[U-Boot] [PATCH v7 1/4] Integrating TCP and wget into u-boot
All the code is new, and not copied from any source.
Commit-notes Why netboot: Central management, including logs and change control, coupled with with enhanced security and unauthorized change detection and remediation by exposing a small attack surface.
Why TCP:
Currently file transfer are done using tftp or NFS both over udp. This requires a request to be sent from client (u-boot) to the boot server.
For a 4 Mbyte kernel, with a 1k block size this requires 4,000 request for a block.
Using a large block size, one greater than the Ethernet maximum frame size limitation, would require fragmentation, which u-boot supports. However missing fragment recovery requires timeout detection and re-transmission requests for missing fragments.
UDP is ideally suited to fast single packet exchanges, inquiry/response, for example dns, becuse of the lack of connection overhead.
UDP as a file transport mechanism is slow, even in low latency networks, because file transfer with udp requires poll/response mechanism to provide transfer integrity.
In networks with large latency, for example: the internet, UDP is even slower. What is a 30 second transfer on a local boot server and LAN increase to over 3 minutes, because of all the requests/response traffic.
This was anticipated in the evolution of the IP protocols and TCP was developed and then enhanced for high latency high bandwidth networks.
The current standard is TCP with selective acknowledgment.
In our testing we have reduce kernel transmission time to around 0.4 seconds for a 4Mbyte kernel, with a 100 Mbps downlink.
Why http and wget:
HTTP is the most efficient file retrieval protocol in common use. The client send a single request, after TCP connection, to receive a file of any length.
WGET is the application which implements http file transfer outside browsers as a file transfer protocol. Versions of wget exists on many operating systems.
END
Signed-off-by: Duncan Hare DuncanCHare@yahoo.com ---
Changes in v7: Integrating TCP and wget into u-boot
include/net.h | 25 +++++++++++++++++++------ net/net.c | 52 ++++++++++++++++++++++++++++++++++------------------ net/ping.c | 9 ++------- 3 files changed, 55 insertions(+), 31 deletions(-)
diff --git a/include/net.h b/include/net.h index 455b48f6c7..7e5f5a6a5b 100644 --- a/include/net.h +++ b/include/net.h @@ -15,17 +15,26 @@ #include <asm/cache.h> #include <asm/byteorder.h> /* for nton* / ntoh* stuff */
-#define DEBUG_LL_STATE 0 /* Link local state machine changes */ -#define DEBUG_DEV_PKT 0 /* Packets or info directed to the device */ -#define DEBUG_NET_PKT 0 /* Packets on info on the network at large */ +#define DEBUG_LL_STATE 0 /* Link local state machine changes */ +#define DEBUG_DEV_PKT 0 /* Packets or info directed to the device */ +#define DEBUG_NET_PKT 0 /* Packets on info on the network at large */ #define DEBUG_INT_STATE 0 /* Internal network state changes */
/* * The number of receive packet buffers, and the required packet buffer * alignment in memory. * + * The number of buffers for TCP is used to calculate a static TCP window + * size, becuse TCP window size is a promise to the sending TCP to be able + * to buffer up to the window size of data. + * When the sending TCP has a window size of outstanding unacknowledged + * data, the sending TCP will stop sending. */
+#if defined(CONFIG_TCP) +#define CONFIG_SYS_RX_ETH_BUFFER 12 /* For TCP */ +#endif + #ifdef CONFIG_SYS_RX_ETH_BUFFER # define PKTBUFSRX CONFIG_SYS_RX_ETH_BUFFER #else @@ -354,6 +363,7 @@ struct vlan_ethernet_hdr {
#define IPPROTO_ICMP 1 /* Internet Control Message Protocol */ #define IPPROTO_UDP 17 /* User Datagram Protocol */ +#define IPPROTO_TCP 6 /* Transmission Control Protocol */
/* * Internet Protocol (IP) header. @@ -596,10 +606,10 @@ int net_set_ether(uchar *xet, const uchar *dest_ethaddr, uint prot); int net_update_ether(struct ethernet_hdr *et, uchar *addr, uint prot);
/* Set IP header */ -void net_set_ip_header(uchar *pkt, struct in_addr dest, struct in_addr source); +void net_set_ip_header(uchar *pkt, struct in_addr dest, struct in_addr source, + u16 pkt_len, u8 prot); void net_set_udp_header(uchar *pkt, struct in_addr dest, int dport, - int sport, int len); - + int sport, int len); /** * compute_ip_checksum() - Compute IP checksum * @@ -670,6 +680,9 @@ static inline void net_send_packet(uchar *pkt, int len) * @param sport Source UDP port * @param payload_len Length of data after the UDP header */ +int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, + int payload_len, int proto); + int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, int payload_len);
diff --git a/net/net.c b/net/net.c index 4259c9e321..df4e7317e7 100644 --- a/net/net.c +++ b/net/net.c @@ -181,6 +181,7 @@ int net_ntp_time_offset; static uchar net_pkt_buf[(PKTBUFSRX+1) * PKTSIZE_ALIGN + PKTALIGN]; /* Receive packets */ uchar *net_rx_packets[PKTBUFSRX]; + /* Current UDP RX packet handler */ static rxhand_f *udp_packet_handler; /* Current ARP RX packet handler */ @@ -777,11 +778,23 @@ void net_set_timeout_handler(ulong iv, thand_f *f) }
int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, - int payload_len) + int payload_len) +{ + return net_send_ip_packet(ether, dest, dport, sport, payload_len, + IPPROTO_UDP); +} + +int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, + int payload_len, int proto) { uchar *pkt; int eth_hdr_size; int pkt_hdr_size; + if (proto == IPPROTO_UDP) { + debug_cond(DEBUG_DEV_PKT, + "UDP Send (to=%pI4, from=%pI4, len=%d)\n", + &dest, &net_ip, payload_len); + }
/* make sure the net_tx_packet is initialized (net_init() was called) */ assert(net_tx_packet != NULL); @@ -799,9 +812,15 @@ int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, pkt = (uchar *)net_tx_packet;
eth_hdr_size = net_set_ether(pkt, ether, PROT_IP); - pkt += eth_hdr_size; - net_set_udp_header(pkt, dest, dport, sport, payload_len); - pkt_hdr_size = eth_hdr_size + IP_UDP_HDR_SIZE; + switch (proto) { + case IPPROTO_UDP: + net_set_udp_header(pkt + eth_hdr_size, dest, + dport, sport, payload_len); + pkt_hdr_size = eth_hdr_size + IP_UDP_HDR_SIZE; + break; + default: + return -1; + }
/* if MAC address was not discovered yet, do an ARP request */ if (memcmp(ether, net_null_ethaddr, 6) == 0) { @@ -1157,9 +1176,6 @@ void net_process_received_packet(uchar *in_packet, int len) /* Can't deal with anything except IPv4 */ if ((ip->ip_hl_v & 0xf0) != 0x40) return; - /* Can't deal with IP options (headers != 20 bytes) */ - if ((ip->ip_hl_v & 0x0f) > 0x05) - return; /* Check the Checksum of the header */ if (!ip_checksum_ok((uchar *)ip, IP_HDR_SIZE)) { debug("checksum bad\n"); @@ -1205,6 +1221,7 @@ void net_process_received_packet(uchar *in_packet, int len) * we send a tftp packet to a dead connection, or when * there is no server at the other end. */ + if (ip->ip_p == IPPROTO_ICMP) { receive_icmp(ip, len, src_ip, et); return; @@ -1365,8 +1382,7 @@ common: } /**********************************************************************/
-int -net_eth_hdr_size(void) +int net_eth_hdr_size(void) { ushort myvlanid;
@@ -1426,25 +1442,28 @@ int net_update_ether(struct ethernet_hdr *et, uchar *addr, uint prot) } }
-void net_set_ip_header(uchar *pkt, struct in_addr dest, struct in_addr source) +void net_set_ip_header(uchar *pkt, struct in_addr dest, struct in_addr source, + u16 pkt_len, u8 prot) { struct ip_udp_hdr *ip = (struct ip_udp_hdr *)pkt;
/* - * Construct an IP header. + * Construct an IP header. */ /* IP_HDR_SIZE / 4 (not including UDP) */ ip->ip_hl_v = 0x45; ip->ip_tos = 0; - ip->ip_len = htons(IP_HDR_SIZE); + ip->ip_len = htons(pkt_len); ip->ip_id = htons(net_ip_id++); - ip->ip_off = htons(IP_FLAGS_DFRAG); /* Don't fragment */ + ip->ip_off = htons(IP_FLAGS_DFRAG); /* Don't fragment */ ip->ip_ttl = 255; + ip->ip_p = prot; ip->ip_sum = 0; /* already in network byte order */ net_copy_ip((void *)&ip->ip_src, &source); /* already in network byte order */ net_copy_ip((void *)&ip->ip_dst, &dest); + ip->ip_sum = compute_ip_checksum(ip, IP_HDR_SIZE); }
void net_set_udp_header(uchar *pkt, struct in_addr dest, int dport, int sport, @@ -1460,11 +1479,8 @@ void net_set_udp_header(uchar *pkt, struct in_addr dest, int dport, int sport, if (len & 1) pkt[IP_UDP_HDR_SIZE + len] = 0;
- net_set_ip_header(pkt, dest, net_ip); - ip->ip_len = htons(IP_UDP_HDR_SIZE + len); - ip->ip_p = IPPROTO_UDP; - ip->ip_sum = compute_ip_checksum(ip, IP_HDR_SIZE); - + net_set_ip_header(pkt, dest, net_ip, IP_UDP_HDR_SIZE + len, + IPPROTO_UDP); ip->udp_src = htons(sport); ip->udp_dst = htons(dport); ip->udp_len = htons(UDP_HDR_SIZE + len); diff --git a/net/ping.c b/net/ping.c index 9508cf1160..254b646193 100644 --- a/net/ping.c +++ b/net/ping.c @@ -20,16 +20,11 @@ struct in_addr net_ping_ip; static void set_icmp_header(uchar *pkt, struct in_addr dest) { /* - * Construct an IP and ICMP header. + * Construct an ICMP header. */ - struct ip_hdr *ip = (struct ip_hdr *)pkt; struct icmp_hdr *icmp = (struct icmp_hdr *)(pkt + IP_HDR_SIZE);
- net_set_ip_header(pkt, dest, net_ip); - - ip->ip_len = htons(IP_ICMP_HDR_SIZE); - ip->ip_p = IPPROTO_ICMP; - ip->ip_sum = compute_ip_checksum(ip, IP_HDR_SIZE); + net_set_ip_header(pkt, dest, net_ip, IP_ICMP_HDR_SIZE, IPPROTO_ICMP);
icmp->type = ICMP_ECHO_REQUEST; icmp->code = 0;
Commit-notes
Routine tcp_print_buffer() is used to print portions of non zero terminated buffers. If there is an existing routine please let me know. I'm from the world of length fields not zero terminated strings (zOS).
