[PATCH] Travis-CI: Drop support
Travis-CI is changing their support for FOSS (understandably) to have a limited per-month number of build minutes. Unfortunately for us, the matrix of jobs we run will exhaust that very quickly. Remove the yml file. Thanks for all the builds, Travis-CI!
Signed-off-by: Tom Rini trini@konsulko.com --- .travis.yml | 698 ---------------------------------------------------- 1 file changed, 698 deletions(-) delete mode 100644 .travis.yml
diff --git a/.travis.yml b/.travis.yml deleted file mode 100644 index 69829fcfa020..000000000000 --- a/.travis.yml +++ /dev/null @@ -1,698 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# Copyright Roger Meier r.meier@siemens.com - -# build U-Boot on Travis CI - https://travis-ci.org/ - -sudo: required -dist: bionic - -language: c - -addons: - apt: - update: true - sources: - - sourceline: 'deb http://apt.llvm.org/bionic/ llvm-toolchain-bionic-10 main' - key_url: 'https://apt.llvm.org/llvm-snapshot.gpg.key' - packages: - - autopoint - - cppcheck - - sloccount - - sparse - - bc - - build-essential - - libsdl2-dev - - python - - python3-sphinx - - python3-virtualenv - - python3-pip - - python3-pygit2 - - swig - - libpython-dev - - iasl - - grub-efi-ia32-bin - - grub-efi-amd64-bin - - rpm2cpio - - wget - - device-tree-compiler - - lzop - - liblz4-tool - - lzma-alone - - libisl15 - - clang-10 - - srecord - - graphviz - - coreutils - - util-linux - - dosfstools - - gdisk - - mount - - mtools - - openssl - - sbsigntool - - fakeroot - - mtd-utils - - squashfs-tools - -install: - # Clone uboot-test-hooks - - git clone --depth=1 git://github.com/swarren/uboot-test-hooks.git /tmp/uboot-test-hooks - - ln -s travis-ci /tmp/uboot-test-hooks/bin/`hostname` - - ln -s travis-ci /tmp/uboot-test-hooks/py/`hostname` - # prepare buildman environment - - echo -e "[toolchain]\nroot = /usr" > ~/.buildman - - echo -e "arc = /tmp/arc_gnu_2019.09_prebuilt_uclibc_le_archs_linux_install" >> ~/.buildman - - echo -e "\n[toolchain-alias]\nsh = sh2" >> ~/.buildman - - echo -e "x86 = i386" >> ~/.buildman; - - echo -e "riscv = riscv64" >> ~/.buildman; - - cat ~/.buildman - - grub-mkimage --prefix="" -o ~/grub_x86.efi -O i386-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd - - grub-mkimage --prefix="" -o ~/grub_x64.efi -O x86_64-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd - - wget http://mirrors.kernel.org/ubuntu/pool/main/m/mpfr4/libmpfr4_3.1.4-1_amd64.de... && sudo dpkg -i libmpfr4_3.1.4-1_amd64.deb && rm libmpfr4_3.1.4-1_amd64.deb - - wget http://mirrors.kernel.org/ubuntu/pool/universe/e/efitools/efitools_1.8.1-0ub... && sudo dpkg -i efitools_1.8.1-0ubuntu2_amd64.deb && rm efitools_1.8.1-0ubuntu2_amd64.deb - -env: - global: - - PATH=/tmp/qemu-install/bin:/tmp/uboot-test-hooks/bin:/sbin:/usr/bin:/bin:/usr/local/bin - - PYTHONPATH=/tmp/uboot-test-hooks/py/travis-ci - - BUILD_DIR=build - - HOSTCC="cc" - - HOSTCXX="c++" - - QEMU_VERSION="v4.2.0" - -before_script: - # install toolchains based on TOOLCHAIN} variable - - if [[ "${TOOLCHAIN}" == *m68k* ]]; then ./tools/buildman/buildman --fetch-arch m68k ; fi - - if [[ "${TOOLCHAIN}" == *microblaze* ]]; then ./tools/buildman/buildman --fetch-arch microblaze ; fi - - if [[ "${TOOLCHAIN}" == *mips* ]]; then ./tools/buildman/buildman --fetch-arch mips ; fi - - if [[ "${TOOLCHAIN}" == *sh* ]]; then ./tools/buildman/buildman --fetch-arch sh2 ; fi - - if [[ "${TOOLCHAIN}" == *i386* ]]; then - ./tools/buildman/buildman --fetch-arch i386; - fi - - if [[ "${TOOLCHAIN}" == arc ]]; then - wget https://github.com/foss-for-synopsys-dwc-arc-processors/toolchain/releases/d... && - tar -C /tmp -xf arc_gnu_2019.09_prebuilt_uclibc_le_archs_linux_install.tar.gz; - fi - - if [[ "${TOOLCHAIN}" == "nds32" ]]; then - wget https://github.com/vincentzwc/prebuilt-nds32-toolchain/releases/download/201... && - tar -C /tmp -xf nds32le-linux-glibc-v3-upstream.tar.gz && - echo -e "\n[toolchain-prefix]\nnds32 = /tmp/nds32le-linux-glibc-v3-upstream/bin/nds32le-linux-" >> ~/.buildman; - fi - - if [[ "${TOOLCHAIN}" == *xtensa* ]]; then - wget https://github.com/foss-xtensa/toolchain/releases/download/2018.02/x86_64-20... && - tar -C /tmp -xf x86_64-2018.02-${TOOLCHAIN}.tar.gz && - echo -e "\n[toolchain-prefix]\nxtensa = /tmp/2018.02/${TOOLCHAIN}/bin/${TOOLCHAIN}-" >> ~/.buildman; - fi - # If TOOLCHAIN is unset, we're on some flavour of ARM. - - if [[ "${TOOLCHAIN}" == "" ]]; then - ./tools/buildman/buildman --fetch-arch arm && - ./tools/buildman/buildman --fetch-arch aarch64; - fi - - if [[ "${TOOLCHAIN}" == "powerpc" ]]; then ./tools/buildman/buildman --fetch-arch powerpc; fi - - if [[ "${TOOLCHAIN}" == "riscv" ]]; then - ./tools/buildman/buildman --fetch-arch riscv32 && - ./tools/buildman/buildman --fetch-arch riscv64; - fi - - if [[ "${QEMU_TARGET}" != "" ]]; then - git clone git://git.qemu.org/qemu.git /tmp/qemu; - pushd /tmp/qemu; - git submodule update --init dtc && - git checkout ${QEMU_VERSION} && - ./configure --prefix=/tmp/qemu-install --target-list=${QEMU_TARGET} && - make -j4 all install; - popd; - fi - - # Build GRUB UEFI targets - - if [[ "${QEMU_TARGET}" == "arm-softmmu" ]]; then - git clone git://git.savannah.gnu.org/grub.git /tmp/grub && - pushd /tmp/grub && - git checkout grub-2.04 && - ./bootstrap && - ./configure --target=arm --with-platform=efi - CC=gcc - TARGET_CC=~/.buildman-toolchains/gcc-9.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-gcc - TARGET_OBJCOPY=~/.buildman-toolchains/gcc-9.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-objcopy - TARGET_STRIP=~/.buildman-toolchains/gcc-9.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-strip - TARGET_NM=~/.buildman-toolchains/gcc-9.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-nm - TARGET_RANLIB=~/.buildman-toolchains/gcc-9.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ranlib && - make -j4 && - ./grub-mkimage -O arm-efi -o ~/grub_arm.efi --prefix= -d - grub-core cat chain configfile echo efinet ext2 fat halt help linux - lsefisystab loadenv lvm minicmd normal part_msdos part_gpt reboot - search search_fs_file search_fs_uuid search_label serial sleep test - true && - popd; - fi - - if [[ "${QEMU_TARGET}" == "aarch64-softmmu" ]]; then - git clone git://git.savannah.gnu.org/grub.git /tmp/grub && - pushd /tmp/grub && - git checkout grub-2.04 && - ./bootstrap && - ./configure --target=aarch64 --with-platform=efi - CC=gcc - TARGET_CC=~/.buildman-toolchains/gcc-9.2.0-nolibc/aarch64-linux/bin/aarch64-linux-gcc - TARGET_OBJCOPY=~/.buildman-toolchains/gcc-9.2.0-nolibc/aarch64-linux/bin/aarch64-linux-objcopy - TARGET_STRIP=~/.buildman-toolchains/gcc-9.2.0-nolibc/aarch64-linux/bin/aarch64-linux-strip - TARGET_NM=~/.buildman-toolchains/gcc-9.2.0-nolibc/aarch64-linux/bin/aarch64-linux-nm - TARGET_RANLIB=~/.buildman-toolchains/gcc-9.2.0-nolibc/aarch64-linux/bin/aarch64-linux-ranlib && - make -j4 && - ./grub-mkimage -O arm64-efi -o ~/grub_arm64.efi --prefix= -d - grub-core cat chain configfile echo efinet ext2 fat halt help linux - lsefisystab loadenv lvm minicmd normal part_msdos part_gpt reboot - search search_fs_file search_fs_uuid search_label serial sleep test - true && - popd; - fi - - if [[ "${QEMU_TARGET}" == "riscv32-softmmu" ]]; then - git clone git://git.savannah.gnu.org/grub.git /tmp/grub && - pushd /tmp/grub && - git checkout grub-2.04 && - ./bootstrap && - ./configure --target=riscv32 --with-platform=efi - CC=gcc - TARGET_CC=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv32-linux/bin/riscv32-linux-gcc - TARGET_OBJCOPY=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv32-linux/bin/riscv32-linux-objcopy - TARGET_STRIP=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv32-linux/bin/riscv32-linux-strip - TARGET_NM=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv32-linux/bin/riscv32-linux-nm - TARGET_RANLIB=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv32-linux/bin/riscv32-linux-ranlib && - make -j4 && - ./grub-mkimage -O riscv32-efi -o ~/grub_riscv32.efi --prefix= -d - grub-core cat chain configfile echo efinet ext2 fat halt help linux - lsefisystab loadenv lvm minicmd normal part_msdos part_gpt reboot - search search_fs_file search_fs_uuid search_label serial sleep test - true && - popd; - fi - - if [[ "${QEMU_TARGET}" == "riscv64-softmmu" ]]; then - git clone git://git.savannah.gnu.org/grub.git /tmp/grub && - pushd /tmp/grub && - git checkout grub-2.04 && - ./bootstrap && - ./configure --target=riscv64 --with-platform=efi - CC=gcc - TARGET_CC=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv64-linux/bin/riscv64-linux-gcc - TARGET_OBJCOPY=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv64-linux/bin/riscv64-linux-objcopy - TARGET_STRIP=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv64-linux/bin/riscv64-linux-strip - TARGET_NM=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv64-linux/bin/riscv64-linux-nm - TARGET_RANLIB=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv64-linux/bin/riscv64-linux-ranlib && - make -j4 && - ./grub-mkimage -O riscv64-efi -o ~/grub_riscv64.efi --prefix= -d - grub-core cat chain configfile echo efinet ext2 fat halt help linux - lsefisystab loadenv lvm minicmd normal part_msdos part_gpt reboot - search search_fs_file search_fs_uuid search_label serial sleep test - true && - popd; - fi - - if [[ "${TEST_PY_BD}" == "qemu-riscv32_spl" ]]; then - wget -O - https://github.com/riscv/opensbi/releases/download/v0.8/opensbi-0.8-rv-bin.t... | tar -C /tmp -xJ; - export OPENSBI=/tmp/opensbi-0.8-rv-bin/share/opensbi/ilp32/generic/firmware/fw_dynamic.bin; - fi - - if [[ "${TEST_PY_BD}" == "qemu-riscv64_spl" ]]; then - wget -O - https://github.com/riscv/opensbi/releases/download/v0.8/opensbi-0.8-rv-bin.t... | tar -C /tmp -xJ; - export OPENSBI=/tmp/opensbi-0.8-rv-bin/share/opensbi/lp64/generic/firmware/fw_dynamic.bin; - fi - -script: - # Comments must