[U-Boot] [PATCH] MX31: Cleanup clock function
The patch provide the same API used with other i.MX processors and get rid of mx31_ functions.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Marek Vasut marek.vasut@gmail.com
--- arch/arm/cpu/arm1136/mx31/generic.c | 21 ++++++++++++++++++++- arch/arm/include/asm/arch-mx31/clock.h | 11 +++++++++-- drivers/spi/mxc_spi.c | 2 -- 3 files changed, 29 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/arm1136/mx31/generic.c b/arch/arm/cpu/arm1136/mx31/generic.c index 4ebf38d..248431b 100644 --- a/arch/arm/cpu/arm1136/mx31/generic.c +++ b/arch/arm/cpu/arm1136/mx31/generic.c @@ -23,6 +23,7 @@
#include <common.h> #include <asm/arch/imx-regs.h> +#include <asm/arch/clock.h> #include <asm/io.h>
static u32 mx31_decode_pll(u32 reg, u32 infreq) @@ -60,7 +61,7 @@ static u32 mx31_get_mcu_main_clk(void) return mx31_get_mpl_dpdgck_clk(); }
-u32 mx31_get_ipg_clk(void) +static u32 mx31_get_ipg_clk(void) { u32 freq = mx31_get_mcu_main_clk(); u32 pdr0 = __REG(CCM_PDR0); @@ -78,6 +79,24 @@ void mx31_dump_clocks(void) printf("ipg clock : %dHz\n", mx31_get_ipg_clk()); }
+unsigned int mxc_get_clock(enum mxc_clock clk) +{ + switch (clk) { + case MXC_ARM_CLK: + return mx31_get_mcu_main_clk(); + case MXC_IPG_CLK: + case MXC_CSPI_CLK: + case MXC_UART_CLK: + return mx31_get_ipg_clk(); + } + return -1; +} + +u32 imx_get_uartclk(void) +{ + return mxc_get_clock(MXC_UART_CLK); +} + void mx31_gpio_mux(unsigned long mode) { unsigned long reg, shift, tmp; diff --git a/arch/arm/include/asm/arch-mx31/clock.h b/arch/arm/include/asm/arch-mx31/clock.h index 9f7ae80..0e780aa 100644 --- a/arch/arm/include/asm/arch-mx31/clock.h +++ b/arch/arm/include/asm/arch-mx31/clock.h @@ -24,8 +24,15 @@ #ifndef __ASM_ARCH_CLOCK_H #define __ASM_ARCH_CLOCK_H
-extern u32 mx31_get_ipg_clk(void); -#define imx_get_uartclk mx31_get_ipg_clk +enum mxc_clock { + MXC_ARM_CLK = 0, + MXC_IPG_CLK, + MXC_CSPI_CLK, + MXC_UART_CLK, +}; + +unsigned int mxc_get_clock(enum mxc_clock clk); +extern u32 imx_get_uartclk(); extern void mx31_gpio_mux(unsigned long mode); extern void mx31_set_pad(enum iomux_pins pin, u32 config);
diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index 698e726..81381d9 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -60,8 +60,6 @@ static unsigned long spi_bases[] = { 0x53f84000, };
-#define mxc_get_clock(x) mx31_get_ipg_clk() - #elif defined(CONFIG_MX51)
#define MXC_CSPICTRL_EN (1 << 0)
Hi Stefano,
On Wed, Jul 13, 2011 at 10:59 AM, Stefano Babic sbabic@denx.de wrote: ...
- MXC_ARM_CLK = 0,
- MXC_IPG_CLK,
- MXC_CSPI_CLK,
- MXC_UART_CLK,
I think the '= 0' can be ommited, right?
Regards,
Fabio Estevam
On 07/13/2011 05:23 PM, Fabio Estevam wrote:
Hi Stefano,
Hi Fabio,
MXC_ARM_CLK = 0,
MXC_IPG_CLK,
MXC_CSPI_CLK,
MXC_UART_CLK,
Right - it has no influence, but we do not need to explicitely set it. I will remove in V2.
Best regards, Stefano Babic
Signed-off-by: Stefano Babic sbabic@denx.de ---
Changes since V1: - remove unneeded initialization for enum (Fabio Estevam)
+unsigned int mxc_get_clock(enum mxc_clock clk) +{ + switch (clk) { + case MXC_ARM_CLK: + return mx31_get_mcu_main_clk(); + case MXC_IPG_CLK: + case MXC_CSPI_CLK: + case MXC_UART_CLK: + return mx31_get_ipg_clk(); + } + return -1; +} + +u32 imx_get_uartclk(void) +{ + return mxc_get_clock(MXC_UART_CLK); +} + void mx31_gpio_mux(unsigned long mode) { unsigned long reg, shift, tmp; diff --git a/arch/arm/include/asm/arch-mx31/clock.h b/arch/arm/include/asm/arch-mx31/clock.h index 9f7ae80..fb035c4 100644 --- a/arch/arm/include/asm/arch-mx31/clock.h +++ b/arch/arm/include/asm/arch-mx31/clock.h @@ -24,8 +24,15 @@ #ifndef __ASM_ARCH_CLOCK_H #define __ASM_ARCH_CLOCK_H
-extern u32 mx31_get_ipg_clk(void); -#define imx_get_uartclk mx31_get_ipg_clk +enum mxc_clock { + MXC_ARM_CLK, + MXC_IPG_CLK, + MXC_CSPI_CLK, + MXC_UART_CLK, +}; + +unsigned int mxc_get_clock(enum mxc_clock clk); +extern u32 imx_get_uartclk(); extern void mx31_gpio_mux(unsigned long mode); extern void mx31_set_pad(enum iomux_pins pin, u32 config);
Fabio Estevam
Stefano Babic
