[U-Boot] [PATCH] sh: Add handling of CONFIG_SYS_NO_FLASH for board.c
Some board of SH does not have flash memoy. This revises it to initialize Flash when CONFIG_SYS_NO_FLASH is not defined.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- arch/sh/lib/board.c | 8 +++++++- 1 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/arch/sh/lib/board.c b/arch/sh/lib/board.c index 968566c..ed91643 100644 --- a/arch/sh/lib/board.c +++ b/arch/sh/lib/board.c @@ -43,6 +43,7 @@ const char version_string[] = U_BOOT_VERSION" ("U_BOOT_DATE" - "U_BOOT_TIME")";
unsigned long monitor_flash_len = CONFIG_SYS_MONITOR_LEN;
+#ifndef CONFIG_SYS_NO_FLASH static int sh_flash_init(void) { gd->bd->bi_flashsize = flash_init(); @@ -54,6 +55,7 @@ static int sh_flash_init(void)
return 0; } +#endif /* CONFIG_SYS_NO_FLASH */
#if defined(CONFIG_CMD_NAND) # include <nand.h> @@ -125,7 +127,9 @@ init_fnc_t *init_sequence[] = dram_init, /* SDRAM init */ timer_init, /* SuperH Timer (TCNT0 only) init */ sh_mem_env_init, - sh_flash_init, /* Flash memory(NOR) init*/ +#ifndef CONFIG_SYS_NO_FLASH + sh_flash_init, /* Flash memory init*/ +#endif INIT_FUNC_NAND_INIT/* Flash memory (NAND) init */ INIT_FUNC_PCI_INIT /* PCI init */ stdio_init, @@ -157,7 +161,9 @@ void sh_generic_init(void) bd = gd->bd; bd->bi_memstart = CONFIG_SYS_SDRAM_BASE; bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE; +#ifndef CONFIG_SYS_NO_FLASH bd->bi_flashstart = CONFIG_SYS_FLASH_BASE; +#endif #if defined(CONFIG_SYS_SRAM_BASE) && defined(CONFIG_SYS_SRAM_SIZE) bd->bi_sramstart = CONFIG_SYS_SRAM_BASE; bd->bi_sramsize = CONFIG_SYS_SRAM_SIZE;
Nobuhiro Iwamatsu
