[U-Boot] [PATCH v2] ext4: Fix comparision of unsigned expression with < 0
In file ext4fs.c funtion ext4fs_read_file() compares an unsigned expression with < 0 like below
lbaint_t blknr; blknr = read_allocated_block(&(node->inode), i); if (blknr < 0) return -1;
blknr is of type ulong/uint64_t. read_allocated_block() returns long int. So comparing blknr with < 0 will always be false. Instead declare blknr as long int.
Similarly ext4/dev.c does a similar comparison. Drop the redundant comparison.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - Fixed similar comparision in ext4/dev.c
fs/ext4/dev.c | 5 ++--- fs/ext4/ext4fs.c | 2 +- 2 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/fs/ext4/dev.c b/fs/ext4/dev.c index ee84d3fbe1..ae2ba6a901 100644 --- a/fs/ext4/dev.c +++ b/fs/ext4/dev.c @@ -60,9 +60,8 @@ int ext4fs_devread(lbaint_t sector, int byte_offset, int byte_len, char *buf) }
/* Check partition boundaries */ - if ((sector < 0) || - ((sector + ((byte_offset + byte_len - 1) >> log2blksz)) - >= part_info->size)) { + if ((sector + ((byte_offset + byte_len - 1) >> log2blksz)) + >= part_info->size) { printf("%s read outside partition " LBAFU "\n", __func__, sector); return 0; diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c index 7187dcfb05..081509dbb4 100644 --- a/fs/ext4/ext4fs.c +++ b/fs/ext4/ext4fs.c @@ -71,7 +71,7 @@ int ext4fs_read_file(struct ext2fs_node *node, loff_t pos, blockcnt = lldiv(((len + pos) + blocksize - 1), blocksize);
for (i = lldiv(pos, blocksize); i < blockcnt; i++) { - lbaint_t blknr; + long int blknr; int blockoff = pos - (blocksize * i); int blockend = blocksize; int skipfirst = 0;
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Lokesh Vutla
