[U-Boot] [PATCH] memmove_wd: copy chunk down from big address if parameter to is larger than from
When watchdog is enabled, memmove_wd() always copy chunk up from small address. This damanges overlapped memory data if destination address is smaller than source address.
Signed-off-by: Sonic Zhang sonic.zhang@analog.com ---
common/image.c | 14 ++++++++++++-- 1 file changed, 12 insertions(+), 2 deletions(-)
diff --git a/common/image.c b/common/image.c index b75a5ce..e691a51 100644 --- a/common/image.c +++ b/common/image.c @@ -485,12 +485,22 @@ void memmove_wd(void *to, void *from, size_t len, ulong chunksz) return;
#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + if (to > from) { + from += len; + to += len; + } while (len > 0) { size_t tail = (len > chunksz) ? chunksz : len; WATCHDOG_RESET(); + if (to > from) { + to -= tail; + from -= tail; + } memmove(to, from, tail); - to += tail; - from += tail; + if (to < from) { + to += tail; + from += tail; + } len -= tail; } #else /* !(CONFIG_HW_WATCHDOG || CONFIG_WATCHDOG) */
Signed-off-by: Sonic Zhang sonic.zhang@analog.com Acked-by: Simon Glass sjg@chromium.org
Sonic Zhang
