[PATCH v4 0/1] sunxi: H616: add LPDDR4 support
At the moment, the driver only supports DDR3 and LPDDR3 memory. Add support for a new type DRAM. These changes have been successfully tested by me with orangepi zero3 4GB (DRAM: Rayson RS1G32LO4D2BDS-53BT). This patch should be applied after this: https://lore.kernel.org/all/20231014170236.16211-1-andre.przywara@arm.com/
Changes from v3: * added LPDDR4 part for mctl_phy_read_training() * added the new part in mctl_phy_configure_odt() as LPDDR4 specific to avoid possible problems with existing devices https://lore.kernel.org/u-boot/20231104062248.32938-1-iuncuim@gmail.com/
Changes from v2: * added default value for TPR6 parameter * added panic for unsupported DRAM types in switch/case conditions * added new line at the end of the timings file, changed the description * added a few small missing parts obtained from boot0 https://lore.kernel.org/u-boot/20231016053441.3197087-2-iuncuim@gmail.com/
Changes from v1: * replaced the phy_init array with one compatible with opizero3 * added DRAM TPR6 parameter * adaptation to new mctl_phy_configure_odt() * added timings for the board orangepi zero3 4GB https://lore.kernel.org/u-boot/20230729111331.173768-2-iuncuim@gmail.com/
Signed-off-by: Mikhail Kalashnikov iuncuim@gmail.com
iuncuim (1): sunxi: H616: add LPDDR4 support
.../include/asm/arch-sunxi/dram_sun50i_h616.h | 2 + arch/arm/mach-sunxi/Kconfig | 17 ++ arch/arm/mach-sunxi/dram_sun50i_h616.c | 218 ++++++++++++++---- arch/arm/mach-sunxi/dram_timings/Makefile | 1 + .../dram_timings/h616_lpddr4_2133.c | 95 ++++++++ 5 files changed, 294 insertions(+), 39 deletions(-) create mode 100644 arch/arm/mach-sunxi/dram_timings/h616_lpddr4_2133.c
The H616 SoC family has support for several types of DRAM: DDR3, LPDDR3, DDR4 and LPDDR4. At the moment, the driver only supports DDR3 and LPDDR3 memory. Let's extend the driver to support the LPDDR4 memory. This type of memory widely used in device with T507(-H) SoC and new orangepi zero3 with H618. The compatibility with T507 is not yet complete, because there is difference in the phy_init array. The LPDDR4-2133 timings correspond to DRAM Rayson RS1G32LO4D2BDS-53BT found on the NOR SPI from the Orangepi Zero 3 4GB.
Signed-off-by: Mikhail Kalashnikov iuncuim@gmail.com --- .../include/asm/arch-sunxi/dram_sun50i_h616.h | 2 + arch/arm/mach-sunxi/Kconfig | 17 ++ arch/arm/mach-sunxi/dram_sun50i_h616.c | 218 ++++++++++++++---- arch/arm/mach-sunxi/dram_timings/Makefile | 1 + .../dram_timings/h616_lpddr4_2133.c | 95 ++++++++ 5 files changed, 294 insertions(+), 39 deletions(-) create mode 100644 arch/arm/mach-sunxi/dram_timings/h616_lpddr4_2133.c
diff --git a/arch/arm/include/asm/arch-sunxi/dram_sun50i_h616.h b/arch/arm/include/asm/arch-sunxi/dram_sun50i_h616.h index 11774deded..a8fdda124a 100644 --- a/arch/arm/include/asm/arch-sunxi/dram_sun50i_h616.h +++ b/arch/arm/include/asm/arch-sunxi/dram_sun50i_h616.h @@ -130,6 +130,7 @@ check_member(sunxi_mctl_ctl_reg, unk_0x4240, 0x4240); #define MSTR_DEVICETYPE_LPDDR2 BIT(2) #define MSTR_DEVICETYPE_LPDDR3 BIT(3) #define MSTR_DEVICETYPE_DDR4 BIT(4) +#define MSTR_DEVICETYPE_LPDDR4 BIT(5) #define MSTR_DEVICETYPE_MASK GENMASK(5, 0) #define MSTR_2TMODE BIT(10) #define MSTR_BUSWIDTH_FULL (0 << 12) @@ -154,6 +155,7 @@ struct dram_para { u32 odt_en; u32 tpr0; u32 tpr2; + u32 tpr6; u32 tpr10; u32 tpr11; u32 tpr12; diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 9d5df2c102..e65bcb36a2 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -85,6 +85,12 @@ config DRAM_SUN50I_H616_TPR2 help TPR2 value from vendor DRAM settings.
+config DRAM_SUN50I_H616_TPR6 + hex "H616 DRAM TPR6 parameter" + default 0x3300c080 + help + TPR6 value from vendor DRAM settings. + config DRAM_SUN50I_H616_TPR10 hex "H616 DRAM TPR10 parameter" help @@ -441,6 +447,9 @@ config SUNXI_DRAM_DDR2 config SUNXI_DRAM_LPDDR3 bool
+config SUNXI_DRAM_LPDDR4 + bool + choice prompt "DRAM Type and Timing" default SUNXI_DRAM_DDR3_1333 if !MACH_SUN8I_V3S @@ -484,6 +493,14 @@ config SUNXI_DRAM_H616_LPDDR3 This option is the LPDDR3 timing used by the stock boot0 by Allwinner.