TCP Prtocol stack,
Why TCP:
Currently u-boot file transfers are done using tftp or NFS, both over udp. This requires a request to be sent from client (u-boot) to the boot server for every block of data.
Using a large block size, one greater than the Ethernet maximum frame size limitation, would require fragmentation, which u-boot supports. However, missing fragment recovery requires timeout detection and re-transmission requests for missing fragments.
END
include/net.h | 8 +- include/net/tcp.h | 218 ++++++++++++++++ net/Kconfig | 35 +-- net/Makefile | 2 +- net/net.c | 51 +++- net/tcp.c | 749 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ 6 files changed, 1024 insertions(+), 39 deletions(-) create mode 100644 include/net/tcp.h create mode 100644 net/tcp.c
diff --git a/include/net.h b/include/net.h index 7e5f5a6a5b..e29d804a23 100644 --- a/include/net.h +++ b/include/net.h @@ -548,7 +548,7 @@ extern int net_restart_wrap; /* Tried all network devices */
enum proto_t { BOOTP, RARP, ARP, TFTPGET, DHCP, PING, DNS, NFS, CDP, NETCONS, SNTP, - TFTPSRV, TFTPPUT, LINKLOCAL + TFTPSRV, TFTPPUT, LINKLOCAL, WGET };
extern char net_boot_file_name[1024];/* Boot File name */ @@ -681,11 +681,15 @@ static inline void net_send_packet(uchar *pkt, int len) * @param payload_len Length of data after the UDP header */ int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, - int payload_len, int proto); + int payload_len, int proto, u8 action, u32 tcp_seq_num, + u32 tcp_ack_num);
+int net_send_tcp_packet(int payload_len, int dport, int sport, u8 action, + u32 tcp_seq_num, u32 tcp_ack_num); + /* Processes a received packet */ void net_process_received_packet(uchar *in_packet, int len);
diff --git a/include/net/tcp.h b/include/net/tcp.h new file mode 100644 index 0000000000..81f263351e --- /dev/null +++ b/include/net/tcp.h @@ -0,0 +1,218 @@ +/* + * TCP Support for file transfer. + * + * Copyright 2017 Duncan Hare, All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#define TCP_ACTIVITY 127 /* Activity on downloading */ + +struct ip_tcp_hdr { + u8 ip_hl_v; /* header length and version */ + u8 ip_tos; /* type of service */ + u16 ip_len; /* total length */ + u16 ip_id; /* identification */ + u16 ip_off; /* fragment offset field */ + u8 ip_ttl; /* time to live */ + u8 ip_p; /* protocol */ + u16 ip_sum; /* checksum */ + struct in_addr ip_src; /* Source IP address */ + struct in_addr ip_dst; /* Destination IP address */ + u16 tcp_src; /* TCP source port */ + u16 tcp_dst; /* TCP destination port */ + u32 tcp_seq; /* TCP sequence number */ + u32 tcp_ack; /* TCP Acknowledgment number */ + u8 tcp_hlen; /* 4 bits TCP header Length/4 */ + /* 4 bits Reserved */ + /* 2 more bits reserved */ + u8 tcp_flags; /* see defines */ + u16 tcp_win; /* TCP windows size */ + u16 tcp_xsum; /* Checksum */ + u16 tcp_ugr; /* Pointer to urgent data */ +} __packed; + +#define IP_TCP_HDR_SIZE (sizeof(struct ip_tcp_hdr)) +#define TCP_HDR_SIZE (IP_TCP_HDR_SIZE - IP_HDR_SIZE) + +#define TCP_DATA 0x00 /* Data Packet - internal use only */ +#define TCP_FIN 0x01 /* Finish flag */ +#define TCP_SYN 0x02 /* Synch (start) flag */ +#define TCP_RST 0x04 /* reset flag */ +#define TCP_PUSH 0x08 /* Push - Notify app */ +#define TCP_ACK 0x10 /* Acknowledgment of data received */ +#define TCP_URG 0x20 /* Urgent */ +#define TCP_ECE 0x40 /* Congestion control */ +#define TCP_CWR 0x80 /* Congestion Control */ + +/* + * TCP header options, Seq, MSS, and SACK + */ + +#define TCP_SACK 32 /* Number of packets analyzed */ + /* on leading edge of stream */ + +#define TCP_O_END 0x00 /* End of option list */ +#define TCP_1_NOP 0x01 /* Single padding NOP */ +#define TCP_O_NOP 0x01010101 /* NOPs pad to 32 bit boundary */ +#define TCP_O_MSS 0x02 /* MSS Size option */ +#define TCP_O_SCL 0x03 /* Window Scale option */ +#define TCP_P_SACK 0x04 /* SACK permitted */ +#define TCP_V_SACK 0x05 /* SACK values */ +#define TCP_O_TS 0x08 /* Timestanp option */ +#define TCP_OPT_LEN_2 0x02 +#define TCP_OPT_LEN_3 0x03 +#define TCP_OPT_LEN_4 0x04 +#define TCP_OPT_LEN_6 0x06 +#define TCP_OPT_LEN_8 0x08 +#define TCP_OPT_LEN_A 0x0a /* Timestamp Length */ + +/* + * Please review the warning in net.c about these two parameters. + * They are part of a promise of RX buffer size to the sending TCP + */ + +#define TCP_MSS 1460 /* Max segment size - 1460 */ +#define TCP_SCALE 0x01 /* Scale 1 */ + +struct tcp_mss { /* TCP Mex Segment size */ + u8 kind; /* 0x02 */ + u8 len; /* 0x04 */ + u16 mss; /* 1460 - Max segment size */ +} __packed; + +struct tcp_scale { /* TCP Windows Scale */ + u8 kind; /* 0x03 */ + u8 len; /* 0x03 */ + u8 scale; /* win shift fat fast networks */ +} __packed; + +struct tcp_sack_p { /* SACK permitted */ + u8 kind; /* 0x04 */ + u8 len; /* Length */ +} __packed; + +struct sack_edges { + u32 l; + u32 r; +} __packed; + +#define TCP_SACK_SIZE (sizeof(struct sack_edges)) + +#define TCP_SACK_HILLS 4 + +struct tcp_sack_v { + u8 kind; /* 0x05 */ + u8 len; /* Length */ + struct sack_edges hill[TCP_SACK_HILLS]; /* L & R widow edges */ +} __packed; + +struct tcp_t_opt { /* TCP time stamps option */ + u8 kind; /* 0x08 */ + u8 len; /* 0x0a */ + u32 t_snd; /* Sender timestamp */ + u32 t_rcv; /* Receiver timestamp */ +} __packed; + +#define TCP_TSOPT_SIZE (sizeof(struct tcp_t_opt)) + +/* + * ip tcp structure with options + */ + +struct ip_tcp_hdr_o { + struct ip_tcp_hdr hdr; + struct tcp_mss mss; + struct tcp_scale scale; + struct tcp_sack_p sack_p; + struct tcp_t_opt t_opt; + u8 end; +} __packed; + +#define IP_TCP_O_SIZE (sizeof(struct ip_tcp_hdr_o)) + +struct ip_tcp_hdr_s { + struct ip_tcp_hdr hdr; + struct tcp_t_opt t_opt; + struct tcp_sack_v sack_v; + u8 end; +} __packed; + +#define IP_TCP_SACK_SIZE (sizeof(struct ip_tcp_hdr_s)) + +/* + * TCP pseudo header definitions + */ +#define PSEUDO_PAD_SIZE 8 + +struct pseudo_hdr { + u8 padding[PSEUDO_PAD_SIZE]; /* pseudo hdr size = ip_tcp hdr size */ + struct in_addr p_src; + struct in_addr p_dst; + u8 rsvd; + u8 p; + u16 len; +} __packed; + +#define PSEUDO_HDR_SIZE (sizeof(struct pseudo_hdr)) - PSEUDO_PAD_SIZE + +/* + * union for building IP/TCP packet. + * build Pseudo header in packed buffer first, calculate TCP checksum + * then build IP header in packed buffer. + */ + +union tcp_build_pkt { + struct pseudo_hdr ph; + struct ip_tcp_hdr_o ip; + struct ip_tcp_hdr_s sack; + uchar raw[1600]; +} __packed; + +/* + * TCP STATE MACHINE STATES FOR SOCKET + */ + +enum TCP_STATE { + TCP_CLOSED, /* Need to send SYN to connect */ + TCP_SYN_SENT, /* Trying to connect, waiting for SYN ACK */ + TCP_ESTABLISHED, /* both server & client have a connection */ + TCP_CLOSE_WAIT, /* Rec FIN, passed to app for FIN, ACK rsp*/ + TCP_CLOSING, /* Rec FIN, sent FIN, ACK waiting for ACK */ + TCP_FIN_WAIT_1, /* Sent FIN waiting for response */ + TCP_FIN_WAIT_2 /* Rec ACK from FIN sent, waiting for FIN */ +}; + +int tcp_find_in_buffer(uchar raw[], int payload_len, uchar field[], + int field_len); +void tcp_print_buffer(uchar raw[], int pkt_len, int payload_len, + int hdr_len, bool hide); +enum TCP_STATE tcp_get_tcp_state(void); +void tcp_set_tcp_state(enum TCP_STATE new_state); +int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, + u8 action, u32 tcp_seq_num, u32 tcp_ack_num); + +/* + * An incoming packet handler. + * @param pkt pointer to the application packet + * @param dport destination UDP port + * @param sip source IP address + * @param sport source UDP port + * @param len packet length + */ +typedef void rxhand_tcp(uchar *pkt, unsigned int dport, + struct in_addr sip, unsigned int sport, + unsigned int len); +void tcp_set_tcp_handler(rxhand_tcp *f); + +void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int len); + +/* + * An incoming TCP packet handler for the TCP protocol. + * There is also a dynamic function pointer for TCP based commands to + * receive incoming traffic after the TCP protocol code has done its work. + */ + +void rxhand_action(u8 tcp_action, int payload_len, u32 tcp_seq_num, + u32 tcp_ack_num, unsigned int pkt_len, + union tcp_build_pkt *b); diff --git a/net/Kconfig b/net/Kconfig index 143c4416cd..895b93dea9 100644 --- a/net/Kconfig +++ b/net/Kconfig @@ -4,12 +4,12 @@
menuconfig NET bool "Networking support" - default y
if NET
config NET_RANDOM_ETHADDR bool "Random ethaddr if unset" + select LIB_RAND help Selecting this will allow the Ethernet interface to function even when the ethaddr variable for that interface is unset. @@ -24,7 +24,6 @@ config NETCONSOLE
config NET_TFTP_VARS bool "Control TFTP timeout and count through environment" - depends on CMD_NET default y help If set, allows controlling the TFTP timeout through the @@ -33,44 +32,22 @@ config NET_TFTP_VARS If unset, timeout and maximum are hard-defined as 1 second and 10 timouts per TFTP transfer.
