[U-Boot] [PATCH v3] Support for multiple SGMII/TBI interfaces for TSEC ethernet
Fix TBI PHY accesses to use the proper offset in CPU register space. The previous code would incorrectly access the TBI PHY by reading/writing to CPU register space at the same location as would be used to access external PHYs.
Signed-off-by: Peter Tyser ptyser@xes-inc.com ---
Dohh... v2 of the patch introduced a compile warning. Please apply this version instead.
I replaced the hardcoding of CFG_TBIPA_VALUE in the tsec_configure_serdes() to support possible changes of the TBI addressing down the road, but kept the default TBI PHY address at CFG_TBIPA_VALUE as Andy Flemming suggested.
drivers/net/tsec.c | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index f81211a..cc7d528 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -283,11 +283,13 @@ uint tsec_local_mdio_read(volatile tsec_t *phyregs, uint phyid, uint regnum) /* Configure the TBI for SGMII operation */ static void tsec_configure_serdes(struct tsec_private *priv) { - tsec_local_mdio_write(priv->phyregs, CFG_TBIPA_VALUE, TBI_ANA, + /* Access TBI PHY registers at given TSEC register offset as opposed to the + * register offset used for external PHY accesses */ + tsec_local_mdio_write(priv->regs, priv->regs->tbipa, TBI_ANA, TBIANA_SETTINGS); - tsec_local_mdio_write(priv->phyregs, CFG_TBIPA_VALUE, TBI_TBICON, + tsec_local_mdio_write(priv->regs, priv->regs->tbipa, TBI_TBICON, TBICON_CLK_SELECT); - tsec_local_mdio_write(priv->phyregs, CFG_TBIPA_VALUE, TBI_CR, + tsec_local_mdio_write(priv->regs, priv->regs->tbipa, TBI_CR, TBICR_SETTINGS); }
@@ -299,12 +301,10 @@ static int init_phy(struct eth_device *dev) { struct tsec_private *priv = (struct tsec_private *)dev->priv; struct phy_info *curphy; - volatile tsec_t *phyregs = priv->phyregs; volatile tsec_t *regs = priv->regs;
/* Assign a Physical address to the TBI */ regs->tbipa = CFG_TBIPA_VALUE; - phyregs->tbipa = CFG_TBIPA_VALUE; asm("sync");
/* Reset MII (due to new addresses) */
Andy,
You're much more qualified than me to accept or reject this, so if you don't mind, please pick it up.
regards, Ben
- /* Access TBI PHY registers at given TSEC register offset as opposed to the
- tsec_local_mdio_write(priv->regs, priv->regs->tbipa, TBI_ANA, TBIANA_SETTINGS);
- tsec_local_mdio_write(priv->regs, priv->regs->tbipa, TBI_TBICON, TBICON_CLK_SELECT);
- tsec_local_mdio_write(priv->regs, priv->regs->tbipa, TBI_CR, TBICR_SETTINGS);
volatile tsec_t *phyregs = priv->phyregs; volatile tsec_t *regs = priv->regs; /* Assign a Physical address to the TBI */ regs->tbipa = CFG_TBIPA_VALUE;
What was the purpose of doing this? The problem I have with it is in the odd situation where the TSEC whose MII regs are connected to the bus is not enabled. It would mean that the TBIPA would never be set to CFG_TBIPA_VALUE.
Andy
I don't quite understand what you mean. My understanding was that if a TSEC is not enabled, the TBIPA for that TSEC should not be enabled either.
The original code was writing the TBIPA value 2 times for every TSEC - once at the TSEC register address in cpu space, and a second time at the TSEC's MII register address in cpu space.
For example, if a board had 4 sgmii interfaces with 4 external PHYs on an mpc8572 - all 4 PHYs could be physically connected to the MDIO bus of TSEC1. The cpu address offsets of the 4 TSECs would be: TSEC1 regs = 0x24000 TSEC1 phyregs = 0x24000 TSEC2 regs = 0x25000 TSEC2 phyregs = 0x24000 TSEC3 regs = 0x26000 TSEC3 phyregs = 0x24000 TSEC4 regs = 0x27000 TSEC4 phyregs = 0x24000
With the old code, on bootup the ethernet initialization would go like:
configure TSEC1 - write TSEC1's TBIPA address, write TSEC1's TBIPA address (2nd write to TSEC1 TBIPA)
configure TSEC2 - write TSEC2's TBIPA address, write TSEC1's TBIPA address (3rd time)
configure TSEC3 - write TSEC3's TBIPA address, write TSEC1's TBIPA address (4th time)
configure TSEC4 - write TSEC4's TBIPA address, write TSEC1's TBIPA address (5th time)
So the old code would write TSEC1's TBIPA address 5 times.
The patch I submitted does the following: configure TSEC1 - write TSEC1's TBIPA address
This 2nd method seems correct to me - each TSECs TBIPA address should only be set for itself, not itself as well as the TSEC its using to access its external PHY.