+config SUNXI_DRAM_H616_LPDDR4 + bool "LPDDR4 DRAM chips on the H616 DRAM controller" + select SUNXI_DRAM_LPDDR4 + depends on DRAM_SUN50I_H616 + help + This option is the LPDDR4 timing used by the stock boot0 by + Allwinner. + config SUNXI_DRAM_H616_DDR3_1333 bool "DDR3-1333 boot0 timings on the H616 DRAM controller" select SUNXI_DRAM_DDR3 diff --git a/arch/arm/mach-sunxi/dram_sun50i_h616.c b/arch/arm/mach-sunxi/dram_sun50i_h616.c index ba5659d409..e7e39d3f6a 100644 --- a/arch/arm/mach-sunxi/dram_sun50i_h616.c +++ b/arch/arm/mach-sunxi/dram_sun50i_h616.c @@ -6,8 +6,8 @@ * unknown. That's why this driver has plenty of magic numbers. Some * meaning was nevertheless deduced from strings found in boot0 and * known meaning of some dram parameters. - * This driver only supports DDR3 memory and omits logic for all - * other supported types supported by hardware. + * This driver supports DDR3, LPDDR3 and LPDDR4 memory. There is no + * DDR4 support yet. * * (C) Copyright 2020 Jernej Skrabec jernej.skrabec@siol.net * @@ -238,6 +238,11 @@ static const u8 phy_init[] = { 0x08, 0x01, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f, 0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x07, 0x17, 0x19, 0x1a +#elif defined(CONFIG_SUNXI_DRAM_H616_LPDDR4) + 0x02, 0x00, 0x17, 0x05, 0x04, 0x19, 0x06, 0x07, + 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f, + 0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x01, + 0x18, 0x03, 0x1a #endif };
@@ -246,8 +251,20 @@ static void mctl_phy_configure_odt(const struct dram_para *para) { uint32_t val_lo, val_hi;
+ /* + * This part should be applicable to all memory types, but is + * usually found in LPDDR4 bootloaders. Therefore, we will leave + * only for this type of memory. + */ + if (para->type == SUNXI_DRAM_TYPE_LPDDR4) { + clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x390, BIT(5), BIT(4)); + clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x3d0, BIT(5), BIT(4)); + clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x410, BIT(5), BIT(4)); + clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x450, BIT(5), BIT(4)); + } + val_lo = para->dx_dri; - val_hi = para->dx_dri; + val_hi = (para->type == SUNXI_DRAM_TYPE_LPDDR4) ? 0x04040404 : para->dx_dri; writel_relaxed(MASK_BYTE(val_lo, 0), SUNXI_DRAM_PHY0_BASE + 0x388); writel_relaxed(MASK_BYTE(val_hi, 0), SUNXI_DRAM_PHY0_BASE + 0x38c); writel_relaxed(MASK_BYTE(val_lo, 1), SUNXI_DRAM_PHY0_BASE + 0x3c8); @@ -265,7 +282,7 @@ static void mctl_phy_configure_odt(const struct dram_para *para) writel_relaxed(MASK_BYTE(val_hi, 1), SUNXI_DRAM_PHY0_BASE + 0x34c);
val_lo = (para->type == SUNXI_DRAM_TYPE_LPDDR3) ? 0 : para->dx_odt; - val_hi = para->dx_odt; + val_hi = (para->type == SUNXI_DRAM_TYPE_LPDDR4) ? 0 : para->dx_odt; writel_relaxed(MASK_BYTE(val_lo, 0), SUNXI_DRAM_PHY0_BASE + 0x380); writel_relaxed(MASK_BYTE(val_hi, 0), SUNXI_DRAM_PHY0_BASE + 0x384); writel_relaxed(MASK_BYTE(val_lo, 1), SUNXI_DRAM_PHY0_BASE + 0x3c0); @@ -392,12 +409,18 @@ static bool mctl_phy_read_calibration(const struct dram_config *config) return result; }
-static bool mctl_phy_read_training(const struct dram_config *config) +static bool mctl_phy_read_training(const struct dram_para *para, + const struct dram_config *config) { u32 val1, val2, *ptr1, *ptr2; bool result = true; int i;
+ if (para->type == SUNXI_DRAM_TYPE_LPDDR4) { + writel(0, SUNXI_DRAM_PHY0_BASE + 0x800); + writel(0, SUNXI_DRAM_PHY0_BASE + 0x81c); + } + clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x198, 3, 2); clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x804, 0x3f, 0xf); clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x808, 0x3f, 0xf); @@ -578,6 +601,8 @@ static void mctl_phy_bit_delay_compensation(const struct dram_para *para) clrbits_le32(SUNXI_DRAM_PHY0_BASE + 0x60, 1); setbits_le32(SUNXI_DRAM_PHY0_BASE + 8, 8); clrbits_le32(SUNXI_DRAM_PHY0_BASE + 0x190, 0x10); + if (para->type == SUNXI_DRAM_TYPE_LPDDR4) + clrbits_le32(SUNXI_DRAM_PHY0_BASE + 0x4, 0x80);