-config BOOTP_BOOTPATH - bool "Enable BOOTP BOOTPATH" - depends on CMD_NET - -config BOOTP_DNS - bool "Enable bootp DNS" - depends on CMD_NET - -config BOOTP_GATEWAY - bool "Enable BOOTP gateway" - depends on CMD_NET - -config BOOTP_HOSTNAME - bool "Enable BOOTP hostname" - depends on CMD_NET - -config BOOTP_PXE - bool "Enable BOOTP PXE" - depends on CMD_NET - -config BOOTP_SUBNETMASK - bool "Enable BOOTP subnetmask" - depends on CMD_NET - depends on CMD_NET - config BOOTP_PXE_CLIENTARCH hex - depends on CMD_NET default 0x16 if ARM64 default 0x15 if ARM default 0 if X86
config BOOTP_VCI_STRING string - depends on CMD_NET default "U-Boot.armv7" if CPU_V7 || CPU_V7M default "U-Boot.armv8" if ARM64 default "U-Boot.arm" if ARM default "U-Boot"
+config TCP + bool "Include TCP for receiving files" + help + TCP support for receiving files. + endif # if NET diff --git a/net/Makefile b/net/Makefile index ae54eee5af..25729ebeeb 100644 --- a/net/Makefile +++ b/net/Makefile @@ -25,7 +25,7 @@ obj-$(CONFIG_CMD_PING) += ping.o obj-$(CONFIG_CMD_RARP) += rarp.o obj-$(CONFIG_CMD_SNTP) += sntp.o obj-$(CONFIG_CMD_NET) += tftp.o - +obj-$(CONFIG_TCP) += tcp.o # Disable this warning as it is triggered by: # sprintf(buf, index ? "foo%d" : "foo", index) # and this is intentional usage. diff --git a/net/net.c b/net/net.c index df4e7317e7..7adc4b472c 100644 --- a/net/net.c +++ b/net/net.c @@ -107,6 +107,9 @@ #if defined(CONFIG_CMD_SNTP) #include "sntp.h" #endif +#if defined(CONFIG_TCP) +#include <net/tcp.h> +#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -382,6 +385,9 @@ void net_init(void)
/* Only need to setup buffer pointers once. */ first_call = 0; +#if defined(CONFIG_TCP) + tcp_set_tcp_state(TCP_CLOSED); +#endif }
net_init_loop(); @@ -781,11 +787,22 @@ int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, int payload_len) { return net_send_ip_packet(ether, dest, dport, sport, payload_len, - IPPROTO_UDP); + IPPROTO_UDP, 0, 0, 0); +} + +#if defined(CONFIG_TCP) +int net_send_tcp_packet(int payload_len, int dport, int sport, u8 action, + u32 tcp_seq_num, u32 tcp_ack_num) +{ + return net_send_ip_packet(net_server_ethaddr, net_server_ip, dport, + sport, payload_len, IPPROTO_TCP, action, + tcp_seq_num, tcp_ack_num); } +#endif
int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, - int payload_len, int proto) + int payload_len, int proto, u8 action, u32 tcp_seq_num, + u32 tcp_ack_num) { uchar *pkt; int eth_hdr_size; @@ -794,6 +811,13 @@ int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, debug_cond(DEBUG_DEV_PKT, "UDP Send (to=%pI4, from=%pI4, len=%d)\n", &dest, &net_ip, payload_len); +#if defined(CONFIG_TCP) + + } else { + debug_cond(DEBUG_DEV_PKT, + "TCP Send (%pI4, %pI4, len=%d, A=%x)\n", + &dest, &net_ip, payload_len, action); +#endif }
/* make sure the net_tx_packet is initialized (net_init() was called) */ @@ -812,15 +836,19 @@ int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, pkt = (uchar *)net_tx_packet;
eth_hdr_size = net_set_ether(pkt, ether, PROT_IP); - switch (proto) { - case IPPROTO_UDP: + if (proto == IPPROTO_UDP) { net_set_udp_header(pkt + eth_hdr_size, dest, dport, sport, payload_len); pkt_hdr_size = eth_hdr_size + IP_UDP_HDR_SIZE; - break; - default: - return -1; + +#if defined(CONFIG_TCP) + } else { + pkt_hdr_size = eth_hdr_size + + tcp_set_tcp_header(pkt + eth_hdr_size, dport, sport, + payload_len, action, + tcp_seq_num, tcp_ack_num); } +#endif
/* if MAC address was not discovered yet, do an ARP request */ if (memcmp(ether, net_null_ethaddr, 6) == 0) { @@ -1225,6 +1253,15 @@ void net_process_received_packet(uchar *in_packet, int len) if (ip->ip_p == IPPROTO_ICMP) { receive_icmp(ip, len, src_ip, et); return; +#if defined(CONFIG_TCP) + } else if (ip->ip_p == IPPROTO_TCP) { + debug_cond(DEBUG_DEV_PKT, + "TCP PH (to=%pI4, from=%pI4, len=%d)\n", + &dst_ip, &src_ip, len); + + rxhand_tcp_f((union tcp_build_pkt *)ip, len); + return; +#endif } else if (ip->ip_p != IPPROTO_UDP) { /* Only UDP packets */ return; } diff --git a/net/tcp.c b/net/tcp.c new file mode 100644 index 0000000000..612a6a4b7d --- /dev/null +++ b/net/tcp.c @@ -0,0 +1,749 @@ +/* + * Copyright 2017 Duncan Hare, all rights reserved. + * SPDX-License-Identifier: GPL-2.0 + */ + +/* + * General Desription: + * + * TCP support for the wget command, for fast file downloading. + * + * HTTP/TCP Receiver: + * + * Prequeisites: - own ethernet address + * - own IP address + * - Server IP address + * - Server with TCP + * - TCP application (eg wget) + * Next Step HTTPS? + */ +#include <common.h> +#include <command.h> +#include <console.h> +#include <environment.h> +#include <errno.h> +#include <net.h> +#include <net/tcp.h> +#if defined(CONFIG_CMD_WGET) +#include "net/wget.h" +#endif + +/* + * TCP sliding window control + * used by us to request re-TX + */ + +static struct tcp_sack_v tcp_lost; + +/* TCP option timestamp */ +static u32 loc_timestamp; +static u32 rmt_timestamp; + +u32 tcp_seq_init; +u32 tcp_ack_edge; +u32 tcp_seq_max; + +int tcp_activity_count; + +/* + * Search for TCP_SACK and review the + * comments before the code section + * TCP_SACK is the number of packets + * at the front of the stream + */ + +enum pkt_state {PKT, NOPKT}; +struct sack_r { + struct sack_edges se; + enum pkt_state st; +}; + +struct sack_r edge_a[TCP_SACK]; +unsigned int sack_idx; +unsigned int prev_len; + +/* TCP connection state */ +static enum TCP_STATE tcp_state; + +/* + * An incoming TCP packet handler for the TCP protocol. + * There is also a dymanic function pointer for TCP based commads to + * receive incoming traffic after the TCP protocol code has done its work. + */ + +/* Current TCP RX packet handler */ +static rxhand_tcp *tcp_packet_handler; + +enum TCP_STATE tcp_get_tcp_state(void) +{ + return tcp_state; +} + +void tcp_set_tcp_state(enum TCP_STATE new_state) +{ + tcp_state = new_state; +} + +void tcp_print_buffer(uchar raw[], int pkt_len, int payload_len, + int hdr_len, bool hide) +{ + int i; + + for (i = pkt_len - payload_len; i < pkt_len; i++) { + if (i <= hdr_len) + printf("%02X", raw[i]); + else if ((raw[i] > 0x19) && (raw[i] < 0x7f)) + putc(raw[i]); + else if (hide == 0) + putc(raw[i]); + else + printf("%02X", raw[i]); + } + printf("%s", "\n"); +} + +int tcp_find_in_buffer(uchar raw[], int payload_len, uchar field[], + int field_len) +{ + int i, j; + + for (i = 0; i < payload_len; i++) { + if (raw[i] == field[0]) { + for (j = 1; j < field_len; j++) { + if (raw[i + j] != field[j]) + break; + if (j == field_len) + return i; + } + } + } + return 0; +} + +static void dummy_handler(uchar *pkt, unsigned int dport, + struct in_addr sip, unsigned int sport, + unsigned int len) +{ +} + +void tcp_set_tcp_handler(rxhand_tcp *f) +{ + debug_cond(DEBUG_INT_STATE, "--- net_loop TCP handler set (%p)\n", f); + if (!f) + tcp_packet_handler = dummy_handler; + else + tcp_packet_handler = f; +} + +u16 tcp_set_pseudo_header(uchar *pkt, struct in_addr src, struct in_addr dest, + int tcp_len, int pkt_len) +{ + union tcp_build_pkt *b = (union tcp_build_pkt *)pkt; + int checksum_len; + + /* + * Pseudo header + * + * Zero the byte after the last byte so that the header checksum + * will always work. + */ + + pkt[pkt_len] = 0x00; + + net_copy_ip((void *)&b->ph.p_src, &src); + net_copy_ip((void *)&b->ph.p_dst, &dest); + b->ph.rsvd = 0x00; + b->ph.p = IPPROTO_TCP; + b->ph.len = htons(tcp_len); + checksum_len = tcp_len + PSEUDO_HDR_SIZE; + + debug_cond(DEBUG_DEV_PKT, + "TCP Pesudo Header (to=%pI4, from=%pI4, Len=%d)\n", + &b->ph.p_dst, &b->ph.p_src, checksum_len); + + return compute_ip_checksum(pkt + PSEUDO_PAD_SIZE, checksum_len); +} + +int net_set_ack_options(union tcp_build_pkt *b) +{ + b->sack.hdr.tcp_hlen = (TCP_HDR_SIZE >> 2) << 4; + + b->sack.t_opt.kind = TCP_O_TS; + b->sack.t_opt.len = TCP_OPT_LEN_A; + b->sack.t_opt.t_snd = htons(loc_timestamp); + b->sack.t_opt.t_rcv = rmt_timestamp; + b->sack.sack_v.kind = 0x01; + b->sack.sack_v.len = 0x00; + + if (tcp_lost.len > TCP_OPT_LEN_2) { + debug_cond(DEBUG_DEV_PKT, "TCP ack opt lost.len %x\n", + tcp_lost.len); + b->sack.sack_v.len = tcp_lost.len; + b->sack.sack_v.kind = TCP_V_SACK; + b->sack.sack_v.hill[0].l = htonl(tcp_lost.hill[0].l); + b->sack.sack_v.hill[0].r = htonl(tcp_lost.hill[0].r); + + /* + * These SACK structures are initialized with NOPs to + * provide TCP header alignment padding. There are 4 + * SACK structures used for both header padding and + * internally. + */ + + b->sack.sack_v.hill[1].l = htonl(tcp_lost.hill[1].l); + b->sack.sack_v.hill[1].r = htonl(tcp_lost.hill[1].r); + b->sack.sack_v.hill[2].l = htonl(tcp_lost.hill[2].l); + b->sack.sack_v.hill[2].r = htonl(tcp_lost.hill[2].r); + b->sack.sack_v.hill[3].l = TCP_O_NOP; + b->sack.sack_v.hill[3].r = TCP_O_NOP; + } + + /* + * TCP lengths are stored as a rounded up number of 32 bit words + * Add 3 to length round up, rounded, then divided into the length + * in 32 bit words. + */ + + b->sack.hdr.tcp_hlen = (((TCP_HDR_SIZE + TCP_TSOPT_SIZE + + tcp_lost.len + 3) >> 2) << 4); + + /* + * This returns the actual rounded up length of the + * TCP header to add to the total packet length + */ + + return b->sack.hdr.tcp_hlen >> 2; +} + +void net_set_syn_options(union tcp_build_pkt *b) +{ + tcp_lost.len = 0; + b->ip.hdr.tcp_hlen = 0xa0; + + b->ip.mss.kind = TCP_O_MSS; + b->ip.mss.len = TCP_OPT_LEN_4; + b->ip.mss.mss = htons(TCP_MSS); + b->ip.scale.kind = TCP_O_SCL; + b->ip.scale.scale = TCP_SCALE; + b->ip.scale.len = TCP_OPT_LEN_3; + b->ip.sack_p.kind = TCP_P_SACK; + b->ip.sack_p.len = TCP_OPT_LEN_2; + b->ip.t_opt.kind = TCP_O_TS; + b->ip.t_opt.len = TCP_OPT_LEN_A; + loc_timestamp = get_ticks() % 3072; + rmt_timestamp = 0x00000000; + b->ip.t_opt.t_snd = 0; + b->ip.t_opt.t_rcv = 0x00000000; + b->ip.end = TCP_O_END; +} + +int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, + u8 action, u32 tcp_seq_num, u32 tcp_ack_num) +{ + union tcp_build_pkt *b = (union tcp_build_pkt *)pkt; + int pkt_hdr_len; + int pkt_len; + int tcp_len; + + b->ip.hdr.tcp_flags = action; + pkt_hdr_len = IP_TCP_HDR_SIZE; + b->ip.hdr.tcp_hlen = 0x50; /* Header is 5 32 bit words */ + /* 4 bits TCP header Length/4*/ + /* 4 bits Reserved */ + /* For options */ + switch (action) { + case TCP_SYN: + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:SYN (%pI4, %pI4, sq=%d, ak=%d)\n", + &net_server_ip, &net_ip, + tcp_seq_num, tcp_ack_num); + tcp_activity_count = 0; + net_set_syn_options(b); + tcp_seq_num = 0; + tcp_ack_num = 0; + pkt_hdr_len = IP_TCP_O_SIZE; + if (tcp_state == TCP_SYN_SENT) { /* Too many sins */ + action = TCP_FIN; + tcp_state = TCP_FIN_WAIT_1; + } else { + tcp_state = TCP_SYN_SENT; + } + break; + case TCP_ACK: + pkt_hdr_len = IP_HDR_SIZE + + net_set_ack_options(b); + b->ip.hdr.tcp_flags = action; + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:ACK (%pI4, %pI4, s=%d, a=%d, A=%x)\n", + &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num, + action); + break; + case TCP_FIN: + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:FIN (%pI4, %pI4, s=%d, a=%d)\n", + &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num); + payload_len = 0; + pkt_hdr_len = IP_TCP_HDR_SIZE; + tcp_state = TCP_FIN_WAIT_1; + + break; + + /* Notify connection closing */ + + case (TCP_FIN | TCP_ACK): + case ((TCP_FIN | TCP_ACK) | TCP_PUSH): + if (tcp_state == TCP_CLOSE_WAIT) + tcp_state = TCP_CLOSING; + tcp_ack_edge++; + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:FIN ACK PSH(%pI4, %pI4, s=%d, a=%d, A=%x)\n", + &net_server_ip, &net_ip, + tcp_seq_num, tcp_ack_edge, action); + /* FALLTHRU */ + default: + pkt_hdr_len = IP_HDR_SIZE + + net_set_ack_options(b); + b->ip.hdr.tcp_flags = action | TCP_PUSH | TCP_ACK; + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:dft (%pI4, %pI4, s=%d, a=%d, A=%x)\n", + &net_server_ip, &net_ip, + tcp_seq_num, tcp_ack_num, action); + } + + pkt_len = pkt_hdr_len + payload_len; + tcp_len = pkt_len - IP_HDR_SIZE; + + /* TCP Header */ + b->ip.hdr.tcp_ack = htonl(tcp_ack_edge); + b->ip.hdr.tcp_src = htons(sport); + b->ip.hdr.tcp_dst = htons(dport); + b->ip.hdr.tcp_seq = htonl(tcp_seq_num); + tcp_seq_num = tcp_seq_num + payload_len; + + /* + * TCP window size - TCP header variable tcp_win. + * Change tcp_win only if you have an understanding of network + * overrun, congestion, TCP segment sizes, TCP windows, TCP scale, + * queuing theory and packet buffering. If there are too few buffers, + * there will be data loss, recovery may work or the sending TCP, + * the server, could abort the stream transmission. + * MSS is governed by maximum Ethernet frame length. + * The number of buffers is governed by the desire to have a queue of + * full buffers to be processed at the destination to maximize + * throughput. Temporary memory use for the boot phase on modern + * SOCs is may not be considered a constraint to buffer space, if + * it is, then the u-boot tftp or nfs kernel netboot should be + * considered. + */ + + b->ip.hdr.tcp_win = htons(PKTBUFSRX * TCP_MSS >> TCP_SCALE); + + b->ip.hdr.tcp_xsum = 0x0000; + b->ip.hdr.tcp_ugr = 0x0000; + + b->ip.hdr.tcp_xsum = tcp_set_pseudo_header(pkt, net_ip, net_server_ip, + tcp_len, pkt_len); + + /* + * IP Header + */ + + net_set_ip_header((uchar *)&b->ip, net_server_ip, net_ip, + pkt_len, IPPROTO_TCP); + + return pkt_hdr_len; +} + +/* + * Selective Acknowledgment (Essential for fast stream transfer) + * + * Before modifying this section of code, which the author found difficult + * to write, please be familiar with the SACK (Selective Acknowledgment) RFCs. + */ + +void tcp_hole(u32 tcp_seq_num, u32 len, u32 tcp_seq_max) +{ + unsigned int idx_sack; + unsigned int sack_end = TCP_SACK - 1; + unsigned int sack_in; + unsigned int hill = 0; + enum pkt_state expect = PKT; + + u32 seq = tcp_seq_num - tcp_seq_init; + u32 hol_l = tcp_ack_edge - tcp_seq_init; + u32 hol_r = 0; + + /* Place seq number in correct place */ + + if (prev_len == 0) + prev_len = len; + idx_sack = sack_idx + ((tcp_seq_num - tcp_ack_edge) / prev_len); + if (idx_sack < TCP_SACK) { + edge_a[idx_sack].se.l = tcp_seq_num; + edge_a[idx_sack].se.r = tcp_seq_num + len; + edge_a[idx_sack].st = PKT; + + /* The fin (last) packet is not the same length as data packets, + * and if it's length is recorded and used for array index + * the array index calculations break. + */ + if (prev_len < len) + prev_len = len; + } + + debug_cond(DEBUG_DEV_PKT, + "TCP 1 seq %d, edg %d, len %d, sack_idx %d, sack_end %d\n", + seq, hol_l, len, sack_idx, sack_end); + + /* Right edge of contiguous stream, is the left edge of first hill */ + + hol_l = tcp_seq_num - tcp_seq_init; + hol_r = hol_l + len; + + tcp_lost.len = TCP_OPT_LEN_2; + + debug_cond(DEBUG_DEV_PKT, + "TCP 1 in %d, seq %d, pkt_l %d, pkt_r %d, sack_idx %d, sack_end %d\n", + idx_sack, seq, hol_l, hol_r, sack_idx, sack_end); + + for (sack_in = sack_idx; sack_in < sack_end && hill < TCP_SACK_HILLS; + sack_in++) { + switch (expect) { + case NOPKT: + switch (edge_a[sack_in].st) { + case NOPKT: + debug_cond(DEBUG_INT_STATE, "N"); + break; + case PKT: + debug_cond(DEBUG_INT_STATE, "n"); + tcp_lost.hill[hill].l = + edge_a[sack_in].se.l; + tcp_lost.hill[hill].r = + edge_a[sack_in].se.r; + expect = PKT; + break; + } + break; + case PKT: + switch (edge_a[sack_in].st) { + case NOPKT: + debug_cond(DEBUG_INT_STATE, "p"); + if ((sack_in > sack_idx) && + (hill < TCP_SACK_HILLS)) { + hill++; + tcp_lost.len += TCP_OPT_LEN_8; + } + expect = NOPKT; + break; + case PKT: + debug_cond(DEBUG_INT_STATE, "P"); + + if (tcp_ack_edge == edge_a[sack_in].se.l) { + tcp_ack_edge = edge_a[sack_in].se.r; + edge_a[sack_in].st = NOPKT; + sack_idx++; + } else { + if (hill < TCP_SACK_HILLS) + tcp_lost.hill[hill].r = + edge_a[sack_in].se.r; + if (sack_in == sack_end - 1) + tcp_lost.hill[hill].r = + edge_a[sack_in].se.r; + } + break; + } + break; + } + } + debug_cond(DEBUG_INT_STATE, "\n"); + if (tcp_lost.len <= TCP_OPT_LEN_2) + sack_idx = 0; +} + +void tcp_parse_options(uchar *o, int o_len) +{ + struct tcp_t_opt *tsopt; + uchar *p = o; + + for (p = o; p < (o + o_len); p = p + p[1]) { + if (p[1] != 0) { + switch (p[0]) { + case TCP_O_END: + return; + case TCP_O_MSS: + break; + case TCP_O_SCL: + break; + case TCP_P_SACK: + break; + case TCP_V_SACK: + break; + case TCP_O_TS: + tsopt = (struct tcp_t_opt *)p; + rmt_timestamp = tsopt->t_snd; + return; + break; + } + if (p[0] == TCP_O_NOP) + p++; + } else { + return; + } + } +} + +u8 tcp_state_machine(u8 tcp_flags, u32 *tcp_seq_num, int payload_len) +{ + u8 tcp_fin = tcp_flags & TCP_FIN; + u8 tcp_syn = tcp_flags & TCP_SYN; + u8 tcp_rst = tcp_flags & TCP_RST; + u8 tcp_push = tcp_flags & TCP_PUSH; + u8 tcp_ack = tcp_flags & TCP_ACK; + u8 action = TCP_DATA; + int i; + + /* + * tcp_flags are examined to determine TX action in a given state + * tcp_push is interpreted to mean "inform the app" + * urg, ece, cer and nonce flags are not supported. + * + * exe and crw are use to signal and confirm knowledge of congestion. + * This TCP only sends a file request and acks. If it generates + * congestion, the network is broken. + */ + + debug_cond(DEBUG_INT_STATE, "TCP STATE ENTRY %x\n", action); + if (tcp_rst) { + action = TCP_DATA; + tcp_state = TCP_CLOSED; + net_set_state(NETLOOP_FAIL); + debug_cond(DEBUG_INT_STATE, "TCP Reset %x\n", tcp_flags); + return TCP_RST; + } + + switch (tcp_state) { + case TCP_CLOSED: + debug_cond(DEBUG_INT_STATE, "TCP CLOSED %x\n", tcp_flags); + if (tcp_fin) + action = TCP_DATA; + if (tcp_syn) + action = TCP_RST; + if (tcp_ack) + action = TCP_DATA; + break; + case TCP_SYN_SENT: + debug_cond(DEBUG_INT_STATE, "TCP_SYN_SENT %x, %d\n", + tcp_flags, *tcp_seq_num); + if (tcp_fin) { + action = action | TCP_PUSH; + tcp_state = TCP_CLOSE_WAIT; + } + if (tcp_syn) { + action = action | TCP_ACK | TCP_PUSH; + if (tcp_ack) { + tcp_seq_init = *tcp_seq_num; + *tcp_seq_num = *tcp_seq_num + 1; + tcp_seq_max = *tcp_seq_num; + tcp_ack_edge = *tcp_seq_num; + sack_idx = 0; + edge_a[sack_idx].se.l = *tcp_seq_num; + edge_a[sack_idx].se.r = *tcp_seq_num; + prev_len = 0; + tcp_state = TCP_ESTABLISHED; + for (i = 0; i < TCP_SACK; i++) + edge_a[i].st = NOPKT; + } + } else { + if (tcp_ack) + action = TCP_DATA; + } + break; + case TCP_ESTABLISHED: + debug_cond(DEBUG_INT_STATE, + "TCP_ESTABLISHED %x\n", tcp_flags); + if (*tcp_seq_num > tcp_seq_max) + tcp_seq_max = *tcp_seq_num; + if (payload_len > 0) { + tcp_hole(*tcp_seq_num, payload_len, tcp_seq_max); + tcp_fin = TCP_DATA; /* cause standalone FIN */ + } + + if ((tcp_fin) && (tcp_lost.len <= TCP_OPT_LEN_2)) { + action = action | TCP_FIN | TCP_PUSH | TCP_ACK; + tcp_state = TCP_CLOSE_WAIT; + } else { + if (tcp_ack) + action = TCP_DATA; + } + if (tcp_push) + action = action | TCP_PUSH; + if (tcp_syn) + action = TCP_ACK + TCP_RST; + break; + case TCP_CLOSE_WAIT: + debug_cond(DEBUG_INT_STATE, "TCP_CLOSE_WAIT (%x)\n", tcp_flags); + action = TCP_DATA; /* Wait for app */ + break; + case TCP_FIN_WAIT_2: + debug_cond(DEBUG_INT_STATE, "TCP_FIN_WAIT_2 (%x)\n", tcp_flags); + if (tcp_fin) + action = TCP_DATA; + if (tcp_syn) + action = TCP_DATA; + if (tcp_ack) { + action = TCP_PUSH | TCP_ACK; + tcp_state = TCP_CLOSED; + puts("\n"); + } + break; + case TCP_FIN_WAIT_1: + debug_cond(DEBUG_INT_STATE, "TCP_FIN_WAIT_1 (%x)\n", tcp_flags); + if (tcp_fin) { + action = TCP_ACK | TCP_FIN; + tcp_state = TCP_FIN_WAIT_2; + } + if (tcp_syn) + action = TCP_RST; + if (tcp_ack) { + tcp_state = TCP_CLOSED; + tcp_seq_num = tcp_seq_num + 1; + } + break; + case TCP_CLOSING: + debug_cond(DEBUG_INT_STATE, "TCP_CLOSING (%x)\n", tcp_flags); + if (tcp_fin) + action = TCP_DATA; + if (tcp_syn) + action = TCP_RST; + if (tcp_ack) { + action = TCP_PUSH; + tcp_state = TCP_CLOSED; + puts("\n"); + } + break; + } + return action; +} + +void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) +{ + int tcp_len = pkt_len - IP_HDR_SIZE; + u16 tcp_rx_xsum = b->ip.hdr.ip_sum; + u8 tcp_action = TCP_DATA; + u32 tcp_seq_num; + u32 tcp_ack_num; + struct in_addr action_and_state; + + int tcp_hdr_len; + int payload_len; + + /* + * Verify IP header + */ + debug_cond(DEBUG_DEV_PKT, + "TCP RX in RX Sum (to=%pI4, from=%pI4, len=%d)\n", + &b->ip.hdr.ip_src, &b->ip.hdr.ip_dst, pkt_len); + + debug_cond(DEBUG_DEV_PKT, + "In__________________________________________\n"); + + b->ip.hdr.ip_src = net_server_ip; + b->ip.hdr.ip_dst = net_ip; + b->ip.hdr.ip_sum = 0x0000; + if (tcp_rx_xsum != compute_ip_checksum(b, IP_HDR_SIZE)) { + debug_cond(DEBUG_DEV_PKT, + "TCP RX IP xSum Error (%pI4, =%pI4, len=%d)\n", + &net_ip, &net_server_ip, pkt_len); + return; + } + + /* + * Build Pseudo header and Verify TCP header + */ + tcp_rx_xsum = b->ip.hdr.tcp_xsum; + b->ip.hdr.tcp_xsum = 0x0000; + if (tcp_rx_xsum != tcp_set_pseudo_header((uchar *)b, b->ip.hdr.ip_src, + b->ip.hdr.ip_dst, tcp_len, + pkt_len)) { + debug_cond(DEBUG_DEV_PKT, + "TCP RX TCP xSum Error (%pI4, %pI4, len=%d)\n", + &net_ip, &net_server_ip, tcp_len); + return; + } + + tcp_hdr_len = (b->ip.hdr.tcp_hlen >> 2); + payload_len = tcp_len - tcp_hdr_len; + + if (tcp_hdr_len > TCP_HDR_SIZE) + tcp_parse_options((uchar *)b + IP_TCP_HDR_SIZE, + tcp_hdr_len - TCP_HDR_SIZE); + /* + * Incoming sequence and ack numbers are server's view of the numbers. + * The app must swap the numbers when responding. + */ + + tcp_seq_num = ntohl(b->ip.hdr.tcp_seq); + tcp_ack_num = ntohl(b->ip.hdr.tcp_ack); + + /* + * Sent first packet send from server as first to app + * Other packets could be ordered, but are currently not ordered. + */ + + tcp_action = tcp_state_machine(b->ip.hdr.tcp_flags, + &tcp_seq_num, payload_len); + + /* + * State altering command to be sent. + * The packet sequence and ack numbers are in the tcp_seq_num + * and tcp_ack_num variables. The current packet, its position + * in the data stream, is the in the range of those variables. + * + * In the "application push" invocation, the TCP header with all + * its information is pointed to by the packet pointer. + * + * in the typedef + * void rxhand_tcp(uchar *pkt, unsigned int dport, + * struct in_addr sip, unsigned int sport, + * unsigned int len); + * *pkt is the pointer to the payload + * dport is used for tcp_seg_num + * action_and_state.s_addr is used for TCP state + * sport is used for tcp_ack_num (which is unused by the app) + * pkt_ length is the payload length. + * + * TCP_PUSH from the state machine with a payload length of 0 is a + * connect or disconnect event + */ + + tcp_activity_count++; + if (tcp_activity_count > TCP_ACTIVITY) { + puts("| "); + tcp_activity_count = 0; + } + + if ((tcp_action & TCP_PUSH) || (payload_len > 0)) { + debug_cond(DEBUG_DEV_PKT, + "TCP Notify (action=%x, Seq=%d,Ack=%d,Pay%d)\n", + tcp_action, tcp_seq_num, tcp_ack_num, payload_len); + + action_and_state.s_addr = tcp_action; + (*tcp_packet_handler) ((uchar *)b + pkt_len - payload_len, + tcp_seq_num, action_and_state, + tcp_ack_num, payload_len); + + } else if (tcp_action != TCP_DATA) { + debug_cond(DEBUG_DEV_PKT, + "TCP Action (action=%x,Seq=%d,Ack=%d,Pay=%d)\n", + tcp_action, tcp_seq_num, tcp_ack_num, payload_len); + + /* + * Warning: Incoming Seq & Ack sequence numbers are transposed here + * to outgoing Seq & Ack sequence numbers + */ + net_send_tcp_packet(0, ntohs(b->ip.hdr.tcp_src), + ntohs(b->ip.hdr.tcp_dst), + (tcp_action & (~TCP_PUSH)), + tcp_seq_num, tcp_ack_num); + } +}
Hi Duncan,
The subject of all these patches ("Integrating TCP and wget into u-boot") is what should be the title of a cover letter. You need to give each patch a reasonable subject about that patch, not all of them together.
This is what should be inside the "Commit-notes:" section... All the things you currently have there should be outside.
Commit-notes
You are missing a ':' so the tool is not detecting this.
TCP Prtocol stack,
Why TCP:
END
A much more appropriate thing to have put here would be something like "Fixed naming of x variable" and "Changed file location of z.h". The point of this is what you changed in this version of the patch.