be outside the command strings below, or the Travis parser - # will get confused. - # - # If we've been asked to use clang only do one configuration. - # - # Build a selection of boards if TEST_PY_BD is empty - - if [[ "${BUILDMAN}" != "" ]]; then - ret=0 - tools/buildman/buildman -P -E -W ${BUILDMAN} ${OVERRIDE} || ret=$?; - if [[ $ret -ne 0 ]]; then - tools/buildman/buildman -seP ${BUILDMAN}; - exit $ret; - fi; - fi - # Build just the one board needed for testing, if TEST_PY_BD is non-empty - # Note: "${var:+"-k $var"}" expands to "" if $var is empty, "-k $var" if not - - if [[ "${TEST_PY_BD}" != "" ]]; then - export UBOOT_TRAVIS_BUILD_DIR=`cd .. && pwd`/${TEST_PY_BD}; - cp ~/grub_x86.efi $UBOOT_TRAVIS_BUILD_DIR/; - cp ~/grub_x64.efi $UBOOT_TRAVIS_BUILD_DIR/; - if [[ -e ~/grub_arm.efi ]]; then - cp ~/grub_arm.efi $UBOOT_TRAVIS_BUILD_DIR/; - fi; - if [[ -e ~/grub_arm64.efi ]]; then - cp ~/grub_arm64.efi $UBOOT_TRAVIS_BUILD_DIR/; - fi; - if [[ -e ~/grub_riscv32.efi ]]; then - cp ~/grub_riscv32.efi $UBOOT_TRAVIS_BUILD_DIR/; - fi; - if [[ -e ~/grub_riscv64.efi ]]; then - cp ~/grub_riscv64.efi $UBOOT_TRAVIS_BUILD_DIR/; - fi; - tools/buildman/buildman -o ${UBOOT_TRAVIS_BUILD_DIR} -w -E -W -e - --board ${TEST_PY_BD} ${OVERRIDE} || exit; - virtualenv -p /usr/bin/python3 /tmp/venv; - . /tmp/venv/bin/activate; - pip install -r test/py/requirements.txt; - ./test/py/test.py -ra --bd ${TEST_PY_BD} ${TEST_PY_ID} - ${TEST_PY_TEST_SPEC:+"-k ${TEST_PY_TEST_SPEC}"} - --build-dir "$UBOOT_TRAVIS_BUILD_DIR" || exit; - if [[ -n "${TEST_PY_TOOLS}" ]]; then - export PYTHONPATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc/pylibfdt"; - export PATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc:${PATH}"; - pip install pyelftools && - ./tools/binman/binman --toolpath ${UBOOT_TRAVIS_BUILD_DIR}/tools test && - ./tools/patman/patman test && - ./tools/buildman/buildman -t && - ./tools/dtoc/dtoc -t && - make testconfig; - fi; - fi - -matrix: - include: - # we need to build by vendor due to 50min time limit for builds - # each env setting here is a dedicated build - - name: "buildman arc" - env: - - BUILDMAN="arc" - TOOLCHAIN="arc" - - name: "buildman arm11 arm7 arm920t arm946es" - env: - - BUILDMAN="arm11 arm7 arm920t arm946es" - - name: "buildman arm926ejs (non-NXP,siemens,at91,kirkwood,spear)" - env: - - JOB="arm926ejs" - BUILDMAN="arm926ejs -x freescale,siemens,at91,kirkwood,spear,omap" - - name: "buildman at91 (non arm v7)" - env: - - BUILDMAN="at91 -x armv7" - - name: "buildman at91 (non arm926ejs)" - env: - - BUILDMAN="at91 -x arm926ejs" - - name: "buildman boundary engicam toradex" - env: - - BUILDMAN="boundary engicam toradex" - - name: "buildman ARM bcm" - env: - - BUILDMAN="bcm -x mips" - - name: "buildman NXP ARM32 (catch-all)" - env: - - BUILDMAN="freescale -x powerpc,m68k,aarch64,ls101,ls102,ls104,ls108,ls20,lx216" - - name: "buildman NXP LS101x" - env: - - BUILDMAN="freescale&ls101" - - name: "buildman NXP LS102x" - env: - - BUILDMAN="freescale&ls102" - - name: "buildman NXP LS104x" - env: - - BUILDMAN="freescale&ls104" - - name: "buildman NXP LS108x" - env: - - BUILDMAN="freescale&ls108" - - name: "buildman NXP LS20xx" - env: - - BUILDMAN="freescale&ls20" - - name: "buildman NXP LX216x" - env: - - BUILDMAN="freescale&lx216" - - name: "buildman i.MX6 tqc" - env: - - BUILDMAN="mx6&tqc" - - name: "buildman i.MX6 (catch-all)" - env: - - BUILDMAN="mx6 -x boundary,engicam,freescale,technexion,toradex,tqc" - - name: "buildman i.MX (non-i.MX6 catch-all)" - env: - - BUILDMAN="mx -x freescale,mx6,toradex,technexion" - - name: "buildman keystone 2/3" - env: - - BUILDMAN="k2 k3" - - name: "buildman samsung socfpga" - env: - - BUILDMAN="samsung socfpga" - - name: "buildman spear" - env: - - BUILDMAN="spear" - - name: "buildman sun4i" - env: - - BUILDMAN="sun4i" - - name: "buildman sun5i" - env: - - BUILDMAN="sun5i" - - name: "buildman sun6i" - env: - - BUILDMAN="sun6i" - - name: "buildman sun7i" - env: - - BUILDMAN="sun7i" - - name: "buildman 64bit sun8i" - env: - - BUILDMAN="sun8i&aarch64 -x orangepi" - - name: "buildman 32bit sun8i" - env: - - BUILDMAN="sun8i&armv7 -x orangepi" - - name: "buildman sun9i" - env: - - BUILDMAN="sun9i" - - name: "buildman sun50i" - env: - - BUILDMAN="sun50i -x orangepi" - - name: "buildman catch-all ARM" - env: - - BUILDMAN="arm -x arm11,arm7,arm9,aarch64,at91,bcm,freescale,kirkwood,mvebu,siemens,tegra,uniphier,mx,samsung,sunxi,am33xx,omap,rk,toradex,socfpga,k2,k3,zynq" - - name: "buildman sandbox x86" - env: - - BUILDMAN="sandbox x86" - TOOLCHAIN="i386" - - name: "buildman technexion" - env: - - BUILDMAN="technexion" - - name: "buildman kirkwood" - env: - - BUILDMAN="kirkwood" - - name: "buildman mvebu" - env: - - BUILDMAN="mvebu" - - name: "buildman m68k" - env: - - BUILDMAN="m68k" - TOOLCHAIN="m68k" - - name: "buildman microblaze" - env: - - BUILDMAN="microblaze" - TOOLCHAIN="microblaze" - - name: "buildman mips" - env: - - BUILDMAN="mips" - TOOLCHAIN="mips" - - name: "buildman non-Freescale PowerPC" - env: - - BUILDMAN="powerpc -x freescale" - TOOLCHAIN="powerpc" - - name: "buildman mpc85xx&freescale (excluding many)" - env: - - BUILDMAN="mpc85xx&freescale -x t208xrdb -x t4qds -x t102* -x p1_p2_rdb_pc -x p1010rdb -x corenet_ds -x b4860qds -x bsc91*" - TOOLCHAIN="powerpc" - - name: "buildman t208xrdb corenet_ds" - env: - - BUILDMAN="t208xrdb corenet_ds" - TOOLCHAIN="powerpc" - - name: "buildman Freescale PowerPC" - env: - - BUILDMAN="t4qds b4860qds mpc83xx&freescale mpc86xx&freescale" - TOOLCHAIN="powerpc" - - name: "buildman t102*" - env: - - BUILDMAN="t102*" - TOOLCHAIN="powerpc" - - name: "buildman p1_p2_rdb_pc" - env: - - BUILDMAN="p1_p2_rdb_pc" - TOOLCHAIN="powerpc" - - name: "buildman p1010rdb bsc91" - env: - - BUILDMAN="p1010rdb bsc91" - TOOLCHAIN="powerpc" - - name: "buildman siemens" - env: - - BUILDMAN="siemens" - - name: "buildman tegra" - env: - - BUILDMAN="tegra -x toradex" - - name: "buildman am33xx (no siemens)" - env: - - BUILDMAN="am33xx -x siemens" - - name: "buildman omap" - env: - - BUILDMAN="omap" - - name: "buildman orangepi" - env: - - BUILDMAN="orangepi" - - name: "buildman uniphier" - env: - - BUILDMAN="uniphier" - - name: "buildman catch-all AArch64" - env: - - BUILDMAN="aarch64 -x bcm,k3,tegra,ls1,ls2,lx216,mvebu,uniphier,sunxi,samsung,socfpga,rk,versal,zynq" - - name: "buildman rockchip" - env: - - BUILDMAN="rk -x orangepi" - - name: "buildman sh" - env: - - BUILDMAN="sh -x arm" - TOOLCHAIN="sh" - - name: "buildman Zynq* (ARMv7)" - env: - - BUILDMAN="zynq&armv7" - - name: "buildman ZynqMP and