[PATCH] Fix squashfs failing to load sparse files
SquashFS supports sprase blocks in files - that is, if a given block is composed only of zeros, it's not written to the output file to save space and it's on-disk length field is set to zero to indicate that.
Previously the squashfs driver did not recognise that, and would attempt to read and decompress a zero-sized block, which obviously failed.
The following command may be used to create a file for testing:
cat <(dd if=/dev/urandom of=/dev/stdout bs=1M count=1) \ <(dd if=/dev/zero of=/dev/stdout bs=1M count=1) \ <(dd if=/dev/urandom of=/dev/stdout bs=1k count=200) >test_file
Signed-off-by: Campbell Suter campbell@snapit.group ---
fs/squashfs/sqfs.c | 54 ++++++++++++++++++++++++++++++---------------- 1 file changed, 35 insertions(+), 19 deletions(-)
diff --git a/fs/squashfs/sqfs.c b/fs/squashfs/sqfs.c index 608a2bb454..2516d920f8 100644 --- a/fs/squashfs/sqfs.c +++ b/fs/squashfs/sqfs.c @@ -1309,7 +1309,7 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len, { char *dir = NULL, *fragment_block, *datablock = NULL, *data_buffer = NULL; char *fragment = NULL, *file = NULL, *resolved, *data; - u64 start, n_blks, table_size, data_offset, table_offset; + u64 start, n_blks, table_size, data_offset, table_offset, sparse_size; int ret, j, i_number, datablk_count = 0; struct squashfs_super_block *sblk = ctxt.sblk; struct squashfs_fragment_block_entry frag_entry; @@ -1443,28 +1443,43 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len, n_blks = DIV_ROUND_UP(table_size + table_offset, ctxt.cur_dev->blksz);
- data_buffer = malloc_cache_aligned(n_blks * ctxt.cur_dev->blksz); + /* Don't load any data for sparse blocks */ + if (finfo.blk_sizes[j] == 0) { + n_blks = 0; + table_offset = 0; + data_buffer = NULL; + data = NULL; + } else { + data_buffer = malloc_cache_aligned(n_blks * ctxt.cur_dev->blksz);
- if (!data_buffer) { - ret = -ENOMEM; - goto out; - } + if (!data_buffer) { + ret = -ENOMEM; + goto out; + }
- ret = sqfs_disk_read(start, n_blks, data_buffer); - if (ret < 0) { - /* - * Possible causes: too many data blocks or too large - * SquashFS block size. Tip: re-compile the SquashFS - * image with mksquashfs's -b <block_size> option. - */ - printf("Error: too many data blocks to be read.\n"); - goto out; - } + ret = sqfs_disk_read(start, n_blks, data_buffer); + if (ret < 0) { + /* + * Possible causes: too many data blocks or too large + * SquashFS block size. Tip: re-compile the SquashFS + * image with mksquashfs's -b <block_size> option. + */ + printf("Error: too many data blocks to be read.\n"); + goto out; + }
- data = data_buffer + table_offset; + data = data_buffer + table_offset; + }
/* Load the data */ - if (SQFS_COMPRESSED_BLOCK(finfo.blk_sizes[j])) { + if (finfo.blk_sizes[j] == 0) { + /* This is a sparse block */ + sparse_size = get_unaligned_le32(&sblk->block_size); + if ((*actread + sparse_size) > len) + sparse_size = len - *actread; + memset(buf + *actread, 0, sparse_size); + *actread += sparse_size; + } else if (SQFS_COMPRESSED_BLOCK(finfo.blk_sizes[j])) { dest_len = get_unaligned_le32(&sblk->block_size); ret = sqfs_decompress(&ctxt, datablock, &dest_len, data, table_size); @@ -1483,7 +1498,8 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len, }
data_offset += table_size; - free(data_buffer); + if (data_buffer) + free(data_buffer); data_buffer = NULL; if (*actread >= len) break;
Campbell Suter
