[PATCH v2] efi_loader: add EFI_TCG2_PROTOCOL.SubmitCommand
This commit adds the EFI_TCG2_PROTOCOL.SubmitCommand required in the TCG PC Client PFP spec. SubmitCommand enables to send the raw command to the TPM device.
To implement this api, tpm2_submit_command() is added into tpm-v2.c.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- Changes in v2: - return EFI_OUT_OF_RESOURCES if the recv buffer is small - remove unused argument of tpm2_submit_command()
include/tpm-v2.h | 14 +++++++++++++ lib/efi_loader/efi_tcg2.c | 41 +++++++++++++++++++++++++++++++++------ lib/tpm-v2.c | 6 ++++++ 3 files changed, 55 insertions(+), 6 deletions(-)
diff --git a/include/tpm-v2.h b/include/tpm-v2.h index e6b68769f3..39c8c0897b 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -642,4 +642,18 @@ u32 tpm2_write_lock(struct udevice *dev, u32 index); */ u32 tpm2_disable_platform_hierarchy(struct udevice *dev);
+/** + * submit user specified data to the TPM and get response + * + * @dev TPM device + * @sendbuf: Buffer of the data to send + * @recvbuf: Buffer to save the response to + * @recv_size: Pointer to the size of the response buffer + * + * Returns 0 on success (and places the number of response bytes at + * recv_size) or -ve on failure. + */ +u32 tpm2_submit_command(struct udevice *dev, const u8 *sendbuf, + u8 *recvbuf, size_t *recv_size); + #endif /* __TPM_V2_H */ diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index ec20530b6b..cb67006b14 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -1033,13 +1033,42 @@ out: * Return: status code */ static efi_status_t EFIAPI -efi_tcg2_submit_command(__maybe_unused struct efi_tcg2_protocol *this, - u32 __maybe_unused input_param_block_size, - u8 __maybe_unused *input_param_block, - u32 __maybe_unused output_param_block_size, - u8 __maybe_unused *output_param_block) +efi_tcg2_submit_command(struct efi_tcg2_protocol *this, + u32 input_param_block_size, + u8 *input_param_block, + u32 output_param_block_size, + u8 *output_param_block) { - return EFI_UNSUPPORTED; + struct udevice *dev; + efi_status_t ret; + u32 rc; + size_t resp_buf_size = output_param_block_size; + + EFI_ENTRY("%p, %u, %p, %u, %p", this, input_param_block_size, + input_param_block, output_param_block_size, output_param_block); + + if (!this || !input_param_block || !input_param_block_size) { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + ret = platform_get_tpm2_device(&dev); + if (ret != EFI_SUCCESS) + goto out; + + rc = tpm2_submit_command(dev, input_param_block, + output_param_block, &resp_buf_size); + if (rc) { + if (rc == -ENOSPC) + ret = EFI_OUT_OF_RESOURCES; + else + ret = EFI_DEVICE_ERROR; + + goto out; + } + +out: + return EFI_EXIT(ret); }
/** diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index 235f8c20d4..2e7b27bd6b 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -659,3 +659,9 @@ u32 tpm2_disable_platform_hierarchy(struct udevice *dev)
return 0; } + +u32 tpm2_submit_command(struct udevice *dev, const u8 *sendbuf, + u8 *recvbuf, size_t *recv_size) +{ + return tpm_sendrecv_command(dev, sendbuf, recvbuf, recv_size); +}
Changes in v2:
- submit user specified data to the TPM and get response
- @dev TPM device
- @sendbuf: Buffer of the data to send
- @recvbuf: Buffer to save the response to
- @recv_size: Pointer to the size of the response buffer
- Returns 0 on success (and places the number of response bytes at
- recv_size) or -ve on failure.
- Return: status code
- struct udevice *dev;
- efi_status_t ret;
- u32 rc;
- size_t resp_buf_size = output_param_block_size;
- EFI_ENTRY("%p, %u, %p, %u, %p", this, input_param_block_size,
- if (!this || !input_param_block || !input_param_block_size) {
goto out;
- ret = platform_get_tpm2_device(&dev);
- if (ret != EFI_SUCCESS)
goto out;
- rc = tpm2_submit_command(dev, input_param_block,
- if (rc) {
nit pick but can you send a new version with and replace this with a ternary operation?
if (rc) { ret = (rc == -ENOSPC) ? EFI_OUT_OF_RESOURCES : EFI_DEVICE_ERROR; goto out; }
if (rc == -ENOSPC)
else
goto out;
+out:
- return EFI_EXIT(ret);
return 0; }
- return tpm_sendrecv_command(dev, sendbuf, recvbuf, recv_size);
2.17.1
Other than that Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
Masahisa Kojima