Versal" - env: - - BUILDMAN="versal|zynqmp&aarch64" - - name: "buildman xtensa" - env: - - BUILDMAN="xtensa" - TOOLCHAIN="xtensa-dc233c-elf" - - name: "buildman riscv" - env: - - BUILDMAN="riscv" - TOOLCHAIN="riscv" - - name: "buildman nds32" - env: - - BUILDMAN="nds32" - TOOLCHAIN="nds32" - - # QA jobs for code analytics - # static code analysis with cppcheck (we can add --enable=all later) - - name: "cppcheck" - script: - - cppcheck -j$(nproc) --force --quiet --inline-suppr . - # build HTML documentation - - name: "htmldocs" - script: - - make htmldocs - # search for TODO within source tree - - name: "grep TODO" - script: - - grep -r TODO . - # search for FIXME within source tree - - name: "grep FIXME HACK" - script: - - grep -r FIXME . - # search for HACK within source tree and ignore HACKKIT board - script: - - grep -r HACK . | grep -v HACKKIT - # some statistics about the code base - - name: "sloccount" - script: - - sloccount . - # ensure all configs have MAINTAINERS entries - - name: "Check for configs without MAINTAINERS entry" - script: - - if [ `./tools/genboardscfg.py -f 2>&1 | wc -l` -ne 0 ]; then exit 1; fi - # Ensure host tools build - - name: "Build tools-only" - script: - - make tools-only_config tools-only -j$(nproc) - # Ensure env tools build - - name: "Build envtools" - script: - - make tools-only_config envtools -j$(nproc) - - - name: "Run tests for Nokia RX-51 (aka N900)" - script: - - export PATH=~/.buildman-toolchains/gcc-9.2.0-nolibc/arm-linux-gnueabi/bin/:$PATH - - test/nokia_rx51_test.sh - - # test/py - - name: "test/py sandbox" - env: - - TEST_PY_BD="sandbox" - TOOLCHAIN="i386" - - name: "test/py sandbox with clang" - env: - - TEST_PY_BD="sandbox" - OVERRIDE="-O clang-10" - - name: "test/py sandbox_spl" - env: - - TEST_PY_BD="sandbox_spl" - TEST_PY_TEST_SPEC="test_ofplatdata or test_handoff or test_spl" - TOOLCHAIN="i386" - TEST_PY_TOOLS="yes" - - name: "test/py sandbox_flattree" - env: - - TEST_PY_BD="sandbox_flattree" - TOOLCHAIN="i386" - - name: "test/py evb-ast2500" - env: - - TEST_PY_BD="evb-ast2500" - TEST_PY_ID="--id qemu" - QEMU_TARGET="arm-softmmu" - - name: "test/py vexpress_ca15_tc2" - env: - - TEST_PY_BD="vexpress_ca15_tc2" - TEST_PY_ID="--id qemu" - QEMU_TARGET="arm-softmmu" - - name: "test/py vexpress_ca9x4" - env: - - TEST_PY_BD="vexpress_ca9x4" - TEST_PY_ID="--id qemu" - QEMU_TARGET="arm-softmmu" - - name: "test/py integratorcp_cm926ejs" - env: - - TEST_PY_BD="integratorcp_cm926ejs" - TEST_PY_TEST_SPEC="not sleep" - TEST_PY_ID="--id qemu" - QEMU_TARGET="arm-softmmu" - - name: "test/py qemu_arm" - env: - - TEST_PY_BD="qemu_arm" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="arm-softmmu" - - name: "test/py qemu_arm64" - env: - - TEST_PY_BD="qemu_arm64" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="aarch64-softmmu" - - name: "test/py qemu_mips" - env: - - TEST_PY_BD="qemu_mips" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="mips-softmmu" - TOOLCHAIN="mips" - - name: "test/py qemu_mipsel" - env: - - TEST_PY_BD="qemu_mipsel" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="mipsel-softmmu" - TOOLCHAIN="mips" - - name: "test/py qemu_mips64" - env: - - TEST_PY_BD="qemu_mips64" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="mips64-softmmu" - TOOLCHAIN="mips" - - name: "test/py qemu_mips64el" - env: - - TEST_PY_BD="qemu_mips64el" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="mips64el-softmmu" - TOOLCHAIN="mips" - - name: "test/py qemu-malta" - env: - - TEST_PY_BD="malta" - TEST_PY_TEST_SPEC="not sleep and not efi" - TEST_PY_ID="--id qemu" - QEMU_TARGET="mips-softmmu" - TOOLCHAIN="mips" - - name: "test/py qemu-maltael" - env: - - TEST_PY_BD="maltael" - TEST_PY_TEST_SPEC="not sleep and not efi" - TEST_PY_ID="--id qemu" - QEMU_TARGET="mipsel-softmmu" - TOOLCHAIN="mips" - - name: "test/py qemu-malta64" - env: - - TEST_PY_BD="malta64" - TEST_PY_TEST_SPEC="not sleep and not efi" - TEST_PY_ID="--id qemu" - QEMU_TARGET="mips64-softmmu" - TOOLCHAIN="mips" - - name: "test/py qemu-malta64el" - env: - - TEST_PY_BD="malta64el" - TEST_PY_TEST_SPEC="not sleep and not efi" - TEST_PY_ID="--id qemu" - QEMU_TARGET="mips64el-softmmu" - TOOLCHAIN="mips" - - name: "test/py qemu-ppce500" - env: - - TEST_PY_BD="qemu-ppce500" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="ppc-softmmu" - TOOLCHAIN="powerpc" - - name: "test/py qemu-riscv32" - env: - - TEST_PY_BD="qemu-riscv32" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="riscv32-softmmu" - TOOLCHAIN="riscv" - - name: "test/py qemu-riscv64" - env: - - TEST_PY_BD="qemu-riscv64" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="riscv64-softmmu" - TOOLCHAIN="riscv" - - name: "test/py qemu-riscv32_spl" - env: - - TEST_PY_BD="qemu-riscv32_spl" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="riscv32-softmmu" - TOOLCHAIN="riscv" - - name: "test/py qemu-riscv64_spl" - env: - - TEST_PY_BD="qemu-riscv64_spl" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="riscv64-softmmu" - TOOLCHAIN="riscv" - - name: "test/py qemu-x86" - env: - - TEST_PY_BD="qemu-x86" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="i386-softmmu" - TOOLCHAIN="i386" - BUILD_ROM="yes" - - name: "test/py qemu-x86_64" - env: - - TEST_PY_BD="qemu-x86_64" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="x86_64-softmmu" - TOOLCHAIN="i386" - BUILD_ROM="yes" - - name: "test/py r2dplus_i82557c" - env: - - TEST_PY_BD="r2dplus" - TEST_PY_ID="--id i82557c_qemu" - QEMU_TARGET="sh4-softmmu" - BUILDMAN="sh -x arm" - TOOLCHAIN="sh" - - name: "test/py r2dplus_pcnet" - env: - - TEST_PY_BD="r2dplus" - TEST_PY_ID="--id pcnet_qemu" - QEMU_TARGET="sh4-softmmu" - BUILDMAN="sh -x arm" - TOOLCHAIN="sh" - - name: "test/py r2dplus_rtl8139" - env: - - TEST_PY_BD="r2dplus" - TEST_PY_ID="--id rtl8139_qemu" - QEMU_TARGET="sh4-softmmu" - BUILDMAN="sh -x arm" - TOOLCHAIN="sh" - - name: "test/py r2dplus_tulip" - env: - - TEST_PY_BD="r2dplus" - TEST_PY_ID="--id tulip_qemu" - QEMU_TARGET="sh4-softmmu" - BUILDMAN="sh -x arm" - TOOLCHAIN="sh" - - name: "test/py xilinx_zynq_virt" - env: - - TEST_PY_BD="xilinx_zynq_virt" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="arm-softmmu" - TEST_PY_ID="--id qemu" - - name: "test/py xilinx_versal_virt" - env: - - TEST_PY_BD="xilinx_versal_virt" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="aarch64-softmmu" - TEST_PY_ID="--id qemu" - - name: "test/py xtfpga" - env: - - TEST_PY_BD="xtfpga" - TEST_PY_TEST_SPEC="not sleep" - QEMU_TARGET="xtensa-softmmu" - TEST_PY_ID="--id qemu" - TOOLCHAIN="xtensa-dc233c-elf" - -# TODO make it perfect ;-r
Bin Meng
