[PATCH 0/6] arm: xea: Provide enhancements for XEA board
This patch series is a preparatory patch for supporting different versions of XEA board HW (until problem with Linux kernel support for multiple revisions is resorted).
Moreover, limits for u-boot.sb and u-boot.img has been set to avoid binary sizes exceeding in the future.
Lukasz Majewski (6): arm: spl: xea: Remove I2S pins configuration from early initialization arm: xea: Add support for reading SoM (CPU) and base board HW revision arm: spl: Add definition for PHY reset GPIO for XEA HW rev. 2 config: xea: Enable late board initialization to set revision variable arm: xea: Print information about XEA's SoM HW revision config: xea: Add limits for SPL and u-boot proper sizes
board/liebherr/xea/spl_xea.c | 21 ++++++++------ board/liebherr/xea/xea.c | 50 ++++++++++++++++++++++++++++++++++ configs/imx28_xea_defconfig | 4 +++ configs/imx28_xea_sb_defconfig | 1 + 4 files changed, 68 insertions(+), 8 deletions(-)
XEA is not supporting and using I2S codec, so there is no need to configure pins for it.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
board/liebherr/xea/spl_xea.c | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/board/liebherr/xea/spl_xea.c b/board/liebherr/xea/spl_xea.c index df354cac64..551ed6fbae 100644 --- a/board/liebherr/xea/spl_xea.c +++ b/board/liebherr/xea/spl_xea.c @@ -112,13 +112,6 @@ const iomux_cfg_t iomux_setup[] = { MX28_PAD_I2C0_SCL__I2C0_SCL, MX28_PAD_I2C0_SDA__I2C0_SDA,
- /* I2S Codec */ - MX28_PAD_SAIF0_BITCLK__SAIF0_BITCLK, - MX28_PAD_SAIF0_LRCLK__SAIF0_LRCLK, - MX28_PAD_SAIF0_MCLK__SAIF0_MCLK, - MX28_PAD_SAIF0_SDATA0__SAIF0_SDATA0, - MX28_PAD_SAIF1_SDATA0__SAIF1_SDATA0, - /* PWR-Hold */ MX28_PAD_SPDIF__GPIO_3_27,
The XEA board now has several HW revisions for both SoM and base boards. This patch provides support for reading those revision ID values in SPL (u-boot.sb) and then pass this information to u-boot proper, as the maximal SPL size (~55KiB) is not allowing for having FIT support in it.
It was necessary to handle reading GPIOs values solely in u-boot proper as one configuration (i.e. 'single binary' - imx28_xea_sb_defconfig) is not using SPL framework.
board/liebherr/xea/spl_xea.c | 11 +++++++++++ board/liebherr/xea/xea.c | 29 +++++++++++++++++++++++++++++ 2 files changed, 40 insertions(+)
diff --git a/board/liebherr/xea/spl_xea.c b/board/liebherr/xea/spl_xea.c index 551ed6fbae..71194db235 100644 --- a/board/liebherr/xea/spl_xea.c +++ b/board/liebherr/xea/spl_xea.c @@ -230,6 +230,17 @@ const iomux_cfg_t iomux_setup[] = { /* TIVA boot control */ MX28_PAD_GPMI_RDY3__GPIO_0_23 | MUX_CONFIG_BOOT, /* TIVA0 */ MX28_PAD_GPMI_WRN__GPIO_0_25 | MUX_CONFIG_BOOT, /* TIVA1 */ + + /* HW revision ID Base Board */ + MX28_PAD_LCD_D12__GPIO_1_12, + MX28_PAD_LCD_D13__GPIO_1_13, + MX28_PAD_LCD_D14__GPIO_1_14, + + /* HW revision ID (SoM) */ + MX28_PAD_LCD_D15__GPIO_1_15, + MX28_PAD_LCD_D16__GPIO_1_16, + MX28_PAD_LCD_D17__GPIO_1_17, + MX28_PAD_LCD_D18__GPIO_1_18, };
u32 mxs_dram_vals[] = { diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c index c8ac526cb4..d9cf27c81b 100644 --- a/board/liebherr/xea/xea.c +++ b/board/liebherr/xea/xea.c @@ -48,6 +48,35 @@ DECLARE_GLOBAL_DATA_PTR; * Functions */
+/* + * Reading the HW ID number for XEA SoM module + * + * GPIOs from Port 1 (GPIO1_15, GPIO1_16, GPIO1_17 and GPIO1_18) + * are used to store HW revision information. + * Reading of GPIOs values is performed before the Device Model is + * bring up as the proper DTB needs to be chosen first. + * + * Moreover, this approach is required as "single binary" configuration + * of U-Boot (imx28_xea_sb_defconfig) is NOT using SPL framework, so + * only minimal subset of functionality is provided when ID is read. + * + * Hence, the direct registers' access. + */ +#define XEA_SOM_HW_ID_GPIO_PORT (MXS_PINCTRL_BASE + (0x0900 + ((1) * 0x10))) +#define XEA_SOM_REV_MASK GENMASK(18, 15) +#define XEA_SOM_REV_SHIFT 15 + +static inline u8 get_som_rev(void) +{ + struct mxs_register_32 *reg = + (struct mxs_register_32 *)XEA_SOM_HW_ID_GPIO_PORT; + + u32 tmp = ~readl(®->reg); + u8 id = (tmp & XEA_SOM_REV_MASK) >> XEA_SOM_REV_SHIFT; + + return id; +} + static void init_clocks(void) { /* IO0 clock at 480MHz */
Hi Lukasz,
There is no need for 'inline' here.
