */ +#endif /* !CONFIG_SPL_BUILD */ diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index 2f9aee5819..f0a9ab8f83 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -24,6 +24,22 @@ #define CONFIG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xf8000000
+#define ROCKPI_4B_IDBLOADER_IMAGE_GUID \ + EFI_GUID(0x02f4d760, 0xcfd5, 0x43bd, 0x8e, 0x2d, \ + 0xa4, 0x2a, 0xcb, 0x33, 0xc6, 0x60) + +#define ROCKPI_4B_UBOOT_IMAGE_GUID \ + EFI_GUID(0x4ce292da, 0x1dd8, 0x428d, 0xa1, 0xc2, \ + 0x77, 0x74, 0x3e, 0xf8, 0xb9, 0x6e) + +#define ROCKPI_4C_IDBLOADER_IMAGE_GUID \ + EFI_GUID(0xfd68510c, 0x12d3, 0x4f0a, 0xb8, 0xd3, \ + 0xd8, 0x79, 0xe1, 0xd3, 0xa5, 0x40) + +#define ROCKPI_4C_UBOOT_IMAGE_GUID \ + EFI_GUID(0xb81fb4ae, 0xe4f3, 0x471b, 0x99, 0xb4, \ + 0x0b, 0x3d, 0xa5, 0x49, 0xce, 0x13) + #ifndef CONFIG_SPL_BUILD
#define ENV_MEM_LAYOUT_SETTINGS \
Enable the UEFI capsule update functionality on the RockPi4B and RockPi4C boards. Support is being enabled for updating the idbloader and u-boot firmware images residing on GPT partitioned uSD card storage device.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Changes since V5: None
configs/rock-pi-4-rk3399_defconfig | 8 ++++++++ configs/rock-pi-4c-rk3399_defconfig | 8 ++++++++ 2 files changed, 16 insertions(+)
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 83721cedf3..b46f3f8c76 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -30,6 +30,7 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y @@ -40,6 +41,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y @@ -84,3 +86,9 @@ CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_TOOLS_MKEFICAPSULE=y +CONFIG_HEXDUMP=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y diff --git a/configs/rock-pi-4c-rk3399_defconfig b/configs/rock-pi-4c-rk3399_defconfig index ac9a3f9830..7075286a21 100644 --- a/configs/rock-pi-4c-rk3399_defconfig +++ b/configs/rock-pi-4c-rk3399_defconfig @@ -30,6 +30,7 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_TPL=y CONFIG_CMD_BOOTZ=y +CONFIG_CMD_DFU=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y @@ -40,6 +41,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y @@ -84,3 +86,9 @@ CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_HDMI=y CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_TOOLS_MKEFICAPSULE=y +CONFIG_HEXDUMP=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y
Sughosh Ganu