if (para->tpr10 & BIT(30)) val = para->tpr11 & 0x3f; @@ -791,8 +816,9 @@ static void mctl_phy_ca_bit_delay_compensation(const struct dram_para *para, writel(val, SUNXI_DRAM_PHY0_BASE + 0x7e0); writel(val, SUNXI_DRAM_PHY0_BASE + 0x7f4);
- if (para->type == SUNXI_DRAM_TYPE_DDR3) { - val = (para->tpr10 >> 7) & 0x1e; + val = (para->tpr10 >> 7) & 0x1e; + switch (para->type) { + case SUNXI_DRAM_TYPE_DDR3: if (para->tpr2 & 1) { writel(val, SUNXI_DRAM_PHY0_BASE + 0x794); if (config->ranks == 2) { @@ -818,8 +844,8 @@ static void mctl_phy_ca_bit_delay_compensation(const struct dram_para *para, writel(val, SUNXI_DRAM_PHY0_BASE + 0x7b8); } } - } else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) { - val = (para->tpr10 >> 7) & 0x1e; + break; + case SUNXI_DRAM_TYPE_LPDDR3: if (para->tpr2 & 1) { writel(val, SUNXI_DRAM_PHY0_BASE + 0x7a0); if (config->ranks == 2) { @@ -833,7 +859,18 @@ static void mctl_phy_ca_bit_delay_compensation(const struct dram_para *para, writel(val, SUNXI_DRAM_PHY0_BASE + 0x7f8); } } - } + break; + case SUNXI_DRAM_TYPE_LPDDR4: + if (para->tpr2 & 1) { + writel(val, SUNXI_DRAM_PHY0_BASE + 0x788); + } else { + writel(val, SUNXI_DRAM_PHY0_BASE + 0x794); + }; + break; + case SUNXI_DRAM_TYPE_DDR4: + default: + panic("This DRAM setup is currently not supported.\n"); + }; }
static bool mctl_phy_init(const struct dram_para *para, @@ -846,30 +883,42 @@ static bool mctl_phy_init(const struct dram_para *para, u32 val, val2, *ptr, mr0, mr2; int i;
+ if (para->type == SUNXI_DRAM_TYPE_LPDDR4) + clrbits_le32(SUNXI_DRAM_PHY0_BASE + 0x4,0x80); + if (config->bus_full_width) val = 0xf; else val = 3; clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x3c, 0xf, val);
- if (para->tpr2 & 0x100) { - if (para->type == SUNXI_DRAM_TYPE_DDR3) { + switch (para->type) { + case SUNXI_DRAM_TYPE_DDR3: + if (para->tpr2 & 0x100) { val = 9; val2 = 7; - } else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) { - // untested setup: use some values for now - val = 14; - val2 = 8; - } - } else { - if (para->type == SUNXI_DRAM_TYPE_DDR3) { + } else { val = 13; val2 = 9; - } else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) { + } + break; + case SUNXI_DRAM_TYPE_LPDDR3: + if (para->tpr2 & 0x100) { + val = 12; + val2 = 6; + } else { val = 14; val2 = 8; } - } + break; + case SUNXI_DRAM_TYPE_LPDDR4: + val = 20; + val2 = 10; + break; + case SUNXI_DRAM_TYPE_DDR4: + default: + panic("This DRAM setup is currently not supported.\n"); + };
writel(val, SUNXI_DRAM_PHY0_BASE + 0x14); writel(val, SUNXI_DRAM_PHY0_BASE + 0x35c); @@ -893,19 +942,40 @@ static bool mctl_phy_init(const struct dram_para *para, if (para->tpr10 & TPR10_CA_BIT_DELAY) mctl_phy_ca_bit_delay_compensation(para, config);
- if (para->type == SUNXI_DRAM_TYPE_DDR3) - val = 0x80; - else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) - val = 0xc0; + switch (para->type) { + case SUNXI_DRAM_TYPE_DDR3: + val = para->tpr6 & 0xff; + break; + case SUNXI_DRAM_TYPE_LPDDR3: + val = para->tpr6 >> 8 & 0xff; + break; + case SUNXI_DRAM_TYPE_LPDDR4: + val = para->tpr6 >> 24 & 0xff; + break; + case SUNXI_DRAM_TYPE_DDR4: + default: + panic("This DRAM setup is currently not supported.\n"); + }; + writel(val, SUNXI_DRAM_PHY0_BASE + 0x3dc); writel(val, SUNXI_DRAM_PHY0_BASE + 0x45c);
mctl_phy_configure_odt(para);
