[U-Boot-Users] [PATCH 14/25] include/configs: Use new CONFIG_CMD_* in various h* named board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/hermes.h | 16 +++++------ include/configs/hmi1001.h | 40 +++++++++++++++--------------- include/configs/hymod.h | 60 +++++++++++++++++++++++--------------------- 3 files changed, 58 insertions(+), 58 deletions(-)
diff --git a/include/configs/hermes.h b/include/configs/hermes.h index 91117ba..f1cc8d2 100644 --- a/include/configs/hermes.h +++ b/include/configs/hermes.h @@ -64,23 +64,21 @@
#undef CONFIG_WATCHDOG /* watchdog disabled */
-#define CONFIG_COMMANDS CONFIG_CMD_DFL
-#define CONFIG_BOOTP_MASK CONFIG_BOOTP_DEFAULT - -/*----------------------------------------------------------------------*/ +/* + * Command line configuration. + */ +#include <config_cmd_default.h>
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h>
-/*----------------------------------------------------------------------*/ +#define CONFIG_BOOTP_MASK CONFIG_BOOTP_DEFAULT
/* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -157,7 +155,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/hmi1001.h b/include/configs/hmi1001.h index 4d813d8..7e1897a 100644 --- a/include/configs/hmi1001.h +++ b/include/configs/hmi1001.h @@ -38,11 +38,6 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) -# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - #define CONFIG_BOARD_EARLY_INIT_R
/* @@ -55,22 +50,22 @@ /* Partitions */ #define CONFIG_DOS_PARTITION
+ /* - * Supported commands + * Command line configuration. */ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_DATE | \ - CFG_CMD_DISPLAY | \ - CFG_CMD_DHCP | \ - CFG_CMD_EEPROM | \ - CFG_CMD_I2C | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS | \ - CFG_CMD_PCI | \ - CFG_CMD_SNTP ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DISPLAY +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_SNTP +
#define CONFIG_TIMESTAMP 1 /* Print image info with timestamp */
@@ -222,7 +217,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -231,6 +226,11 @@ #define CFG_MAXARGS 16 /* max number of command args */ #define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */
+#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + /* Enable an alternate, more extensive memory test */ #define CFG_ALT_MEMTEST
diff --git a/include/configs/hymod.h b/include/configs/hymod.h index 8cad98d..0fdfb15 100644 --- a/include/configs/hymod.h +++ b/include/configs/hymod.h @@ -174,32 +174,34 @@
#define CONFIG_LAST_STAGE_INIT
-#define CONFIG_COMMANDS (CFG_CMD_ALL & ~( \ - CFG_CMD_BEDBUG | \ - CFG_CMD_BMP | \ - CFG_CMD_DISPLAY | \ - CFG_CMD_DOC | \ - CFG_CMD_EXT2 | \ - CFG_CMD_FDC | \ - CFG_CMD_FDOS | \ - CFG_CMD_FPGA | \ - CFG_CMD_HWFLOW | \ - CFG_CMD_IDE | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_NAND | \ - CFG_CMD_MMC | \ - CFG_CMD_PCMCIA | \ - CFG_CMD_PCI | \ - CFG_CMD_USB | \ - CFG_CMD_REISER | \ - CFG_CMD_SCSI | \ - CFG_CMD_SPI | \ - CFG_CMD_UNIVERSE| \ - CFG_CMD_VFD | \ - CFG_CMD_XIMG ) ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_all.h> + +#undef CONFIG_CMD_BEDBUG +#undef CONFIG_CMD_BMP +#undef CONFIG_CMD_DISPLAY +#undef CONFIG_CMD_DOC +#undef CONFIG_CMD_EXT2 +#undef CONFIG_CMD_FDC +#undef CONFIG_CMD_FDOS +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_HWFLOW +#undef CONFIG_CMD_IDE +#undef CONFIG_CMD_JFFS2 +#undef CONFIG_CMD_NAND +#undef CONFIG_CMD_MMC +#undef CONFIG_CMD_PCMCIA +#undef CONFIG_CMD_PCI +#undef CONFIG_CMD_USB +#undef CONFIG_CMD_REISER +#undef CONFIG_CMD_SCSI +#undef CONFIG_CMD_SPI +#undef CONFIG_CMD_UNIVERSE +#undef CONFIG_CMD_VFD +#undef CONFIG_CMD_XIMG +
#ifdef DEBUG #define CONFIG_BOOTDELAY -1 /* autoboot disabled */ @@ -218,7 +220,7 @@ #define DEBUG_BOOTKEYS 0 #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #undef CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */ #define CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */ #undef CONFIG_KGDB_NONE /* define if kgdb on something else */ @@ -247,7 +249,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -400,7 +402,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value*/ #endif
Jon Loeliger
