[PATCH] Azure: Do not run "udelay" test on sandbox
With the changes in commit 88db4fc5fec2 ("test: Update time tests to use unit-test asserts") we now frequently exceed the limit on the udelay test, leading to false failures in CI. Skip this test.
Signed-off-by: Tom Rini trini@konsulko.com --- Cc: Simon Glass sjg@chromium.org --- .azure-pipelines.yml | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 4ecf76eaa0b5..a51db936d83a 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -320,12 +320,14 @@ stages: matrix: sandbox: TEST_PY_BD: "sandbox" + TEST_PY_TEST_SPEC: "not udelay" sandbox_asan: TEST_PY_BD: "sandbox" OVERRIDE: "-a ASAN" TEST_PY_TEST_SPEC: "version" sandbox_clang: TEST_PY_BD: "sandbox" + TEST_PY_TEST_SPEC: "not udelay" OVERRIDE: "-O clang-17" sandbox_clang_asan: TEST_PY_BD: "sandbox" @@ -333,8 +335,10 @@ stages: TEST_PY_TEST_SPEC: "version" sandbox64: TEST_PY_BD: "sandbox64" + TEST_PY_TEST_SPEC: "not udelay" sandbox64_clang: TEST_PY_BD: "sandbox64" + TEST_PY_TEST_SPEC: "not udelay" OVERRIDE: "-O clang-17" sandbox_spl: TEST_PY_BD: "sandbox_spl" @@ -351,6 +355,7 @@ stages: OVERRIDE: "-a CONFIG_SPL_LOAD_FIT_FULL=y" sandbox_flattree: TEST_PY_BD: "sandbox_flattree" + TEST_PY_TEST_SPEC: "not udelay" sandbox_trace: TEST_PY_BD: "sandbox" BUILD_ENV: "FTRACE=1 NO_LTO=1"
Tested-by: Andrew Goodbody andrew.goodbody@linaro.org Reviewed-by: Andrew Goodbody andrew.goodbody@linaro.org
Andrew Goodbody
