[U-Boot] [RFC] igep00x0: UBI everywhere but SPL
This patch converts IGEP board to use UBI volumes for environment, u-boot, kernel... With exception of first four sectors with SPL loaded by SoC boot ROM whole NAND is UBI managed. I misused BOOT_DEVICE_BOARD, which is probably not briliant idea, but works well enough. Also code it too big, so I dropped CONFIG_SPL_EXT_SUPPORT to make it fit. It is meant more likely as a test of Thomas' patch, so more people can play with that. Thanks to Marek Vasut for pointing me to Thomas' work and arguing so well towards UBI that I had no other choice than giving it a try.
--- diff --git a/arch/arm/include/asm/arch-omap3/spl.h b/arch/arm/include/asm/arch-omap3/spl.h index a31b4ea..ebac396 100644 --- a/arch/arm/include/asm/arch-omap3/spl.h +++ b/arch/arm/include/asm/arch-omap3/spl.h @@ -14,9 +14,10 @@ #define BOOT_DEVICE_MMC2 0x05 #define BOOT_DEVICE_MMC1 0x06 #define BOOT_DEVICE_XIPWAIT 0x07 -#define BOOT_DEVICE_MMC2_2 0x08 +#define BOOT_DEVICE_MMC2_2 0x08 #define BOOT_DEVICE_UART 0x10 #define BOOT_DEVICE_USB 0x11 +#define BOOT_DEVICE_BOARD 0xffffffff
#define MMC_BOOT_DEVICES_START BOOT_DEVICE_MMC2 #define MMC_BOOT_DEVICES_END BOOT_DEVICE_MMC1 diff --git a/board/isee/igep00x0/igep00x0.c b/board/isee/igep00x0/igep00x0.c index e2fce50..4c4394f 100644 --- a/board/isee/igep00x0/igep00x0.c +++ b/board/isee/igep00x0/igep00x0.c @@ -10,6 +10,9 @@ #include <ns16550.h> #include <twl4030.h> #include <netdev.h> +#include <nand.h> +#include <ubispl.h> +#include <spl.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/mem.h> @@ -212,3 +215,64 @@ int board_eth_init(bd_t *bis) #endif } #endif + +#ifdef CONFIG_SPL_OS_BOOT +int spl_start_uboot(void) +{ + /* break into full u-boot on 'c' */ + if (serial_tstc() && serial_getc() == 'c') + return 1; + + return 0; +} +#endif + +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_BOARD_LOAD_IMAGE) + +#define SPL_FINFO_ADDR 0x88800000 +#define SPL_FTD_LOAD_ADDR 0x88000000 /* fdtaddr=0x88000000 */ +#define SPL_LOAD_ADDR 0x82000000 /* loadaddr=0x82000000 */ + +int spl_board_load_image(void) +{ + int ret; + struct image_header *header; + struct ubispl_info info; + struct ubispl_load volumes[4]; + + info.ubi = (struct ubi_scan_info *) SPL_FINFO_ADDR; + info.fastmap = 1; + info.read = nand_spl_read_flash; + + info.peb_offset = 4; + info.peb_size = CONFIG_SYS_NAND_BLOCK_SIZE; + info.vid_offset = 512; + info.leb_start = 2048; + info.peb_count = 4096 - info.peb_offset; + + header = (struct image_header *)(CONFIG_SYS_TEXT_BASE); + memset(volumes, 0, sizeof(volumes)); + volumes[0].name = "loader"; + volumes[0].vol_id = 3; + volumes[0].load_addr = (void *)header; + + nand_init(); + ret = ubispl_load_volumes(&info, volumes, 1); + nand_deselect(); + if (ret) + return ret; + + spl_parse_image_header(header); + return 0; +} + +void board_boot_order(u32 *spl_boot_list) +{ + spl_boot_list[0] = BOOT_DEVICE_BOARD; +} + +void spl_board_announce_boot_device(void) +{ + puts("UBI volume"); +} +#endif diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index 3e2c074..f55be5f 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -10,6 +10,13 @@ #include <asm/io.h> #include <nand.h>
