[U-Boot] [PATCH V2] MAKEALL: allow regex matches for -s option
This allows:
MAKEALL -s tegra
to replace:
MAKEALL -s tegra20 -s tegra30 -s tegra114
The following also works:
MAKEALL -s tegra -s omap
Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: Modified the commit description marginally to s/tegra*/tegra/ in the first example MAKEALL command; it's a regex match so a substring, so the * isn't needed. Also add the dual tegra/omap example command.
MAKEALL | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/MAKEALL b/MAKEALL index c1d8957..91fa495 100755 --- a/MAKEALL +++ b/MAKEALL @@ -104,9 +104,9 @@ while true ; do -s|--soc) # echo "Option SoC: argument `$2'" if [ "$opt_s" ] ; then - opt_s="${opt_s%)} || $6 == "$2")" + opt_s="${opt_s%)} || $6 == "$2" || $6 ~ /$2/)" else - opt_s="($6 == "$2")" + opt_s="($6 == "$2" || $6 ~ /$2/)" fi SELECTED='y' shift 2 ;;
On Wed, Mar 27, 2013 at 11:51:25AM -0600, Stephen Warren wrote:
This allows:
MAKEALL -s tegra
to replace:
- isn't needed. Also add the dual tegra/omap example command.
Stephen Warren
