[U-Boot] arm, am33xx: move uart soft reset code to common place
move uart soft reset code to common place and call this function from board code, instead of copy and paste this code for every board.
Signed-off-by: Heiko Schocher hs@denx.de Cc: Matt Porter mporter@ti.com Cc: Lars Poeschel poeschel@lemonage.de Cc: Tom Rini trini@ti.com Cc: Enric Balletbo i Serra eballetbo@iseebcn.com --- arch/arm/cpu/armv7/am33xx/board.c | 22 ++++++++++++++++++++++ arch/arm/include/asm/arch-am33xx/sys_proto.h | 1 + board/isee/igep0033/board.c | 22 +--------------------- board/phytec/pcm051/board.c | 20 +------------------- board/ti/am335x/board.c | 23 +---------------------- board/ti/ti814x/evm.c | 19 +------------------ 6 Dateien geändert, 27 Zeilen hinzugefügt(+), 80 Zeilen entfernt(-)
diff --git a/arch/arm/cpu/armv7/am33xx/board.c b/arch/arm/cpu/armv7/am33xx/board.c index d3b3612..b935a29 100644 --- a/arch/arm/cpu/armv7/am33xx/board.c +++ b/arch/arm/cpu/armv7/am33xx/board.c @@ -166,4 +166,26 @@ void rtc32k_enable(void) /* Enable the RTC 32K OSC by setting bits 3 and 6. */ writel((1 << 3) | (1 << 6), &rtc->osc); } + +#define UART_RESET (0x1 << 1) +#define UART_CLK_RUNNING_MASK 0x1 +#define UART_SMART_IDLE_EN (0x1 << 0x3) + +void uart_soft_reset(void) +{ + struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE; + u32 regval; + + regval = readl(&uart_base->uartsyscfg); + regval |= UART_RESET; + writel(regval, &uart_base->uartsyscfg); + while ((readl(&uart_base->uartsyssts) & + UART_CLK_RUNNING_MASK) != UART_CLK_RUNNING_MASK) + ; + + /* Disable smart idle */ + regval = readl(&uart_base->uartsyscfg); + regval |= UART_SMART_IDLE_EN; + writel(regval, &uart_base->uartsyscfg); +} #endif diff --git a/arch/arm/include/asm/arch-am33xx/sys_proto.h b/arch/arm/include/asm/arch-am33xx/sys_proto.h index 71a1677..2422924 100644 --- a/arch/arm/include/asm/arch-am33xx/sys_proto.h +++ b/arch/arm/include/asm/arch-am33xx/sys_proto.h @@ -43,5 +43,6 @@ void omap_nand_switch_ecc(uint32_t, uint32_t);
#ifdef CONFIG_SPL_BUILD void rtc32k_enable(void); +void uart_soft_reset(void); #endif #endif diff --git a/board/isee/igep0033/board.c b/board/isee/igep0033/board.c index e82d722..842051f 100644 --- a/board/isee/igep0033/board.c +++ b/board/isee/igep0033/board.c @@ -36,21 +36,12 @@ DECLARE_GLOBAL_DATA_PTR;
static struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE; -#ifdef CONFIG_SPL_BUILD -static struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE; -#endif
/* MII mode defines */ #define RMII_MODE_ENABLE 0x4D
static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE;
-/* UART Defines */ -#ifdef CONFIG_SPL_BUILD -#define UART_RESET (0x1 << 1) -#define UART_CLK_RUNNING_MASK 0x1 -#define UART_SMART_IDLE_EN (0x1 << 0x3) - static const struct ddr_data ddr3_data = { .datardsratio0 = K4B2G1646EBIH9_RD_DQS, .datawdsratio0 = K4B2G1646EBIH9_WR_DQS, @@ -111,18 +102,7 @@ void s_init(void)
enable_uart0_pin_mux();
- regval = readl(&uart_base->uartsyscfg); - regval |= UART_RESET; - writel(regval, &uart_base->uartsyscfg); - while ((readl(&uart_base->uartsyssts) & - UART_CLK_RUNNING_MASK) != UART_CLK_RUNNING_MASK) - ; - - /* Disable smart idle */ - regval = readl(&uart_base->uartsyscfg); - regval |= UART_SMART_IDLE_EN; - writel(regval, &uart_base->uartsyscfg); - + uart_soft_reset(); gd = &gdata;
