[U-Boot] [PATCH 1/2] spl: Fix compile warning for arm64
Make the cast explicit for "warning: cast to pointer from integer of different size".
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 494f683..ce58c58 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -44,7 +44,7 @@ static int mmc_load_image_raw_sector(struct mmc *mmc, unsigned long sector)
/* Read the header too to avoid extra memcpy */ count = mmc->block_dev.block_read(0, sector, image_size_sectors, - (void *)spl_image.load_addr); + (void *)(ulong)spl_image.load_addr); debug("read %x sectors to %x\n", image_size_sectors, spl_image.load_addr);
Please help to review the two patches. Thanks!:)
Regards, Qianyu
-----Original Message----- From: Gong Qianyu [mailto:Qianyu.Gong@freescale.com] Sent: Thursday, July 30, 2015 2:07 PM To: u-boot@lists.denx.de Cc: Hu Mingkai-B21284; Gong Qianyu-B52263 Subject: [PATCH 1/2] spl: Fix compile warning for arm64
-- 2.1.0.27.g96db324
-----Original Message----- From: Gong Qianyu [mailto:Qianyu.Gong@freescale.com] Sent: Thursday, July 30, 2015 2:00 PM To: u-boot@lists.denx.de Cc: Hu Mingkai-B21284; Gong Qianyu-B52263 Subject: [PATCH 2/2] common/cmd_source.c: Fix the source command failure under 64-bit platform
Modify the data pointer type from ulong* to u32*.
For arm64 type "ulong" could be 64-bit. Then in line 89 of common/cmd_source.c: "while (*data++);" data will point to the next 64 bits each time. As the uImage file generated by mkimage tool keeps the same data format in either 32-bit or 64-bit platform, the difference would cause failure in 64-bit platform.
diff --git a/common/cmd_source.c b/common/cmd_source.c index d2a881d..db7ab7e 100644 --- a/common/cmd_source.c +++ b/common/cmd_source.c @@ -33,7 +33,7 @@ source (ulong addr, const char *fit_uname) #if defined(CONFIG_IMAGE_FORMAT_LEGACY) const image_header_t *hdr; #endif - ulong *data; + u32 *data; int verify; void *buf; #if defined(CONFIG_FIT) @@ -74,7 +74,7 @@ source (ulong addr, const char *fit_uname) }
/* get length of script */ - data = (ulong *)image_get_data (hdr); + data = (u32 *)image_get_data (hdr);
if ((len = uimage_to_cpu (*data)) == 0) { puts ("Empty Script\n"); @@ -128,7 +128,7 @@ source (ulong addr, const char *fit_uname) return 1; }
- data = (ulong *)fit_data; + data = (u32 *)fit_data; len = (ulong)fit_len; break; #endif -- 2.1.0.27.g96db324
Gong Q.Y.
Gong Qianyu
