[U-Boot] [PATCH v3 0/9] Add a pre-relocation malloc() implementation
There has been talk on and off of a pre-relocation malloc() implementation. Driver model needs this so that it can work before relocation.
A previous implementation was sent in a v1 series.
This implementation works by allocating space on the stack. The benefit is that boards do not need to specify the address of the malloc() area, only the size. The down-side is that due to the way board_init_f() is called, architecture-specific code needs to be used to allocate the space.
No clever algorithms are used to allocate space, free() is a nop and realloc() is not supported. This fits well with the desire to avoid wasting space on bucket tables and the hassle of supporting BSS data before relocation. We don't expect 'churn' in the pre-relocation case - we just want to allocate small amounts of memory temporarily.
After relocation a new malloc() pool is created and the old one is lost, although pointers into it will survive the immediate process of relocation.
Implementations are provided for sandbox and arm (32-bit only).
A related change is made to the early init for each arch to make this work.
Changes in v3: - Fix assembler code comment in crt0.S to say GD, not BSS - Ensure that aarch64 stays as it was - Add newline after clr_gd label - Remove redundant mov r0, #0 - Rebase on earlier patch - Put the two CONFIG changes together in sandbox.h
Changes in v2: - Tidy up commit message typo
Simon Glass (9): Remove form-feeds from dlmalloc.c arm: Set up global data before board_init_f() sandbox: Set up global data before board_init_f() Add a simple malloc() implementation for pre-relocation arm: Support pre-relocation malloc() exynos: Enable pre-relocation malloc() sandbox: Support pre-relocation malloc() sandbox: config: Enable pre-relocation malloc() sandbox: Always enable malloc debug
README | 16 ++++++++ arch/arm/include/asm/config.h | 2 + arch/arm/lib/crt0.S | 12 ++++++ arch/sandbox/cpu/start.c | 8 ++++ arch/sandbox/include/asm/config.h | 1 - common/board_f.c | 12 ++++++ common/board_r.c | 4 ++ common/dlmalloc.c | 85 ++++++++++++++++++++++++++++----------- include/asm-generic/global_data.h | 5 +++ include/configs/exynos5-dt.h | 4 +- include/configs/sandbox.h | 4 +- lib/asm-offsets.c | 3 ++ 12 files changed, 129 insertions(+), 27 deletions(-)
These don't really serve any purpose in the modern age. On the other hand they show up as annoying control characters in my editor, which then happily removes them.
I believe we can drop these characters from the file.
Changes in v3: None Changes in v2: - Tidy up commit message typo
common/dlmalloc.c | 46 +++++++++++++++++++++++----------------------- 1 file changed, 23 insertions(+), 23 deletions(-)
diff --git a/common/dlmalloc.c b/common/dlmalloc.c index 3c70d5d..d1cd561 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -220,7 +220,7 @@
/* Preliminaries */
@@ -1132,7 +1132,7 @@ gAllocatedSize))
#endif
/* Type declarations @@ -1272,7 +1272,7 @@ nextchunk-> +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ serviced via calls to mmap, and then later released via munmap.
