[PATCH] xilinx: common: Add support for SOC detection
Code supports board detection based on information available in EEPROM in legacy or FRU format. But this is not enough for emulation and simulation systems which are lacking these identification EEPROMs. But SOC itself has normally registers for SOC identification. Based on them it is possible to compose detected name. That's why prepare infrastructure in common location for SOC platform detection which is called before board platform detection. SOC platform detection shouldn't detect real silicon and should fallback to current existing mechanism to identify boards based on EEPROMs.
Signed-off-by: Michal Simek michal.simek@amd.com ---
board/xilinx/common/board.c | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 5e3638636123..e1f71049603f 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -585,8 +585,33 @@ bool __maybe_unused __weak board_detection(void) return false; }
+bool __maybe_unused __weak soc_detection(void) +{ + return false; +} + +char * __maybe_unused __weak soc_name_decode(void) +{ + return NULL; +} + int embedded_dtb_select(void) { + if (soc_detection()) { + char *soc_local_name; + + soc_local_name = soc_name_decode(); + if (soc_local_name) { + board_name = soc_local_name; + printf("Detected SOC name: %s\n", board_name); + + /* Time to change DTB on fly */ + /* Both ways should work here */ + /* fdtdec_resetup(&rescan); */ + return fdtdec_setup(); + } + } + if (board_detection()) { char *board_local_name;
Ășt 6. 9. 2022 v 12:40 odesĂlatel Michal Simek michal.simek@amd.com napsal:
return false;
return NULL;
-- 2.36.1
Applied. M
Michal Simek
Michal Simek
