drivers: clk: stm32h7: Endless loop of dead in driver probe function
Some IMHO fatal issues in the the clock driver for the STM32H7 series driver.
Affected driver: drivers/clk/clk_stm32h7.c
Affected configs (boards): configs/stm32h750-art-pi_defconfig configs/stm32h743-disco_defconfig configs/stm32h743-eval_defconfig
Description: The driver currently requires a external working clock source (HSE). No issues in the circuit are accepted by the current implementation. Also a fixed (defined) frequency of the external clock source.
In the probe function stm32_clk_probe() from the driver there will be configure_clocks() called. Here are the issues.
As code snippet from configure_clocks():
/* Switch on HSE */ setbits_le32(®s->cr, RCC_CR_HSEON); while (!(readl(®s->cr) & RCC_CR_HSERDY)) ;
RCC_CR_HSERDY will here never set, when there is no external clock source or an issue in the circuit. -> Endless loop of dead.
My possible fixes: At a timeout when reading the register and if the timeout is elapsed, print an error message and return with ETIMEDOUT, so the dm manger can call the hang() function.
Johannes K.
Yes, the current clock driver for STM32 MCU is not perfect,
as the all U-Boot and the Linux support on STM32 MCU.
For information, in the other driver based on a other version of RCC for STM32 MPU
STM32MP1 = clk_stm32mp1.c, it is correctly managed in
stm32mp1_osc_wait(1, rcc, RCC_OCRDYR, RCC_OCRDYR_HSERDY);
by using readl_poll_timeout() function.
I agree, it is a correct management: at least indicate this hardware issue
even if the rdy bit can't be stay at 0 in normal use case when HSE is
present.
=> replace all while() in the RCC clock driver with readl_poll_timeout
but to call readl_poll_timeout(), the arch timer need to ready
(timer_init() already called) when RCC clokc driver probe is executed.
An issue the I encounters on STM32MP need to be checked in MCU driver:
the timer can't dependant of RCC probe when polling function is used.
This issue was solved in STM32MP by using the generic armv7 timer
(only dependant of Cortex core) and call the initialization in
arch/arm/mach-stm32mp/cpu.c:
int arch_cpu_init(void) { ....
/* early armv7 timer init: needed for polling */ timer_init();
return 0; }
The timer management on MCU need to be check before any patch.
Can you propose something ?
Johannes K.
Patrick
Hi Patrick!
Sorry, for my late response. :(
On 08.03.22 10:00, Patrick DELAUNAY wrote:> Yes, the current clock driver for STM32 MCU is not perfect,> > as the all U-Boot and the Linux support on STM32 MCU.>
present.> => replace all while() in the RCC clock driver with readl_poll_timeout
return 0; }
Is there any reason why not use the ARMv7-M SysTick Timer? There exists an initialization routine in the U-Boot source tree:
arch/arm/cpu/armv4m/systick-timer.c
The routines should work for Cortex-M3/M4/M7.
timer_init() and all required functions for mdelay() which are will be called by the polling functions are implemented.
Don't looked into other TRM's, other than for STM32H745/STM32H747 and STM32H755/STM32H757 yet, but according the TRM, the SysTick timer for the core Cortex-M7 should run at 8MHz, after reset:
- HSI should be selected as system clock (sys_ck), running at 64MHz - Domain 1 prescaler (D1CPRE) with scale 1 - SysTick timer at default configuration (external source) which has a fixed prescale from 8, according the block schematic in TRM.
Correct me please, if I'm wrong.
Yes, but I can currently only test the correct behavior on a STM32H747I-DISCO board. Currently creating the device-tree for the SoC.
I would use the SysTick Timer on the other devices from the STM32H7 series too, so I would change the current code.
Before I release a patch series here in the official mailing list, I would suggest, if some other developers or users can verify my modification on their real hardware.
My GitHub repo: https://github.com/krjdev/stm32_u-boot (branch stm32h747_disco)
That I can offer. :)
Kind regards,
Johannes
Hi johannes
On 3/9/22 08:24, Johannes (krjdev) Krottmayer wrote:
Hi Patrick!
return 0; }
Simply because when i introduced stm32h7 board, i didn't need it ;-)
I have a stm21h7xxi-disco (MB1248) i can give it a try this week. I will keep you in touch.
Thanks Patrice
Kind regards,
Johannes
Hi Patrice!
On 09.03.22 08:43, Patrice CHOTARD wrote:
Hi johannes
Hi Patrick!
return 0; }
Please can you give me some additional time for this? The device-tree needs some fixes. Missing clocks and resets for the required driver.
I will create a git tag, when I'm ready and I have tested to run U-Boot on my board. :)
Working since sunday on the device-trees...Maybe tommorrow. :)
Thanks Patrice
Kind regards,
Johannes
Kind regards
Johannes
On 3/9/22 09:02, Johannes (krjdev) Krottmayer wrote:
Hi Patrice!
Hi johannes
Hi Patrick!
return 0; }
No problem, i will wait your green light :-D
Patrice
Thanks Patrice
Kind regards,
Johannes
Kind regards
Johannes
Hi Patrice!
I have bricked my board. LOL. Hope I can recover it, when soldering BOOT0 to VDD. Solder Bridge 192 (SB192).
Don't verified the power settings first in the clock driver.
The current power configuration clears SCUEN. But on STM32H747, this disables the SMPS converter. Same bit position (SDEN) in PWR_CR3...
Hi Patrice!
Hi johannes
Hi Patrick!
return 0; }
Patrice
Thanks Patrice
Kind regards,
Johannes
Kind regards
Johannes
Hi Johannes
On 3/9/22 12:38, Johannes (krjdev) Krottmayer wrote:
Hi Patrice!
Right, i double check in datasheets, PWR_CR3 register differs between STM32H743 (single core M7 only) and STM32H747 (dual core M7+M4).
This driver must be updated to fit with dual core STM32H747.
Patrice
Hi Patrice!
Hi johannes
Hi Patrick!
> My possible fixes: > At a timeout when reading the register and if the timeout is > elapsed, print an error message and return with ETIMEDOUT, so > the dm manger can call the hang() function.
return 0; }
Patrice
Thanks Patrice
Kind regards,
Johannes
Kind regards
Johannes
Patrice CHOTARD
Patrick DELAUNAY
