[PATCH] mtd: spi-nor-ids: Enable quad read for Gigadevice gd25lq128
The Gigadevice gd25lq128 serial flash exists in different versions, all which identify themselves using the same JEDEC id.
gd25lq128c: https://www.gigadevice.com/datasheet/gd25lq128
gd25lq128d: https://www.gigadevice.com/datasheet/gd25lq128d
However, all versions support quad read, so enable it. Tested and verified on the Sipeed MAix BiT board.
Fixes: 30b9a28a3f2d ("mtd: spi-nor-ids: Add Gigadevice gd25lq128 ID") Signed-off-by: Niklas Cassel niklas.cassel@wdc.com --- drivers/mtd/spi/spi-nor-ids.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index b551ebd75e..763bab04c6 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -119,7 +119,7 @@ const struct flash_info spi_nor_ids[] = { }, { INFO("gd25lq128", 0xc86018, 0, 64 * 1024, 256, - SECT_4K | SPI_NOR_DUAL_READ | + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) }, {
Niklas Cassel