- @param payload_len Length of data after the UDP header
u32 tcp_ack_num);
+} __packed;
- TCP header options, Seq, MSS, and SACK
- Please review the warning in net.c about these two parameters.
- They are part of a promise of RX buffer size to the sending TCP
u8 kind; /* 0x02 */
u8 len; /* 0x04 */
+} __packed;
u8 kind; /* 0x03 */
u8 len; /* 0x03 */
+} __packed;
u8 kind; /* 0x04 */
+} __packed;
u32 l;
u32 r;
+} __packed;
u8 kind; /* 0x05 */
+} __packed;
u8 kind; /* 0x08 */
u8 len; /* 0x0a */
+} __packed;
- ip tcp structure with options
struct tcp_mss mss;
u8 end;
+} __packed;
u8 end;
+} __packed;
- TCP pseudo header definitions
u8 rsvd;
u8 p;
u16 len;
+} __packed;
- union for building IP/TCP packet.
- build Pseudo header in packed buffer first, calculate TCP checksum
- then build IP header in packed buffer.
uchar raw[1600];
+} __packed;
- TCP STATE MACHINE STATES FOR SOCKET
+enum TCP_STATE {
int field_len);
- An incoming packet handler.
- @param pkt pointer to the application packet
- @param dport destination UDP port
- @param sip source IP address
- @param sport source UDP port
- @param len packet length
unsigned int len);
- An incoming TCP packet handler for the TCP protocol.
- There is also a dynamic function pointer for TCP based commands to
- receive incoming traffic after the TCP protocol code has done its work.
default y
if NET
depends on CMD_NET
-config BOOTP_DNS
depends on CMD_NET
depends on CMD_NET
depends on CMD_NET
-config BOOTP_PXE
depends on CMD_NET
depends on CMD_NET
depends on CMD_NET
+config TCP
help
+#endif }
net_init_loop();
IPPROTO_UDP);
} +#endif
u32 tcp_ack_num)
} else {
+#endif }
switch (proto) {
case IPPROTO_UDP:
break;
default:
return -1;
} else {
return;
- General Desription:
- TCP support for the wget command, for fast file downloading.
- HTTP/TCP Receiver:
- own IP address
- Server IP address
- Server with TCP
Next Step HTTPS?
- TCP sliding window control
- used by us to request re-TX
- Search for TCP_SACK and review the
- comments before the code section
- TCP_SACK is the number of packets
- at the front of the stream
enum pkt_state st;
- There is also a dymanic function pointer for TCP based commads to
return tcp_state;
int i;
if (i <= hdr_len)
putc(raw[i]);
else if (hide == 0)
putc(raw[i]);
else
printf("%s", "\n");
int field_len)
int i, j;
break;
if (j == field_len)
return i;
unsigned int len)
if (!f)
else
int checksum_len;
* Pseudo header
* will always work.
b->ph.rsvd = 0x00;
tcp_lost.len);
* internally.
* in 32 bit words.
tcp_lost.len = 0;
int pkt_hdr_len;
int pkt_len;
int tcp_len;
/* For options */
switch (action) {
case TCP_SYN:
tcp_seq_num = 0;
tcp_ack_num = 0;
action = TCP_FIN;
} else {
break;
case TCP_ACK:
action);
break;
case TCP_FIN:
payload_len = 0;
break;
tcp_ack_edge++;
/* FALLTHRU */
default:
/* TCP Header */
* considered.
tcp_len, pkt_len);
* IP Header
return pkt_hdr_len;
- Selective Acknowledgment (Essential for fast stream transfer)
- Before modifying this section of code, which the author found difficult
- to write, please be familiar with the SACK (Selective Acknowledgment) RFCs.
u32 hol_r = 0;
if (prev_len == 0)
prev_len = len;
if (prev_len < len)
prev_len = len;
sack_in++) {
switch (expect) {
case NOPKT:
case NOPKT:
break;
case PKT:
expect = PKT;
break;
break;
case PKT:
case NOPKT:
hill++;
expect = NOPKT;
break;
case PKT:
sack_idx++;
} else {
break;
break;
sack_idx = 0;
uchar *p = o;
if (p[1] != 0) {
switch (p[0]) {
case TCP_O_END:
return;
case TCP_O_MSS:
break;
case TCP_O_SCL:
break;
case TCP_P_SACK:
break;
case TCP_V_SACK:
break;
case TCP_O_TS:
return;
break;
p++;
} else {
return;
int i;
if (tcp_rst) {
action = TCP_DATA;
return TCP_RST;
case TCP_CLOSED:
if (tcp_fin)
action = TCP_DATA;
if (tcp_syn)
action = TCP_RST;
if (tcp_ack)
action = TCP_DATA;
break;
case TCP_SYN_SENT:
if (tcp_fin) {
if (tcp_syn) {
if (tcp_ack) {
sack_idx = 0;
prev_len = 0;
} else {
if (tcp_ack)
action = TCP_DATA;
break;
} else {
if (tcp_ack)
action = TCP_DATA;
if (tcp_push)
if (tcp_syn)
break;
break;
if (tcp_fin)
action = TCP_DATA;
if (tcp_syn)
action = TCP_DATA;
if (tcp_ack) {
puts("\n");
break;
if (tcp_fin) {
if (tcp_syn)
action = TCP_RST;
if (tcp_ack) {
break;
case TCP_CLOSING:
if (tcp_fin)
action = TCP_DATA;
if (tcp_syn)
action = TCP_RST;
if (tcp_ack) {
action = TCP_PUSH;
puts("\n");
break;
return action;
u32 tcp_seq_num;
u32 tcp_ack_num;
int tcp_hdr_len;
int payload_len;
* Verify IP header
return;
pkt_len)) {
return;
* in the typedef
puts("| ");
2.11.0
Commit-notes Integrating TCP and wget into u-boot
Commit-notes
Why http and wget:
WGET is the application which implements http file transfer outside browsers as a file transfer protocol. Versions of wget exists on many operating systems. Integrating TCP and wget into u-boot
Commit-notes
Why http and wget:
END
Changes in v7: Integrating TCP and wget into u-boot Integrating TCP and wget into u-boot
cmd/Kconfig | 93 ++---------- cmd/net.c | 13 ++ include/net/wget.h | 17 +++ net/Makefile | 1 + net/wget.c | 419 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 466 insertions(+), 77 deletions(-) create mode 100644 include/net/wget.h create mode 100644 net/wget.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 136836d146..46b489a966 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -23,29 +23,6 @@ config HUSH_PARSER If disabled, you get the old, much simpler behaviour with a somewhat smaller memory footprint.
-config CMDLINE_EDITING - bool "Enable command line editing" - depends on CMDLINE - default y - help - Enable editing and History functions for interactive command line - input operations - -config AUTO_COMPLETE - bool "Enable auto complete using TAB" - depends on CMDLINE - default y - help - Enable auto completion of commands using TAB. - -config SYS_LONGHELP - bool "Enable long help messages" - depends on CMDLINE - default y if CMDLINE - help - Defined when you want long help messages included - Do not set this option when short of memory. - config SYS_PROMPT string "Shell prompt" default "=> " @@ -331,12 +308,6 @@ config CMD_SPL_WRITE_SIZE flash used by Falcon-mode boot. See the documentation until CMD_SPL for detail.
-config CMD_FITUPD - bool "fitImage update command" - help - Implements the 'fitupd' command, which allows to automatically - store software updates present on a TFTP server in NOR Flash - config CMD_THOR_DOWNLOAD bool "thor - TIZEN 'thor' download" help @@ -426,7 +397,6 @@ menu "Memory commands" config CMD_CRC32 bool "crc32" select HASH - default n if ARCH_SUNXI default y help Compute CRC32. @@ -568,7 +538,6 @@ config CMD_LZMADEC
config CMD_UNZIP bool "unzip" - default n if ARCH_SUNXI default y if CMD_BOOTI help Uncompress a zip-compressed memory region. @@ -611,7 +580,7 @@ config CMD_DEMO
config CMD_DFU bool "dfu" - select DFU + select USB_FUNCTION_DFU help Enables the command "dfu" which is used to have U-Boot create a DFU class device via USB. This command requires that the "dfu_alt_info" @@ -645,7 +614,6 @@ config CMD_FLASH
config CMD_FPGA bool "fpga" - depends on FPGA default y help FPGA support. @@ -701,7 +669,6 @@ config CMD_GPT bool "GPT (GUID Partition Table) command" select PARTITION_UUIDS select EFI_PARTITION - select HAVE_BLOCK_DEVICE imply RANDOM_UUID help Enable the 'gpt' command to ready and write GPT style partition @@ -709,7 +676,6 @@ config CMD_GPT
config RANDOM_UUID bool "GPT Random UUID generation" - select LIB_UUID help Enable the generation of partitions with random UUIDs if none are provided. @@ -780,14 +746,12 @@ config CMD_I2C
config CMD_LOADB bool "loadb" - default n if ARCH_SUNXI default y help Load a binary file over serial line.
config CMD_LOADS bool "loads" - default n if ARCH_SUNXI default y help Load an S-Record file over serial line @@ -849,7 +813,6 @@ config CMD_ONENAND config CMD_PART bool "part" select PARTITION_UUIDS - select HAVE_BLOCK_DEVICE help Read and display information about the partition table on various media. @@ -900,15 +863,6 @@ config CMD_SAVES Provides a way to save a binary file using the Motorola S-Record format over the serial line.
-config CMD_SCSI - bool "scsi - Access to SCSI devices" - default y if SCSI - help - This provides a 'scsi' command which provides access to SCSI (Small - Computer System Interface) devices. The command provides a way to - scan the bus, reset the bus, read and write data and get information - about devices. - config CMD_SDRAM bool "sdram - Print SDRAM configuration information" help @@ -951,7 +905,6 @@ config CMD_UNIVERSE
config CMD_USB bool "usb" - select HAVE_BLOCK_DEVICE help USB support.
