[PATCH] env: Convert ENV_ACCESS_IGNORE_FORCE to Kconfig
Convert ENV_ACCESS_IGNORE_FORCE to Kconfig, no functional change.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com --- README | 4 ---- env/Kconfig | 7 +++++++ scripts/config_whitelist.txt | 1 - 3 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/README b/README index be9e6391d6..17dc0ee33b 100644 --- a/README +++ b/README @@ -2729,10 +2729,6 @@ Configuration Settings: regular expression. This allows multiple variables to define the same flags without explicitly listing them for each variable.
-- CONFIG_ENV_ACCESS_IGNORE_FORCE - If defined, don't allow the -f switch to env set override variable - access flags. - The following definitions that deal with the placement and management of environment data (variable area); in general, we support the following configurations: diff --git a/env/Kconfig b/env/Kconfig index ed94e83ec1..ca7fef682b 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -604,6 +604,13 @@ config DELAY_ENVIRONMENT later by U-Boot code. With CONFIG_OF_CONTROL this is instead controlled by the value of /config/load-environment.
+config ENV_ACCESS_IGNORE_FORCE + bool "Block forced environment operations" + default n + help + If defined, don't allow the -f switch to env set override variable + access flags. + if SPL_ENV_SUPPORT config SPL_ENV_IS_NOWHERE bool "SPL Environment is not stored" diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 3f5e6504e1..0b3fb728a0 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -415,7 +415,6 @@ CONFIG_ENABLE_36BIT_PHYS CONFIG_ENABLE_MMU CONFIG_ENABLE_MUST_CHECK CONFIG_ENABLE_WARN_DEPRECATED -CONFIG_ENV_ACCESS_IGNORE_FORCE CONFIG_ENV_ADDR_FLEX CONFIG_ENV_CALLBACK_LIST_DEFAULT CONFIG_ENV_CALLBACK_LIST_STATIC