+#ifdef CONFIG_SPL_BOARD_LOAD_IMAGE +int spl_nand_load_image(void) +{ + return -EINVAL; +} +#else + #if defined(CONFIG_SPL_NAND_RAW_ONLY) int spl_nand_load_image(void) { @@ -102,3 +109,4 @@ int spl_nand_load_image(void) return err; } #endif +#endif diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index a64b38f..c18df59 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -80,6 +80,7 @@ #endif #define CONFIG_CMD_DHCP #define CONFIG_CMD_PING +#define CONFIG_CMD_UBI
#ifndef CONFIG_SPL_BUILD
@@ -89,6 +90,10 @@ "stdout=serial\0" \ "stderr=serial\0"
+#define ENV_MTD_SETTINGS \ + "mtdids=nand0=gpmc-nand.0\0" \ + "mtdparts=mtdparts=gpmc-nand.0:512k(SPL),-(UBI)\0" + #define MEM_LAYOUT_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ "scriptaddr=0x87E00000\0" \ @@ -102,33 +107,13 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ ENV_DEVICE_SETTINGS \ + ENV_MTD_SETTINGS \ MEM_LAYOUT_SETTINGS \ BOOTENV
#endif
/* - * FLASH and environment organization - */ - -#ifdef CONFIG_BOOT_ONENAND -#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP - -#define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ - -#define CONFIG_ENV_IS_IN_ONENAND 1 -#define CONFIG_ENV_SIZE (512 << 10) /* Total Size Environment */ -#define CONFIG_ENV_ADDR ONENAND_ENV_OFFSET -#endif - -#ifdef CONFIG_NAND -#define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ -#define CONFIG_ENV_IS_IN_NAND 1 -#define CONFIG_ENV_SIZE (512 << 10) /* Total Size Environment */ -#define CONFIG_ENV_ADDR NAND_ENV_OFFSET -#endif - -/* * SMSC911x Ethernet */ #if defined(CONFIG_CMD_NET) @@ -137,15 +122,34 @@ #define CONFIG_SMC911X_BASE 0x2C000000 #endif /* (CONFIG_CMD_NET) */
+/* + * FLASH and environment organization + */ +#define CONFIG_SPL_UBI 1 +#define CONFIG_SPL_UBI_MAX_VOL_LEBS 256 +#define CONFIG_SPL_UBI_MAX_PEB_SIZE (256*1024) +#define CONFIG_SPL_UBI_MAX_PEBS 4096 +#define CONFIG_SPL_UBI_VOL_IDS 8 + +#define CONFIG_SPL_BOARD_LOAD_IMAGE + +#define CONFIG_ENV_IS_IN_UBI 1 +#define CONFIG_ENV_UBI_PART "UBI" +#define CONFIG_ENV_UBI_VOLUME "config" +#define CONFIG_ENV_UBI_VOLUME_REDUND "config_r" +/*#define CONFIG_UBI_SILENCE_MSG 1 +#define CONFIG_UBIFS_SILENCE_MSG 1*/ +#define CONFIG_ENV_SIZE (32*1024) + +#define CONFIG_RBTREE +#define CONFIG_MTD_PARTITIONS +#define MTDIDS_DEFAULT "nand0=gpmc-nand.0" +#define MTDPARTS_DEFAULT "mtdparts=gpmc-nand.0:512k(SPL),-(UBI)" + /* OneNAND boot config */ #ifdef CONFIG_BOOT_ONENAND -#define CONFIG_SPL_ONENAND_SUPPORT -#define CONFIG_SYS_ONENAND_U_BOOT_OFFS 0x80000 +#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP #define CONFIG_SYS_ONENAND_PAGE_SIZE 2048 -#define CONFIG_SPL_ONENAND_LOAD_ADDR 0x80000 -#define CONFIG_SPL_ONENAND_LOAD_SIZE \ - (512 * 1024 - CONFIG_SPL_ONENAND_LOAD_ADDR) - #endif
/* NAND boot config */ @@ -169,14 +173,6 @@ #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW #define CONFIG_NAND_OMAP_GPMC #define CONFIG_BCH - -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 -/* NAND: SPL falcon mode configs */ -#ifdef CONFIG_SPL_OS_BOOT -#define CONFIG_CMD_SPL_NAND_OFS 0x240000 -#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 -#endif #endif
#endif /* __IGEP00X0_H */
Ladislav Michl
