[U-Boot] [PATCH] rockchip: rk3399: spl: Don't init dram if TPL enabled
DRAM init would require in - TPL stage if target support TPL and - SPL stage if target support SPL alone
So, don't initialize the dram in SPL if TPL defined and at the same time enable it if TPL undefined which is SPL alone.
Tested in TPL and SPL supported boards.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-rockchip/rk3399-board-spl.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3399-board-spl.c b/arch/arm/mach-rockchip/rk3399-board-spl.c index 3eea73ef33..a439e09b61 100644 --- a/arch/arm/mach-rockchip/rk3399-board-spl.c +++ b/arch/arm/mach-rockchip/rk3399-board-spl.c @@ -198,11 +198,13 @@ void board_init_f(ulong dummy) return; }
+#if !defined(SUPPORT_TPL) ret = uclass_get_device(UCLASS_RAM, 0, &dev); if (ret) { pr_err("DRAM init failed: %d\n", ret); return; } +#endif }
#if defined(SPL_GPIO_SUPPORT)
Hi Jagan,
We still need to init DRAM driver in SPL so that we can get correct ram info, but we don't need to run the dram init program, which should have been handled in DRAM driver.
Thanks, - Kever
Jagan Teki
Kever Yang