*/ - + /* sizes, alignments */
#define SIZE_SZ (sizeof(INTERNAL_SIZE_T)) @@ -1297,7 +1297,7 @@ nextchunk-> +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ #define aligned_OK(m) (((unsigned long)((m)) & (MALLOC_ALIGN_MASK)) == 0)
/* Physical chunk operations @@ -1332,7 +1332,7 @@ nextchunk-> +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ #define chunk_at_offset(p, s) ((mchunkptr)(((char*)(p)) + (s)))
/* Dealing with use bits @@ -1371,7 +1371,7 @@ nextchunk-> +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ (((mchunkptr)(((char*)(p)) + (s)))->size &= ~(PREV_INUSE))
/* Dealing with size fields @@ -1394,7 +1394,7 @@ nextchunk-> +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ #define set_foot(p, s) (((mchunkptr)((char*)(p) + (s)))->prev_size = (s))
/* @@ -1566,7 +1566,7 @@ void mem_malloc_init(ulong start, ulong size)
#define is_small_request(nb) (nb < MAX_SMALLBIN_SIZE - SMALLBIN_WIDTH)
/* To help compensate for the large number of bins, a one-level index @@ -1590,7 +1590,7 @@ void mem_malloc_init(ulong start, ulong size) #define clear_binblock(ii) (binblocks_w = (mbinptr)(binblocks_r & ~(idx2binblock(ii))))
/* Other static bookkeeping data */ @@ -1628,7 +1628,7 @@ static unsigned int max_n_mmaps = 0; static unsigned long max_mmapped_mem = 0; #endif
/* Debugging support @@ -1769,7 +1769,7 @@ static void do_check_malloced_chunk(p, s) mchunkptr p; INTERNAL_SIZE_T s; #define check_malloced_chunk(P,N) #endif
/* Macro-based internal utilities @@ -1841,7 +1841,7 @@ static void do_check_malloced_chunk(p, s) mchunkptr p; INTERNAL_SIZE_T s; (last_remainder->fd = last_remainder->bk = last_remainder)
/* Routines dealing with mmap(). */ @@ -1972,7 +1972,7 @@ static mchunkptr mremap_chunk(p, new_size) mchunkptr p; size_t new_size; #endif /* HAVE_MMAP */
/* Extend the top-most chunk by obtaining memory from system. @@ -2089,7 +2089,7 @@ static void malloc_extend_top(nb) INTERNAL_SIZE_T nb; }
/* Main public routines */
@@ -2396,7 +2396,7 @@ Void_t* mALLOc(bytes) size_t bytes; }
@@ -2513,7 +2513,7 @@ void fREe(mem) Void_t* mem; }
/* @@ -2750,7 +2750,7 @@ Void_t* rEALLOc(oldmem, bytes) Void_t* oldmem; size_t bytes; }
@@ -2868,7 +2868,7 @@ Void_t* mEMALIGn(alignment, bytes) size_t alignment; size_t bytes;
/* @@ -2975,7 +2975,7 @@ void cfree(mem) Void_t *mem; } #endif
@@ -3056,7 +3056,7 @@ int malloc_trim(pad) size_t pad; } }
/* malloc_usable_size: @@ -3092,7 +3092,7 @@ size_t malloc_usable_size(mem) Void_t* mem; }
/* Utility to update current_mallinfo for malloc_stats and mallinfo() */
@@ -3136,7 +3136,7 @@ static void malloc_update_mallinfo() } #endif /* DEBUG */
@@ -3183,7 +3183,7 @@ struct mallinfo mALLINFo() #endif /* DEBUG */
/* mallopt:
Applied to dm/master.
At present arm defines CONFIG_SYS_GENERIC_GLOBAL_DATA, meaning that the global_data pointer is set up in board_init_f(). However it is actually set up before this, it just isn't zeroed.
If we zero the global data before calling board_init_f() then we don't need to define CONFIG_SYS_GENERIC_GLOBAL_DATA.
Make this change (on arm32 only) to simplify the init process. I don't have the ability to test aarch64 yet.
Changes in v2: None
arch/arm/include/asm/config.h | 2 ++ arch/arm/lib/crt0.S | 9 +++++++++ 2 files changed, 11 insertions(+)
diff --git a/arch/arm/include/asm/config.h b/arch/arm/include/asm/config.h index d3433da..5f2a5f4 100644 --- a/arch/arm/include/asm/config.h +++ b/arch/arm/include/asm/config.h @@ -7,7 +7,9 @@ #ifndef _ASM_CONFIG_H_ #define _ASM_CONFIG_H_
+#ifdef __aarch64__ #define CONFIG_SYS_GENERIC_GLOBAL_DATA +#endif
#define CONFIG_LMB #define CONFIG_SYS_BOOT_RAMDISK_HIGH diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index dfc2de9..43aa212 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -67,10 +67,19 @@ ENTRY(_main) ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) #endif bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ + mov r2, sp sub sp, sp, #GD_SIZE /* allocate one GD above SP */ bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ mov r9, sp /* GD is above SP */ + mov r1, sp mov r0, #0 +clr_gd: + cmp r1, r2 /* while not at end of GD */ + strlo r0, [r1] /* clear 32-bit GD word */ + addlo r1, r1, #4 /* move to next */ + blo clr_gd + + /* mov r0, #0 not needed due to above code */ bl board_init_f
#if ! defined(CONFIG_SPL_BUILD)
Hello Simon,
Changes in v3:
Changes in v2: None
Looks good to me. I picked up this one instead of my memset version.
