[PATCH 1/2] x86: serial: Use NS16550_DYNAMIC in Slim Bootloader
Slim Bootloader provides serial port info in its HOB to support both IO or MMIO serial ports, but it's controlled by SYS_NS16550_MEM32 or SYS_NS16550_PORT_MAPPED in U-Boot. To support both serial port configurations dynamically at runtime, Slim Bootloader serial driver leverages NS16550_DYNAMIC.
Signed-off-by: Aiden Park aiden.park@intel.com --- arch/x86/cpu/slimbootloader/serial.c | 5 +++++ include/configs/slimbootloader.h | 13 ------------- 2 files changed, 5 insertions(+), 13 deletions(-)
diff --git a/arch/x86/cpu/slimbootloader/serial.c b/arch/x86/cpu/slimbootloader/serial.c index 7b44a59bff..0f45b3ba72 100644 --- a/arch/x86/cpu/slimbootloader/serial.c +++ b/arch/x86/cpu/slimbootloader/serial.c @@ -45,7 +45,12 @@ static int slimbootloader_serial_ofdata_to_platdata(struct udevice *dev) plat->base = data->base; /* ns16550 uses reg_shift, then covert stride to shift */ plat->reg_shift = data->stride >> 1; + plat->reg_width = data->stride; plat->clock = data->clk; + plat->fcr = UART_FCR_DEFVAL; + plat->flags = 0; + if (data->type == 1) + plat->flags |= NS16550_FLAG_IO;
return 0; } diff --git a/include/configs/slimbootloader.h b/include/configs/slimbootloader.h index e0011ed446..b8169072cc 100644 --- a/include/configs/slimbootloader.h +++ b/include/configs/slimbootloader.h @@ -8,19 +8,6 @@
#include <configs/x86-common.h>
-/* - * By default, CONFIG_SYS_NS16550_PORT_MAPPED is enabled for port io serial. - * To use mmio base serial, enable CONFIG_SYS_NS16550_MEM32 and disable - * CONFIG_SYS_NS16550_PORT_MAPPED until ns16550 driver supports serial port - * configuration in run-time. - * - * #define CONFIG_SYS_NS16550_MEM32 - * #undef CONFIG_SYS_NS16550_PORT_MAPPED - */ -#ifdef CONFIG_SYS_NS16550_MEM32 -#undef CONFIG_SYS_NS16550_PORT_MAPPED -#endif - #define CONFIG_STD_DEVICES_SETTINGS \ "stdin=serial,i8042-kbd,usbkbd\0" \ "stdout=serial\0" \
Hi Aiden,
plat->flags = 0;
nits: the following comments in this function should be removed:
/* * The data->type provides port io or mmio access type info, * but the access type will be controlled by * CONFIG_SYS_NS16550_PORT_MAPPED or CONFIG_SYS_NS16550_MEM32. * * TBD: ns16550 access type configuration in runtime. * ex) plat->access_type = data->type */
- By default, CONFIG_SYS_NS16550_PORT_MAPPED is enabled for port io serial.
- To use mmio base serial, enable CONFIG_SYS_NS16550_MEM32 and disable
- CONFIG_SYS_NS16550_PORT_MAPPED until ns16550 driver supports serial port
- configuration in run-time.
- #define CONFIG_SYS_NS16550_MEM32
- #undef CONFIG_SYS_NS16550_PORT_MAPPED
#define CONFIG_STD_DEVICES_SETTINGS \ "stdin=serial,i8042-kbd,usbkbd\0" \ "stdout=serial\0" \ --
Regards, Bin
On Mon, Feb 3, 2020 at 10:43 AM Bin Meng bmeng.cn@gmail.com wrote:
Hi Aiden,
plat->flags = 0;
- The data->type provides port io or mmio access type info,
- but the access type will be controlled by
- CONFIG_SYS_NS16550_PORT_MAPPED or CONFIG_SYS_NS16550_MEM32.
- TBD: ns16550 access type configuration in runtime.
Removed these obsolete comments, and
applied to u-boot-x86, thanks!
Bin Meng
Park, Aiden