- if (para->type == SUNXI_DRAM_TYPE_DDR3) + switch (para->type) { + case SUNXI_DRAM_TYPE_DDR3: val = 0x0a; - else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) + break; + case SUNXI_DRAM_TYPE_LPDDR3: val = 0x0b; + break; + case SUNXI_DRAM_TYPE_LPDDR4: + val = 0x0d; + break; + case SUNXI_DRAM_TYPE_DDR4: + default: + panic("This DRAM setup is currently not supported.\n"); + }; clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 4, 0x7, val);
if (para->clk <= 672) @@ -955,8 +1025,8 @@ static bool mctl_phy_init(const struct dram_para *para, mr0 = 0x1f14; mr2 = 0x20; } - - if (para->type == SUNXI_DRAM_TYPE_DDR3) { + switch (para->type) { + case SUNXI_DRAM_TYPE_DDR3: writel(mr0, &mctl_ctl->mrctrl1); writel(0x80000030, &mctl_ctl->mrctrl0); mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); @@ -972,7 +1042,8 @@ static bool mctl_phy_init(const struct dram_para *para, writel(0, &mctl_ctl->mrctrl1); writel(0x80003030, &mctl_ctl->mrctrl0); mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); - } else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) { + break; + case SUNXI_DRAM_TYPE_LPDDR3: writel(mr0, &mctl_ctl->mrctrl1); writel(0x800000f0, &mctl_ctl->mrctrl0); mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); @@ -988,7 +1059,48 @@ static bool mctl_phy_init(const struct dram_para *para, writel(0x301, &mctl_ctl->mrctrl1); writel(0x800000f0, &mctl_ctl->mrctrl0); mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); - } + break; + case SUNXI_DRAM_TYPE_LPDDR4: + writel(0x0, &mctl_ctl->mrctrl1); + writel(0x80000030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(0x134, &mctl_ctl->mrctrl1); + writel(0x80000030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(0x21b, &mctl_ctl->mrctrl1); + writel(0x80000030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(0x333, &mctl_ctl->mrctrl1); + writel(0x80000030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(0x403, &mctl_ctl->mrctrl1); + writel(0x80000030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(0xb04, &mctl_ctl->mrctrl1); + writel(0x80000030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(0xc72, &mctl_ctl->mrctrl1); + writel(0x80000030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(0xe09, &mctl_ctl->mrctrl1); + writel(0x80000030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + + writel(0x1624, &mctl_ctl->mrctrl1); + writel(0x80000030, &mctl_ctl->mrctrl0); + mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0); + break; + case SUNXI_DRAM_TYPE_DDR4: + default: + panic("This DRAM setup is currently not supported.\n"); + };
writel(0, SUNXI_DRAM_PHY0_BASE + 0x54);
@@ -1018,7 +1130,7 @@ static bool mctl_phy_init(const struct dram_para *para,
if (para->tpr10 & TPR10_READ_TRAINING) { for (i = 0; i < 5; i++) - if (mctl_phy_read_training(config)) + if (mctl_phy_read_training(para, config)) break; if (i == 5) { debug("read training failed!\n"); @@ -1057,17 +1169,29 @@ static bool mctl_ctrl_init(const struct dram_para *para,
setbits_le32(&mctl_com->unk_0x008, 0xff00);
+ if (para->type == SUNXI_DRAM_TYPE_LPDDR4) + writel(1, SUNXI_DRAM_COM_BASE + 0x50); clrsetbits_le32(&mctl_ctl->sched[0], 0xff00, 0x3000);
writel(0, &mctl_ctl->hwlpctl);
- reg_val = MSTR_BURST_LENGTH(8) | MSTR_ACTIVE_RANKS(config->ranks); - if (para->type == SUNXI_DRAM_TYPE_DDR3) - reg_val |= MSTR_DEVICETYPE_DDR3 | MSTR_2TMODE; - else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) - reg_val |= MSTR_DEVICETYPE_LPDDR3; + reg_val = MSTR_ACTIVE_RANKS(config->ranks); + switch (para->type) { + case SUNXI_DRAM_TYPE_DDR3: + reg_val |= MSTR_BURST_LENGTH(8) | MSTR_DEVICETYPE_DDR3 | MSTR_2TMODE; + break; + case SUNXI_DRAM_TYPE_LPDDR3: + reg_val |= MSTR_BURST_LENGTH(8) | MSTR_DEVICETYPE_LPDDR3; + break; + case SUNXI_DRAM_TYPE_LPDDR4: + reg_val |= MSTR_BURST_LENGTH(16) | MSTR_DEVICETYPE_LPDDR4; + break; + case SUNXI_DRAM_TYPE_DDR4: + default: + panic("This DRAM setup is currently not supported.\n"); + }; if (config->bus_full_width) reg_val |= MSTR_BUSWIDTH_FULL; else @@ -1079,10 +1203,20 @@ static bool mctl_ctrl_init(const struct dram_para *para, else writel(0x0201, &mctl_ctl->odtmap);