Thanks, Jeroen
+Albert, Tom
Hi Albert,
On 11 July 2014 11:44, Jeroen Hofstee dasuboot@myspectrum.nl wrote:
Hello Simon,
Changes in v3:
Are you happy with this patch? I would like to apply to to the dm repo, but would quite like to get an ack first.
Changes in v2: None
Thanks, Jeroen
On Wed, Jul 23, 2014 at 06:16:52AM -0600, Simon Glass wrote:
+Albert, Tom
Hi Albert,
Hello Simon,
Changes in v3:
Acked-by: Tom Rini trini@ti.com
But still want Albert to chime in too. He should be back now :)
Changes in v2: None
Thanks, Jeroen
Regards, Simon _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Albert,
+Albert, Tom
Hi Albert,
Hello Simon,
Changes in v3:
Any objections to me pulling this through the -dm repo?
Applied to u-boot-dm/master.
At present sandbox defines CONFIG_SYS_GENERIC_GLOBAL_DATA, meaning that the global_data pointer is set up in board_init_f().
If we set up and zero the global data before calling board_init_f() then we don't need to define CONFIG_SYS_GENERIC_GLOBAL_DATA.
Make this change to simplify the init process.
arch/sandbox/cpu/start.c | 5 +++++ arch/sandbox/include/asm/config.h | 1 - 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index aad3b8b..5289291 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -6,6 +6,7 @@ #include <common.h> #include <os.h> #include <asm/getopt.h> +#include <asm/io.h> #include <asm/sections.h> #include <asm/state.h>
@@ -218,6 +219,7 @@ SANDBOX_CMDLINE_OPT_SHORT(terminal, 't', 1, int main(int argc, char *argv[]) { struct sandbox_state *state; + gd_t data; int ret;
ret = state_init(); @@ -236,6 +238,9 @@ int main(int argc, char *argv[]) if (state->ram_buf_rm && state->ram_buf_fname) os_unlink(state->ram_buf_fname);
+ memset(&data, '\0', sizeof(data)); + gd = &data; + /* Do pre- and post-relocation init */ board_init_f(0);
diff --git a/arch/sandbox/include/asm/config.h b/arch/sandbox/include/asm/config.h index 6c1bff9..ec7729e 100644 --- a/arch/sandbox/include/asm/config.h +++ b/arch/sandbox/include/asm/config.h @@ -7,7 +7,6 @@ #ifndef _ASM_CONFIG_H_ #define _ASM_CONFIG_H_
-#define CONFIG_SYS_GENERIC_GLOBAL_DATA #define CONFIG_SANDBOX_ARCH
/* Used by drivers/spi/sandbox_spi.c and arch/sandbox/include/asm/state.h */
If we are to have driver model before relocation we need to support some way of calling memory allocation routines.
The standard malloc() is pretty complicated:
1. It uses some BSS memory for its state, and BSS is not available before relocation
2. It supports algorithms for reducing memory fragmentation and improving performace of free(). Before relocation we could happily just not support free().
3. It includes about 4KB of code (Thumb 2) and 1KB of data. However since this has been loaded anyway this is not really a problem.
The simplest way to support pre-relocation malloc() is to reserve an area of memory and allocate it in increasing blocks as needed. This implementation does this.
To enable it, you need to define the size of the malloc() pool as described in the README. It will be located above the pre-relocation stack on supported architectures.
Note that this implementation is only useful on machines which have some memory available before dram_init() is called - this includes those that do no DRAM init (like tegra) and those that do it in SPL (quite a few boards). Enabling driver model preior to relocation for the rest of the boards is left for a later exercise.
