Re: [U-Boot-Users] hang up after start_here
Wolfgang,
thanks for your reply. How can you bet that my initialization sequence is incomplete? I remember you that it works on 15 boards out of 16.
Laurent
Wolfgang Denk wd@denx.de Sent by: wd@denx.de 18/08/03 10:39
To: "Laurent Mohin" laurent.mohin@acterna.com cc: linuxppc-embedded@lists.linuxppc.org, u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] hang up after start_here
In message OFE8EA1A87.9A7B8A06-ONC1256D86.0028950A-C1256D86.002D5CE3@se.wavetek.com you wrote:
I've debugged and found that the board hangs in start_here function and doesn't reach the early_init function.
Because the problem appears on only one of my boards out of 16, I
suspect
a hardware problem, and because it occurs just after mmu initialisation and caches enabling, I suspect more especially sdram accesses.
I want to know if anybody has encountered a similar problem and if the diagnostic was the same.
This is a standard problem, which can show up in many forms. My bet is that your SDRAM initialization sequence is incomplete / broken. Remember that it is NOT sufficient to set up the mmeory controller, you must also intialize the SDRAM chips themself.
Is this Motorola MPC8XX family?
If so ... I would suggest that if you don't turn on the MMU and the cache it may work.... normally indicating a SDRAM problem
What are you doing to set the mode and CAS latency on your SDRAM IC's .
There is no Pure SDRAM controller on this processor family you have to do some of the work to get SDRAM running
Once the cache and MMU are on then the chip will really ROCK the SDRAM hence strange failures.
Regards
Frank Robbins
Analogue & Micro Ltd, 9 Clytha Park Road Newport South Wales NP20 4US United Kingdom (Great Britain) Email : Frank.Robbins@Analogue-Micro.com Email : Frank@Analogue-Micro.com
Tel: 44 (0)1633 666787 Fax: 44 (0)1633 666788
----- Original Message ----- From: "Laurent Mohin" laurent.mohin@acterna.com To: "Wolfgang Denk" wd@denx.de Cc: linuxppc-embedded@lists.linuxppc.org; u-boot-users@lists.sourceforge.net; wd@denx.de Sent: Tuesday, August 19, 2003 8:51 AM Subject: Re: [U-Boot-Users] hang up after start_here
Wolfgang,
Laurent
To: "Laurent Mohin" <laurent.mohin@acterna.com> cc: linuxppc-embedded@lists.linuxppc.org,
suspect
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de "What is wanted is not the will to believe, but the will to find out, which is the exact opposite." - Bertrand Russell, _Sceptical_Essays_, 1928
** Sent via the linuxppc-embedded mail list. See
On Tue, 2003-08-19 at 09:51, Laurent Mohin wrote:
Wolfgang,
Laurent
It's a common error on the motorola parts however that particular problem is impossible to get on the IBM chip. you can still have the timing to fast and wrong mode for the chip but thats it.
I say throw the card away :)
Frank Robbins
Kenneth Johansson
Laurent Mohin