- if (para->type == SUNXI_DRAM_TYPE_DDR3) + switch (para->type) { + case SUNXI_DRAM_TYPE_DDR3: reg_val = 0x06000400; - else if (para->type == SUNXI_DRAM_TYPE_LPDDR3) + break; + case SUNXI_DRAM_TYPE_LPDDR3: reg_val = 0x09020400; + break; + case SUNXI_DRAM_TYPE_LPDDR4: + reg_val = 0x04000400; + break; + case SUNXI_DRAM_TYPE_DDR4: + default: + panic("This DRAM setup is currently not supported.\n"); + }; writel(reg_val, &mctl_ctl->odtcfg); writel(reg_val, &mctl_ctl->unk_0x2240); writel(reg_val, &mctl_ctl->unk_0x3240); @@ -1102,6 +1236,9 @@ static bool mctl_ctrl_init(const struct dram_para *para, setbits_le32(&mctl_ctl->unk_0x3180, BIT(31) | BIT(30)); setbits_le32(&mctl_ctl->unk_0x4180, BIT(31) | BIT(30));
+ if (para->type == SUNXI_DRAM_TYPE_LPDDR4) + setbits_le32(&mctl_ctl->dbictl, 0x1); + setbits_le32(&mctl_ctl->rfshctl3, BIT(0)); clrbits_le32(&mctl_ctl->dfimisc, BIT(0));
@@ -1224,6 +1361,8 @@ static const struct dram_para para = { .type = SUNXI_DRAM_TYPE_DDR3, #elif defined(CONFIG_SUNXI_DRAM_H616_LPDDR3) .type = SUNXI_DRAM_TYPE_LPDDR3, +#elif defined(CONFIG_SUNXI_DRAM_H616_LPDDR4) + .type = SUNXI_DRAM_TYPE_LPDDR4, #endif .dx_odt = CONFIG_DRAM_SUN50I_H616_DX_ODT, .dx_dri = CONFIG_DRAM_SUN50I_H616_DX_DRI, @@ -1231,6 +1370,7 @@ static const struct dram_para para = { .odt_en = CONFIG_DRAM_SUN50I_H616_ODT_EN, .tpr0 = CONFIG_DRAM_SUN50I_H616_TPR0, .tpr2 = CONFIG_DRAM_SUN50I_H616_TPR2, + .tpr6 = CONFIG_DRAM_SUN50I_H616_TPR6, .tpr10 = CONFIG_DRAM_SUN50I_H616_TPR10, .tpr11 = CONFIG_DRAM_SUN50I_H616_TPR11, .tpr12 = CONFIG_DRAM_SUN50I_H616_TPR12, diff --git a/arch/arm/mach-sunxi/dram_timings/Makefile b/arch/arm/mach-sunxi/dram_timings/Makefile index 8bfd99448a..5f20341924 100644 --- a/arch/arm/mach-sunxi/dram_timings/Makefile +++ b/arch/arm/mach-sunxi/dram_timings/Makefile @@ -5,3 +5,4 @@ obj-$(CONFIG_SUNXI_DRAM_H6_LPDDR3) += h6_lpddr3.o obj-$(CONFIG_SUNXI_DRAM_H6_DDR3_1333) += h6_ddr3_1333.o obj-$(CONFIG_SUNXI_DRAM_H616_DDR3_1333) += h616_ddr3_1333.o obj-$(CONFIG_SUNXI_DRAM_H616_LPDDR3) += h616_lpddr3.o +obj-$(CONFIG_SUNXI_DRAM_H616_LPDDR4) += h616_lpddr4_2133.o diff --git a/arch/arm/mach-sunxi/dram_timings/h616_lpddr4_2133.c b/arch/arm/mach-sunxi/dram_timings/h616_lpddr4_2133.c new file mode 100644 index 0000000000..c11cb8678f --- /dev/null +++ b/arch/arm/mach-sunxi/dram_timings/h616_lpddr4_2133.c @@ -0,0 +1,95 @@ +/* + * sun50i H616 LPDDR4-2133 timings, as programmed by Allwinner's boot0 + * for orangepi zero3 with the H618 and LPDDR4 memory. + * + * (C) Copyright 2023 Mikhail Kalashnikov iuncuim@gmail.com + * Based on H6 DDR3 timings: + * (C) Copyright 2020 Jernej Skrabec jernej.skrabec@siol.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/dram.h> +#include <asm/arch/cpu.h> + +void mctl_set_timing_params(const struct dram_para *para) +{ + struct sunxi_mctl_ctl_reg * const mctl_ctl = + (struct sunxi_mctl_ctl_reg *)SUNXI_DRAM_CTL0_BASE; + + u8 tccd = 4; + u8 tfaw = ns_to_t(40); + u8 trrd = max(ns_to_t(10), 2); + u8 trcd = max(ns_to_t(18), 2); + u8 trc = ns_to_t(65); + u8 txp = max(ns_to_t(8), 2); + u8 trtp = max(ns_to_t(8), 4); + u8 trp = ns_to_t(21); + u8 tras = ns_to_t(42); + u16 trefi = ns_to_t(3904) / 32; + u16 trfc = ns_to_t(280); + u16 txsr = ns_to_t(190); + + u8 tmrw = max(ns_to_t(14), 5); + u8 tmrd = tmrw; + u8 tmod = 12; + u8 tcke = max(ns_to_t(15), 2); + u8 tcksrx = max(ns_to_t(2), 2); + u8 tcksre = max(ns_to_t(5), 2); + u8 tckesr = tcke; + u8 trasmax = (trefi * 9) / 32; + u8 txs = 4; + u8 txsdll = 16; + u8 txsabort = 4; + u8 txsfast = 4; + u8 tcl = 10; + u8 tcwl = 5; + u8 t_rdata_en = 17; + u8 tphy_wrlat = 5; + + u8 twtp = 24; + u8 twr2rd = max(trrd, (u8)4) + 14; + u8 trd2wr = (ns_to_t(4) + 17) - ns_to_t(1); + + /* set DRAM timing */ + writel((twtp << 24) | (tfaw << 16) | (trasmax << 8) | tras, + &mctl_ctl->dramtmg[0]); + writel((txp << 16) | (trtp << 8) | trc, &mctl_ctl->dramtmg[1]); + writel((tcwl << 24) | (tcl << 16) | (trd2wr << 8) | twr2rd, + &mctl_ctl->dramtmg[2]); + writel((tmrw << 20) | (tmrd << 12) | tmod, &mctl_ctl->dramtmg[3]); + writel((trcd << 24) | (tccd << 16) | (trrd << 8) | trp, + &mctl_ctl->dramtmg[4]); + writel((tcksrx << 24) | (tcksre << 16) | (tckesr << 8) | tcke, + &mctl_ctl->dramtmg[5]); + /* Value suggested by ZynqMP manual and used by libdram */ + writel((txp + 2) | 0x02020000, &mctl_ctl->dramtmg[6]); + writel((txsfast << 24) | (txsabort << 16) | (txsdll << 8) | txs, + &mctl_ctl->dramtmg[8]); + writel(0x00020208, &mctl_ctl->dramtmg[9]); + writel(0xE0C05, &mctl_ctl->dramtmg[10]); + writel(0x440C021C, &mctl_ctl->dramtmg[11]); + writel(8, &mctl_ctl->dramtmg[12]); + writel(0xA100002, &mctl_ctl->dramtmg[13]); + writel(txsr, &mctl_ctl->dramtmg[14]); + + clrsetbits_le32(&mctl_ctl->init[0], 0xC0000FFF, 0x3f0); + writel(0x01f20000, &mctl_ctl->init[1]); + writel(0x00000d05, &mctl_ctl->init[2]); + writel(0, &mctl_ctl->dfimisc); + writel(0x0034001b, &mctl_ctl->init[3]); + writel(0x00330000, &mctl_ctl->init[4]); + writel(0x00040072, &mctl_ctl->init[6]); + writel(0x00240009, &mctl_ctl->init[7]); + + clrsetbits_le32(&mctl_ctl->rankctl, 0xff0, 0x660); + + /* Configure DFI timing */ + writel(tphy_wrlat | 0x2000000 | (t_rdata_en << 16) | 0x808000, + &mctl_ctl->dfitmg0); + writel(0x100202, &mctl_ctl->dfitmg1); + + /* set refresh timing */ + writel((trefi << 16) | trfc, &mctl_ctl->rfshtmg); +}
Dne sobota, 11. november 2023 ob 10:10:00 CET je Mikhail Kalashnikov napisal(a):
Reviewed-by: Jernej Skrabec jernej.skrabec@gmail.com
Best regards, Jernej
On Sat, 11 Nov 2023 12:10:00 +0300 Mikhail Kalashnikov iuncuim@gmail.com wrote:
Hi Mikhail,
many thanks for staying on this and posting a new version of this patch! I cannot judge the LPDDR4 changes really, other than saying they work for me (TM). But it fills me with confidence that basically every change is guarded by the new LPDDR4 symbol, so the chances for regressions are very slim. I quickly boot tested on my X96 Mate without issues, so:
Acked-by: Andre Przywara andre.przywara@arm.com
Also many thanks to Piotr and Jernej for participating in the development efforts and for testing this!
So I will take this patch and send a pull request later today.
There are some smaller things below, but those actually don't affect the compiled code and can be fixed later, if needed.
- u32 tpr6; u32 tpr10; u32 tpr11; u32 tpr12;
- hex "H616 DRAM TPR6 parameter"
- default 0x3300c080
- help
- bool
- bool "LPDDR4 DRAM chips on the H616 DRAM controller"
- select SUNXI_DRAM_LPDDR4
- depends on DRAM_SUN50I_H616
- help
Allwinner.
- unknown. That's why this driver has plenty of magic numbers. Some
- meaning was nevertheless deduced from strings found in boot0 and
- known meaning of some dram parameters.
- This driver only supports DDR3 memory and omits logic for all
- other supported types supported by hardware.
- This driver supports DDR3, LPDDR3 and LPDDR4 memory. There is no
- DDR4 support yet.