@@ -961,18 +914,9 @@ config CMD_USB_SDP help Enables the command "sdp" which is used to have U-Boot emulating the Serial Download Protocol (SDP) via USB. -config CMD_ROCKUSB - bool "rockusb" - depends on USB_FUNCTION_ROCKUSB - help - Rockusb protocol is widely used by Rockchip SoC based devices. It can - read/write info, image to/from devices. This enable rockusb command - support to communication with rockusb device. for more detail about - this command, please read doc/README.rockusb.
config CMD_USB_MASS_STORAGE bool "UMS usb mass storage" - select USB_FUNCTION_MASS_STORAGE help USB mass storage support
@@ -1012,10 +956,9 @@ endmenu
menu "Network commands"
-if NET - config CMD_NET bool "bootp, tftpboot" + select NET default y help Network commands. @@ -1039,13 +982,11 @@ config CMD_RARP
config CMD_DHCP bool "dhcp" - depends on CMD_NET help Boot image via network using DHCP/TFTP protocol
config CMD_PXE bool "pxe" - depends on CMD_NET select MENU help Boot image via network using PXE protocol @@ -1094,7 +1035,11 @@ config CMD_ETHSW operations such as enabling / disabling a port and viewing/maintaining the filtering database (FDB)
-endif +config CMD_WGET + bool "wget" + select TCP + help + Download a kernel, or other files, from a web server over TCP.
endmenu
@@ -1187,7 +1132,6 @@ config CMD_GETTIME # TODO: rename to CMD_SLEEP config CMD_MISC bool "sleep" - default n if ARCH_SUNXI default y help Delay execution for some time @@ -1227,7 +1171,6 @@ config CMD_TERMINAL
config CMD_UUID bool "uuid, guid - generation of unique IDs" - select LIB_UUID help This enables two commands:
@@ -1239,8 +1182,6 @@ config CMD_UUID
endmenu
-source "cmd/ti/Kconfig" - config CMD_BOOTSTAGE bool "Enable the 'bootstage' command" depends on BOOTSTAGE @@ -1422,20 +1363,17 @@ config CMD_CRAMFS
config CMD_EXT2 bool "ext2 command support" - select FS_EXT4 help Enables EXT2 FS command
config CMD_EXT4 bool "ext4 command support" - select FS_EXT4 help Enables EXT4 FS command
config CMD_EXT4_WRITE depends on CMD_EXT4 bool "ext4 write command support" - select EXT4_WRITE help Enables EXT4 FS write command
@@ -1503,6 +1441,15 @@ config CMD_REISER reiserls - list files reiserload - load a file
+config CMD_SCSI + bool "scsi - Access to SCSI devices" + default y if SCSI + help + This provides a 'scsi' command which provides access to SCSI (Small + Computer System Interface) devices. The command provides a way to + scan the bus, reset the bus, read and write data and get information + about devices. + config CMD_YAFFS2 bool "yaffs2 - Access of YAFFS2 filesystem" depends on YAFFS2 @@ -1561,14 +1508,6 @@ config CMD_KGDB single-stepping, inspecting variables, etc. This is supported only on PowerPC at present.
-config CMD_LOG - bool "log - Generation, control and access to logging" - help - This provides access to logging features. It allows the output of - log data to be controlled to a limited extent (setting up the default - maximum log level for emitting of records). It also provides access - to a command used for testing the log system. - config CMD_TRACE bool "trace - Support tracing of function calls and timing" help diff --git a/cmd/net.c b/cmd/net.c index d7c776aacf..6a7a51f357 100644 --- a/cmd/net.c +++ b/cmd/net.c @@ -110,6 +110,19 @@ U_BOOT_CMD( ); #endif
+#if defined(CONFIG_CMD_WGET) +static int do_wget(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return netboot_common(WGET, cmdtp, argc, argv); +} + +U_BOOT_CMD( + wget, 3, 1, do_wget, + "boot image via network using HTTP protocol", + "[loadAddress] [[hostIPaddr:]path and image name]" +); +#endif + static void netboot_update_env(void) { char tmp[22]; diff --git a/include/net/wget.h b/include/net/wget.h new file mode 100644 index 0000000000..dce16c573d --- /dev/null +++ b/include/net/wget.h @@ -0,0 +1,17 @@ +/* + * Duncan Hare Copyright 2017 + */ + +void wget_start(void); /* Begin wget */ + +enum WGET_STATE { + WGET_CLOSED, + WGET_CONNECTING, + WGET_CONNECTED, + WGET_TRANSFERRING, + WGET_TRANSFERRED}; + +#define DEBUG_WGET 0 /* Set to 1 for debug messges */ +#define SERVER_PORT 80 +#define WGET_RETRY_COUNT 30 +#define WGET_TIMEOUT 2000UL diff --git a/net/Makefile b/net/Makefile index 25729ebeeb..f83df5b728 100644 --- a/net/Makefile +++ b/net/Makefile @@ -26,6 +26,7 @@ obj-$(CONFIG_CMD_RARP) += rarp.o obj-$(CONFIG_CMD_SNTP) += sntp.o obj-$(CONFIG_CMD_NET) += tftp.o obj-$(CONFIG_TCP) += tcp.o +obj-$(CONFIG_CMD_WGET) += wget.o # Disable this warning as it is triggered by: # sprintf(buf, index ? "foo%d" : "foo", index) # and this is intentional usage. diff --git a/net/wget.c b/net/wget.c new file mode 100644 index 0000000000..f7923e35c8 --- /dev/null +++ b/net/wget.c @@ -0,0 +1,419 @@ +/* + * WGET/HTTP support driver based on U-BOOT's nfs.c + * Copyright Duncan Hare dh@synoia.com 2017 + * SPDX-License-Identifier:GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <mapmem.h> +#include <net.h> +#include <net/wget.h> +#include <net/tcp.h> + +const char bootfile1[] = "GET "; +const char bootfile3[] = " HTTP/1.0\r\n\r\n"; +const char http_eom[] = "\r\n\r\n"; +const char http_ok[] = "200"; +const char content_len[] = "Content-Length"; +const char linefeed[] = "\r\n"; +static struct in_addr web_server_ip; +static int our_port; +static int wget_timeout_count; + +struct pkt_qd { + uchar *pkt; + unsigned int tcp_seq_num; + unsigned int len; +}; + +/* + * This is a control structure for out of order packets received. + * The actual packet bufers are in the kernel space, and are + * expected to be overwritten by the downloaded image. + */ + +static struct pkt_qd pkt_q[PKTBUFSRX / 4]; +static int pkt_q_idx; +static unsigned long content_length; +static unsigned int packets; + +static unsigned int initial_data_seq_num; + +static enum WGET_STATE wget_state; + +static char *image_url; +static unsigned int wget_timeout = WGET_TIMEOUT; + +static void wget_timeout_handler(void); + +static enum net_loop_state wget_loop_state; + +/* Timeout retry parameters */ +static u8 r_action; +static unsigned int r_tcp_ack_num; +static unsigned int r_tcp_seq_num; +static int r_len; + +static inline int store_block(uchar *src, unsigned int offset, unsigned int len) +{ + ulong newsize = offset + len; + uchar *ptr; + +#ifdef CONFIG_SYS_DIRECT_FLASH_WGET + int i, rc = 0; + + for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { + /* start address in flash? */ + if (load_addr + offset >= flash_info[i].start[0]) { + rc = 1; + break; + } + } + + if (rc) { /* Flash is destination for this packet */ + rc = flash_write((uchar *)src, + (ulong)(load_addr + offset), len); + if (rc) { + flash_perror(rc); + return -1; + } + } else { +#endif /* CONFIG_SYS_DIRECT_FLASH_WGET */ + + ptr = map_sysmem(load_addr + offset, len); + memcpy(ptr, src, len); + unmap_sysmem(ptr); + +#ifdef CONFIG_SYS_DIRECT_FLASH_WGET + } +#endif + if (net_boot_file_size < (offset + len)) + net_boot_file_size = newsize; + return 0; +} + +/* + * wget response dispatcher + * WARNING, This, and only this, is the place in wget,c where + * SEQUENCE NUMBERS are swapped between incoming (RX) + * and outgoing (TX). + * Procedure wget_handler() is correct for RX traffic. + */ +static void wget_send_stored(void) +{ + u8 action = r_action; + unsigned int tcp_ack_num = r_tcp_ack_num; + unsigned int tcp_seq_num = r_tcp_seq_num; + int len = r_len; + uchar *ptr; + uchar *offset; + + tcp_ack_num = tcp_ack_num + len; + + switch (wget_state) { + case WGET_CLOSED: + debug_cond(DEBUG_WGET, "wget: send SYN\n"); + wget_state = WGET_CONNECTING; + net_send_tcp_packet(0, SERVER_PORT, our_port, action, + tcp_seq_num, tcp_ack_num); + packets = 0; + break; + case WGET_CONNECTING: + pkt_q_idx = 0; + net_send_tcp_packet(0, SERVER_PORT, our_port, action, + tcp_seq_num, tcp_ack_num); + + ptr = net_tx_packet + net_eth_hdr_size() + + IP_TCP_HDR_SIZE + TCP_TSOPT_SIZE + 2; + offset = ptr; + + memcpy(offset, &bootfile1, strlen(bootfile1)); + offset = offset + strlen(bootfile1); + + memcpy(offset, image_url, strlen(image_url)); + offset = offset + strlen(image_url); + + memcpy(offset, &bootfile3, strlen(bootfile3)); + offset = offset + strlen(bootfile3); + net_send_tcp_packet((offset - ptr), SERVER_PORT, our_port, + TCP_PUSH, tcp_seq_num, tcp_ack_num); + wget_state = WGET_CONNECTED; + break; + case WGET_CONNECTED: + case WGET_TRANSFERRING: + case WGET_TRANSFERRED: + net_send_tcp_packet(0, SERVER_PORT, our_port, action, + tcp_seq_num, tcp_ack_num); + break; + } +} + +static void wget_send(u8 action, unsigned int tcp_ack_num, + unsigned int tcp_seq_num, int len) +{ + r_action = action; + r_tcp_ack_num = tcp_ack_num; + r_tcp_seq_num = tcp_seq_num; + r_len = len; + wget_send_stored(); +} + +void wget_fail(char *error_message, unsigned int tcp_seq_num, + unsigned int tcp_ack_num, u8 action) +{ + printf("%s", error_message); + printf("%s", "wget: Transfer Fail\n"); + net_set_timeout_handler(0, NULL); + wget_send(action, tcp_seq_num, tcp_ack_num, 