Best, Peter
Yes, unfortunately, it might be necessary. Imagine this scenario:
1) TSEC0 is not enabled 2) The current value of TSEC0's TBIPA register contains the address of a PHY we want to use 3) One of the other TSECs comes up, and tries to access its PHY at that address.
You see, the TBIPA register setting has *two* purposes. Most controllers aren't connected to any external PHYs (via their MII regs), so the purpose of TBIPA is to tell the controller what address you want to use to access the TBI PHY. However, for controllers attached to an external PHY, setting the TBIPA register serves not only to define where the TBI PHY is, but where *other* PHYs are not. If TSEC0's TBIPA register is not set, it might conflict with a PHY that doesn't belong to TSEC0.
It's admittedly an unlikely corner case, but I trust in the ability of board designers to break my code in such ways. My trust has been validated several times. :)
So while I agree with you that it's almost always wasteful, it's necessary without more significant changes. One other option would be to only write priv->phyregs->tbipa (n times, even though it would almost always be written to the same place all n times). Then, priv->regs->tbipa would contain whatever was in the register to start with, which is fine, since the address only matters for the regs which access external PHYs.
One other note: currently we don't support accessing the TBI PHYs through the mii utilities. This is mostly due to difficulties in finding addresses for the TBI PHYs that don't conflict with existing PHY addresses. If you have some clever ideas that don't involve hard-coding the addresses (I have to anticipate the advent of chips with 10+ ethernet controllers), I'm open to hearing them. :) It's an issue I intend to address, but it's not getting any timeslices this quarter.
Andy
Hi Andy,
- TSEC0 is not enabled
- The current value of TSEC0's TBIPA register contains the address of
According to the 8548 and 8572 manuals (not sure about others...), the TBIPA register value for all PHYs is 0x0 at reset, which is reserved according to the manuals. The description of the MIIMADD register supports this by stating: "Up to 31 PHYs can be addressed (0 is reserved)". So I believe that if the TBIPA value is 0, the corresponding TBI PHY can't be accessed and thus doesn't cause any problems as far as overlapping with other PHY addresses. The fact that the TBI phy never shows up when probing the MII bus on a variety of 8548 boards (which don't use any TBI PHYs) I've used supports this.
Also, in the above example, if you were to write the TBIPA register of TSEC0 which did not have an external PHY with a non-zero value, I believe this unused TBI PHY would show up when probing the MII bus (see comments below) which would be a bit confusing to a user. It would already be confusing to see 8 PHYs listed for 4 interfaces - 9 would make it even less sane:)
I was under the impression that PHY address 0 was reserved for broadcast usage, or something similar. I don't have the PHY spec handy to verify that however.
Agreed wholeheartedly:)
If you feel more comfortable leaving the write to priv->phyregs->tbipa in place, its OK with me. I don't think its necessary (at least for the 8548 and 8572 processors) but the only damage it does is some extra MII writes and adding a non-existent TBI PHY which a user might find a bit confusing.
FWIW, I was able to see the TBI PHY on an 8572 board using U-Boot's mii command. I only had one TBI PHY configured, but I could read its registers at address 0x1f as desired. I was surprised this worked and didn't dig into why it did however... I'm not sure how the mii command would work with multiple TBI PHYs at 0x1f on different busses however, but if it doesn't work that seems like an issue with the mii subsystem more than the tsec driver in my opinion. We have a board in the pipeline with multiple TBI PHYs - perhaps I can dig into it then.
Thanks for the feedback. I'd vote for keeping the patch the same as it is now, but if you'd like me to resubmit with the "phyregs->tbipa = CFG_TBIPA_VALUE" put back in let me know and I'll send it again.
Thanks again, Peter
Oh, there is much confusion, here.
1) 0 is reserved, according to the spec. However, *most* Freescale development systems use address zero for the PHY connected to TSEC0. 2) The manual only recently added this information, perhaps to encourage our own board designers to pay attention to it. :) 3) If the TBI PHY doesn't show up on a scan, it is because we have done something to make them ignored. I used to see the TBI PHY all the time, and I think we changed things so it didn't show up anymore (to avoid confusion). 4) The current default value for CFG_TBIPA_VALUE is 0x1f, not 0. So keep that in mind.
Anyway, I think we should leave in that write for now. In the future, we will change the code to sensibly move the TBIPA out of the way, like Linux does.
Yeah, I'm not sure what it's reserved for, but many board designers ignore that, and put the first PHY at 0.
No extra MII writes should be done. Just a few memory-mapped io register writes.
Sorry, I should have been clearer -- we support accessing the TBI PHY connected to TSEC0. The others require knowing that you have to use different registers. One solution might be to create 4 MDIO buses, but that seems excessive. We might want to just create a tsec-specific command to deal with it. Anyway, thank you for bearing with me.
Please do.
Thanks, Andy
Andy Fleming
Ben Warren
Peter Tyser