- (C) Copyright 2020 Jernej Skrabec jernej.skrabec@siol.net
- 0x02, 0x00, 0x17, 0x05, 0x04, 0x19, 0x06, 0x07,
- 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f,
- 0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x01,
- 0x18, 0x03, 0x1a
#endif };
- if (para->type == SUNXI_DRAM_TYPE_LPDDR4) {
- val_lo = para->dx_dri;
- val_hi = (para->type == SUNXI_DRAM_TYPE_LPDDR4) ? 0x04040404 : para->dx_dri; writel_relaxed(MASK_BYTE(val_lo, 0), SUNXI_DRAM_PHY0_BASE + 0x388); writel_relaxed(MASK_BYTE(val_hi, 0), SUNXI_DRAM_PHY0_BASE + 0x38c); writel_relaxed(MASK_BYTE(val_lo, 1), SUNXI_DRAM_PHY0_BASE + 0x3c8);
- val_hi = (para->type == SUNXI_DRAM_TYPE_LPDDR4) ? 0 : para->dx_odt; writel_relaxed(MASK_BYTE(val_lo, 0), SUNXI_DRAM_PHY0_BASE + 0x380); writel_relaxed(MASK_BYTE(val_hi, 0), SUNXI_DRAM_PHY0_BASE + 0x384); writel_relaxed(MASK_BYTE(val_lo, 1), SUNXI_DRAM_PHY0_BASE + 0x3c0);
- clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x198, 3, 2); clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x804, 0x3f, 0xf); clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x808, 0x3f, 0xf);
- switch (para->type) {
- case SUNXI_DRAM_TYPE_DDR3: if (para->tpr2 & 1) { writel(val, SUNXI_DRAM_PHY0_BASE + 0x794); if (config->ranks == 2) {
break;
- case SUNXI_DRAM_TYPE_LPDDR3: if (para->tpr2 & 1) { writel(val, SUNXI_DRAM_PHY0_BASE + 0x7a0); if (config->ranks == 2) {
break;
- case SUNXI_DRAM_TYPE_LPDDR4:
} else {
break;
- case SUNXI_DRAM_TYPE_DDR4:
- default:
I understand I suggested that, but looking closer having panic messages down here is actually not needed: The only place where we set para->type is in the definition below, and there is no chance that anything else other than the three supported DRAM types comes in at the moment. We still need to appease the compiler about the missing case when doing a switch/case on an enum, but we can just "break;" here. Instead we could have one check very early in sunxi_dram_init() with a message, but more importantly a build time message (#else #error) in the dram_para definition. I will send a patch to that effect later, but as mentioned, all those panic messages get optimised away anyway, so we can keep this patch as is.
- if (config->bus_full_width) val = 0xf; else val = 3; clrsetbits_le32(SUNXI_DRAM_PHY0_BASE + 0x3c, 0xf, val);
val = 14;
val2 = 8;
- } else {
break;
val = 12;
val2 = 6;
}} else { val = 14; val2 = 8;
break;
So this refactoring above (reordering the tpr2 and DRAM type checks) is a bit confusing, but looks correct nevertheless. I saw that you changed one case above, from 14/8 to 12/6, but this was the unused and untested path, so that's probably fine. In hindsight it would have made sense to refactor the file first (go from "if/else" to "switch/case", and reorder the comparisons above), but this is too late now, and I checked that the changes are fine.
Many thanks, Andre
val = 20;
val2 = 10;
break;
default:
val = 0x80;
val = 0xc0;
break;
break;
break;
default:
- case SUNXI_DRAM_TYPE_DDR3: val = 0x0a;
break;
break;
val = 0x0d;
break;
default:
- case SUNXI_DRAM_TYPE_DDR3: writel(mr0, &mctl_ctl->mrctrl1); writel(0x80000030, &mctl_ctl->mrctrl0); mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0);
break;
- case SUNXI_DRAM_TYPE_LPDDR3: writel(mr0, &mctl_ctl->mrctrl1); writel(0x800000f0, &mctl_ctl->mrctrl0); mctl_await_completion(&mctl_ctl->mrctrl0, BIT(31), 0);
break;
break;
default:
if (i == 5) { debug("read training failed!\n");if (mctl_phy_read_training(para, config)) break;
- reg_val = MSTR_ACTIVE_RANKS(config->ranks);
break;
break;
break;
- default:
- }; if (config->bus_full_width) reg_val |= MSTR_BUSWIDTH_FULL; else
- case SUNXI_DRAM_TYPE_DDR3: reg_val = 0x06000400;
break;
- case SUNXI_DRAM_TYPE_LPDDR3: reg_val = 0x09020400;
break;
break;
- default:
- }; writel(reg_val, &mctl_ctl->odtcfg); writel(reg_val, &mctl_ctl->unk_0x2240); writel(reg_val, &mctl_ctl->unk_0x3240);
- setbits_le32(&mctl_ctl->rfshctl3, BIT(0)); clrbits_le32(&mctl_ctl->dfimisc, BIT(0));
- .type = SUNXI_DRAM_TYPE_LPDDR4,
- .tpr6 = CONFIG_DRAM_SUN50I_H616_TPR6, .tpr10 = CONFIG_DRAM_SUN50I_H616_TPR10, .tpr11 = CONFIG_DRAM_SUN50I_H616_TPR11, .tpr12 = CONFIG_DRAM_SUN50I_H616_TPR12,
- sun50i H616 LPDDR4-2133 timings, as programmed by Allwinner's boot0
- for orangepi zero3 with the H618 and LPDDR4 memory.
