[v2] misc: Correct Kconfig dependencies for a number of options
We have many cases of SPL (or TPL or VPL) drivers that don't depend on SPL_MISC (and so on) but rather just MISC.
Cc: Sean Anderson sean.anderson@seco.com Signed-off-by: Tom Rini trini@konsulko.com --- Changes in v2: - [STV]PL_CROS_EC should depend on the correct _MISC only, per Sean --- drivers/misc/Kconfig | 23 ++++++++++++----------- 1 file changed, 12 insertions(+), 11 deletions(-)
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 85ae7f62e911..419ddd31c0b9 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -125,7 +125,7 @@ config CROS_EC
config SPL_CROS_EC bool "Enable Chrome OS EC in SPL" - depends on SPL + depends on SPL_MISC help Enable access to the Chrome OS EC in SPL. This is a separate microcontroller typically available on a SPI bus on Chromebooks. It @@ -135,7 +135,7 @@ config SPL_CROS_EC
config TPL_CROS_EC bool "Enable Chrome OS EC in TPL" - depends on TPL + depends on TPL_MISC help Enable access to the Chrome OS EC in TPL. This is a separate microcontroller typically available on a SPI bus on Chromebooks. It @@ -145,7 +145,7 @@ config TPL_CROS_EC
config VPL_CROS_EC bool "Enable Chrome OS EC in VPL" - depends on VPL + depends on VPL_MISC help Enable access to the Chrome OS EC in VPL. This is a separate microcontroller typically available on a SPI bus on Chromebooks. It @@ -173,7 +173,7 @@ config CROS_EC_LPC
config SPL_CROS_EC_LPC bool "Enable Chrome OS EC LPC driver in SPL" - depends on CROS_EC + depends on CROS_EC && SPL_MISC help Enable I2C access to the Chrome OS EC. This is used on x86 Chromebooks such as link and falco. The keyboard is provided @@ -182,7 +182,7 @@ config SPL_CROS_EC_LPC
config TPL_CROS_EC_LPC bool "Enable Chrome OS EC LPC driver in TPL" - depends on CROS_EC + depends on CROS_EC && TPL_MISC help Enable I2C access to the Chrome OS EC. This is used on x86 Chromebooks such as link and falco. The keyboard is provided @@ -191,7 +191,7 @@ config TPL_CROS_EC_LPC
config VPL_CROS_EC_LPC bool "Enable Chrome OS EC LPC driver in VPL" - depends on CROS_EC + depends on CROS_EC && VPL_MISC help Enable I2C access to the Chrome OS EC. This is used on x86 Chromebooks such as link and falco. The keyboard is provided @@ -284,7 +284,7 @@ config MXC_OCOTP
config SPL_MXC_OCOTP bool "Enable MXC OCOTP driver in SPL" - depends on SPL && (ARCH_IMX8M || ARCH_MX6 || ARCH_MX7 || ARCH_MX7ULP || ARCH_VF610) + depends on SPL_MISC && (ARCH_IMX8M || ARCH_MX6 || ARCH_MX7 || ARCH_MX7ULP || ARCH_VF610) default y help If you say Y here, you will get support for the One Time @@ -314,7 +314,7 @@ config P2SB
config SPL_P2SB bool "Intel Primary to Sideband Bridge in SPL" - depends on SPL && (X86 || SANDBOX) + depends on SPL_MISC && (X86 || SANDBOX) help The Primary to Sideband Bridge is used to access various peripherals through memory-mapped I/O in a large chunk of PCI space. The space is @@ -324,7 +324,7 @@ config SPL_P2SB
config TPL_P2SB bool "Intel Primary to Sideband Bridge in TPL" - depends on TPL && (X86 || SANDBOX) + depends on TPL_MISC && (X86 || SANDBOX) help The Primary to Sideband Bridge is used to access various peripherals through memory-mapped I/O in a large chunk of PCI space. The space is @@ -343,7 +343,7 @@ config PWRSEQ
config SPL_PWRSEQ bool "Enable power-sequencing drivers for SPL" - depends on PWRSEQ + depends on SPL_MISC && PWRSEQ help Power-sequencing drivers provide support for controlling power for devices. They are typically referenced by a phandle from another @@ -451,7 +451,7 @@ config I2C_EEPROM
config SPL_I2C_EEPROM bool "Enable driver for generic I2C-attached EEPROMs for SPL" - depends on MISC && SPL && SPL_DM + depends on SPL_MISC help This option is an SPL-variant of the I2C_EEPROM option. See the help of I2C_EEPROM for details. @@ -504,6 +504,7 @@ config FS_LOADER
config SPL_FS_LOADER bool "Enable loader driver for file system" + depends on SPL help This is file system generic loader which can be used to load the file image from the storage into target such as memory.
Changes in v2:
- depends on SPL
- depends on SPL_MISC help Enable access to the Chrome OS EC in SPL. This is a separate microcontroller typically available on a SPI bus on Chromebooks. It
- depends on TPL
- depends on TPL_MISC help Enable access to the Chrome OS EC in TPL. This is a separate microcontroller typically available on a SPI bus on Chromebooks. It
- depends on VPL
- depends on VPL_MISC help Enable access to the Chrome OS EC in VPL. This is a separate microcontroller typically available on a SPI bus on Chromebooks. It
- depends on CROS_EC && SPL_MISC help Enable I2C access to the Chrome OS EC. This is used on x86 Chromebooks such as link and falco. The keyboard is provided
- depends on CROS_EC && TPL_MISC help Enable I2C access to the Chrome OS EC. This is used on x86 Chromebooks such as link and falco. The keyboard is provided
- depends on CROS_EC && VPL_MISC help Enable I2C access to the Chrome OS EC. This is used on x86 Chromebooks such as link and falco. The keyboard is provided
- depends on SPL_MISC && (ARCH_IMX8M || ARCH_MX6 || ARCH_MX7 || ARCH_MX7ULP || ARCH_VF610) default y help If you say Y here, you will get support for the One Time
- depends on SPL_MISC && (X86 || SANDBOX) help The Primary to Sideband Bridge is used to access various peripherals through memory-mapped I/O in a large chunk of PCI space. The space is
- depends on TPL_MISC && (X86 || SANDBOX) help The Primary to Sideband Bridge is used to access various peripherals through memory-mapped I/O in a large chunk of PCI space. The space is
- depends on PWRSEQ
- depends on SPL_MISC && PWRSEQ help Power-sequencing drivers provide support for controlling power for devices. They are typically referenced by a phandle from another
- depends on SPL_MISC help This option is an SPL-variant of the I2C_EEPROM option. See the help of I2C_EEPROM for details.
- depends on SPL help This is file system generic loader which can be used to load the file image from the storage into target such as memory.
Reviewed-by: Sean Anderson sean.anderson@seco.com
Any reason not to remove the defaults in this patch?
--Sean
Cc: Sean Anderson sean.anderson@seco.com Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Sean Anderson sean.anderson@seco.com
Sean Anderson