preloader_console_init(); diff --git a/board/phytec/pcm051/board.c b/board/phytec/pcm051/board.c index 6c0993a..72c5612 100644 --- a/board/phytec/pcm051/board.c +++ b/board/phytec/pcm051/board.c @@ -39,9 +39,6 @@ DECLARE_GLOBAL_DATA_PTR;
/* MII mode defines */ #define MII_MODE_ENABLE 0x0 @@ -50,11 +47,7 @@ static struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE;
-/* UART defines */ #ifdef CONFIG_SPL_BUILD -#define UART_RESET (0x1 << 1) -#define UART_CLK_RUNNING_MASK 0x1 -#define UART_SMART_IDLE_EN (0x1 << 0x3)
/* DDR RAM defines */ #define DDR_CLK_MHZ 303 /* DDR_DPLL_MULT value */ @@ -120,18 +113,7 @@ void s_init(void) u32 regval;
enable_uart0_pin_mux(); - - regval = readl(&uart_base->uartsyscfg); - regval |= UART_RESET; - writel(regval, &uart_base->uartsyscfg); - while ((readl(&uart_base->uartsyssts) & UART_CLK_RUNNING_MASK) - != UART_CLK_RUNNING_MASK) - ; - - /* Disable smart idle */ - regval = readl(&uart_base->uartsyscfg); - regval |= UART_SMART_IDLE_EN; - writel(regval, &uart_base->uartsyscfg); + uart_soft_reset();
gd = &gdata;
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index bf25878..b04e385 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -38,9 +38,6 @@ DECLARE_GLOBAL_DATA_PTR;
/* MII mode defines */ #define MII_MODE_ENABLE 0x0 @@ -126,12 +123,7 @@ static int read_eeprom(void) return 0; }
-/* UART Defines */ #ifdef CONFIG_SPL_BUILD -#define UART_RESET (0x1 << 1) -#define UART_CLK_RUNNING_MASK 0x1 -#define UART_SMART_IDLE_EN (0x1 << 0x3) - static const struct ddr_data ddr2_data = { .datardsratio0 = ((MT47H128M16RT25E_RD_DQS<<30) | (MT47H128M16RT25E_RD_DQS<<20) | @@ -305,9 +297,6 @@ void s_init(void) /* Enable RTC32K clock */ rtc32k_enable();
- /* UART softreset */ - u32 regVal; - #ifdef CONFIG_SERIAL1 enable_uart0_pin_mux(); #endif /* CONFIG_SERIAL1 */ @@ -327,17 +316,7 @@ void s_init(void) enable_uart5_pin_mux(); #endif /* CONFIG_SERIAL6 */
- regVal = readl(&uart_base->uartsyscfg); - regVal |= UART_RESET; - writel(regVal, &uart_base->uartsyscfg); - while ((readl(&uart_base->uartsyssts) & - UART_CLK_RUNNING_MASK) != UART_CLK_RUNNING_MASK) - ; - - /* Disable smart idle */ - regVal = readl(&uart_base->uartsyscfg); - regVal |= UART_SMART_IDLE_EN; - writel(regVal, &uart_base->uartsyscfg); + uart_soft_reset();
gd = &gdata;
diff --git a/board/ti/ti814x/evm.c b/board/ti/ti814x/evm.c index 0049c4b..661921a 100644 --- a/board/ti/ti814x/evm.c +++ b/board/ti/ti814x/evm.c @@ -37,33 +37,16 @@ DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_SPL_BUILD static struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE; -static struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE; #endif
/* UART Defines */ #ifdef CONFIG_SPL_BUILD -#define UART_RESET (0x1 << 1) -#define UART_CLK_RUNNING_MASK 0x1 -#define UART_SMART_IDLE_EN (0x1 << 0x3) - static void uart_enable(void) { - u32 regVal; - /* UART softreset */ - regVal = readl(&uart_base->uartsyscfg); - regVal |= UART_RESET; - writel(regVal, &uart_base->uartsyscfg); - while ((readl(&uart_base->uartsyssts) & - UART_CLK_RUNNING_MASK) != UART_CLK_RUNNING_MASK) - ; - - /* Disable smart idle */ - regVal = readl(&uart_base->uartsyscfg); - regVal |= UART_SMART_IDLE_EN; - writel(regVal, &uart_base->uartsyscfg); + uart_soft_reset(); }
static void wdt_disable(void)
Acked-by: Tom Rini trini@ti.com
Heiko Schocher