README | 13 +++++++++++++ common/board_f.c | 12 ++++++++++++ common/board_r.c | 4 ++++ common/dlmalloc.c | 35 +++++++++++++++++++++++++++++++++++ include/asm-generic/global_data.h | 5 +++++ lib/asm-offsets.c | 3 +++ 6 files changed, 72 insertions(+)
diff --git a/README b/README index 4ac7399..11e9d31 100644 --- a/README +++ b/README @@ -3736,6 +3736,19 @@ Configuration Settings: - CONFIG_SYS_MALLOC_LEN: Size of DRAM reserved for malloc() use.
+- CONFIG_SYS_MALLOC_F_LEN + Size of the malloc() pool for use before relocation. If + this is defined, then a very simple malloc() implementation + will become available before relocation. The address is just + below the global data, and the stack is moved down to make + space. + + This feature allocates regions with increasing addresses + within the region. calloc() is supported, but realloc() + is not available. free() is supported but does nothing. + The memory will be freed (or in fact just forgotton) when + U-Boot relocates itself. + - CONFIG_SYS_BOOTM_LEN: Normally compressed uImages are limited to an uncompressed size of 8 MBytes. If this is not enough, diff --git a/common/board_f.c b/common/board_f.c index 4ea4cb2..b5e2031 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -776,6 +776,17 @@ static int mark_bootstage(void) return 0; }
+static int initf_malloc(void) +{ +#ifdef CONFIG_SYS_MALLOC_F_LEN + assert(gd->malloc_base); /* Set up by crt0.S */ + gd->malloc_limit = gd->malloc_base + CONFIG_SYS_MALLOC_F_LEN; + gd->malloc_ptr = 0; +#endif + + return 0; +} + static init_fnc_t init_sequence_f[] = { #ifdef CONFIG_SANDBOX setup_ram_buf, @@ -833,6 +844,7 @@ static init_fnc_t init_sequence_f[] = { sdram_adjust_866, init_timebase, #endif + initf_malloc, init_baud_rate, /* initialze baudrate settings */ serial_init, /* serial communications setup */ console_init_f, /* stage 1 init of console */ diff --git a/common/board_r.c b/common/board_r.c index 602a239..86424a0 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -259,6 +259,10 @@ static int initr_malloc(void) { ulong malloc_start;
+#ifdef CONFIG_SYS_MALLOC_F_LEN + debug("Pre-reloc malloc() used %#lx bytes (%ld KB)\n", gd->malloc_ptr, + gd->malloc_ptr / 1024); +#endif /* The malloc area is immediately below the monitor copy in DRAM */ malloc_start = gd->relocaddr - TOTAL_MALLOC_LEN; mem_malloc_init((ulong)map_sysmem(malloc_start, TOTAL_MALLOC_LEN), diff --git a/common/dlmalloc.c b/common/dlmalloc.c index d1cd561..26ba8fd 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -930,6 +930,8 @@ struct mallinfo mALLINFo(); #endif /* 0 */ /* Moved to malloc.h */
#include <malloc.h> +#include <asm/io.h> + #ifdef DEBUG #if __STD_C static void malloc_update_mallinfo (void); @@ -2174,6 +2176,20 @@ Void_t* mALLOc(bytes) size_t bytes;
INTERNAL_SIZE_T nb;
+#ifdef CONFIG_SYS_MALLOC_F_LEN + if (!(gd->flags & GD_FLG_RELOC)) { + ulong new_ptr; + void *ptr; + + new_ptr = gd->malloc_ptr + bytes; + if (new_ptr > gd->malloc_limit) + panic("Out of pre-reloc memory"); + ptr = map_sysmem(gd->malloc_base + gd->malloc_ptr, bytes); + gd->malloc_ptr = ALIGN(new_ptr, sizeof(new_ptr)); + return ptr; + } +#endif + /* check if mem_malloc_init() was run */ if ((mem_malloc_start == 0) && (mem_malloc_end == 0)) { /* not initialized yet */ @@ -2437,6 +2453,12 @@ void fREe(mem) Void_t* mem; mchunkptr fwd; /* misc temp for linking */ int islr; /* track whether merging with last_remainder */
