[U-Boot] [PATCH 1/2] gpio: Add GPIO driver framework for Marvell SoCs
This patch adds generic GPIO driver framework support for Marvell SoCs.
To enable GPIO driver define CONFIG_MV_GPIO and for GPIO commands define CONFIG_CMD_GPIO in your board configuration file.
Signed-off-by: Ajay Bhargav ajay.bhargav@einfochips.com --- drivers/gpio/Makefile | 1 + drivers/gpio/mvgpio.c | 125 +++++++++++++++++++++++++++++++++++++++++++++++++ include/mvgpio.h | 52 ++++++++++++++++++++ 3 files changed, 178 insertions(+), 0 deletions(-) create mode 100644 drivers/gpio/mvgpio.c create mode 100644 include/mvgpio.h
diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 62ec97d..c6f652f 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -28,6 +28,7 @@ LIB := $(obj)libgpio.o COBJS-$(CONFIG_AT91_GPIO) += at91_gpio.o COBJS-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o COBJS-$(CONFIG_MARVELL_MFP) += mvmfp.o +COBJS-$(CONFIG_MV_GPIO) += mvgpio.o COBJS-$(CONFIG_MXC_GPIO) += mxc_gpio.o COBJS-$(CONFIG_PCA953X) += pca953x.o COBJS-$(CONFIG_S5P) += s5p_gpio.o diff --git a/drivers/gpio/mvgpio.c b/drivers/gpio/mvgpio.c new file mode 100644 index 0000000..d64f0db --- /dev/null +++ b/drivers/gpio/mvgpio.c @@ -0,0 +1,125 @@ +/* + * (C) Copyright 2011 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * (C) Copyright 2010 + * Marvell Semiconductor <www.marvell.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/gpio.h> + +char gpio_names[MV_MAX_GPIO][GPIO_LABEL_MAX]; + +static int get_gpio_base(int bank) +{ + switch (bank) { + case 0: + return GPIO_BANK0_BASE; + case 1: + return GPIO_BANK1_BASE; + case 2: + return GPIO_BANK2_BASE; + case 3: + return GPIO_BANK3_BASE; + } + return 0; +} + +int gpio_request(int gp, const char *label) +{ + if (gp >= MV_MAX_GPIO) + return -EINVAL; + + if (strlen(gpio_names[gp]) == 0) { + strncpy(gpio_names[gp], label, GPIO_LABEL_MAX); + gpio_names[gp][GPIO_LABEL_MAX - 1] = '\0'; + } else { + return -EBUSY; + } + return 0; +} + +void gpio_free(int gp) +{ + gpio_names[gp][0] = '\0'; +} + +void gpio_toggle_value(int gp) +{ + gpio_set_value(gp, !gpio_get_value(gp)); +} + +int gpio_direction_input(int gp) +{ + struct gpio_reg *gpio_reg_bank; + + if (gp >= MV_MAX_GPIO) + return -EINVAL; + + gpio_reg_bank = (struct gpio_reg *) get_gpio_base(GPIO_TO_REG(gp)); + writel(GPIO_TO_BIT(gp), &gpio_reg_bank->gcdr); + return 0; +} + +int gpio_direction_output(int gp, int value) +{ + struct gpio_reg *gpio_reg_bank; + + if (gp >= MV_MAX_GPIO) + return -EINVAL; + + gpio_reg_bank = (struct gpio_reg *) get_gpio_base(GPIO_TO_REG(gp)); + writel(GPIO_TO_BIT(gp), &gpio_reg_bank->gsdr); + gpio_set_value(gp, value); + return 0; +} + +int gpio_get_value(int gp) +{ + struct gpio_reg *gpio_reg_bank; + u32 gp_val; + + if (gp >= MV_MAX_GPIO) + return -EINVAL; + + gpio_reg_bank = (struct gpio_reg *) get_gpio_base(GPIO_TO_REG(gp)); + gp_val = readl(&gpio_reg_bank->gplr); + + return GPIO_VAL(gp, gp_val); +} + +void gpio_set_value(int gp, int value) +{ + struct gpio_reg *gpio_reg_bank; + + if (gp >= MV_MAX_GPIO) + return; + + gpio_reg_bank = (struct gpio_reg *) get_gpio_base(GPIO_TO_REG(gp)); + if (value) + writel(GPIO_TO_BIT(gp), &gpio_reg_bank->gpsr); + else + writel(GPIO_TO_BIT(gp), &gpio_reg_bank->gpcr); +} diff --git a/include/mvgpio.h b/include/mvgpio.h new file mode 100644 index 0000000..7d0258f --- /dev/null +++ b/include/mvgpio.h @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2011 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * (C) Copyright 2010 + * Marvell Semiconductor <www.marvell.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _MV_GPIO_H +#define _MV_GPIO_H + +#include <asm/types.h> + +#if defined(CONFIG_MV_GPIO) + +#define MV_GPIO_BASE 0xD4019000 +#define GPIO_BANK0_BASE (MV_GPIO_BASE + 0x0000) +#define GPIO_BANK1_BASE (MV_GPIO_BASE + 0x0004) +#define GPIO_BANK2_BASE (MV_GPIO_BASE + 0x0008) +#define GPIO_BANK3_BASE (MV_GPIO_BASE + 0x0100) + +#define GPIO_LABEL_MAX 20 +#define MV_MAX_GPIO 128 + +#define GPIO_TO_REG(gp) (gp >> 5) +#define GPIO_TO_BIT(gp) (1 << (gp & 0x1F)) +#define GPIO_VAL(gp, val) ((val >> (gp & 0x1F)) & 0x01) + +#define GPIO_SET 1 +#define GPIO_CLR 0 + +#endif /* CONFIG_MV_GPIO */ +#endif /* _MV_GPIO_H */
Hi Ajay,
On Thu, Jul 21, 2011 at 1:39 PM, Ajay Bhargav ajay.bhargav@einfochips.com wrote:
- (C) Copyright 2011
- eInfochips Ltd. <www.einfochips.com>
- Written-by: Ajay Bhargav ajay.bhargav@einfochips.com
- (C) Copyright 2010
- Marvell Semiconductor <www.marvell.com>
- project.
- Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
- MA 02110-1301 USA
- switch (bank) {
- case 0:
- return GPIO_BANK0_BASE;
- case 1:
- return GPIO_BANK1_BASE;
- case 2:
- return GPIO_BANK2_BASE;
- case 3:
- return GPIO_BANK3_BASE;
Please put this get_gpio_base into arch's self directory, since different soc may have different number of banks. For example, mmp3 has 6 banks.
Best regards, Lei
probably want to be static ... and this functionality is optional if you want to just ignore the labels. for Blackfin gpio, i make it a build option (useful for debug, not so much for production).
if this returned a "struct gpio_reg *", you wouldnt need to cast everything else below ... -mike
-----Original Message----- From: Ajay Bhargav [mailto:ajay.bhargav@einfochips.com] Sent: Thursday, July 21, 2011 11:10 AM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Ajay Bhargav Subject: [PATCH 1/2] gpio: Add GPIO driver framework for Marvell SoCs
I don't think mvgpio.h is needed here, basically header file in include/ is intended to provide interface to other subsystems.
In this case mvgpio.c is enabling support for gpio framework that will be interfaced using asm/gpio.h.
1. You can split stuff in mvgpio.h to asm/arch/gpio.h and/or mvgpio.c 2. you can move it to drivers/gpio/
I would recommend first option.
Make it CONFIG_MARVELL_GPIO to sync with other configurations i.e. CONFIG_MARVELL_MFP
- project.
- MA 02110-1301 USA
This is overhead, what is need? Just avoid it.
- switch (bank) {
- case 0:
- case 1:
- case 2:
- case 3:
As discussed, this would be preferred macro in gpio.h
- if (gp >= MV_MAX_GPIO)
return -EINVAL;
Minimum fulfillment, this should be okay here.
- if (strlen(gpio_names[gp]) == 0) {
- } else {
return -EBUSY;
Pls remove this.
Just return
- gpio_names[gp][0] = '\0';
- gpio_set_value(gp, !gpio_get_value(gp));
- struct gpio_reg *gpio_reg_bank;
return -EINVAL;
- gpio_reg_bank = (struct gpio_reg *) get_gpio_base(GPIO_TO_REG(gp));
- writel(GPIO_TO_BIT(gp), &gpio_reg_bank->gcdr);
return -EINVAL;
- writel(GPIO_TO_BIT(gp), &gpio_reg_bank->gsdr);
- gpio_set_value(gp, value);
- u32 gp_val;
return -EINVAL;
- gp_val = readl(&gpio_reg_bank->gplr);
- return GPIO_VAL(gp, gp_val);
return;
- if (value)
- else
- project.
- MA 02110-1301 USA
Above BAR should go in armada100.h like- #define ARMD1_GPIO0_BASE 0xD4019000 #define ARMD1_GPIO1_BASE 0xD4019004 #define ARMD1_GPIO2_BASE 0xD4019008 #define ARMD1_GPIO3_BASE 0xD4019100
Rest stuff should go in asm/arch/gpio.h
1.7.0.4
Regards.. Prafulla . .
Hi Prafulla,
Thank you so much for feedback.
- You can split stuff in mvgpio.h to asm/arch/gpio.h and/or mvgpio.c
- you can move it to drivers/gpio/
So you mean the first patch will have only mvgpio.c that enables the support for gpio for Marvell SoCs and then second patch will enable support for Armada series via gpio.h file. So if anyone want to use mvgpio.c he/she should write a compatible version of gpio.h in their arch folder. I hope i am getting your right.
switch (bank) {
case 0:
case 1:
case 2:
case 3:
I am finding it difficult to fit this as a macro. so i thought to have it as inline function in gpio.h will that be ok?
Regards, Ajay Bhargav
-----Original Message----- From: Ajay Bhargav [mailto:ajay.bhargav@einfochips.com] Sent: Friday, July 22, 2011 10:08 AM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de Subject: Re: [PATCH 1/2] gpio: Add GPIO driver framework for Marvell SoCs
Hi Prafulla,
I don't mind if you merge these two patches, any future support will add gpio.h
switch (bank) {
case 0:
case 1:
case 2:
case 3:
Inline function should be okay
Regards.. Prafulla . . .
- project.
- MA 02110-1301 USA
Please define this function as
static struct gpio_reg *get_gpio_base(int gp)
- switch (bank) {
- case 0:
- case 1:
- case 2:
- case 3:
And make it part of gpio.h
return -EINVAL;
- } else {
return -EBUSY;
return -EINVAL;
return -EINVAL;
- u32 gp_val;
It is good to display some error message here.
return -EINVAL;
Regards.. Prafulla. . .
Ajay Bhargav
Lei Wen
Mike Frysinger
Prafulla Wadaskar
