Re: [PATCH v3] clk: set initial best mux parent to current parent with CLK_MUX_ROUND_CLOSEST
On 3/11/2024 5:34 PM, Maxime Ripard wrote:
On Thu, Mar 07, 2024 at 07:18:05PM +0800, Yang Xiwen wrote:
On 3/7/2024 4:48 PM, Maxime Ripard wrote:
On Thu, Mar 07, 2024 at 10:03:50AM +0800, Yang Xiwen via B4 Relay wrote:
Originally, the initial clock rate is hardcoded to 0, this can lead to some problem when setting a very small rate with CLK_MUX_ROUND_CLOSEST.
For example, if the lowest possible rate provided by the mux is 1000Hz, setting a rate below 500Hz will fail, because no clock can provide a better rate than the non-existant 0Hz. But it should succeed with 1000Hz being set.
Setting the initial best parent to current parent could solve this bug.
Signed-off-by: Yang Xiwen forbidden405@outlook.com
I don't think it would be the way to go. The biggest issue to me is that it's inconsistent, and only changing the behaviour for a given flag doesn't solve that.
I think the current behavior is odd but conforms to the document if CLK_MUX_ROUND_CLOSEST is not specified.
clk_mux_determine_rate_flags isn't documented, and the determine_rate clk_ops documentation doesn't mention it can return an error.
If i understand correctly, the default behavior of mux clocks is to select the closest rate lower than requested rate, and CLK_MUX_ROUND_CLOSEST removes the "lower than" limitation, which is what this version tries to accomplish.
The situation is not as clear-cut as you make it to be, unfortunately. The determine_rate clk_ops implementation states:
Given a target rate as input, returns the closest rate actually supported by the clock, and optionally the parent clock that should be used to provide the clock rate.
So CLK_MUX_ROUND_CLOSEST shouldn't exist, because that's what determine_rate expects so it should always be there.
Now, the "actually supported by the clock" can be interpreted in multiple ways, and most importantly, doesn't state what the behaviour is if we can't find a rate actually supported by the clock.
But now, this situation has been ambiguous for a while and thus drivers kind of relied on that ambiguity.
So the way to fix it up is:
- Assess what drivers are relying on
- Document the current behaviour in clk_ops determine_rate
From my investigation, it's totally a mess, especially for platform clk drivers (PLL). Some drivers always round down, the others round to nearest, with or without a specific flag to switch between them, depend on the division functions they choose. Fixing all of them seems needs quite a lot of time and would probably introduce some regressions.
We'd probably only have to say both rounding to nearest and rounding down are acceptable, though either one is preferred.
- Make clk_mux_determine_rate_flags consistent with that
I think we must keep existing flags and document the current behavior correctly because of the massive existing users of clk_mux.
That's why i'm going to only fix CLK_MUX_ROUND_CLOSEST users. Hopefully it won't cause too many regressions.
- Run that through kernelci to make sure we don't have any regression
We don't. I run 'tools/testing/kunit/kunit.py run --kunitconfig drivers/clk/.kunitconfig' each time before i send patches.
Over all, it seems quite a lot of work here.
Maxime
The situation here becomes even more complex when it comes to U-Boot clk framework. They chose slightly different prototypes and stated clk_set_rate() can fail with -ve. It's a great burden for clk driver authors and maintainers when they try to port their drivers to U-Boot. Let's Cc U-Boot clk maintainers as well, and see how we can resolve the mess here.
I agree it's a mess, but that's a mess you wanted to clean up in the first place :)
Which, without a documentation, makes it more of a mess.
That's kunit, not kernelci (https://linux.kernelci.org/job/)
I mean, eventually, that's on them. If U-Boot chose to have a somewhat-similar-but-not-really clock framework, there's nothing Linux can solve here, even though I definitely can see the frustration for the developpers that have to work on both.
Maxime
- Assess what drivers are relying on - Document the current behaviour in clk_ops determine_rate
Maxime
Maybe you mean clk_get_rate? Setting a rate can always fail due to the nature of clocks...
Personally, I am not terribly attached to the API (as not many callers handle errors correctly), but I have not had the time recently to do any cleanup.
Regarding rounding mode, IMO it is better to let driver authors pick whatever is convenient. Round closest is best, but there may be code size savings for round lowest or some other scheme. [1] has the current recommendation, which is to punt and let the caller use round_rate if they actually care.
--Sean
[1] https://source.denx.de/u-boot/custodians/u-boot-clk/-/blob/a8dc4965f09d28a59...
Maxime Ripard
Sean Anderson
Yang Xiwen