+#ifdef CONFIG_SYS_MALLOC_F_LEN + /* free() is a no-op - all the memory will be freed on relocation */ + if (!(gd->flags & GD_FLG_RELOC)) + return; +#endif + if (mem == NULL) /* free(0) has no effect */ return;
@@ -2588,6 +2610,13 @@ Void_t* rEALLOc(oldmem, bytes) Void_t* oldmem; size_t bytes; /* realloc of null is supposed to be same as malloc */ if (oldmem == NULL) return mALLOc(bytes);
+#ifdef CONFIG_SYS_MALLOC_F_LEN + if (!(gd->flags & GD_FLG_RELOC)) { + /* This is harder to support and should not be needed */ + panic("pre-reloc realloc() is not supported"); + } +#endif + newp = oldp = mem2chunk(oldmem); newsize = oldsize = chunksize(oldp);
@@ -2933,6 +2962,12 @@ Void_t* cALLOc(n, elem_size) size_t n; size_t elem_size; return NULL; else { +#ifdef CONFIG_SYS_MALLOC_F_LEN + if (!(gd->flags & GD_FLG_RELOC)) { + MALLOC_ZERO(mem, sz); + return mem; + } +#endif p = mem2chunk(mem);
/* Two optional cases in which clearing not necessary */ diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 2850ed8..f6a2a20 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -85,6 +85,11 @@ typedef struct global_data { #endif unsigned long timebase_h; unsigned long timebase_l; +#ifdef CONFIG_SYS_MALLOC_F_LEN + unsigned long malloc_base; /* base address of early malloc() */ + unsigned long malloc_limit; /* limit address */ + unsigned long malloc_ptr; /* current address */ +#endif struct arch_global_data arch; /* architecture-specific data */ } gd_t; #endif diff --git a/lib/asm-offsets.c b/lib/asm-offsets.c index 6ea7b03..129bc3e 100644 --- a/lib/asm-offsets.c +++ b/lib/asm-offsets.c @@ -28,6 +28,9 @@ int main(void) DEFINE(GD_SIZE, sizeof(struct global_data));
DEFINE(GD_BD, offsetof(struct global_data, bd)); +#ifdef CONFIG_SYS_MALLOC_F_LEN + DEFINE(GD_MALLOC_BASE, offsetof(struct global_data, malloc_base)); +#endif
#if defined(CONFIG_ARM)
- It uses some BSS memory for its state, and BSS is not available before
relocation
- It supports algorithms for reducing memory fragmentation and improving
- It includes about 4KB of code (Thumb 2) and 1KB of data. However since
Add support for re-relocation malloc() in arm's start-up code.
Changes in v3: - Rebase on earlier patch
Changes in v2: None
README | 3 +++ arch/arm/lib/crt0.S | 5 ++++- 2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/README b/README index 11e9d31..73abbf0 100644 --- a/README +++ b/README @@ -3749,6 +3749,9 @@ Configuration Settings: The memory will be freed (or in fact just forgotton) when U-Boot relocates itself.
+ Pre-relocation malloc() is only supported on ARM at present + but is fairly easy to enable for other archs. + - CONFIG_SYS_BOOTM_LEN: Normally compressed uImages are limited to an uncompressed size of 8 MBytes. If this is not enough, diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index 43aa212..29cdad0 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -78,7 +78,10 @@ clr_gd: strlo r0, [r1] /* clear 32-bit GD word */ addlo r1, r1, #4 /* move to next */ blo clr_gd - +#if defined(CONFIG_SYS_MALLOC_F_LEN) && !defined(CONFIG_SPL_BUILD) + sub sp, sp, #CONFIG_SYS_MALLOC_F_LEN + str sp, [r9, #GD_MALLOC_BASE] +#endif /* mov r0, #0 not needed due to above code */ bl board_init_f
+Tom
Hi Albert,
Changes in v3:
Can you please take a look at this patch? I would like to apply it to the dm repo.
