[PATCH v4] board: ea: mx7ulp_com: move setting CONFIG_BOOTCOMMAND to defconfig
Move setting CONFIG_BOOTCOMMAND to the mx7ulp_com_defconfig file. It also allows replacing the default CONFIG_BOOTCOMMAND without code modification.
Signed-off-by: Ricardo Salveti ricardo@foundries.io Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Reviewed-by: Fabio Estevam festevam@gmail.com Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v4: - oops, restored Reviewed-by records.
Changes in v3: - rebased on top of 49c8ef0e45 ("Convert CONFIG_SYS_LOAD_ADDR to Kconfig").
Changes in v2: - move setting the command to defconfig.
configs/mx7ulp_com_defconfig | 2 ++ include/configs/mx7ulp_com.h | 5 ----- 2 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/configs/mx7ulp_com_defconfig b/configs/mx7ulp_com_defconfig index 6e6b821d90..d57d1a2ed3 100644 --- a/configs/mx7ulp_com_defconfig +++ b/configs/mx7ulp_com_defconfig @@ -10,6 +10,8 @@ CONFIG_DEFAULT_DEVICE_TREE="imx7ulp-com" CONFIG_LDO_ENABLED_MODE=y CONFIG_TARGET_MX7ULP_COM=y CONFIG_SYS_LOAD_ADDR=0x60800000 +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="if run loadimage; then run mmcboot; fi" CONFIG_DEFAULT_FDT_FILE="imx7ulp-com" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y diff --git a/include/configs/mx7ulp_com.h b/include/configs/mx7ulp_com.h index 48172de1d0..58d48edac4 100644 --- a/include/configs/mx7ulp_com.h +++ b/include/configs/mx7ulp_com.h @@ -60,11 +60,6 @@ "bootz ${loadaddr} - ${fdt_addr}; " \ "fi;\0" \
-#define CONFIG_BOOTCOMMAND \ - "if run loadimage; then " \ - "run mmcboot; " \ - "fi; " \ - #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CONFIG_SYS_INIT_RAM_SIZE SZ_256K
Oleksandr Suvorov
