[U-Boot-Users] [PATCH] Fixed reset for syscon3
Signed-off-by: Sergei Poselenov sposelenov@emcraft.com --- cpu/mpc85xx/cpu.c | 23 ++++++++++++++--------- 1 files changed, 14 insertions(+), 9 deletions(-)
diff --git a/cpu/mpc85xx/cpu.c b/cpu/mpc85xx/cpu.c index 74b210c..9873383 100644 --- a/cpu/mpc85xx/cpu.c +++ b/cpu/mpc85xx/cpu.c @@ -174,28 +174,33 @@ int do_reset (cmd_tbl_t *cmdtp, bd_t *bd, int flag, int argc, char *argv[]) { uint pvr; uint ver; + unsigned long val, msr; + pvr = get_pvr(); ver = PVR_VER(pvr); + if (ver & 1){ /* e500 v2 core has reset control register */ volatile unsigned int * rstcr; rstcr = (volatile unsigned int *)(CFG_IMMR + 0xE00B0); *rstcr = 0x2; /* HRESET_REQ */ - }else{ + udelay(100); + } + /* + * Fallthrough if the code above failed * Initiate hard reset in debug control register DBCR0 * Make sure MSR[DE] = 1 */ - unsigned long val, msr;
- msr = mfmsr (); - msr |= MSR_DE; - mtmsr (msr); + msr = mfmsr (); + msr |= MSR_DE; + mtmsr (msr); + + val = mfspr(DBCR0); + val |= 0x70000000; + mtspr(DBCR0,val);
- val = mfspr(DBCR0); - val |= 0x70000000; - mtspr(DBCR0,val); - } return 1; }
Hi Andy,
could you please have a look at this patch?
The situation is that we don't understand why it's necessary - we have verified that the correct register (RSTCR at IMMR+0xe00b0) is updated with the correct value (0x2), but this doesn't cause a reset. Documentation states that no other prerequisites or conditions are required for hard reset to work.
We have the same problem in Linux, too.
This is on a custom MPC8548 board...
Any ideas what might be causing such behaviour and/or how to avoid this?
Thanks in advance.
Wolfgang,
I don't think this patch is necessary because for all e500v2 core, setting RSTCR is the right way to reset the board.
I think you should check board FPGA. I met the similar problem before. Since FPGA did not correctly route the HRESET_REQ signal, setting RSTCR did not cause reset. After hardware person fixed the FPGA code, it worked fine.
Haiying
On Fri, 2008-05-09 at 17:51 +0200, Wolfgang Denk wrote:
Hi Andy,
Thanks in advance.
Agreed,t hat's how it should wor. But it doesn't on the syscon3 board.
Ummm... This is on a custom design, the syscon3 board. There is no FPGA there...
There must be some mechanism to reset the board if the HRESET_REQ is connected. If not connected, the board design must accomplish it in another way. Then the platform code should take care of that.
York
Thanks a lot.
I see only a 1k pull-up in the schematics, nothing else.
I have a customized MPC8548 board with several hardware reset source (to HRESET AG17), and the trigger signal is a GPIO pin instead of the default HRESET_REQ (AG16). the patch simply replaces the HRESET_REQ by the certain pin of GUR registers on both cpu/mpc85xx/cpu.c of the u-boot and arch/powerpc/platforms/85xx/misc.c of the linux.
For your reference. BRs
HarryCheng
Thanks a lot.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "The number of Unix installations has grown to 10, with more expected." - The Unix Programmer's Manual, 2nd Edition, June, 1972
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javao... _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Haiying Wang
HarryCheng
York Sun