- (C) Copyright 2023 Mikhail Kalashnikov iuncuim@gmail.com
- Based on H6 DDR3 timings:
- struct sunxi_mctl_ctl_reg * const mctl_ctl =
- u8 tccd = 4;
- u8 tfaw = ns_to_t(40);
- u8 trrd = max(ns_to_t(10), 2);
- u8 trcd = max(ns_to_t(18), 2);
- u8 trc = ns_to_t(65);
- u8 txp = max(ns_to_t(8), 2);
- u8 trtp = max(ns_to_t(8), 4);
- u8 trp = ns_to_t(21);
- u8 tras = ns_to_t(42);
- u16 trefi = ns_to_t(3904) / 32;
- u16 trfc = ns_to_t(280);
- u16 txsr = ns_to_t(190);
- u8 tmrw = max(ns_to_t(14), 5);
- u8 tmrd = tmrw;
- u8 tmod = 12;
- u8 tcke = max(ns_to_t(15), 2);
- u8 tcksrx = max(ns_to_t(2), 2);
- u8 tcksre = max(ns_to_t(5), 2);
- u8 tckesr = tcke;
- u8 trasmax = (trefi * 9) / 32;
- u8 txs = 4;
- u8 txsdll = 16;
- u8 txsabort = 4;
- u8 txsfast = 4;
- u8 tcl = 10;
- u8 tcwl = 5;
- u8 t_rdata_en = 17;
- u8 tphy_wrlat = 5;
- u8 twtp = 24;
- u8 twr2rd = max(trrd, (u8)4) + 14;
- u8 trd2wr = (ns_to_t(4) + 17) - ns_to_t(1);
- /* set DRAM timing */
- writel((twtp << 24) | (tfaw << 16) | (trasmax << 8) | tras,
- writel((txp << 16) | (trtp << 8) | trc, &mctl_ctl->dramtmg[1]);
- writel((tcwl << 24) | (tcl << 16) | (trd2wr << 8) | twr2rd,
- writel((tmrw << 20) | (tmrd << 12) | tmod, &mctl_ctl->dramtmg[3]);
- writel((trcd << 24) | (tccd << 16) | (trrd << 8) | trp,
- writel((tcksrx << 24) | (tcksre << 16) | (tckesr << 8) | tcke,
- /* Value suggested by ZynqMP manual and used by libdram */
- writel((txp + 2) | 0x02020000, &mctl_ctl->dramtmg[6]);
- writel((txsfast << 24) | (txsabort << 16) | (txsdll << 8) | txs,
- writel(0x00020208, &mctl_ctl->dramtmg[9]);
- writel(0xE0C05, &mctl_ctl->dramtmg[10]);
- writel(0x440C021C, &mctl_ctl->dramtmg[11]);
- writel(8, &mctl_ctl->dramtmg[12]);
- writel(0xA100002, &mctl_ctl->dramtmg[13]);
- writel(txsr, &mctl_ctl->dramtmg[14]);
- clrsetbits_le32(&mctl_ctl->init[0], 0xC0000FFF, 0x3f0);
- writel(0x01f20000, &mctl_ctl->init[1]);
- writel(0x00000d05, &mctl_ctl->init[2]);
- writel(0, &mctl_ctl->dfimisc);
- writel(0x0034001b, &mctl_ctl->init[3]);
- writel(0x00330000, &mctl_ctl->init[4]);
- writel(0x00040072, &mctl_ctl->init[6]);
- writel(0x00240009, &mctl_ctl->init[7]);
- clrsetbits_le32(&mctl_ctl->rankctl, 0xff0, 0x660);
- /* Configure DFI timing */
- writel(tphy_wrlat | 0x2000000 | (t_rdata_en << 16) | 0x808000,
- writel(0x100202, &mctl_ctl->dfitmg1);
- /* set refresh timing */
- writel((trefi << 16) | trfc, &mctl_ctl->rfshtmg);
Wiadomość napisana przez Mikhail Kalashnikov iuncuim@gmail.com w dniu 11.11.2023, o godz. 10:09:
Changes from v3:
- added LPDDR4 part for mctl_phy_read_training()
- added the new part in mctl_phy_configure_odt() as LPDDR4 specific to
Changes from v2:
- added default value for TPR6 parameter
- added panic for unsupported DRAM types in switch/case conditions
- added new line at the end of the timings file, changed the description
- added a few small missing parts obtained from boot0
Changes from v1:
- replaced the phy_init array with one compatible with opizero3
- added DRAM TPR6 parameter
- adaptation to new mctl_phy_configure_odt()
- added timings for the board orangepi zero3 4GB
-- 2.42.0
Mikhail
Mikhail,
FYI
Great work!
I launched 20h+ stress tests (continuous hd tv live playback) on my: ddr3, lpddr3 and lpddr4 h616/h618 devices and had stable operation on all tested devices.
Nice!
br
Andre Przywara
Jernej Škrabec
Mikhail Kalashnikov
Piotr Oniszczuk
