[PATCH 1/1] net: fm: fix build error when not using nand
If CONFIG_CMD_NAND is disabled, get_nand_dev_by_index() is not accessible.
This fix allows the build to succeed in this case.
Signed-off-by: Francois Gervais fgervais@distech-controls.com --- drivers/net/fm/fm.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index 926cf81a07..7a081b9d03 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -360,6 +360,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) if (src == BOOT_SOURCE_IFC_NOR) { addr = (void *)(CONFIG_SYS_FMAN_FW_ADDR + CONFIG_SYS_FSL_IFC_BASE); +#ifdef CONFIG_CMD_NAND } else if (src == BOOT_SOURCE_IFC_NAND) { size_t fw_length = CONFIG_SYS_QE_FMAN_FW_LENGTH;
@@ -372,6 +373,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) printf("NAND read of FMAN firmware at offset 0x%x failed %d\n", CONFIG_SYS_FMAN_FW_ADDR, rc); } +#endif } else if (src == BOOT_SOURCE_QSPI_NOR) { struct spi_flash *ucode_flash;
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Francois Gervais Sent: Wednesday, April 8, 2020 7:18 PM To: u-boot@lists.denx.de Cc: grygorii.strashko@ti.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Gervais, Francois FGervais@distech-controls.com Subject: [PATCH 1/1] net: fm: fix build error when not using nand
Applied to fsl-qoriq. Awaiting upstream.
Thanks Priyanka
Francois Gervais
Priyanka Jain (OSS)
