[U-Boot] [PATCH 1/3] test: dfu: cleanup before execution
Call cleanup() before running tests too. If a previous test was CTRL-C'd some stale files may have been left around. dfu-util refuses to receive a file to a filename that already exists, which results in false test failures if the files aren't cleaned up first.
Signed-off-by: Stephen Warren swarren@nvidia.com --- test/dfu/dfu_gadget_test.sh | 1 + 1 file changed, 1 insertion(+)
diff --git a/test/dfu/dfu_gadget_test.sh b/test/dfu/dfu_gadget_test.sh index c5c5f1d957f1..4133155ae97d 100755 --- a/test/dfu/dfu_gadget_test.sh +++ b/test/dfu/dfu_gadget_test.sh @@ -66,6 +66,7 @@ printf "$COLOUR_GREEN=========================================================== echo "DFU EP0 transmission test program" echo "Trouble shoot -> disable DBG (even the KERN_DEBUG) in the UDC driver" echo "@ -> TRATS2 # dfu 0 mmc 0" +cleanup mkdir -p $DIR$RCV_DIR touch $LOG_FILE
On Tegra, the DFU buffer size is 1M. Consequently, the 8M test always fails. Add tests for the 1M size, and one byte less as a corner case, so that some large tests are executed and expected to pass.
Signed-off-by: Stephen Warren swarren@nvidia.com --- test/dfu/dfu_gadget_test_init.sh | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/dfu/dfu_gadget_test_init.sh b/test/dfu/dfu_gadget_test_init.sh index fb54ad8c55ee..2163a685a55d 100755 --- a/test/dfu/dfu_gadget_test_init.sh +++ b/test/dfu/dfu_gadget_test_init.sh @@ -9,7 +9,7 @@ COLOUR_DEFAULT="\33[0m"
LOG_DIR="./log"
-TEST_FILES_SIZES="63 64 65 127 128 129 4095 4096 4097 959 960 961 8M" +TEST_FILES_SIZES="63 64 65 127 128 129 4095 4096 4097 959 960 961 1048575 1048576 8M"
printf "Init script for generating data necessary for DFU test script"
Hi Stephen,
LOG_DIR="./log"
-TEST_FILES_SIZES="63 64 65 127 128 129 4095 4096 4097 959 960 961 8M" +TEST_FILES_SIZES="63 64 65 127 128 129 4095 4096 4097 959 960 961 1048575 1048576 8M" printf "Init script for generating data necessary for DFU test script"
Applied to u-boot-dfu tree.
Stephen, thanks for your support.
The buffer is too small if it's < size to read, not if it's <= the size. This fixes the 1MB test case on Tegra, which has a 1MB buffer.
Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/dfu/dfu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/dfu/dfu.c b/drivers/dfu/dfu.c index 6cd3fbb58ae4..3512b149c560 100644 --- a/drivers/dfu/dfu.c +++ b/drivers/dfu/dfu.c @@ -332,7 +332,7 @@ int dfu_read(struct dfu_entity *dfu, void *buf, int size, int blk_seq_num) case DFU_RAM_ADDR: break; default: - if (dfu->r_left >= dfu_buf_size) { + if (dfu->r_left > dfu_buf_size) { printf("%s: File too big for buffer\n", __func__); return -EOVERFLOW;
Hi Stephen,
Hi Stephen,
Lukasz Majewski
Stephen Warren