Changes in v2: None
-- 2.0.0.526.g5318336
Enable this feature to support driver model before relocation.
include/configs/exynos5-dt.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/exynos5-dt.h b/include/configs/exynos5-dt.h index 3c2036e..fb03500 100644 --- a/include/configs/exynos5-dt.h +++ b/include/configs/exynos5-dt.h @@ -63,7 +63,8 @@ #define INFORM2_OFFSET 0x808 #define INFORM3_OFFSET 0x80c
-/* Size of malloc() pool */ +/* Size of malloc() pool before and after relocation */ +#define CONFIG_SYS_MALLOC_F_LEN (1 << 10) #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (4 << 20))
/* select serial console configuration */ @@ -156,7 +157,6 @@ #define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5E00000) #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) - #define CONFIG_RD_LVL
#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE
Set up and zero global data before board_init_f() is called so that we can remove the need for CONFIG_SYS_GENERIC_GLOBAL_DATA.
README | 4 ++-- arch/sandbox/cpu/start.c | 3 +++ 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/README b/README index 73abbf0..70beeeb 100644 --- a/README +++ b/README @@ -3749,8 +3749,8 @@ Configuration Settings: The memory will be freed (or in fact just forgotton) when U-Boot relocates itself.
- Pre-relocation malloc() is only supported on ARM at present - but is fairly easy to enable for other archs. + Pre-relocation malloc() is only supported on ARM and sandbox + at present but is fairly easy to enable for other archs.
- CONFIG_SYS_BOOTM_LEN: Normally compressed uImages are limited to an diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 5289291..b3d7051 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -240,6 +240,9 @@ int main(int argc, char *argv[])
memset(&data, '\0', sizeof(data)); gd = &data; +#ifdef CONFIG_SYS_MALLOC_F_LEN + gd->malloc_base = CONFIG_MALLOC_F_ADDR; +#endif
Enable this for sandbox so that we will be able to use driver model before relocation.
Changes in v3: - Put the two CONFIG changes together in sandbox.h
Changes in v2: None
include/configs/sandbox.h | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 12b69d9..bf2d25c 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -68,8 +68,10 @@ #define CONFIG_EFI_PARTITION
/* - * Size of malloc() pool, although we don't actually use this yet. + * Size of malloc() pool, before and after relocation */ +#define CONFIG_SYS_MALLOC_F_LEN (1 << 10) +#define CONFIG_MALLOC_F_ADDR 0x0010000 #define CONFIG_SYS_MALLOC_LEN (32 << 20) /* 32MB */
#define CONFIG_SYS_HUSH_PARSER
Tun on DEBUG in malloc(). This adds code space and slows things down but for sandbox this is acceptable. We gain the ability to check for memory leaks in tests.
common/dlmalloc.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/common/dlmalloc.c b/common/dlmalloc.c index 26ba8fd..f987339 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -1,5 +1,9 @@ #include <common.h>
+#ifdef CONFIG_SANDBOX +#define DEBUG +#endif + #if 0 /* Moved to malloc.h */ /* ---------- To make a malloc.h, start cutting here ------------ */
My concern without a fix right now is how to make use of this in SPL, when we're able to move SPL over to using still more generic code rather than re-inventing the board_init_{f,r} wheels, in the case where we init DRAM.
Hi Tom,
One option would be to split this new code out into a separate file, and have two malloc() implementations:
- big one - falls back to small one pre-relocation - small one - used for SPL
On 14 July 2014 18:16, Simon Glass sjg@chromium.org wrote:
Hi Tom,
I'm thinking of applying this to the dm repo now, except for the arm patches where I would like to get Albert's ack (so I'll wait a few more days).
Any objections?
Hi Tom,
Any objections?
I think we'll be OK. I checked over the callpath again on OMAP parts and we setup DDR prior to _main (in SPL) so we'll be fine.
Hi Tom,
Hi Tom,
Any objections?
OK, I'll prepare a pull request for the ARM-related malloc() patches soon, along with the GPIO things (sandbox only at this stage as we need to make progress on applying exynos patches first).
On 28 July 2014 06:16, Simon Glass sjg@chromium.org wrote:
Hi Tom,
Hi Tom,
Any objections?
I haven't heard from Albert or Minkyu so will go ahead with this plan.
Jeroen Hofstee