0); +} + +void wget_success(u8 action, unsigned int tcp_seq_num, + unsigned int tcp_ack_num, int len, int packets) +{ + printf("Packets received %d, Transfer Successful\n", packets); + wget_send(action, tcp_seq_num, tcp_ack_num, len); +} + +/* + * Interfaces of U-BOOT + */ +static void wget_timeout_handler(void) +{ + if (++wget_timeout_count > WGET_RETRY_COUNT) { + puts("\nRetry count exceeded; starting again\n"); + wget_send(TCP_RST, 0, 0, 0); + net_start_again(); + } else { + puts("T "); + net_set_timeout_handler(wget_timeout + + WGET_TIMEOUT * wget_timeout_count, + wget_timeout_handler); + wget_send_stored(); + } +} + +static void wget_connected(uchar *pkt, unsigned int tcp_seq_num, + struct in_addr action_and_state, + unsigned int tcp_ack_num, unsigned int len) +{ + u8 action = action_and_state.s_addr; + uchar *pkt_in_q; + char *pos; + int hlen; + int i; + + pkt[len] = '\0'; + pos = strstr((char *)pkt, http_eom); + + if (pos == 0) { + debug_cond(DEBUG_WGET, + "wget: Connected, data before Header %p\n", pkt); + pkt_in_q = (void *)load_addr + 0x20000 + (pkt_q_idx * 0x800); + memcpy(pkt_in_q, pkt, len); + pkt_q[pkt_q_idx].pkt = pkt_in_q; + pkt_q[pkt_q_idx].tcp_seq_num = tcp_seq_num; + pkt_q[pkt_q_idx].len = len; + pkt_q_idx++; + } else { + debug_cond(DEBUG_WGET, "wget: Connected HTTP Header %p\n", pkt); + hlen = pos - (char *)pkt + sizeof(http_eom) - 1; + pos = strstr((char *)pkt, linefeed); + if (pos > 0) + i = pos - (char *)pkt; + else + i = hlen; + tcp_print_buffer(pkt, i, i, -1, 0); + + wget_state = WGET_TRANSFERRING; + + if (strstr((char *)pkt, http_ok) == 0) { + debug_cond(DEBUG_WGET, + "wget: Connected Bad Xfer\n"); + wget_loop_state = NETLOOP_FAIL; + wget_send(action, tcp_seq_num, tcp_ack_num, len); + } else { + debug_cond(DEBUG_WGET, + "wget: Connctd pkt %p hlen %x\n", + pkt, hlen); + initial_data_seq_num = tcp_seq_num + hlen; + + pos = strstr((char *)pkt, content_len); + if (!pos) { + content_length = -1; + } else { + pos = pos + sizeof(content_len) + 2; + strict_strtoul(pos, 10, &content_length); + debug_cond(DEBUG_WGET, + "wget: Connected Len %lu\n", + content_length); + } + + net_boot_file_size = 0; + + if (len > hlen) + store_block(pkt + hlen, 0, len - hlen); + debug_cond(DEBUG_WGET, + "wget: Connected Pkt %p hlen %x\n", + pkt, hlen); + + for (i = 0; i < pkt_q_idx; i++) { + store_block(pkt_q[i].pkt, + pkt_q[i].tcp_seq_num - + initial_data_seq_num, + pkt_q[i].len); + debug_cond(DEBUG_WGET, + "wget: Connctd pkt Q %p len %x\n", + pkt_q[i].pkt, pkt_q[i].len); + } + } + } + wget_send(action, tcp_seq_num, tcp_ack_num, len); +} + + /* + * In the "application push" invocation, the TCP header with all + * its information is pointed to by the packet pointer. + * + * in the typedef + * void rxhand_tcp(uchar *pkt, unsigned int dport, + * struct in_addr sip, unsigned int sport, + * unsigned int len); + * *pkt is the pointer to the payload + * dport is used for tcp_seg_num + * action_and_state.s_addr is used for TCP state + * sport is used for tcp_ack_num (which is unused by the app) + * pkt_ length is the payload length. + */ +static void wget_handler(uchar *pkt, unsigned int tcp_seq_num, + struct in_addr action_and_state, + unsigned int tcp_ack_num, unsigned int len) +{ + enum TCP_STATE wget_tcp_state = tcp_get_tcp_state(); + u8 action = action_and_state.s_addr; + + net_set_timeout_handler(wget_timeout, wget_timeout_handler); + packets++; + + switch (wget_state) { + case WGET_CLOSED: + debug_cond(DEBUG_WGET, "wget: Handler: Error!, State wrong\n"); + break; + case WGET_CONNECTING: + debug_cond(DEBUG_WGET, + "wget: Connecting In len=%x, Seq=%x, Ack=%x\n", + len, tcp_seq_num, tcp_ack_num); + if (len == 0) { + if (wget_tcp_state == TCP_ESTABLISHED) { + debug_cond(DEBUG_WGET, + "wget: Cting, send, len=%x\n", len); + wget_send(action, tcp_seq_num, tcp_ack_num, len); + } else { + tcp_print_buffer(pkt, len, len, -1, 0); + wget_fail("wget: Handler Connected Fail\n", + tcp_seq_num, tcp_ack_num, action); + } + } + break; + case WGET_CONNECTED: + debug_cond(DEBUG_WGET, "wget: Connected seq=%x, len=%x\n", + tcp_seq_num, len); + if (len == 0) { + wget_fail("Image not found, no data returned\n", + tcp_seq_num, tcp_ack_num, action); + } else { + wget_connected(pkt, tcp_seq_num, action_and_state, + tcp_ack_num, len); + } + break; + case WGET_TRANSFERRING: + debug_cond(DEBUG_WGET, + "wget: Transferring, seq=%x, ack=%x,len=%x\n", + tcp_seq_num, tcp_ack_num, len); + + if (store_block(pkt, + tcp_seq_num - initial_data_seq_num, len) != 0) { + wget_fail("wget: store error\n", + tcp_seq_num, tcp_ack_num, action); + } else { + switch (wget_tcp_state) { + case TCP_FIN_WAIT_2: + wget_send(TCP_ACK, tcp_seq_num, tcp_ack_num, + len); + case TCP_SYN_SENT: + case TCP_CLOSING: + case TCP_FIN_WAIT_1: + case TCP_CLOSED: + net_set_state(NETLOOP_FAIL); + break; + case TCP_ESTABLISHED: + wget_send(TCP_ACK, tcp_seq_num, tcp_ack_num, + len); + wget_loop_state = NETLOOP_SUCCESS; + break; + case TCP_CLOSE_WAIT: /* End of transfer */ + wget_state = WGET_TRANSFERRED; + wget_send(action | TCP_ACK | TCP_FIN, + tcp_seq_num, tcp_ack_num, len); + break; + } + } + break; + case WGET_TRANSFERRED: + printf("Packets received %d, Transfer Successful\n", packets); + net_set_state(wget_loop_state); + break; + } +} + +void wget_start(void) +{ + debug_cond(DEBUG_WGET, "%s\n", __func__); + + image_url = strchr(net_boot_file_name, ':'); + if (!image_url) { + web_server_ip = string_to_ip(net_boot_file_name); + ++image_url; + } else { + web_server_ip = net_server_ip; + image_url = net_boot_file_name; + } + + debug_cond(DEBUG_WGET, + "wget: Transfer HTTP Server %pI4; our IP %pI4\n", + &web_server_ip, &net_ip); + + /* Check if we need to send across this subnet */ + if (net_gateway.s_addr && net_netmask.s_addr) { + struct in_addr our_net; + struct in_addr server_net; + + our_net.s_addr = net_ip.s_addr & net_netmask.s_addr; + server_net.s_addr = net_server_ip.s_addr & net_netmask.s_addr; + if (our_net.s_addr != server_net.s_addr) + debug_cond(DEBUG_WGET, "wget: sending through gateway %pI4", + &net_gateway); + } + debug_cond(DEBUG_WGET, "URL '%s\n", image_url); + + if (net_boot_file_expected_size_in_blocks) { + debug_cond(DEBUG_WGET, "wget: Size is 0x%x Bytes = ", + net_boot_file_expected_size_in_blocks << 9); + print_size(net_boot_file_expected_size_in_blocks << 9, ""); + } + debug_cond(DEBUG_WGET, + "\nwget:Load address: 0x%lx\nLoading: *\b", load_addr); + + net_set_timeout_handler(wget_timeout, wget_timeout_handler); + tcp_set_tcp_handler(wget_handler); + + wget_timeout_count = 0; + wget_state = WGET_CLOSED; + + our_port = random_port(); + + /* zero out server ether in case the server ip has changed */ + memset(net_server_ethaddr, 0, 6); + + wget_send(TCP_SYN, 0, 0, 0); +}
Too long a line in wget, line 386 Embedded blanks and tabs in clarifying comments in tcp.c
Signed-off-by: Duncan Hare DuncanCHare@yahoo.com ---
Changes in v7: None
net/tcp.c | 14 +++++++------- net/wget.c | 3 ++- 2 files changed, 9 insertions(+), 8 deletions(-)
diff --git a/net/tcp.c b/net/tcp.c index 612a6a4b7d..5ae2382179 100644 --- a/net/tcp.c +++ b/net/tcp.c @@ -23,7 +23,7 @@ #include <environment.h> #include <errno.h> #include <net.h> -#include <net/tcp.h> +#include "tcp.h" #if defined(CONFIG_CMD_WGET) #include "net/wget.h" #endif @@ -199,10 +199,10 @@ int net_set_ack_options(union tcp_build_pkt *b) }
/* - * TCP lengths are stored as a rounded up number of 32 bit words - * Add 3 to length round up, rounded, then divided into the length - * in 32 bit words. - */ + * TCP lengths are stored as a rounded up number of 32 bit words + * Add 3 to length round up, rounded, then divided into the length + * in 32 bit words. + */
b->sack.hdr.tcp_hlen = (((TCP_HDR_SIZE + TCP_TSOPT_SIZE + tcp_lost.len + 3) >> 2) << 4); @@ -210,7 +210,7 @@ int net_set_ack_options(union tcp_build_pkt *b) /* * This returns the actual rounded up length of the * TCP header to add to the total packet length - */ + */
return b->sack.hdr.tcp_hlen >> 2; } @@ -703,7 +703,7 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) * its information is pointed to by the packet pointer. * * in the typedef - * void rxhand_tcp(uchar *pkt, unsigned int dport, + * void rxhand_tcp(uchar *pkt, unsigned int dport, * struct in_addr sip, unsigned int sport, * unsigned int len); * *pkt is the pointer to the payload diff --git a/net/wget.c b/net/wget.c index f7923e35c8..5429a1f7b1 100644 --- a/net/wget.c +++ b/net/wget.c @@ -391,7 +391,8 @@ void wget_start(void) our_net.s_addr = net_ip.s_addr & net_netmask.s_addr; server_net.s_addr = net_server_ip.s_addr & net_netmask.s_addr; if (our_net.s_addr != server_net.s_addr) - debug_cond(DEBUG_WGET, "wget: sending through gateway %pI4", + debug_cond(DEBUG_WGET, + "wget: sending through gateway %pI4", &net_gateway); } debug_cond(DEBUG_WGET, "URL '%s\n", image_url);
These changes should be squashed into the previous patches.
DH@synoia.com
Joe Hershberger
