[U-Boot] U-boot to Beaglebone Black Issue
We are trying to get Kubos-Linux up and running on our Beaglebone Black board but are having issues with making the program. We ran `make beaglebone-black_defconfig` and are getting the error:
vagrant@vagrant:~/uboot$ make beaglebone-black_defconfig *** *** Can't find default configuration "arch/../configs/beaglebone-black_defconfig"! *** scripts/kconfig/Makefile:114: recipe for target 'beaglebone-black_defconfig' failed make[1]: *** [beaglebone-black_defconfig] Error 1 Makefile:478: recipe for target 'beaglebone-black_defconfig' failed make: *** [beaglebone-black_defconfig] Error 2
How do we make for the Beaglebone Black board?
Thank you,
James Eckler
On Mon, Dec 4, 2017 at 9:53 PM, James David Eckler james.d.eckler@wmich.edu wrote:
There's two configs for the BBone devices, am335x_boneblack_defconfig although I tend to use am335x_evm_defconfig these days as it supports all the various *bone devices. A simple ls of the configs/ directory would have at least given you the former.
Peter
Hello James,
Am 04.12.2017 um 22:53 schrieb James David Eckler:
In U-Boot there is no "arch/../configs/beaglebone-black_defconfig" defconfig.
Do you want to build linux or u-boot for the BeagelBoneblack?
I have an weekly tbot u-boot build for the BBB, see log from last working version:
http://xeidos.ddns.net/tbot/id_488/tbot.txt
You may can extract infos here for how to clone/setup toolchain/compile and install new U-Boot on the BBB.
Attention since commit : http://git.denx.de/?p=u-boot.git;a=commit;h=6b867dabe84bae1e74e88f4af620c26c...
you need a gcc > 6.0 for compiling U-Boot.
For compiling linux, see my weekly linux tbot test for the BBB with the git tree from Robert Nelson for the BBB here:
http://xeidos.ddns.net/tbot/id_519/tbot.txt
(In both logs, search for "git clone" or "make", and you should find the needed infos ...
bye, Heiko
Heiko Schocher
James David Eckler
Peter Robinson
