[U-Boot] [PATCH] MPC8377EWLAN: Fix DDR configuration bug
Changelog for this patch: This patch is used to fix the bug that u-boot and kernel can not smoothly work because of insufficient DDR2 chip output strength. The setting of DDR2 output strength is changed from "reduced" to "full" status.
diff -Nur a/include/configs/MPC8377EWLAN.h b/include/configs/MPC8377EWLAN.h --- a/include/configs/MPC8377EWLAN.h 2009-07-08 22:54:50.000000000 -0700 +++ b/include/configs/MPC8377EWLAN.h 2009-07-12 21:50:27.000000000 -0700 @@ -299,18 +299,16 @@ | SDRAM_CFG_DBW_32) #else #define CFG_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ - | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT \ - | SDRAM_CFG_HSE) - /* 0x43000000 */ + | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT) #endif #define CFG_DDR_SDRAM_CFG2 0x00001000 /* 1 posted refresh */
#ifdef CONFIG_CORE_667MHZ -#define CFG_DDR_MODE ((0x0406 << SDRAM_MODE_ESD_SHIFT) \ +#define CFG_DDR_MODE ((0x0404 << SDRAM_MODE_ESD_SHIFT) \ | (0x0442 << SDRAM_MODE_SD_SHIFT)) /* 0x44440232 */ #else -#define CFG_DDR_MODE ((0x0406 << SDRAM_MODE_ESD_SHIFT) \ +#define CFG_DDR_MODE ((0x0404 << SDRAM_MODE_ESD_SHIFT) \ | (0x0232 << SDRAM_MODE_SD_SHIFT)) #endif #define CFG_DDR_MODE2 0x00000000;
Best regards, Lu Chen
Don't include messages like this in the actual changelog, because then you force the git repository maintainer (Kim, in this case) to edit your patch when applying it.
You forgot a Signed-off-by: line here.
Lu Chen-B21101
Timur Tabi