Also, get_som_rev() is only used 5/6, so I suggest to squash this patch with 5/6.
Besides that, the series looks good.
The imx287 based XEA board's revision 2 uses GPIO_3_21 for PHY reset
It is safe to keep the GPIO_2_13 as well, as in the SPL SPI1 is not used for transmission. This simplifies the code, as the proper configuration is performed either in falcon boot's read DTB or in u-boot proper (with correct FIT configuration chosen).
board/liebherr/xea/spl_xea.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/board/liebherr/xea/spl_xea.c b/board/liebherr/xea/spl_xea.c index 71194db235..6cf8f8390e 100644 --- a/board/liebherr/xea/spl_xea.c +++ b/board/liebherr/xea/spl_xea.c @@ -225,7 +225,8 @@ const iomux_cfg_t iomux_setup[] = { MX28_PAD_ENET0_TXD0__ENET0_TXD0 | MUX_CONFIG_ENET, MX28_PAD_ENET0_TXD1__ENET0_TXD1 | MUX_CONFIG_ENET, MX28_PAD_ENET0_TXD3__ENET1_TXD1 | MUX_CONFIG_ENET, - MX28_PAD_SSP1_CMD__GPIO_2_13, /* PHY reset */ + MX28_PAD_SSP1_CMD__GPIO_2_13, /* PHY reset HW Rev. 1*/ + MX28_PAD_SAIF0_LRCLK__GPIO_3_21, /* PHY reset HW Rev. 2*/
The 'board_som_rev' environment variable will be used to point correct configuration from the Linux FIT file.
board/liebherr/xea/xea.c | 12 ++++++++++++ configs/imx28_xea_defconfig | 1 + configs/imx28_xea_sb_defconfig | 1 + 3 files changed, 14 insertions(+)
diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c index d9cf27c81b..90a1e03077 100644 --- a/board/liebherr/xea/xea.c +++ b/board/liebherr/xea/xea.c @@ -282,6 +282,18 @@ int board_init(void) return 0; }
+#if defined(CONFIG_BOARD_LATE_INIT) +int board_late_init(void) +{ + int ret = env_set_ulong("board_som_rev", get_som_rev()); + + if (ret) + printf("Cannot set XEA's SoM revision env variable!\n"); + + return 0; +} +#endif + int dram_init(void) { return mxs_dram_init(); diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig index 64a0561a34..6098c1f3be 100644 --- a/configs/imx28_xea_defconfig +++ b/configs/imx28_xea_defconfig @@ -39,6 +39,7 @@ CONFIG_BOOTCOMMAND="run ${bootpri} ; run ${bootsec}" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="run prebootcmd" CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set diff --git a/configs/imx28_xea_sb_defconfig b/configs/imx28_xea_sb_defconfig index 9872d35c1b..8d48d8c507 100644 --- a/configs/imx28_xea_sb_defconfig +++ b/configs/imx28_xea_sb_defconfig @@ -23,6 +23,7 @@ CONFIG_BOOTARGS="console=ttyAMA0,115200n8" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="run prebootcmd" CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y # CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y
As now XEA has its second HW revision - this information is printed when u-boot proper starts.
board/liebherr/xea/xea.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/board/liebherr/xea/xea.c b/board/liebherr/xea/xea.c index 90a1e03077..c117a8cb19 100644 --- a/board/liebherr/xea/xea.c +++ b/board/liebherr/xea/xea.c @@ -294,6 +294,15 @@ int board_late_init(void) } #endif
+#if defined(CONFIG_DISPLAY_BOARDINFO) +int checkboard(void) +{ + printf("Board: LWE XEA SoM HW rev %d\n", get_som_rev()); + + return 0; +} +#endif + int dram_init(void) { return mxs_dram_init();
The XEA board has following hard constraints regarding size of binaries: - u-boot.sb < 48 KiB - u-boot.img < 448 KiB
Added values are supposed to avoid exceeding size of binaries during future u-boot development.
configs/imx28_xea_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig index 6098c1f3be..822a329187 100644 --- a/configs/imx28_xea_defconfig +++ b/configs/imx28_xea_defconfig @@ -21,12 +21,15 @@ CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0x20000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x1000 +CONFIG_SPL_SIZE_LIMIT=0xa000 CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x90000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x42000000 CONFIG_SPL_PAYLOAD="u-boot.img" +CONFIG_HAS_BOARD_SIZE_LIMIT=y +CONFIG_BOARD_SIZE_LIMIT=458752 CONFIG_TIMESTAMP=y CONFIG_FIT=y # CONFIG_BOOTMETH_EXTLINUX is not set
Fabio Estevam
Lukasz Majewski
